  3. Home Assistant
  4. Home Assistant v 0.11.1 with switch support
switchserial gatewayhome assistant
53 Posts 5 Posters 28.5k Views 5 Watching
  • D
    drock1985
    Hi @martinhjelmare
    I have installed 0.11.1 and added the lines to configuration.yaml, but my sensors are bit showing in ha itself. The ID of the nodes is being passed to ha in the log, but nothing else. Trying to set to a pir, temp/humid, and relay switches.
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • D drock1985
      Hi @martinhjelmare
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @drock1985
      Please show me the home assistant log. I can't really say anything useful without it.
      • D
        drock1985
        Hi @martinhjelmare
        here is the output from /home/pi/.homeassistant/home-assistant.log:
        6-01-24 15:08:16 netdisco.ssdp: Found malformed XML at http://192.168.86.142:9080: status=ok
        This is my configuration.yaml
        homeassistant:
          # Name of the location where Home Assistant is running
          # Location required to calculate the time the sun rises and sets
          latitude:
          longitude:
          # C for Celcius, F for Fahrenheit
          temperature_unit: C
          # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
          time_zone: America/Halifax
        # Enables the frontend
        frontend:
        # Checks for available updates
        updater:
        # View all events in a logbook
        logbook:
        # Track the sun
        sun:
        # Enables support for tracking state changes over time.
        history:
        # Show links to resources in log and frontend
        #introduction:
        # Allows you to issue voice commands from the frontend
        conversation:
        # Discover some devices automatically
        discovery:
        # Webcams
        camera 1:
          platform: mjpeg
          mjpeg_url: http://192.168.86.117:10012/videofeed
          username: root
          password: groot
        # Squeezebox Server
        media_player 1:
          platform: squeezebox
          host: 192.168.86.113
          port: 9090
        # MySensors Serial Gateway
        mysensors:
          gateways:
            - port: '/dev/ttyUSB0'
              persistence_file: '/home/pi/.homeassistant/mysensors.json'
        #  debug: true
          persistence: true
          version: '1.5'
        Would it be because my nodes are set for manual ID and not auto?
        My Projects
        2 Door Chime Sensor
        • D drock1985
          Hi @martinhjelmare
          homeassistant:
            latitude:
            longitude:
            temperature_unit: C
          frontend:
          updater:
          logbook:
          # Track the sun
          sun:
          history:
          #introduction:
          conversation:
          discovery:
          # Webcams
          camera 1:
            platform: mjpeg
            username: root
            password: groot
          # Squeezebox Server
          media_player 1:
            port: 9090
          mysensors:
            gateways:
          #  debug: true
            persistence: true
            version: '1.5'
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @drock1985
          The log file only outputs errors as default. Try starting home assistant from the command line with hass and then copy the output. It should be a lot more than one line.
          You should shut down home assistant first if you have it running as a service.
          Activate debug first for mysensors though.
          • D
            drock1985
            @martinhjelmare
            Here is the .log file
            16-01-24 15:25:28 mysensors.mysensors: Error decoding message from gateway, probably received bad byte.
            And from the SSH console after running hass as instructed
            INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.111
            INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.163
            INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.108
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.master_bedroom=off; supported_media_commands=1021, friendly_name=Master Bedroom @ 15:25:41 24-01-2016>, entity_id=media_player.master_bedroom>
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.man_cave=off; supported_media_commands=1021, friendly_name=Man Cave @ 15:25:41 24-01-2016>, entity_id=media_player.man_cave>
            INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "CatFan">
            INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "LivingRoomLamp">
            INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "CatFan">
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.living_room=off; supported_media_commands=1021, friendly_name=Living Room @ 15:25:41 24-01-2016>, entity_id=media_player.living_room>
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.catfan=off; friendly_name=CatFan @ 15:25:41 24-01-2016>, entity_id=switch.catfan>
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=unknown; auto=True, entity_id=[], friendly_name=all switches @ 15:25:41 24-01-2016>, entity_id=group.all_switches>
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.catfan',), friendly_name=all switches @ 15:25:41 24-01-2016>, entity_id=group.all_switches>
            INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "LivingRoomLamp">
            INFO:pywemo.subscribe:Received event from <WeMo Switch "CatFan">(192.168.86.108)
            INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "CatFan">
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.livingroomlamp=off; friendly_name=LivingRoomLamp @ 15:25:42 24-01-2016>, entity_id=switch.livingroomlamp>
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.catfan', 'switch.livingroomlamp'), friendly_name=all switches @ 15:25:42 24-01-2016>, entity_id=group.all_switches>
            INFO:pywemo.subscribe:Received event from <WeMo Switch "LivingRoomLamp">(192.168.86.163)
            INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "LivingRoomLamp">
            INFO:pywemo.subscribe:Subscribing to events from <WeMo Insight "Christmas Tree Lights">
            INFO:pywemo.subscribe:Resubscribe for <WeMo Insight "Christmas Tree Lights">
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.christmas_tree_lights=off; friendly_name=Christmas Tree Lights @ 15:25:42 24-01-2016>, entity_id=switch.christmas_tree_lights>
            INFO:pywemo.subscribe:Received event from <WeMo Insight "Christmas Tree Lights">(192.168.86.111)
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.christmas_tree_lights', 'switch.catfan', 'switch.livingroomlamp'), friendly_name=all switches @ 15:25:42 24-01-2016>, entity_id=group.all_switches>
            INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Insight "Christmas Tree Lights">
            INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.117
            INFO:homeassistant.components.http:"GET /states HTTP/1.1" 200 -
            INFO:homeassistant.components.http:"GET /static/frontend-1003c31441ec44b3db84b49980f736a7.html HTTP/1.1" 200 -
            INFO:homeassistant.components.http:"GET /static/favicon-192x192.png HTTP/1.1" 200 -
            INFO:homeassistant.components.http:"GET /static/favicon.ico HTTP/1.1" 200 -
            INFO:homeassistant.components.http:"GET /api/bootstrap HTTP/1.1" 200 -
            INFO:homeassistant.components.http:"GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
            INFO:homeassistant.components.media_player:Updating media_player entities
            INFO:homeassistant.components.http:"GET /api/error_log HTTP/1.1" 200 -
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=2,c=1,t=16,pt=0,l=1,sg=0:1
            INFO:homeassistant.components.light:Updating light entities
            INFO:homeassistant.components.camera:Updating camera entities
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663560.5128732, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663530.5116684, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.1
            INFO:homeassistant.components.mysensors:update sensor_update: node 3
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-3-3 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=11,pt=0,l=25,sg=0:2 Door bell/chime
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=0,c=0,t=1,pt=0,l=0,sg=0:
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=3,c=0,t=3,pt=0,l=0,sg=0:
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=2,c=0,t=1,pt=0,l=0,sg=0:
            INFO:homeassistant.components.api:Found broken event stream to 192.168.86.162, cleaning up
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663590.5271018, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663560.5128732, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.76, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, old_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.88, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, entity_id=sun.sun>
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.5
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.6
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663620.51471, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663590.5271018, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663650.5204854, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663620.51471, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.63, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, old_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.76, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, entity_id=sun.sun>
            My Projects
            2 Door Chime Sensor
            • D drock1985
              @martinhjelmare
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @drock1985
              Is it node 3 that is missing for you? It seems you're presenting it fine but never send the needed value for the four sensors, 0-3, on the node.
              Then you also have node 1 with two sensors 0 and 2 that seems to update, but you haven't posted the beginning of the log where those are presented or loaded from persistence. I'm also missing the gateway started confirmation in the log.
              • D
                drock1985
                Hi @martinhjelmare
                the file /home/pi/.homeassistant/home-assistant.log has no errors in it, and it's all of my nodes that are missing (1 through 4 and 6), Node 5 isn't online right now.
                Is that what you are looking for at the top?
                INFO:homeassistant.components.recorder:Closing database
                pi@home-assistant:~/.homeassistant $ clear
                pi@home-assistant:~/.homeassistant $ hass
                Config directory: /home/pi/.homeassistant
                WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
                INFO:homeassistant.bootstrap:Home Assistant core initialized
                INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
                INFO:homeassistant.loader:Loaded media_player from homeassistant.components.media_player
                INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
                INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
                INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
                INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
                INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
                INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                INFO:homeassistant.loader:Loaded camera from homeassistant.components.camera
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
                INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.sensors, discovered=>
                INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
                INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.switches, discovered=>
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                INFO:homeassistant.loader:Loaded media_player.squeezebox from homeassistant.components.media_player.squeezebox
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.airspeaker=off; friendly_name=AirSpeaker, supported_media_commands=447 @ 17:05:03 24-01-2016>, entity_id=media_player.airspeaker>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_down>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play_pause>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_pause>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_up>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_previous_track>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_off>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_media>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_next_track>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_on>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_set>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_mute>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_seek>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_fireplace>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_epic_sax>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_youtube_video>
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=media_player>
                INFO:urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.17 @ 17:05:03 24-01-2016>, entity_id=sun.sun>
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
                INFO:urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
                /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning
                  warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning')
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                INFO:homeassistant.loader:Loaded camera.mjpeg from homeassistant.components.camera.mjpeg
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669504.2007444 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera>
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=camera>
                INFO:homeassistant.core:Starting Home Assistant (17 threads)
                INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
                INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
                INFO:homeassistant.core:Timer:starting
                INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
                INFO:homeassistant.components.mysensors:update persistence: node 2
                INFO:homeassistant.components.mysensors:No sketch_name: node 2
                INFO:homeassistant.components.mysensors:update persistence: node 3
                INFO:netdisco.service:Scanning
                INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
                INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
                WARNING:mysensors.mysensors:Error decoding message from gateway, probably received bad byte.
                INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.4
                INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.113
                INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.101
                INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.142
                INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.199
                INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.102
                INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.4:32469/DeviceDescription.xml
                INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.113:9000/plugins/UPnP/MediaServer.xml
                INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.101', 8009)
                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.101', 8009)>
                INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.102', 8009)
                INFO:homeassistant.loader:Loaded media_player.cast from homeassistant.components.media_player.cast
                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.102', 8009)>
                INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')
                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')>
                INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')
                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')>
                INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')
                INFO:homeassistant.loader:Loaded switch.wemo from homeassistant.components.switch.wemo
                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')>
                ERROR:homeassistant.components.switch:Error while setting up platform wemo
                  File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 145, in _setup_platform
                    self.hass, platform_config, self.add_entities, discovery_info)
                  File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/switch/wemo.py", line 25, in setup_platform
                    import pywemo.discovery as discovery
                AttributeError: 'module' object has no attribute 'discovery'
                INFO:pychromecast:Querying device status
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.man_cave=off; friendly_name=Man Cave, supported_media_commands=1021 @ 17:05:19 24-01-2016>, entity_id=media_player.man_cave>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.master_bedroom=off; friendly_name=Master Bedroom, supported_media_commands=1021 @ 17:05:19 24-01-2016>, entity_id=media_player.master_bedroom>
                INFO:homeassistant.components.discovery:Found new service: plex_mediaserver ('Rocknet Server', 'https://192.168.86.4:32400')
                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=plex_mediaserver, discovered=('Rocknet Server', 'https://192.168.86.4:32400')>
                INFO:homeassistant.components.discovery:Found new service: philips_hue ('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')
                INFO:homeassistant.loader:Loaded media_player.plex from homeassistant.components.media_player.plex
                INFO:homeassistant.loader:Loaded light from homeassistant.components.light
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_on>
                INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_off>
                INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=light>
                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=philips_hue, discovered=('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')>
                INFO:homeassistant.loader:Loaded light.hue from homeassistant.components.light.hue
                INFO:phue:Attempting to connect to the bridge...
                INFO:phue:Using ip: 192.168.86.199
                INFO:phue:Using username from config: 30f609e6210320e41f0dfc32220a525f
                Exception in thread Thread-25:
                  File "/usr/lib/python3.4/threading.py", line 920, in _bootstrap_inner
                    self.run()
                  File "/home/pi/.homeassistant/lib/zeroconf.py", line 1063, in run
                    handler(self.zc)
                  File "/home/pi/.homeassistant/lib/zeroconf.py", line 1014, in <lambda>
                    state_change=state_change,
                  File "/home/pi/.homeassistant/lib/zeroconf.py", line 931, in fire
                    h(**kwargs)
                  File "/home/pi/.homeassistant/lib/zeroconf.py", line 989, in on_change
                    listener.add_service(*args)
                  File "/home/pi/.homeassistant/lib/netdisco/discoverables/__init__.py", line 84, in add_service
                    service = zconf.get_service_info(typ, name)
                  File "/home/pi/.homeassistant/lib/zeroconf.py", line 1404, in get_service_info
                    if info.request(self, timeout):
                  File "/home/pi/.homeassistant/lib/zeroconf.py", line 1221, in request
                    zc.send(out)
                  File "/home/pi/.homeassistant/lib/zeroconf.py", line 1663, in send
                    bytes_sent = s.sendto(packet, 0, (addr, port))
                OSError: [Errno 9] Bad file descriptor
                INFO:plexapi:GET http://192.168.86.4:32400/
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_1=off; friendly_name=Master bedroom 1 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_1>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_2=off; friendly_name=Master bedroom 2 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_2>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.aprils_lamp=off; friendly_name=April's lamp @ 17:05:20 24-01-2016>, entity_id=light.aprils_lamp>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_1=off; friendly_name=Living room light 1 @ 17:05:20 24-01-2016>, entity_id=light.living_room_light_1>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_light_strip=off; friendly_name=Master bedroom light strip @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_light_strip>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_2=off; friendly_name=Living room light 2 @ 17:05:20 24-01-2016>, entity_id=light.living_room_light_2>
                INFO:homeassistant.components.media_player.plex:Connected to: htts://192.168.86.4:32400
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_3=off; friendly_name=Master bedroom 3 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_3>
                INFO:plexapi:GET http://192.168.86.4:32400/clients
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=unknown; entity_id=[], friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>, entity_id=group.all_lights>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=off; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>, entity_id=group.all_lights>
                INFO:plexapi:GET http://192.168.86.4:32400/status/sessions
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669530.5242217 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669504.2007444 @ 17:05:04 24-01-2016>>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.1 @ 17:05:03 24-01-2016>, entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.17 @ 17:05:03 24-01-2016>>
                INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=homeassistant, entity_id=light.living_room_light_1, service_call_id=1981876976-1, service=turn_on>
                INFO:homeassistant.loader:Loaded group from homeassistant.components.group
                INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=light, entity_id=['light.living_room_light_1'], service_call_id=1981876976-2, service=turn_on>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_1=on; brightness=254, friendly_name=Living room light 1 @ 17:05:47 24-01-2016>, entity_id=light.living_room_light_1, old_state=<state light.living_room_light_1=off; friendly_name=Living room light 1 @ 17:05:20 24-01-2016>>
                INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-2>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=on; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:47 24-01-2016>, entity_id=group.all_lights, old_state=<state group.all_lights=off; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>>
                INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-1>
                INFO:homeassistant.components.http:"POST /api/services/homeassistant/turn_on HTTP/1.1" 200 -
                INFO:homeassistant.components.http:"GET /api/history/period?filter_entity_id=light.living_room_light_2 HTTP/1.1" 200 -
                INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=homeassistant, entity_id=light.living_room_light_2, service_call_id=1981876976-3, service=turn_on>
                INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=light, entity_id=['light.living_room_light_2'], service_call_id=1981876976-4, service=turn_on>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_2=on; brightness=254, friendly_name=Living room light 2 @ 17:05:49 24-01-2016>, entity_id=light.living_room_light_2, old_state=<state light.living_room_light_2=off; friendly_name=Living room light 2 @ 17:05:20 24-01-2016>>
                INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-4>
                INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-3>
                INFO:homeassistant.components.http:"GET /api/history/period?filter_entity_id=light.living_room_light_1 HTTP/1.1" 200 -
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669560.5092123 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669530.5242217 @ 17:05:04 24-01-2016>>
                INFO:homeassistant.components.http:"GET /devInfo HTTP/1.1" 200 -
                ^CINFO:homeassistant.core:Stopping
                INFO:homeassistant.core:Bus:Handling <Event homeassistant_stop[L]>
                INFO:mysensors.mysensors:Disconnecting from /dev/ttyUSB0
                INFO:mysensors.mysensors:Stopping thread
                My Projects
                2 Door Chime Sensor
                • D
                  drock1985
                  I'm still trying to get this to work, with mixed results. Noticed on startup sometimes that HA was starting before my Serial port was initialized. Added a .timer file to delay the start of HA until the Pi is fully booted. Still having problems, but now i'm getting this in the HA logs:
                  16-01-24 18:37:40 homeassistant.core: BusHandler:Exception doing job
                    File "/usr/local/lib/python3.4/dist-packages/homeassistant/core.py", line 829, in job_handler
                      func(arg)
                    File "/usr/local/lib/python3.4/dist-packages/homeassistant/core.py", line 302, in onetime_listener
                      listener(event)
                    File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 104, in gw_start
                      gateway.event_callback('persistence', node_id)
                    File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 226, in node_update
                      callback(self, node_id)
                    File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 165, in mysensors_callback
                      add_devices(devices[node_id])
                    File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 81, in add_entities
                      entity.update_ha_state()
                    File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 108, in update_ha_state
                      self.unit_of_measurement is not None:
                    File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/sensor/mysensors.py", line 137, in unit_of_measurement
                      self.value_type == self.gateway.const.SetReq.V_PERCENTAGE or \
                    File "/usr/lib/python3.4/enum.py", line 255, in __getattr__
                      raise AttributeError(name) from None
                  AttributeError: V_PERCENTAGE
                  16-01-24 18:37:43 mysensors.mysensors: Error decoding message from gateway, probably received bad byte.
                  My Projects
                  2 Door Chime Sensor
                  • D drock1985
                        func(arg)
                        listener(event)
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @drock1985
                    I think you need to delete the persistence file and start over and present your sensors. You should do this while looking at the output from hass so you get feedback if it's working or not.
                    From the top of your log output there was a warning about bad byte from the gateway. The gateway started confirmation was never logged. You should see this before you start your sensors. If you don't get the gateway confirmation, try restarting home assistant.
                    Also in the log, the persistence file loaded sensor 2 and 3, but some data was missing, probably. There was a note about missing sketch name for one of the sensors.
                    You need to present the sensors properly, including sketch name and then send one value per sensor before they show up in the gui.
                    • asmA
                      asmA
                      asm
                      Hey @drock1985 , would you please update the thread if you are able to work around this ? I am experiencing something similar after my latest upgrade: None of the sensors appear in the UI. I have disabled persistence and removed the json files, and presented the nodes again, but still nothing appears. In debug mode I can see the messages from the Humidity sensor, for instance, but that's all.
                      D 1 Reply Last reply
                      • asmA asm
                        drock1985
                        Hi @asm and @martinhjelmare
                        Still having issues after multiple restarts and two different nano's and NRF radios. I am like you, can see the messages but whatever I try I can't get rid of the bad byte error in the beginning.
                        Going to try a uno next and see if that changes anything.
                        My Projects
                        2 Door Chime Sensor
                        • D drock1985
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @drock1985
                          What version of pyserial do you have installed?
                          pip show pyserial
                          Try version 2.5, which has been the least buggy for me.
                          pip3 install pyserial==2.5
                          pip show will not output anything if you have version 2.5 of pyserial installed.
                          • D
                            drock1985
                            I have 2.7 installed right now; installing 2.5 and i'll reboot and see what happens.
                            My Projects
                            2 Door Chime Sensor
                            • D
                              drock1985
                              Hi @martinhjelmare
                              I have installed pyserial2.5, but I still get errors. This is the latest when using an Arduino Uno (not genuine, but pretty close) and I do not see the unexpected byte messages anymore. Still not getting anything to show though.
                               hass
                              WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring dis                                                             abled
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeas                                                             sistant, service=turn_off>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeas                                                             sistant, service=turn_on>
                              INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discove                                                             ry
                              INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysenso                                                             rs
                              INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conv                                                             ersation
                              INFO:homeassistant.loader:Loaded media_player from homeassistant.components.medi                                                             a_player
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recor                                                             der>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbo                                                             ok>
                              INFO:urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.co                                                             m
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state s                                                             un.sun=below_horizon; elevation=-12.86, next_setting=21:17:57 26-01-2016, friend                                                             ly_name=Sun, next_rising=11:42:09 26-01-2016 @ 18:28:34 25-01-2016>, entity_id=s                                                             un.sun>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updat                                                             er>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=disco                                                             very>
                              INFO:homeassistant.loader:Loaded camera.mjpeg from homeassistant.components.came                                                             ra.mjpeg
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state c                                                             amera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/a                                                             pi/camera_proxy/camera.livingroom_camera?time=1453760914.813284 @ 18:28:34 25-01                                                             -2016>, entity_id=camera.livingroom_camera>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=camer                                                             a>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=front                                                             end>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=histo                                                             ry>
                              INFO:mysensors.mysensors:File does not exist or is not readable: /home/pi/.homea                                                             ssistant/mysensors1.pickle
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=senso                                                             r>
                              INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=myse                                                             nsors.sensors, discovered=>
                              INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.                                                             sensor.mysensors
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch                                                             , service=turn_off>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch                                                             , service=turn_on>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switc                                                             h>
                              INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=myse                                                             nsors.switches, discovered=>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysen                                                             sors>
                              INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.                                                             switch.mysensors
                              /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-                                                             python SequenceMatcher. Install python-Levenshtein to remove this warning
                                warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levensht                                                             ein to remove this warning')
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conver                                                             sation, service=process>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conve                                                             rsation>
                              INFO:homeassistant.loader:Loaded media_player.squeezebox from homeassistant.comp                                                             onents.media_player.squeezebox
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state m                                                             edia_player.airspeaker=off; friendly_name=AirSpeaker, supported_media_commands=4                                                             47 @ 18:28:35 25-01-2016>, entity_id=media_player.airspeaker>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=media_next_track>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=media_play>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=volume_up>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=media_pause>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=turn_on>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=turn_off>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=volume_down>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=media_play_pause>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=play_media>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=media_previous_track>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=volume_set>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=volume_mute>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=media_seek>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=start_fireplace>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=start_epic_sax>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=play_youtube_video>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=media                                                             _player>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeas                                                             sistant, service=stop>
                              INFO:homeassistant.components.http:"GET /api/stream?api_password=no_password_set                                                             &restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                              Exception in thread Thread-14:
                                  self.run()
                                File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 312, in run
                                  response = self.handle_queue()
                                File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 222, in handle                                                             _queue
                                  reply = func(*args, **kwargs)
                                File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 105, in logic
                                  msg = Message(data)
                                File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 397, in __init                                                             __
                                  self.decode(data)
                                File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 417, in decode
                                  self.sub_type) = [int(f) for f in data]
                                File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 417, in <listc                                                             omp>
                              ValueError: invalid literal for int() with base 10: '\x00\x00\x00\x00\x00\x00\x0                                                             0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x0                                                             0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x0                                                             0\x00\x00\x0
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=light                                                             >
                              INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=phil                                                             ips_hue, discovered=('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/'                                                             )>
                              INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('CatFan'                                                             , 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')
                              INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belk                                                             in_wemo, discovered=('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml'                                                             , '94103E30CDBC')>
                              INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('LivingR                                                             oomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')
                              INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belk                                                             in_wemo, discovered=('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/se                                                             tup.xml', '94103E30C688')>
                              INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.8                                                             6.113:9000/plugins/UPnP/MediaServer.xml
                              INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.8                                                             6.4:32469/DeviceDescription.xml
                              INFO:homeassistant.loader:Loaded light.hue from homeassistant.components.light.h                                                             ue
                              INFO:homeassistant.loader:Loaded switch.wemo from homeassistant.components.switc                                                             h.wemo
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state l                                                             ight.aprils_lamp=off; friendly_name=April's lamp @ 18:28:50 25-01-2016>, entity_                                                             id=light.aprils_lamp>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state l                                                             ight.master_bedroom_3=off; friendly_name=Master bedroom 3 @ 18:28:50 25-01-2016>                                                             , entity_id=light.master_bedroom_3>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state l                                                             ight.master_bedroom_2=off; friendly_name=Master bedroom 2 @ 18:28:50 25-01-2016>                                                             , entity_id=light.master_bedroom_2>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state l                                                             ight.living_room_light_2=on; brightness=254, friendly_name=Living room light 2 @                                                              18:28:50 25-01-2016>, entity_id=light.living_room_light_2>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state l                                                             ight.master_bedroom_1=off; friendly_name=Master bedroom 1 @ 18:28:50 25-01-2016>                                                             , entity_id=light.master_bedroom_1>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state l                                                             ight.living_room_light_1=on; brightness=254, friendly_name=Living room light 1 @                                                              18:28:50 25-01-2016>, entity_id=light.living_room_light_1>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state l                                                             ight.master_bedroom_light_strip=off; friendly_name=Master bedroom light strip @                                                              18:28:50 25-01-2016>, entity_id=light.master_bedroom_light_strip>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state g                                                             roup.all_lights=unknown; friendly_name=all lights, entity_id=[], auto=True @ 18:                                                             28:50 25-01-2016>, entity_id=group.all_lights>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state g                                                             roup.all_lights=on; friendly_name=all lights, entity_id=('light.living_room_ligh                                                             t_1', 'light.aprils_lamp', 'light.master_bedroom_light_strip', 'light.living_roo                                                             m_light_2', 'light.master_bedroom_1', 'light.master_bedroom_2', 'light.master_be                                                             droom_3'), auto=True @ 18:28:50 25-01-2016>, entity_id=group.all_lights>
                              INFO:pywemo.subscribe:Listening on port 8989
                              INFO:homeassistant.components.discovery:Found new service: plex_mediaserver ('Ro                                                             cknet Server', 'https://192.168.86.4:32400')
                              INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=plex                                                             _mediaserver, discovered=('Rocknet Server', 'https://192.168.86.4:32400')>
                              INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168                                                             .86.101', 8009)
                              INFO:homeassistant.loader:Loaded media_player.plex from homeassistant.components                                                             .media_player.plex
                              INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=goog                                                             le_cast, discovered=('192.168.86.101', 8009)>
                              INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168                                                             .86.142', 8009)
                              INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=goog                                                             le_cast, discovered=('192.168.86.142', 8009)>
                              INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168                                                             .86.102', 8009)
                              INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=goog                                                             le_cast, discovered=('192.168.86.102', 8009)>
                              INFO:homeassistant.loader:Loaded media_player.cast from homeassistant.components                                                             .media_player.cast
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state s                                                             witch.catfan=off; friendly_name=CatFan @ 18:28:51 25-01-2016>, entity_id=switch.                                                             catfan>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state g                                                             roup.all_switches=unknown; friendly_name=all switches, entity_id=[], auto=True @                                                              18:28:51 25-01-2016>, entity_id=group.all_switches>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state g                                                             roup.all_switches=off; friendly_name=all switches, entity_id=('switch.catfan',),                                                              auto=True @ 18:28:52 25-01-2016>, entity_id=group.all_switches>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state s                                                             witch.livingroomlamp=on; friendly_name=LivingRoomLamp @ 18:28:52 25-01-2016>, en                                                             tity_id=switch.livingroomlamp>
                              INFO:pywemo.subscribe:Received event from <WeMo Switch "LivingRoomLamp">(192.168                                                             .86.163)
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state g                                                             roup.all_switches=on; friendly_name=all switches, entity_id=('switch.catfan', 's                                                             witch.livingroomlamp'), auto=True @ 18:28:52 25-01-2016>, entity_id=group.all_sw                                                             itches>
                              INFO:homeassistant.components.media_player.plex:Connected to: htts://192.168.86.                                                             4:32400
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state m                                                             edia_player.man_cave=off; friendly_name=Man Cave, supported_media_commands=1021                                                              @ 18:28:52 25-01-2016>, entity_id=media_player.man_cave>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state m                                                             edia_player.master_bedroom=off; friendly_name=Master Bedroom, supported_media_co                                                             mmands=1021 @ 18:28:52 25-01-2016>, entity_id=media_player.master_bedroom>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state m                                                             edia_player.living_room=off; friendly_name=Living Room, supported_media_commands                                                             =1021 @ 18:28:53 25-01-2016>, entity_id=media_player.living_room>
                              INFO:homeassistant.components.switch.wemo:Shutting down subscriptions.
                              pi@home-assistant:~ $
                              My Projects
                              2 Door Chime Sensor
                              • D
                                drock1985
                                Ok, here is a better log. I decided to set up a new node, one that would auto get the node_ID to see if there was atleast some communication both ways. There seems to be, as the gateway did assign a node_ID, but it didn't show up in HA on the web at all.
                                Maybe I need to start HA all over again, just keep the configuration.yaml file?
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453761305.5420914, friendly_name=LivingRoom Camera @ 18:35:05 25-01-2016>, entity_id=camera.livingroom_camera>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; friendly_name=Sun, next_rising=11:42:09 26-01-2016, next_setting=21:17:57 26-01-2016, elevation=-14.01 @ 18:35:11 25-01-2016>, entity_id=sun.sun>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.airspeaker=off; supported_media_commands=447, friendly_name=AirSpeaker @ 18:35:11 25-01-2016>, entity_id=media_player.airspeaker>
                                INFO:mysensors.mysensors:File does not exist or is not readable: /home/pi/.homeassistant/mysensors1.pickle
                                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=, service=mysensors.sensors>
                                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=, service=mysensors.switches>
                                WARNING:homeassistant.components.recorder:Found unfinished sessions
                                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('Rocknet Server', 'https://192.168.86.4:32400'), service=plex_mediaserver>
                                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('192.168.86.102', 8009), service=google_cast>
                                INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.142', 8009)
                                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('192.168.86.142', 8009), service=google_cast>
                                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('192.168.86.101', 8009), service=google_cast>
                                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C'), service=belkin_wemo>
                                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688'), service=belkin_wemo>
                                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC'), service=belkin_wemo>
                                INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/'), service=philips_hue>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_1=off; friendly_name=Master bedroom 1 @ 18:35:27 25-01-2016>, entity_id=light.master_bedroom_1>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.aprils_lamp=off; friendly_name=April's lamp @ 18:35:27 25-01-2016>, entity_id=light.aprils_lamp>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_2=off; friendly_name=Master bedroom 2 @ 18:35:27 25-01-2016>, entity_id=light.master_bedroom_2>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_light_strip=off; friendly_name=Master bedroom light strip @ 18:35:27 25-01-2016>, entity_id=light.master_bedroom_light_strip>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_2=on; brightness=254, friendly_name=Living room light 2 @ 18:35:27 25-01-2016>, entity_id=light.living_room_light_2>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_3=off; friendly_name=Master bedroom 3 @ 18:35:27 25-01-2016>, entity_id=light.master_bedroom_3>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_1=on; brightness=254, friendly_name=Living room light 1 @ 18:35:27 25-01-2016>, entity_id=light.living_room_light_1>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=unknown; entity_id=[], auto=True, friendly_name=all lights @ 18:35:27 25-01-2016>, entity_id=group.all_lights>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=on; entity_id=('light.aprils_lamp', 'light.master_bedroom_1', 'light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_light_strip', 'light.master_bedroom_3', 'light.master_bedroom_2'), auto=True, friendly_name=all lights @ 18:35:27 25-01-2016>, entity_id=group.all_lights>
                                ERROR:homeassistant.components.media_player:Error while setting up platform cast
                                  File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/media_player/cast.py", line 39, in setup_platform
                                    import pychromecast
                                  File "/home/pi/.homeassistant/lib/pychromecast/__init__.py", line 14, in <module>
                                    from . import socket_client
                                ImportError: cannot import name 'socket_client'
                                    import pychromecast
                                  File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/media_player/cast.py", line 68, in setup_platform
                                    casts.append(CastDevice(host))
                                  File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/media_player/cast.py", line 84, in __init__
                                    import pychromecast.controllers.youtube as youtube
                                AttributeError: 'module' object has no attribute 'controllers'
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.catfan=off; friendly_name=CatFan @ 18:35:29 25-01-2016>, entity_id=switch.catfan>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=unknown; entity_id=[], auto=True, friendly_name=all switches @ 18:35:29 25-01-2016>, entity_id=group.all_switches>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; entity_id=('switch.catfan',), auto=True, friendly_name=all switches @ 18:35:29 25-01-2016>, entity_id=group.all_switches>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.livingroomlamp=on; friendly_name=LivingRoomLamp @ 18:35:29 25-01-2016>, entity_id=switch.livingroomlamp>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=on; entity_id=('switch.livingroomlamp', 'switch.catfan'), auto=True, friendly_name=all switches @ 18:35:29 25-01-2016>, entity_id=group.all_switches>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.christmas_tree_lights=off; friendly_name=Christmas Tree Lights @ 18:35:29 25-01-2016>, entity_id=switch.christmas_tree_lights>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=on; entity_id=('switch.livingroomlamp', 'switch.christmas_tree_lights', 'switch.catfan'), auto=True, friendly_name=all switches @ 18:35:29 25-01-2016>, entity_id=group.all_switches>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453761330.5161493, friendly_name=LivingRoom Camera @ 18:35:05 25-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453761305.5420914, friendly_name=LivingRoom Camera @ 18:35:05 25-01-2016>>
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; friendly_name=Sun, next_rising=11:42:09 26-01-2016, next_setting=21:17:57 26-01-2016, elevation=-14.07 @ 18:35:11 25-01-2016>, entity_id=sun.sun, old_state=<state sun.sun=below_horizon; friendly_name=Sun, next_rising=11:42:09 26-01-2016, next_setting=21:17:57 26-01-2016, elevation=-14.01 @ 18:35:11 25-01-2016>>
                                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.1
                                INFO:homeassistant.components.mysensors:update sensor_update: node 1
                                INFO:homeassistant.components.mysensors:No sketch_name: node 1
                                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
                                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=0,t=1,pt=0,l=0,sg=0:
                                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453761360.5125034, friendly_name=LivingRoom Camera @ 18:35:05 25-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453761330.5161493, friendly_name=LivingRoom Camera @ 18:35:05 25-01-2016>>
                                My Projects
                                2 Door Chime Sensor
                                asmA martinhjelmareM 2 Replies Last reply
                                • D drock1985
                                      import pychromecast
                                      import pychromecast
                                  asmA
                                  asmA
                                  asm
                                  @drock1985 Interesting ! I restarted a few times too with persistence enabled and at some point the json file gets populated. Another restart and the sensor appears in the UI ...
                                  • D
                                    drock1985
                                    Hi @asm
                                    Glad to hear you had some luck. I'm getting closer (i think), getting different errors in the log now. The Motion sensor shows up in terminal, and even identifies it just not in the GUI.
                                    ARG! I bet it is something so small it's not funny anymore!
                                    Jan 25 19:03:23 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sun.sun, new_state=<state sun.sun=below_horizon; elevation=-18.97, next_setting=21:17:57 26-01-2016, friendly_name=Sun, next_rising=11:42:09 26-01-2016 @ 19:03:24 25-01-2016>>
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.sensors, discovered=>
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=switch>
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=switch>
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.switches, discovered=>
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Starting Home Assistant (17 threads)
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Timer:starting
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:update persistence: node 1
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:No sketch_name: node 1
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.components.http:"GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:netdisco.service:Scanning
                                    Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.components.http:"GET /api/bootstrap HTTP/1.1" 200 -
                                    Jan 25 19:03:27 home-assistant hass[1416]: INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
                                    Jan 25 19:03:27 home-assistant hass[1416]: INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
                                    Jan 25 19:03:27 home-assistant hass[1416]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                                    Jan 25 19:03:30 home-assistant hass[1416]: INFO:homeassistant.components.media_player:Updating media_player entities
                                    Jan 25 19:03:30 home-assistant hass[1416]: INFO:homeassistant.components.camera:Updating camera entities
                                    Jan 25 19:03:30 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453763003.501535, friendly_name=LivingRoom Camera @ 19:03:23 25-01-2016>, entity_id=camera.livingroom_camera, new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453763010.532438, friendly_name=LivingRoom Camera @ 19:03:23 25-01-2016>>
                                    Jan 25 19:03:30 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sun.sun=below_horizon; elevation=-18.97, next_setting=21:17:57 26-01-2016, friendly_name=Sun, next_rising=11:42:09 26-01-2016 @ 19:03:24 25-01-2016>, entity_id=sun.sun, new_state=<state sun.sun=below_horizon; elevation=-18.99, next_setting=21:17:57 26-01-2016, friendly_name=Sun, next_rising=11:42:09 26-01-2016 @ 19:03:24 25-01-2016>>
                                    Jan 25 19:03:37 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.1
                                    Jan 25 19:03:37 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.101
                                    Jan 25 19:03:37 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.113
                                    Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.142
                                    Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.199
                                    Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.113
                                    Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.102
                                    Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.108
                                    Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.163
                                    Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.111
                                    Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.4
                                    Jan 25 19:03:38 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.113:9000/plugins/UPnP/MediaServer.xml
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: plex_mediaserver ('Rocknet Server', 'https://192.168.86.4:32400')
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=plex_mediaserver, discovered=('Rocknet Server', 'https://192.168.86.4:32400')>
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.142', 8009)
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.142', 8009)>
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.101', 8009)
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.101', 8009)>
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.102', 8009)
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.102', 8009)>
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')>
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded media_player.plex from homeassistant.components.media_player.plex
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded media_player.cast from homeassistant.components.media_player.cast
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')>
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded switch.wemo from homeassistant.components.switch.wemo
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')>
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: philips_hue ('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')
                                    Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded light from homeassistant.components.light
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=light>
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=light>
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=light>
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=philips_hue, discovered=('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')>
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded light.hue from homeassistant.components.light.hue
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:phue:Attempting to connect to the bridge...
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:phue:Using ip: 192.168.86.199
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:phue:Using username from config: 30f609e6210320e41f0dfc32220a525f
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:plexapi:GET http://192.168.86.4:32400/
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.4
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=light.master_bedroom_1, new_state=<state light.master_bedroom_1=off; friendly_name=Master bedroom 1 @ 19:03:40 25-01-2016>>
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=light.master_bedroom_light_strip, new_state=<state light.master_bedroom_light_strip=off; friendly_name=Master bedroom light strip @ 19:03:40 25-01-2016>>
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=light.master_bedroom_3, new_state=<state light.master_bedroom_3=off; friendly_name=Master bedroom 3 @ 19:03:40 25-01-2016>>
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=light.master_bedroom_2, new_state=<state light.master_bedroom_2=off; friendly_name=Master bedroom 2 @ 19:03:40 25-01-2016>>
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=light.living_room_light_1, new_state=<state light.living_room_light_1=on; friendly_name=Living room light 1, brightness=254 @ 19:03:40 25-01-2016>>
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=light.aprils_lamp, new_state=<state light.aprils_lamp=on; friendly_name=April's lamp, brightness=254 @ 19:03:40 25-01-2016>>
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=light.living_room_light_2, new_state=<state light.living_room_light_2=on; friendly_name=Living room light 2, brightness=254 @ 19:03:40 25-01-2016>>
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.components.media_player.plex:Connected to: htts://192.168.86.4:32400
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, new_state=<state group.all_lights=unknown; entity_id=[], auto=True, friendly_name=all lights @ 19:03:40 25-01-2016>>
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:plexapi:GET http://192.168.86.4:32400/clients
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, new_state=<state group.all_lights=on; entity_id=('light.master_bedroom_3', 'light.aprils_lamp', 'light.living_room_light_1', 'light.master_bedroom_1', 'light.master_bedroom_2', 'light.master_bedroom_light_strip', 'light.living_room_light_2'), auto=True, friendly_name=all lights @ 19:03:40 25-01-2016>>
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:plexapi:GET http://192.168.86.4:32400/status/sessions
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.163
                                    Jan 25 19:03:40 home-assistant hass[1416]: ERROR:homeassistant.components.switch:Error while setting up platform wemo
                                    Jan 25 19:03:40 home-assistant hass[1416]: Traceback (most recent call last):
                                    Jan 25 19:03:40 home-assistant hass[1416]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 145, in _setup_platform
                                    Jan 25 19:03:40 home-assistant hass[1416]: self.hass, platform_config, self.add_entities, discovery_info)
                                    Jan 25 19:03:40 home-assistant hass[1416]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/switch/wemo.py", line 25, in setup_platform
                                    Jan 25 19:03:40 home-assistant hass[1416]: import pywemo.discovery as discovery
                                    Jan 25 19:03:40 home-assistant hass[1416]: AttributeError: 'module' object has no attribute 'discovery'
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:pywemo.subscribe:Listening on port 8989
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.components.media_player:Updating media_player entities
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:pychromecast:Querying device status
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.102
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.101
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.142
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:update sensor_update: node 1
                                    Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:No sketch_name: node 1
                                    Jan 25 19:03:41 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=media_player.man_cave, new_state=<state media_player.man_cave=off; supported_media_commands=1021, friendly_name=Man Cave @ 19:03:40 25-01-2016>>
                                    Jan 25 19:03:41 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.163
                                    Jan 25 19:03:41 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=media_player.master_bedroom, new_state=<state media_player.master_bedroom=off; supported_media_commands=1021, friendly_name=Master Bedroom @ 19:03:41 25-01-2016>>
                                    Jan 25 19:03:41 home-assistant hass[1416]: INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "LivingRoomLamp">
                                    Jan 25 19:03:41 home-assistant hass[1416]: INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "LivingRoomLamp">
                                    Jan 25 19:03:41 home-assistant hass[1416]: INFO:pywemo.subscribe:Received event from <WeMo Switch "LivingRoomLamp">(192.168.86.163)
                                    Jan 25 19:03:41 home-assistant hass[1416]: INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "LivingRoomLamp">
                                    Jan 25 19:03:41 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=switch.livingroomlamp, new_state=<state switch.livingroomlamp=on; friendly_name=LivingRoomLamp @ 19:03:41 25-01-2016>>
                                    Jan 25 19:03:41 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=group.all_switches, new_state=<state group.all_switches=unknown; entity_id=[], auto=True, friendly_name=all switches @ 19:03:41 25-01-2016>>
                                    Jan 25 19:03:41 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=group.all_switches, new_state=<state group.all_switches=on; entity_id=('switch.livingroomlamp',), auto=True, friendly_name=all switches @ 19:03:41 25-01-2016>>
                                    Jan 25 19:03:41 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=media_player.living_room, new_state=<state media_player.living_room=off; supported_media_commands=1021, friendly_name=Living Room @ 19:03:41 25-01-2016>>
                                    Jan 25 19:03:45 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.117
                                    Jan 25 19:03:50 home-assistant hass[1416]: INFO:homeassistant.components.media_player:Updating media_player entities
                                    Jan 25 19:03:51 home-assistant hass[1416]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.1
                                    Jan 25 19:03:51 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:update sensor_update: node 1
                                    Jan 25 19:03:51 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:No sketch_name: node 1
                                    Jan 25 19:03:51 home-assistant hass[1416]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                    Jan 25 19:03:51 home-assistant hass[1416]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                                    Jan 25 19:03:53 home-assistant hass[1416]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
                                    Jan 25 19:03:53 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:update sensor_update: node 1
                                    Jan 25 19:03:53 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:adding new devices: [<Entity Motion Sensor 1.1: >]
                                    Jan 25 19:04:00 home-assistant hass[1416]: Exception in thread Thread-15:
                                    Jan 25 19:04:00 home-assistant hass[1416]: Traceback (most recent call last):
                                    Jan 25 19:04:00 home-assistant hass[1416]: File "/usr/lib/python3.4/threading.py", line 920, in _bootstrap_inner
                                    Jan 25 19:04:00 home-assistant hass[1416]: self.run()
                                    Jan 25 19:04:00 home-assistant hass[1416]: File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 312, in run
                                    Jan 25 19:04:00 home-assistant hass[1416]: response = self.handle_queue()
                                    Jan 25 19:04:00 home-assistant hass[1416]: File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 222, in handle_queue
                                    Jan 25 19:04:00 home-assistant hass[1416]: reply = func(*args, **kwargs)
                                    Jan 25 19:04:00 home-assistant hass[1416]: File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 112, in logic
                                    Jan 25 19:04:00 home-assistant hass[1416]: return self._handle_internal(msg)
                                    Jan 25 19:04:00 home-assistant hass[1416]: File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 74, in _handle_internal
                                    Jan 25 19:04:00 home-assistant hass[1416]: self.alert(msg.node_id)
                                    Jan 25 19:04:00 home-assistant hass[1416]: File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 175, in alert
                                    Jan 25 19:04:00 home-assistant hass[1416]: self.event_callback("sensor_update", nid)
                                    Jan 25 19:04:00 home-assistant hass[1416]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 226, in node_update
                                    Jan 25 19:04:00 home-assistant hass[1416]: callback(self, node_id)
                                    Jan 25 19:04:00 home-assistant hass[1416]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 165, in mysensors_callback
                                    Jan 25 19:04:00 home-assistant hass[1416]: add_devices(devices[node_id])
                                    Jan 25 19:04:00 home-assistant hass[1416]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 81, in add_entities
                                    Jan 25 19:04:00 home-assistant hass[1416]: entity.update_ha_state()
                                    Jan 25 19:04:00 home-assistant hass[1416]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 108, in update_ha_state
                                    Jan 25 19:04:00 home-assistant hass[1416]: self.unit_of_measurement is not None:
                                    Jan 25 19:04:00 home-assistant hass[1416]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/sensor/mysensors.py", line 137, in unit_of_measurement
                                    Jan 25 19:04:00 home-assistant hass[1416]: self.value_type == self.gateway.const.SetReq.V_PERCENTAGE or \
                                    Jan 25 19:04:00 home-assistant hass[1416]: File "/usr/lib/python3.4/enum.py", line 255, in __getattr__
                                    Jan 25 19:04:00 home-assistant hass[1416]: raise AttributeError(name) from None
                                    Jan 25 19:04:00 home-assistant hass[1416]: AttributeError: V_PERCENTAGE
                                    Jan 25 19:04:00 home-assistant hass[1416]: INFO:homeassistant.components.media_player:Updating media_player entities
                                    Jan 25 19:04:00 home-assistant hass[1416]: INFO:homeassistant.components.light:Updating light entities
                                    Jan 25 19:04:00 home-assistant hass[1416]: INFO:homeassistant.components.camera:Updating camera entities
                                    Jan 25 19:04:00 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453763010.532438, friendly_name=LivingRoom Camera @ 19:03:23 25-01-2016>, entity_id=camera.livingroom_camera, new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453763040.5191662, friendly_name=LivingRoom Camera @ 19:03:23 25-01-2016>>
                                    Jan 25 19:04:00 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.117
                                    My Projects
                                    2 Door Chime Sensor
                                    Washing Machine Monitor
                                    • D drock1985
                                      pi@home-assistant:~/.homeassistant $ hass
                                      Config directory: /home/pi/.homeassistant
                                      WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
                                      INFO:homeassistant.bootstrap:Home Assistant core initialized
                                      INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
                                      INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                                      INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                                      INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                                      INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
                                      INFO:homeassistant.loader:Loaded camera from homeassistant.components.camera
                                      INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
                                      INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
                                      INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                                      INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                                      INFO:homeassistant.loader:Loaded media_player from homeassistant.components.media_player
                                      INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
                                      INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                                      INFO:homeassistant.loader:Loaded camera.mjpeg from homeassistant.components.camera.mjpeg
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=camera>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                                      INFO:homeassistant.loader:Loaded media_player.squeezebox from homeassistant.components.media_player.squeezebox
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_pause>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_on>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_media>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_off>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_up>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_down>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play_pause>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_next_track>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_previous_track>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_set>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_mute>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_seek>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_fireplace>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_epic_sax>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_youtube_video>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=media_player>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
                                      /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning
                                        warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning')
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
                                      INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.4:32469/DeviceDescription.xml
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_on>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_off>
                                          import pychromecast
                                          import pychromecast
                                      INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "CatFan">
                                      INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "CatFan">
                                      INFO:pywemo.subscribe:Received event from <WeMo Switch "CatFan">(192.168.86.108)
                                      INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "CatFan">
                                      INFO:pywemo.subscribe:Subscribing to events from <WeMo Insight "Christmas Tree Lights">
                                      INFO:pywemo.subscribe:Resubscribe for <WeMo Insight "Christmas Tree Lights">
                                      INFO:pywemo.subscribe:Received event from <WeMo Insight "Christmas Tree Lights">(192.168.86.111)
                                      INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Insight "Christmas Tree Lights">
                                      INFO:homeassistant.components.http:"GET /api/error_log HTTP/1.1" 200 -
                                      INFO:homeassistant.components.http:"GET /states HTTP/1.1" 200 -
                                      INFO:homeassistant.components.http:"GET /static/frontend-1003c31441ec44b3db84b49980f736a7.html HTTP/1.1" 200 -
                                      INFO:homeassistant.components.http:"GET /static/favicon-192x192.png HTTP/1.1" 200 -
                                      INFO:homeassistant.components.http:"GET /static/favicon.ico HTTP/1.1" 200 -
                                      INFO:homeassistant.components.recorder:Closing database
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      #44
                                      @drock1985
                                      All the messages logged from the gateway look good in the latest log output without errors. Only thing missing is a log line saying "adding new devices...". There are three main reasons why this doesn't happen when the code executes:
                                      • A device with the same node id is already added.
                                      • Some node/sensor data is missing in the data stuctures, sketch name, child id, S_TYPE, V_TYPE.
                                      • The S_TYPE and V_TYPE for the child sensor is not handled by any of the platforms that home assistant supports.
                                      All pure sensors in version 1.5 are currently supported by the sensor platform. The switch platform supports:
                                      S_DOOR,
                                      S_MOTION,
                                      S_SMOKE,
                                      S_LIGHT,
                                      S_LOCK,
                                      S_BINARY,
                                      S_SPRINKLER,
                                      S_WATER_LEAK,
                                      S_SOUND,
                                      S_VIBRATION,
                                      S_MOISTURE,
                                      V_ARMED,
                                      V_LIGHT,
                                      V_LOCK_STATUS,
                                      V_STATUS
                                      There's a bug if you don't specify version 1.5 in the config of home assistant. It's related to the V_PERCENTAGE attribute error. I'm fixing that now. But I don't think that's your problem here. My guess is point 1 or 2 above is the problem.
                                      You could try the following:
                                      • Remove any json or pickle persistence files from your config directory.
                                      • Activate persistence in your config (and set version 1.5).
                                      • Connect your gateway
                                      • Start hass
                                      • Wait for "gateway started" log line
                                      • Connect the sensor
                                      • If no errors occur, open the newly generated persistence file and copy/paste the contents here. This might give us more clues.
                                      • martinhjelmareM
                                        martinhjelmareM
                                        martinhjelmare
                                        I'm trying to replicate the problem, and there seem to be some issue with adding devices "on the fly" and not from the persistence file.
                                        A workaround seems to be, as @asm reported:
                                        • Present sensors and send a value per sensor
                                        • Restart home assistant
                                        I'll try to figure out the cause and make a fix.
                                        • martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          Ok, I've found the bug. I'll make the fix and pull request to home assistant. It should make the next release.
                                          Until then the workaround above should be usable, at least.
                                          Make sure you present the sensors and send at least one value per sensor, and the persistence file will be populated. Then after the restart of home assistant your sensors should show in the gui.
                                          Sorry for the inconvenience, and thanks for helping me troubleshoot this! I really appreciate all feedback and also any criticism, which in the end will make the controller and plugin better.
                                          asmA 1 Reply Last reply
                                          12.5k
