  3. Home Assistant
  4. Error using Home Assistant with a serial gateway
21 Posts 3 Posters 11.0k Views 2 Watching
  • B
    B
    BastienVH
    wrote on last edited by BastienVH
    Hi Martin,
    @martinhjelmare
    I've been trying the last couple of days to get it working, but to no avail...
    I stell get errors like
    ValueError: need more than 1 value to unpack
    The number can change though.
    I've tried your suggestions, updated and rebooted the pi but still no luck.
    Uninstalled and reinstalled home assistant but that also didn't help.
    Any other things I could try?
    • delsD
      delsD
      dels
      @BastienVH said:
      Hi Martin,
      @martinhjelmare
      I have been getting the same thing... it worked on one occasion where it was able to load, but I didnt know the sensors had to "present" themselves at that time... so I made some research, restarted HA, rebooted the pi, disconnected the serial gw... I have been trying at least 25 times since and now I am always getting this:
      16-01-23 14:32:29 homeassistant.bootstrap: Error during setup of component mysensors
        File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 98, in _setup_component
          if not component.setup(hass, config):
        File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 124, in setup
          port, persistence, persistence_file, version)
        File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 90, in setup_gateway
          protocol_version=version)
        File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 261, in __init__
          persistence_file, protocol_version)
        File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 33, in __init__
          self._load_sensors()
        File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 153, in _load_sensors
          self._perform_file_action(self.persistence_file, 'load')
        File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 167, in _perform_file_action
          fn(filename)
        File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 136, in _load_json
          self.sensors = json.load(f, cls=MySensorsJSONDecoder)
        File "/usr/lib/python3.4/json/__init__.py", line 268, in load
          parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
        File "/usr/lib/python3.4/json/__init__.py", line 331, in loads
          return cls(**kw).decode(s)
        File "/usr/lib/python3.4/json/decoder.py", line 343, in decode
          obj, end = self.raw_decode(s, idx=_w(s, 0).end())
        File "/usr/lib/python3.4/json/decoder.py", line 361, in raw_decode
          raise ValueError(errmsg("Expecting value", s, err.value)) from None
      ValueError: Expecting value: line 1 column 1 (char 0)
      Any help appreciated :)
      dels
      delsD 1 Reply Last reply
      • delsD dels
        @BastienVH said:
        Hi Martin,
        @martinhjelmare
            fn(filename)
        dels
        delsD
        delsD
        dels
        @dels said:
        @BastienVH said:
        Hi Martin,
        @martinhjelmare
            fn(filename)
        dels
        Well... I feel stupid. I had completely forgotten that I had a Domoticz installed back a few weeks back when I first started searching for the right controller and it restarted when I rebooted the server... when I saw it was loaded, I shut it down and disabled it... then restarted home-assistant, which loaded mysensors perfectly and discovered the PIR sensor as soon as I reconnected it (after the mysensors component was loaded in HA). My guess is it loaded before HA and had dibs on the serial port or something...
        I hope it helps someone else!
        • delsD dels
          @dels said:
          @BastienVH said:
          Hi Martin,
          @martinhjelmare
              fn(filename)
          dels
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @dels
          Nice catch! Yes, the serial port is exclusive. Only one device/user at a time per port per end, is allowed.
          • B BastienVH
            Hi Martin,
            @martinhjelmare
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @BastienVH
            What version of pyserial do you have installed?
            For me version 2.5 has been the least buggy. Version 2.7 has a bug which was solved in version 3, but other bugs have emerged. I'm hoping they will be fixed soon.
            pip3 install pyserial==2.5
            Repeat this if you upgrade home assistant.
            Do you also only see the error on startup, or have you every successfully started up home assistant and loaded mysensors without errors, and later while running had this error?
            I'd like to try and make a workaround in the pymysensors api, but as I haven't really nailed down the bottom cause, all information will help me.
            • martinhjelmareM
              martinhjelmareM
              martinhjelmare
              Btw, I'm also working on a mysensors ethernet gateway for home assistant, but there is still some work and testing to be done.
              If you already have an ethernet module and like mqtt and don't mind having to do some configuring for every sensor/switch, mqtt is supported by home assistant in general. @Mihai has written a couple of guides both here and in the home assistant forum, for that.
              Soon I'm hoping you will have the option of choosing between all three gateway types when using home assistant, but of course we should try and make the serial connection more reliable.
              B 1 Reply Last reply
                B
                B
                BastienVH
                @martinhjelmare
                I was running pyserial 2.6, but have now installed version 2.5.
                I get the error, the moment I restart a sensor to have it included in HA.
                When I press the reset button on my sensor, the error shows up almost instantly in the terminal.
                So I guess that means that HA can connect to the serial gateway and receive messages, but just doesn't deal with it properly...
                Also: I had some trouble uninstalling the pyserial version and after some messing around, I now get this in my 'pip freeze'
                pyserial-py3k==2.5
                No mention of a 'normal' pyserial.
                Thanks for the help you've already provided!
                • B BastienVH
                  @martinhjelmare
                  pyserial-py3k==2.5
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  @BastienVH
                  Regarding py3k, that was a bug solved in 2.7:
                  "[Bug pyserial:130] setup.py should not append py3k to package name"
                  in https://github.com/pyserial/pyserial/blob/master/CHANGES.rst
                  But that shouldn't affect the performance of 2.5, I think.
                  If I understand correct, you do:
                  hass
                  wait for and get:
                  n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                  Then you reset your sensor node, and get the error?
                  Edit:
                  In my experience, I don't think I get the gateway started confirmation before I get the error. You should make sure that the gateway is ready before you do the restart of the sensor node. I think the problem might be that the gateway tries to talk to homeassistant before homeassistant is ready, and only part of the message gets "translated".
                    @BastienVH
                    hass
                    wait for and get:
                    Edit:
                    B
                    B
                    BastienVH
                    @martinhjelmare
                    I never got the "n:0 c:0 ...." message, only "Connected to /dev/MSgw".
                    I found out there was an instance of FHEM running and occuping the GW.
                    I stopped that and now it does give the "gateway started" message.
                    Now the error occurs indeed before the gateway started message.
                    Now I get the following after trying to let a node with DHT send its data to the gateway:
                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 10-10-0 s=255,c=3,t=15,pt=2,l=2,sg=0:0
                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 10-10-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.3
                    INFO:homeassistant.components.mysensors:update sensor_update: node 10
                    INFO:homeassistant.components.sensor.mysensors:Motion Sensor 10.1: value_type 16, value = 0
                    Exception in thread Thread-15:
                      File "/usr/lib/python3.4/threading.py", line 920, in _bootstrap_inner
                        self.run()
                      File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 312, in run
                        response = self.handle_queue()
                      File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 222, in handle_queue
                        reply = func(*args, **kwargs)
                      File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 108, in logic
                        self._handle_presentation(msg)
                      File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 51, in _handle_presentation
                        self.alert(msg.node_id)
                      File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 175, in alert
                        self.event_callback("sensor_update", nid)
                      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 226, in node_update
                        callback(self, node_id)
                      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 149, in mysensors_callback
                        entity.update_ha_state(True)
                      File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 108, in update_ha_state
                        self.unit_of_measurement is not None:
                      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/sensor/mysensors.py", line 137, in unit_of_measurement
                        self.value_type == self.gateway.const.SetReq.V_PERCENTAGE or \
                      File "/usr/lib/python3.4/enum.py", line 255, in __getattr__
                        raise AttributeError(name) from None
                    AttributeError: V_PERCENTAGE
                    Is there a list with which kinds of sensors are supported in HA?
                    Is motion/pir supported?
                    • B BastienVH
                      @martinhjelmare
                          self.run()
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @BastienVH
                      Basically all pure sensors are supported. Not all actuator types, though.
                      You can look at the source code for specifics. I want to add more documentation, but it's not done currently.
                      Your log seems to concern a motion sensor, but you said DHT?
                      You need to post the sensor sketch and all of the log from gateway started confirmation, to give me more background.
                        @BastienVH
                        B
                        B
                        BastienVH
                        @martinhjelmare
                        Yeah, I was also trying to get my motion sketch working, so that log message may have been something left over from that.
                        This is everything in my terminal
                        INFO:mysensors.mysensors:/dev/MSgw is open...
                        INFO:mysensors.mysensors:Connected to /dev/MSgw
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                        INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): 192.168.1.1
                        INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): 192.168.1.70
                        INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.1.70:1972/DeviceDescription.xml
                        Exception in thread Thread-6:
                            self.run()
                        I hope you can find something there...
                        • B BastienVH
                          @martinhjelmare
                              self.run()
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                            [[topic:post-is-deleted]]
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @BastienVH
                            I don't see a line in the log for presentation of the child sensor, or sketch name, or sketch version, but there already seem to be info loaded, sketch name and version and value type, looking at the line before the stack trace.
                            Is persistence disabled? Do you present the sensor in the sketch? Can you link to or post your sketch?
                            I think the problem might be that you're reusing an old node id with a different sensor type that's already been loaded via persistence.
                            I don't think I support these dynamics at the moment. I'll have to look more closely in the code, but if you can link your sketch, that will help me confirm this.
                            Solution would be to clear the persistence file.
                              @BastienVH
                              B
                              B
                              BastienVH
                              @martinhjelmare
                              Sorry, I was away from the computer for a little while.
                              I did reuse an old node id, that could have been the problem.
                              Assigned a new node ID and this is where I stand now:
                              Firts up: the node sketch:
                               * Version 1.0 - Henrik EKblad
                               * This sketch provides an example how to implement a humidity/temperature
                               * sensor using DHT11/DHT-22
                              #define DIGITAL_INPUT_MOTION 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                              #define INTERRUPT DIGITAL_INPUT_MOTION-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
                              #define CHILD_ID_HUM 0
                              #define CHILD_ID_TEMP 1
                              #define CHILD_ID_MOT 2
                              unsigned long SLEEP_TIME = 15000; // Sleep time between reads (in milliseconds)
                              DHT dht;
                              float lastTemp;
                              float lastHum;
                              boolean metric = true;
                              MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
                              int node_id = 20;
                              boolean lastTripped = false ;
                                gw.begin(NULL, node_id);
                                gw.sendSketchInfo("Humidity and motion", "1.0");
                                pinMode(DIGITAL_INPUT_MOTION, INPUT);      // sets the motion sensor digital pin as input
                                gw.present(CHILD_ID_MOT, S_MOTION);
                                /* int wake;
                                wake = gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
                                 if (wake == 1) {
                                   Serial.println("wake by motion");
                                   Serial.println("reading motion");
                                   motion();
                                 else {
                                   Serial.println("wake by timer");
                                   motion();
                                   Serial.println("reading temp/hum");
                                   humTemp();
                                motion();
                                Serial.println("read temp / hum");
                                humTemp();
                                Serial.println("going to sleep now.");
                                gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME); //sleep a bit
                              void motion() {
                                // Read digital motion value
                                boolean tripped = digitalRead(DIGITAL_INPUT_MOTION);
                                Serial.println(tripped);
                                if (lastTripped != tripped) {
                                  gw.send(msgMot.set(tripped ? "1" : "0")); // Send tripped value to gw
                                  lastTripped = tripped;
                              void humTemp() {
                                gw.wait(dht.getMinimumSamplingPeriod());
                                if (isnan(temperature)) {
                                  lastTemp = temperature;
                                  if (!metric) {
                                  Serial.print("T: ");
                                if (isnan(humidity)) {
                                  lastHum = humidity;
                                  Serial.print("H: ");
                                  Serial.println(humidity);
                              Now, my HA config:
                              homeassistant:
                                # Name of the location where Home Assistant is running
                                # Location required to calculate the time the sun rises and sets
                                latitude: xxxxxxxx
                                longitude: xxxxxxxxxxxxxx
                                # C for Celcius, F for Fahrenheit
                                temperature_unit: C
                                # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
                                time_zone: Europe/Brussels
                              # View all events in a logbook
                              logbook:
                              # Checks for available updates
                              updater:
                              # Discover some devices automatically
                              discovery:
                              # Track the sun
                              sun:
                              # Allows you to issue voice commands from the frontend
                              conversation:
                              # Enables support for tracking state changes over time.
                              history:
                              # Enables the frontend
                              frontend:
                              # Show links to resources in log and frontend
                              introduction:
                              mysensors:
                                gateways:
                                  - port: '/dev/MSgw'
                                debug: true
                                persistence: false
                              and the output when starting hass:
                              Config directory: /home/pi/.homeassistant
                              WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
                              INFO:homeassistant.bootstrap:Home Assistant core initialized
                              INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
                              INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                              INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                              INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                              INFO:homeassistant.loader:Loaded introduction from homeassistant.components.introduction
                              INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
                              INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
                              INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
                              INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
                              INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                              INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                              INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
                              INFO:homeassistant.components.introduction:
                                      Hello, and welcome to Home Assistant!
                                      We'll hope that we can make all your dreams come true.
                                      Here are some resources to get started:
                                       - Configuring Home Assistant:
                                         https://home-assistant.io/getting-started/configuration/
                                       - Available components:
                                         https://home-assistant.io/components/
                                       - Troubleshooting your configuration:
                                         https://home-assistant.io/getting-started/troubleshooting-configuration/
                                       - Getting help:
                                         https://home-assistant.io/help/
                                      This message is generated by the introduction component. You can
                                      disable it in configuration.yaml.
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=introduction>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                              INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
                              /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning
                                warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning')
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
                              INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                              INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=, service=mysensors.sensors>
                              INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                              INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                              INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=, service=mysensors.switches>
                              INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                              INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; next_setting=16:19:22 25-01-2016, friendly_name=Sun, next_rising=07:29:47 25-01-2016, elevation=-33.1 @ 20:51:46 24-01-2016>, entity_id=sun.sun>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
                              INFO:homeassistant.core:Starting Home Assistant (16 threads)
                              INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
                              INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
                              INFO:homeassistant.core:Timer:starting
                              INFO:mysensors.mysensors:Trying to connect to /dev/MSgw
                              INFO:homeassistant.components.http:"GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                              INFO:homeassistant.components.http:"GET /api/bootstrap HTTP/1.1" 200 -
                              INFO:netdisco.service:Scanning
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=0,c=1,t=1,pt=7,l=5,sg=0:54.0
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=0,c=1,t=1,pt=7,l=5,sg=0:53.0
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; next_setting=16:19:22 25-01-2016, friendly_name=Sun, next_rising=07:29:47 25-01-2016, elevation=-33.21 @ 20:51:46 24-01-2016>, entity_id=sun.sun, old_state=<state sun.sun=below_horizon; next_setting=16:19:22 25-01-2016, friendly_name=Sun, next_rising=07:29:47 25-01-2016, elevation=-33.1 @ 20:51:46 24-01-2016>>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; next_setting=16:19:22 25-01-2016, friendly_name=Sun, next_rising=07:29:47 25-01-2016, elevation=-33.36 @ 20:51:46 24-01-2016>, entity_id=sun.sun, old_state=<state sun.sun=below_horizon; next_setting=16:19:22 25-01-2016, friendly_name=Sun, next_rising=07:29:47 25-01-2016, elevation=-33.21 @ 20:51:46 24-01-2016>>
                              INFO:homeassistant.components.http:"GET /states HTTP/1.1" 200 -
                              INFO:homeassistant.components.http:"GET /static/frontend-1003c31441ec44b3db84b49980f736a7.html HTTP/1.1" 200 -
                              INFO:homeassistant.components.http:"GET /static/favicon-192x192.png HTTP/1.1" 200 -
                              INFO:homeassistant.components.http:"GET /static/favicon.ico HTTP/1.1" 200 -
                              I don't get errors anymore, but nothing shows up in the web interface.
                              I think the messages aren't being interpreted?
                              • B BastienVH
                                @martinhjelmare
                                DHT dht;
                                float lastTemp;
                                float lastHum;
                                int node_id = 20;
                                  /* int wake;
                                   if (wake == 1) {
                                     motion();
                                   else {
                                     motion();
                                     humTemp();
                                  motion();
                                  humTemp();
                                void motion() {
                                void humTemp() {
                                    if (!metric) {
                                    lastHum = humidity;
                                Now, my HA config:
                                homeassistant:
                                  latitude: xxxxxxxx
                                  temperature_unit: C
                                logbook:
                                updater:
                                discovery:
                                # Track the sun
                                sun:
                                conversation:
                                history:
                                frontend:
                                introduction:
                                mysensors:
                                  gateways:
                                    - port: '/dev/MSgw'
                                  debug: true
                                  persistence: false
                                         - Getting help:
                                delsD
                                delsD
                                dels
                                @BastienVH said:
                                @martinhjelmare
                                DHT dht;
                                float lastTemp;
                                float lastHum;
                                int node_id = 20;
                                  /* int wake;
                                   if (wake == 1) {
                                     motion();
                                   else {
                                     motion();
                                     humTemp();
                                  motion();
                                  humTemp();
                                void motion() {
                                void humTemp() {
                                    if (!metric) {
                                    lastHum = humidity;
                                Now, my HA config:
                                homeassistant:
                                  latitude: xxxxxxxx
                                  temperature_unit: C
                                logbook:
                                updater:
                                discovery:
                                # Track the sun
                                sun:
                                conversation:
                                history:
                                frontend:
                                introduction:
                                mysensors:
                                  gateways:
                                    - port: '/dev/MSgw'
                                  debug: true
                                  persistence: false
                                         - Getting help:
                                You have to reboot your individual sensors so HA can see their Presentation message. Your output seems to be good for the gateway itself, but the gateway is not an actual "item" in HA, when it detects the sensors though, you should see their status.
                                • delsD dels
                                  @BastienVH said:
                                  @martinhjelmare
                                  DHT dht;
                                  float lastTemp;
                                  float lastHum;
                                  int node_id = 20;
                                    /* int wake;
                                     if (wake == 1) {
                                       motion();
                                     else {
                                       motion();
                                       humTemp();
                                    motion();
                                    humTemp();
                                  void motion() {
                                  void humTemp() {
                                      if (!metric) {
                                      lastHum = humidity;
                                  Now, my HA config:
                                  homeassistant:
                                    latitude: xxxxxxxx
                                    temperature_unit: C
                                  logbook:
                                  updater:
                                  discovery:
                                  # Track the sun
                                  sun:
                                  conversation:
                                  history:
                                  frontend:
                                  introduction:
                                  mysensors:
                                    gateways:
                                      - port: '/dev/MSgw'
                                    debug: true
                                    persistence: false
                                           - Getting help:
                                  B
                                  B
                                  BastienVH
                                  It seems I did in fact forget to reboot my node when trying to include it in HA. (long day messing around with code...)
                                  Here is a console log from today in which I start up HA and reboot my node.
                                  HA receives the messages, but the node never shows up in the web interface:
                                  pi@raspberrypi ~ $ hass
                                           - Getting help:
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sun.sun, new_state=<state sun.sun=above_horizon; next_rising=07:28:30 26-01-2016, friendly_name=Sun, next_setting=16:19:22 25-01-2016, elevation=1.59 @ 08:45:51 25-01-2016>>
                                  INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.sensors, discovered=>
                                  INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.switches, discovered=>
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=255,c=3,t=15,pt=2,l=2,sg=0:0
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.3
                                  INFO:homeassistant.components.mysensors:update sensor_update: node 20
                                  INFO:homeassistant.components.mysensors:No sketch_name: node 20
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-20-20 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=255,c=3,t=11,pt=0,l=19,sg=0:Humidity and mo
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=0,c=0,t=7,pt=0,l=0,sg=0:
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=2,c=0,t=1,pt=0,l=0,sg=0:
                                  INFO:homeassistant.components.http:"GET /api/logbook/2016-1-25 HTTP/1.1" 200 -
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.0
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=0,c=1,t=1,pt=7,l=5,sg=0:51.0
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=2,c=1,t=16,pt=0,l=1,sg=0:1
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sun.sun, new_state=<state sun.sun=above_horizon; next_rising=07:28:30 26-01-2016, friendly_name=Sun, next_setting=16:19:22 25-01-2016, elevation=1.67 @ 08:45:51 25-01-2016>, old_state=<state sun.sun=above_horizon; next_rising=07:28:30 26-01-2016, friendly_name=Sun, next_setting=16:19:22 25-01-2016, elevation=1.59 @ 08:45:51 25-01-2016>>
                                  ^CINFO:homeassistant.core:Stopping
                                  INFO:homeassistant.core:Bus:Handling <Event homeassistant_stop[L]>
                                  INFO:mysensors.mysensors:Disconnecting from /dev/MSgw
                                  INFO:mysensors.mysensors:Stopping thread
                                  INFO:homeassistant.components.recorder:Closing database
                                  This is the line when I start my node:
                                  Your thoughts?
                                  martinhjelmareM 2 Replies Last reply
                                  • B BastienVH
                                             - Getting help:
                                    Your thoughts?
                                    martinhjelmareM
                                    martinhjelmareM
                                    martinhjelmare
                                    @BastienVH
                                    I can't see anything wrong in the log. You present properly and end by sending a value per sensor. The only thing is, there's no adding of the entity device in the log. Home assistant should report that in the log, when that happens: "adding new devices...".
                                    This is an internal message of type 15: I_REQUEST_SIGNING.
                                    This is a presentation message for node 20 of type 17: S_ARDUINO_NODE.
                                    First line is an internal message from node 20 to controller as request of type 6: I_CONFIG.
                                    The second line is an internal message from controller to node as response of type 6: I_CONFIG, payload:M for metric.
                                    This is an internal message of type 11: I_SKETCH_NAME.
                                    This is an internal message of type 12: I_SKETCH_VERSION.
                                    This is a presentation message for sensor 0 of type 7: S_HUM.
                                    Then you have presentation messages for sensor 1 of type 6 and for sensor 2 of type 1.
                                    See the API to figure those out:
                                    https://www.mysensors.org/download/serial_api_15
                                    The last three messages are reporting sensor values:
                                    This is a set message for sensor 1 of type 0: V_TEMP, payload: 22.0.
                                    The other two are set messages for sensor 0 of type 1 and sensor 2 of type 16.
                                    Maybe you can try everything again. Did you disable persistence? I think it's good to have it disabled, until you know everything is working, then you can activate persistence and do the presentation a final time. Remember to delete the persistence file if you have an old one, first though.
                                    Edit:
                                    There's a bug in home assistant version 0.11.1, which makes it impossible to load devices on the fly. A workaround is to enable persistence, present the sensors and send a value per sensor and then restart home assistant. After the restart the sensors should show up in the gui.
                                    • B BastienVH
                                               - Getting help:
                                      Your thoughts?
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @BastienVH
                                      We've been troubleshooting this in the other thread, and there seems to be a problem in the code somewhere. See this post for a workaround:
                                      http://forum.mysensors.org/topic/2831/home-assistant-v-0-11-1-with-switch-support/45
                                      Edit:
                                      The bug is found, and there will be a fix.
                                        @BastienVH
                                        Edit:
                                        B
                                        B
                                        BastienVH
                                        @martinhjelmare
                                        Thanks for the heads up!
                                        After following the steps there, I get my node up and running.
                                        Thanks for the help!
