  3. Solar Powered Mini-Weather Station
111 Posts 39 Posters 149.5k Views 27 Watching
  • bisschopsrB
    bisschopsrB
    bisschopsr
    The lamp is not shipped to NL and many other countries :unamused: . Did anyone find it in Europe?
    Domoticz, P1 meter interface, MySensors and more to come!
    • R
      R
      RiVoW
      In The Netherlands they used to have it at Action .
      But haven't been there lately
      • korttomaK
        korttomaK
        korttoma
        #57
        This One looks similar -> http://www.banggood.com/Solar-LED-Motion-Sensor-Waterproof-Wall-Light-For-Home-Garden-Outdoor-p-921885.html
        Maybe banggood ships to NL?
        • Tomas
        • R
          R
          RiVoW
          There seems to be a similar one for sale right now at groupdeal.nl
          but just for another 9 hours or so...
          • soifS
            soifS
            soif
            wrote on last edited by soif
            #59
            I really liked this project (@Salmoides ThankYou for sharing it)
            Expecially the solar powered box.
            I've successully prototyped one, but would like to report something to pepople trying to also make this.
            The solar panel included in the box, is outputting 6V, while the Charger board is sized to acced only 5V as input.
            The consequence, is (at least on my prototype) that when there is enought sun, the charger board don't charge the battery (the blue led lights on, and the red seems to vibrate slighty : I guess this is a "protection mode" when VCCin is to high). If i remove the solar panel, and put a usb cable in the charger input, then the RED led lights on, and the barrety is being charged.
            I guess that slighly modifying the charger board, would allow it to accept 6V as input, but this is too far from my electronic skills (Anyone?)
            As a workaround, I've ordered a StepDown module to reduce the 6V provided by the solar panel to 5V for the charger input. I guess It will do the job. I will report back as soon as I get the StepUp module from china.
            HTH those interested in this excellent project.
            BTW @Salmoides , How did you solved it? Does your Solar panel outputs 5V, instead of 6V? Does your charger works with 6V input (might be slighly diffrent board or mine has an issue)? Did you modified the charger or added extra component to reduce the input voltage ?
            Cheeers to evereyone !
            • soifS soif
              Put one or two silicon diodes in series with the solar panel. Each diode will lower the voltage by approx 0.7volts
              • soifS
                soifS
                soif
                #61
                @Yveaux thank you for the amazing fast and really helpful answer.
                Droping the voltage by 0.7v would certainly change the charger beahaviour to behave properly, and not be in "protection mode", Definitively better than inserting a stepDown module.
                I assume that I put the diode in serie from the VCC+ out of the Solar panel TO the VCC+ IN of the charger (right?), ie:
                Solar VCC out ------ --->| ---- Charger VCC in.
                3 questions:
                • Is there any diode reference recommendation, or any value do the job (1N400x) ?
                • Will the diode "eat" some current, ot just drop the voltage -0,7v. ?
                • BTW what is a "Silicon" diode?
                thank you very much for your valuable support !
                Berst regards,
                • soifS soif
                  3 questions:
                  Berst regards,
                  @soif Your connection idea is correct. If you mount it in reverse, it simply won't work.
                  The actual voltage drop over the diode will depend on the amount of current flowing through it, so that's why you might require 2 in series.
                  An 1N400x will do just fine. The higher the x, the more current it can handle.
                  The diode will consume some current, but that will be less then a step-down converter.
                  Most diodes nowadays use silicon as semiconductor. Years ago Germanium diodes were used, which have a lower voltage drop.
                  As a reference: everything you need to know about diodes
                  soifS 1 Reply Last reply
                  • YveauxY Yveaux
                    soifS
                    soifS
                    soif
                    @Yveaux Thank you very much for the diode explanation, as well as the very interesting diode tutorial.
                    Thanks to you, I've learned something more today.
                    I'm gonna test it very soon, and will report back.
                    • bisschopsrB bisschopsr
                      @bisschopsr @RiVoW @korttoma Accidentally ran into this one: http://www.aliexpress.com/store/product/1set-Garden-Security-Lamp-16-LED-Solar-Power-Motion-Sensor-Outdoor-Waterproof-Light/124364_32274407358.html
                      Looks identical, and free shipment to The Netherlands :+1:
                      • soifS
                        soifS
                        soif
                        This is similar to the one I have also bought at aliexpress ;-)
                        • thmT
                          thmT
                          thm
                          Hello, thank you for this beautiful project.
                          I have recreated it with a DHT22, a BMP180 and a BH1750FVI on a breadboard. From there everything is transferred to Domoticz via WiFi gateway. Everything is working properly. Only the light sensor makes problems ...
                          The reading of the sensor gives correct values in Lux. These are sent right to the gateway. The Gateway appears to be wrong to interpret these values. It transmits incorrect values via WiFi.
                          What can I do against it? Did anyone have an idea?
                          I'm using MySensors 1.5 on Arduino 1.6.7.
                          Thomas
                          • SalmoidesS Salmoides
                            @floris, Thank you for your kind words. The luxmeter faces down, so the light is indirectly collected through the diffuser. If I were to build V2.0, I would look into adding a light pipe to provide more direct lighting on the sensor.
                            maciejka
                            @Salmoides
                            Hi, where i can find light pipe lie this?
                            • C
                              C
                              chickey
                              I have one of these lights and got it with the plan of dissembling it for this very project but it was too good lol so think I'll buy another to dissect. The only disappointing thing is how the light is always on at a dim level so drains the battery. I'd much rather have it only activate on motion detection with the PIR.
                              • D
                                Dylano
                                Dear...
                                Great project...[ when i got my stuff i am going to build to...
                                Only how do you use the motionsensor of this light...[ new one or do you use the build in one ]
                                In the sketch is can not see this motionsensor?
                                Only in our Vera controller is see arm and bypass?
                                Can you set the level of the lights, in vera?
                                Two times temperature?
                                And how is your battery action in the winter-period?
                                Domoticz, with a lot of working hardware, include mysensors :-)
                                OpenPLI, RuneAudio, Solarmeter, etc......
                                Not a great builder of software and hardware, more a user...
                                Only i try to do my best :-(
                                • E
                                  E
                                  Elfnoir
                                  wrote on last edited by Elfnoir
                                  #70
                                  Here is the fritzing shema ; could you please tell me if it is correct before I begin the building of the weather station ?
                                  Thanks for your support !
                                  D 1 Reply Last reply
                                  • E Elfnoir
                                    Dylano
                                    @Elfnoir
                                    This is great.....[ and great for a dummy like me ]
                                    Would you please tell me all the hardware you use?
                                    Or the strength of the resistor etc etc
                                    • E
                                      E
                                      Elfnoir
                                      The left resistor is a 1Mohm 2W(I'll confirm the power value once I'll received it), the right one is 4,7kohm, 1/4W.
                                      For the Hardware, I read the beginning of the post, but unfortunately I'm also a newby, and need to have a validation of this diagram, because I'm not sure if it is correct, and I don't want to burn my house if I'll do cabling mistakes ;-)
                                      I am not able to put the file created under fritzing, but if someone wants it, tell me how to do it please.
                                      Thanks for your feedback!
                                      Regards.
                                      • bisschopsrB
                                        bisschopsrB
                                        bisschopsr
                                        Hi all,
                                        the lamp used as a basis for this desing is now frequently offered at Aliexpress. Price is around $10,-. DOn't know about quality, but looks very simular.
                                        Ralph
                                        • peerkersezuukerP
                                          peerkersezuukerP
                                          peerkersezuuker
                                          Hello All,
                                          Long time reader, first time poster.
                                          I've been building my-sensors in combo with Domoticz for a while now , and this project is one of my favorites.
                                          I can confirm that the fritzing schema is correct, i checked it against the one i build. (whish i had the schema earlier, it would have been so much easier ;-))
                                          I used the followin library from Rob Tillaart for the DHT22 (http://playground.arduino.cc/Main/DHTLib / https://github.com/RobTillaart/Arduino/tree/master/libraries/DHTlib) because the standard was not working...
                                          Change line 37 to dht DHT;
                                          comment out line 51
                                          From line 78 i changed the code to this :
                                          delay(2000);
                                                int chk = DHT.read22(HUMIDITY_SENSOR_DIGITAL_PIN);
                                                temp = DHT.temperature;
                                                       //Serial.print("Temperature DHT :");
                                                       //Serial.println(temp);
                                                if (isnan(temp)) {
                                                    lastTemp = -1;
                                                  lastTemp = temp;
                                                  if (!metric) {
                                                    temp = temp * 1.8 + 32.0;
                                                  gw.send(msgTemp.set(temp, 1));
                                                hum = DHT.humidity;
                                                if (isnan(hum)) {
                                                    lastHum = -1;
                                                } else if (hum != lastHum) {
                                                    lastHum = hum;
                                                    gw.send(msgHum.set(hum, 1));
                                          And it is working like a charm.
                                          Now i ordered one of these : Wind Sensor
                                          I want to trie to get it working with this build.
                                          And indeed the lamp is stil available Solar Lamp
                                          Hope this helps,
                                          With Regard's
                                          Peer
                                          Domoticz / My Sensors / Z-Wave
                                          https://www.kermisbuks.nl
                                          peerkersezuukerP 1 Reply Last reply
