  3. Solar Powered Mini-Weather Station
111 Posts 39 Posters 149.5k Views 27 Watching
  • B
    B
    Bazeman
    Please add an wiring diagram. Especially for the solar panel, battery and connection to the Nano.
    D 1 Reply Last reply
    • 5546dug5 5546dug
      @Salmoides great thread and project
      Was trying to follow the wiring on the back side of the board to wire my project and was wondering how you wrap the wires around the posts sticking through the board for soldering.
      Also is there a wiring diagram?
      B
      B
      Bazeman
      @5546dug Have you a wiring diagram?
      • YveauxY Yveaux
        @hek tricky, as we seem to be the only ones having issues with the library included with MySensors. I only have one DHT22 so I cannot test with other sensors...
        A Former User
        I've build something like this that logs temperature to an SD card, so no radio or gateway involved. Been getting NaNs from my DHT22 every few readings since I switched from a 5v Pro Mini to a 3.3v one. This never happened on the 5v one, so I guess I'll try switching library as well!
        • G
          G
          gbfromhb
          wrote on last edited by gbfromhb
          #53
          @hek I like the following library https://github.com/adafruit/DHT-sensor-library (ladyada).
          This seems to be working fine with the Arduino Pro Mini 8mhz.
          Here is a MySensors example using this library:
           * Version 1.0 - Henrik EKblad
           * Version 1.1 - Glenn Byron - September 6, 2015 - Converted to new DHT library written by ladyada
           * This sketch provides an example how to implement a humidity/temperature
           * sensor using DHT11, DHT21, DHT-22
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          #define HUMIDITY_SENSOR_DIGITAL_PIN 2
          #define DHTTYPE DHT22
          // DHTTYPE choices: DHT11, DHT21, DHT22
          DHT dht(HUMIDITY_SENSOR_DIGITAL_PIN, DHTTYPE);
          float lastTemp;
          float lastHum;
          boolean metric = false;
            Serial.flush();
            Serial.println("MySensors: DHT example");
            gw.begin();
            dht.begin();
            gw.sendSketchInfo("Humidity", "1.0");
            delay(2000);
            float temperature = dht.readTemperature(!metric);
            if (isnan(temperature)) {
              lastTemp = temperature;
              Serial.print("Temperature: ");
            float humidity = dht.readHumidity();
            if (isnan(humidity)) {
                lastHum = humidity;
                Serial.print("Humidity: ");
                Serial.println(humidity);
          • B Bazeman
            drock1985
            wrote on last edited by drock1985
            #54
            @Bazeman
            If i'm not mistaken, the solor panel is directly connected to the power input of the solar charger. @Salmoides wired a mini/microUSB to the power cables to make it easy connect/disconnect. It's this one, from what I can see in the pictures. http://www.aliexpress.com/item/5PCS-Micro-USB-5V-1A-18650-Lithium-Battery-Charger-Board-With-Protection-Module/1852341893.html
            From there, it's pretty straight forward. The battery is connected to the B+ and B- leads. The OUT+ and OUT- would be connected to the VIN/RAW and GND on your Nano, respectively.
            My Projects
            2 Door Chime Sensor
            Washing Machine Monitor
            • bisschopsrB
              bisschopsrB
              bisschopsr
              The lamp is not shipped to NL and many other countries :unamused: . Did anyone find it in Europe?
              Domoticz, P1 meter interface, MySensors and more to come!
              • R
                R
                RiVoW
                In The Netherlands they used to have it at Action .
                But haven't been there lately
                • korttomaK
                  korttomaK
                  korttoma
                  #57
                  This One looks similar -> http://www.banggood.com/Solar-LED-Motion-Sensor-Waterproof-Wall-Light-For-Home-Garden-Outdoor-p-921885.html
                  Maybe banggood ships to NL?
                  • Tomas
                  • R
                    R
                    RiVoW
                    There seems to be a similar one for sale right now at groupdeal.nl
                    but just for another 9 hours or so...
                    • soifS
                      soifS
                      soif
                      wrote on last edited by soif
                      #59
                      I really liked this project (@Salmoides ThankYou for sharing it)
                      Expecially the solar powered box.
                      I've successully prototyped one, but would like to report something to pepople trying to also make this.
                      The solar panel included in the box, is outputting 6V, while the Charger board is sized to acced only 5V as input.
                      The consequence, is (at least on my prototype) that when there is enought sun, the charger board don't charge the battery (the blue led lights on, and the red seems to vibrate slighty : I guess this is a "protection mode" when VCCin is to high). If i remove the solar panel, and put a usb cable in the charger input, then the RED led lights on, and the barrety is being charged.
                      I guess that slighly modifying the charger board, would allow it to accept 6V as input, but this is too far from my electronic skills (Anyone?)
                      As a workaround, I've ordered a StepDown module to reduce the 6V provided by the solar panel to 5V for the charger input. I guess It will do the job. I will report back as soon as I get the StepUp module from china.
                      HTH those interested in this excellent project.
                      BTW @Salmoides , How did you solved it? Does your Solar panel outputs 5V, instead of 6V? Does your charger works with 6V input (might be slighly diffrent board or mine has an issue)? Did you modified the charger or added extra component to reduce the input voltage ?
                      Cheeers to evereyone !
                      • soifS soif
                        Put one or two silicon diodes in series with the solar panel. Each diode will lower the voltage by approx 0.7volts
                        • soifS
                          soifS
                          soif
                          #61
                          @Yveaux thank you for the amazing fast and really helpful answer.
                          Droping the voltage by 0.7v would certainly change the charger beahaviour to behave properly, and not be in "protection mode", Definitively better than inserting a stepDown module.
                          I assume that I put the diode in serie from the VCC+ out of the Solar panel TO the VCC+ IN of the charger (right?), ie:
                          Solar VCC out ------ --->| ---- Charger VCC in.
                          3 questions:
                          • Is there any diode reference recommendation, or any value do the job (1N400x) ?
                          • Will the diode "eat" some current, ot just drop the voltage -0,7v. ?
                          • BTW what is a "Silicon" diode?
                          thank you very much for your valuable support !
                          Berst regards,
                          • soifS soif
                            3 questions:
                            Berst regards,
                            @soif Your connection idea is correct. If you mount it in reverse, it simply won't work.
                            The actual voltage drop over the diode will depend on the amount of current flowing through it, so that's why you might require 2 in series.
                            An 1N400x will do just fine. The higher the x, the more current it can handle.
                            The diode will consume some current, but that will be less then a step-down converter.
                            Most diodes nowadays use silicon as semiconductor. Years ago Germanium diodes were used, which have a lower voltage drop.
                            As a reference: everything you need to know about diodes
                            soifS 1 Reply Last reply
                            • YveauxY Yveaux
                              soifS
                              soifS
                              soif
                              @Yveaux Thank you very much for the diode explanation, as well as the very interesting diode tutorial.
                              Thanks to you, I've learned something more today.
                              I'm gonna test it very soon, and will report back.
                              • bisschopsrB bisschopsr
                                @bisschopsr @RiVoW @korttoma Accidentally ran into this one: http://www.aliexpress.com/store/product/1set-Garden-Security-Lamp-16-LED-Solar-Power-Motion-Sensor-Outdoor-Waterproof-Light/124364_32274407358.html
                                Looks identical, and free shipment to The Netherlands :+1:
                                • soifS
                                  soifS
                                  soif
                                  This is similar to the one I have also bought at aliexpress ;-)
                                  • thmT
                                    thmT
                                    thm
                                    Hello, thank you for this beautiful project.
                                    I have recreated it with a DHT22, a BMP180 and a BH1750FVI on a breadboard. From there everything is transferred to Domoticz via WiFi gateway. Everything is working properly. Only the light sensor makes problems ...
                                    The reading of the sensor gives correct values in Lux. These are sent right to the gateway. The Gateway appears to be wrong to interpret these values. It transmits incorrect values via WiFi.
                                    What can I do against it? Did anyone have an idea?
                                    I'm using MySensors 1.5 on Arduino 1.6.7.
                                    Thomas
                                    • SalmoidesS Salmoides
                                      @floris, Thank you for your kind words. The luxmeter faces down, so the light is indirectly collected through the diffuser. If I were to build V2.0, I would look into adding a light pipe to provide more direct lighting on the sensor.
                                      maciejka
                                      @Salmoides
                                      Hi, where i can find light pipe lie this?
                                      • C
                                        C
                                        chickey
                                        I have one of these lights and got it with the plan of dissembling it for this very project but it was too good lol so think I'll buy another to dissect. The only disappointing thing is how the light is always on at a dim level so drains the battery. I'd much rather have it only activate on motion detection with the PIR.
                                        • D
                                          Dylano
                                          Dear...
                                          Great project...[ when i got my stuff i am going to build to...
                                          Only how do you use the motionsensor of this light...[ new one or do you use the build in one ]
                                          In the sketch is can not see this motionsensor?
                                          Only in our Vera controller is see arm and bypass?
                                          Can you set the level of the lights, in vera?
                                          Two times temperature?
                                          And how is your battery action in the winter-period?
                                          Domoticz, with a lot of working hardware, include mysensors :-)
                                          OpenPLI, RuneAudio, Solarmeter, etc......
                                          Not a great builder of software and hardware, more a user...
                                          Only i try to do my best :-(
