  3. Home Assistant
  4. Home Assistant v 0.11.1 with switch support
switchserial gatewayhome assistant
53 Posts 5 Posters 28.5k Views 5 Watching
  • M mirko314
    Alright then, I started to feel a bit dumb :D
    If you need any help let me know!
    Thank you for looking into the issue :+1:
    martinhjelmareM
    martinhjelmareM
    martinhjelmare
    @mirko314
    Thanks for testing and reporting the problem. All feedback is very welcome and important, cause even though I try to test most scenarios, it's easy to miss something. In this case, though, I feel a bit embarrassed. :flushed:
    I've submitted a tested pull request which fixes this, and it has already been merged. Hopefully the bugfix release will be live very soon.
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      Update: Bugfix release 0.11.1 is now out.
        mirko314
        Nice!
        Thank you, I installed it, works like a charm!
        Going to try a HA switch tomorrow!
        Are 1-Wire Components like AM2301 Temp-Sensor already supported?
        • martinhjelmareM
          martinhjelmareM
          martinhjelmare
          #21
          I'm not sure that the library provided with mysensors supports DHT21 (AM2301). The readme for DHT library only mentions "DHT11 and DHT22, AM2302, RHT03".
          But I found this post, where the adafruit library is used together with mysensors:
          http://forum.mysensors.org/topic/841/solar-powered-mini-weather-station/53
          As long as you get your temp/hum sensors going with the correct library there shouldn't be a problem of presenting them as mysensors sensors to home assistant.
            mirko314
            wrote on last edited by mirko314
            #22
            Well I will look into, thank you!
            I do not know if this is the right place for further problems, if not tell me.
            I tried to remote control a relay today
            I used the official sketch of MYS at https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/RelayActuator/RelayActuator.ino
            Even though it Looks like they are properly connected, there is no switch appearing on HA-Dashboard.
            Log of the Sensor-Arduino Running RelayActuator.ino:
            send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.1
            send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
            read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
            repeater started, id=1, parent=0, distance=1
            send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
            send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
            Log of HA:
            INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
            INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
            INFO:homeassistant.components.sensor:Updating sensor entities
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=18,pt=0,l=5,sg=0:1.5.1
            INFO:homeassistant.components.mysensors:update sensor_update: node 1
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
            INFO:homeassistant.components.device_tracker.nmap_tracker:Scanning
            INFO:homeassistant.components.device_tracker.nmap_tracker:No MAC address found for 192.168.2.111
            INFO:homeassistant.components.device_tracker.nmap_tracker:nmap scan successful
            INFO:homeassistant.components.mysensors:update sensor_update: node 1```
              mirko314
              #23
              Sorry, I forgot to ask, is it implemented yet? :D
              I just scrambled through the code at HA
              https://github.com/balloob/home-assistant/blob/dev/homeassistant/components/switch/mysensors.py
              and I could not detect the RELAY type. But than again I do not know alot of both of the systems, just guessing.
              • M mirko314
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @mirko314
                You should send a value from the node child to set initial state also. I think that's what's missing.
                Read my post here:
                http://forum.mysensors.org/topic/2388/home-assistant-how-to-recognize-mysensors-nodes/27
                  mirko314
                  #25
                  @martinhjelmare
                  Would you mind to elaborate a bit more?
                  I am not sure how to alter the script.
                  • M mirko314
                    @martinhjelmare
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    #26
                    @mirko314
                    For example:
                    MyMessage msgArray[NUMBER_OF_RELAYS];
                    for (int sensor=1; sensor<=NUMBER_OF_RELAYS;sensor++) {
                        msgArray[sensor-1] = msg(sensor, V_STATUS);
                        gw.begin();
                            gw.present(sensor, S_BINARY);
                            gw.send(msgArray[sensor-1].set(0));
                    If you don't need to send any more messages after the setup funtion, ie access the message variables in the array anywhere else, you can move the assigning of the array in the first for loop to the second for loop in the setup function, to avoid code duplication.
                    You need to send at least one value per child to populate all data structures in home assistant.
                    Edit: You can actually move the assigning of the array and only have one for loop, inside the setup funtion, anyhow, since the array is initialized separately outside the functions.
                    • D
                      drock1985
                      Hi @martinhjelmare
                      I have installed 0.11.1 and added the lines to configuration.yaml, but my sensors are bit showing in ha itself. The ID of the nodes is being passed to ha in the log, but nothing else. Trying to set to a pir, temp/humid, and relay switches.
                      My Projects
                      2 Door Chime Sensor
                      Washing Machine Monitor
                      • D drock1985
                        Hi @martinhjelmare
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        @drock1985
                        Please show me the home assistant log. I can't really say anything useful without it.
                        • D
                          drock1985
                          Hi @martinhjelmare
                          here is the output from /home/pi/.homeassistant/home-assistant.log:
                          6-01-24 15:08:16 netdisco.ssdp: Found malformed XML at http://192.168.86.142:9080: status=ok
                          This is my configuration.yaml
                          homeassistant:
                            # Name of the location where Home Assistant is running
                            # Location required to calculate the time the sun rises and sets
                            latitude:
                            longitude:
                            # C for Celcius, F for Fahrenheit
                            temperature_unit: C
                            # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
                            time_zone: America/Halifax
                          # Enables the frontend
                          frontend:
                          # Checks for available updates
                          updater:
                          # View all events in a logbook
                          logbook:
                          # Track the sun
                          sun:
                          # Enables support for tracking state changes over time.
                          history:
                          # Show links to resources in log and frontend
                          #introduction:
                          # Allows you to issue voice commands from the frontend
                          conversation:
                          # Discover some devices automatically
                          discovery:
                          # Webcams
                          camera 1:
                            platform: mjpeg
                            mjpeg_url: http://192.168.86.117:10012/videofeed
                            username: root
                            password: groot
                          # Squeezebox Server
                          media_player 1:
                            platform: squeezebox
                            host: 192.168.86.113
                            port: 9090
                          # MySensors Serial Gateway
                          mysensors:
                            gateways:
                              - port: '/dev/ttyUSB0'
                                persistence_file: '/home/pi/.homeassistant/mysensors.json'
                          #  debug: true
                            persistence: true
                            version: '1.5'
                          Would it be because my nodes are set for manual ID and not auto?
                          My Projects
                          2 Door Chime Sensor
                          • D drock1985
                            Hi @martinhjelmare
                            homeassistant:
                              latitude:
                              longitude:
                              temperature_unit: C
                            frontend:
                            updater:
                            logbook:
                            # Track the sun
                            sun:
                            history:
                            #introduction:
                            conversation:
                            discovery:
                            # Webcams
                            camera 1:
                              platform: mjpeg
                              username: root
                              password: groot
                            # Squeezebox Server
                            media_player 1:
                              port: 9090
                            mysensors:
                              gateways:
                            #  debug: true
                              persistence: true
                              version: '1.5'
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @drock1985
                            The log file only outputs errors as default. Try starting home assistant from the command line with hass and then copy the output. It should be a lot more than one line.
                            You should shut down home assistant first if you have it running as a service.
                            Activate debug first for mysensors though.
                            • D
                              drock1985
                              @martinhjelmare
                              Here is the .log file
                              16-01-24 15:25:28 mysensors.mysensors: Error decoding message from gateway, probably received bad byte.
                              And from the SSH console after running hass as instructed
                              INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.111
                              INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.163
                              INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.108
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.master_bedroom=off; supported_media_commands=1021, friendly_name=Master Bedroom @ 15:25:41 24-01-2016>, entity_id=media_player.master_bedroom>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.man_cave=off; supported_media_commands=1021, friendly_name=Man Cave @ 15:25:41 24-01-2016>, entity_id=media_player.man_cave>
                              INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "CatFan">
                              INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "LivingRoomLamp">
                              INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "CatFan">
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.living_room=off; supported_media_commands=1021, friendly_name=Living Room @ 15:25:41 24-01-2016>, entity_id=media_player.living_room>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.catfan=off; friendly_name=CatFan @ 15:25:41 24-01-2016>, entity_id=switch.catfan>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=unknown; auto=True, entity_id=[], friendly_name=all switches @ 15:25:41 24-01-2016>, entity_id=group.all_switches>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.catfan',), friendly_name=all switches @ 15:25:41 24-01-2016>, entity_id=group.all_switches>
                              INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "LivingRoomLamp">
                              INFO:pywemo.subscribe:Received event from <WeMo Switch "CatFan">(192.168.86.108)
                              INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "CatFan">
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.livingroomlamp=off; friendly_name=LivingRoomLamp @ 15:25:42 24-01-2016>, entity_id=switch.livingroomlamp>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.catfan', 'switch.livingroomlamp'), friendly_name=all switches @ 15:25:42 24-01-2016>, entity_id=group.all_switches>
                              INFO:pywemo.subscribe:Received event from <WeMo Switch "LivingRoomLamp">(192.168.86.163)
                              INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "LivingRoomLamp">
                              INFO:pywemo.subscribe:Subscribing to events from <WeMo Insight "Christmas Tree Lights">
                              INFO:pywemo.subscribe:Resubscribe for <WeMo Insight "Christmas Tree Lights">
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.christmas_tree_lights=off; friendly_name=Christmas Tree Lights @ 15:25:42 24-01-2016>, entity_id=switch.christmas_tree_lights>
                              INFO:pywemo.subscribe:Received event from <WeMo Insight "Christmas Tree Lights">(192.168.86.111)
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.christmas_tree_lights', 'switch.catfan', 'switch.livingroomlamp'), friendly_name=all switches @ 15:25:42 24-01-2016>, entity_id=group.all_switches>
                              INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Insight "Christmas Tree Lights">
                              INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.117
                              INFO:homeassistant.components.http:"GET /states HTTP/1.1" 200 -
                              INFO:homeassistant.components.http:"GET /static/frontend-1003c31441ec44b3db84b49980f736a7.html HTTP/1.1" 200 -
                              INFO:homeassistant.components.http:"GET /static/favicon-192x192.png HTTP/1.1" 200 -
                              INFO:homeassistant.components.http:"GET /static/favicon.ico HTTP/1.1" 200 -
                              INFO:homeassistant.components.http:"GET /api/bootstrap HTTP/1.1" 200 -
                              INFO:homeassistant.components.http:"GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                              INFO:homeassistant.components.media_player:Updating media_player entities
                              INFO:homeassistant.components.http:"GET /api/error_log HTTP/1.1" 200 -
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=2,c=1,t=16,pt=0,l=1,sg=0:1
                              INFO:homeassistant.components.light:Updating light entities
                              INFO:homeassistant.components.camera:Updating camera entities
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663560.5128732, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663530.5116684, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.1
                              INFO:homeassistant.components.mysensors:update sensor_update: node 3
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-3-3 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=11,pt=0,l=25,sg=0:2 Door bell/chime
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=0,c=0,t=1,pt=0,l=0,sg=0:
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=3,c=0,t=3,pt=0,l=0,sg=0:
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=2,c=0,t=1,pt=0,l=0,sg=0:
                              INFO:homeassistant.components.api:Found broken event stream to 192.168.86.162, cleaning up
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663590.5271018, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663560.5128732, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.76, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, old_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.88, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, entity_id=sun.sun>
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.5
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.6
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663620.51471, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663590.5271018, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663650.5204854, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663620.51471, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.63, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, old_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.76, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, entity_id=sun.sun>
                              My Projects
                              2 Door Chime Sensor
                              • D drock1985
                                @martinhjelmare
                                martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                @drock1985
                                Is it node 3 that is missing for you? It seems you're presenting it fine but never send the needed value for the four sensors, 0-3, on the node.
                                Then you also have node 1 with two sensors 0 and 2 that seems to update, but you haven't posted the beginning of the log where those are presented or loaded from persistence. I'm also missing the gateway started confirmation in the log.
                                • D
                                  drock1985
                                  Hi @martinhjelmare
                                  the file /home/pi/.homeassistant/home-assistant.log has no errors in it, and it's all of my nodes that are missing (1 through 4 and 6), Node 5 isn't online right now.
                                  Is that what you are looking for at the top?
                                  INFO:homeassistant.components.recorder:Closing database
                                  pi@home-assistant:~/.homeassistant $ clear
                                  pi@home-assistant:~/.homeassistant $ hass
                                  Config directory: /home/pi/.homeassistant
                                  WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
                                  INFO:homeassistant.bootstrap:Home Assistant core initialized
                                  INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
                                  INFO:homeassistant.loader:Loaded media_player from homeassistant.components.media_player
                                  INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
                                  INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
                                  INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
                                  INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
                                  INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                                  INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                                  INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                                  INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
                                  INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                                  INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                                  INFO:homeassistant.loader:Loaded camera from homeassistant.components.camera
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
                                  INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                                  INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.sensors, discovered=>
                                  INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
                                  INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                                  INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.switches, discovered=>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                                  INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                                  INFO:homeassistant.loader:Loaded media_player.squeezebox from homeassistant.components.media_player.squeezebox
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.airspeaker=off; friendly_name=AirSpeaker, supported_media_commands=447 @ 17:05:03 24-01-2016>, entity_id=media_player.airspeaker>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_down>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play_pause>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_pause>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_up>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_previous_track>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_off>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_media>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_next_track>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_on>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_set>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_mute>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_seek>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_fireplace>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_epic_sax>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_youtube_video>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=media_player>
                                  INFO:urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.17 @ 17:05:03 24-01-2016>, entity_id=sun.sun>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
                                  INFO:urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
                                  /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning
                                    warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning')
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                                  INFO:homeassistant.loader:Loaded camera.mjpeg from homeassistant.components.camera.mjpeg
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669504.2007444 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=camera>
                                  INFO:homeassistant.core:Starting Home Assistant (17 threads)
                                  INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
                                  INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
                                  INFO:homeassistant.core:Timer:starting
                                  INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
                                  INFO:homeassistant.components.mysensors:update persistence: node 2
                                  INFO:homeassistant.components.mysensors:No sketch_name: node 2
                                  INFO:homeassistant.components.mysensors:update persistence: node 3
                                  INFO:netdisco.service:Scanning
                                  WARNING:mysensors.mysensors:Error decoding message from gateway, probably received bad byte.
                                  INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.4
                                  INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.113
                                  INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.101
                                  INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.142
                                  INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.199
                                  INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.102
                                  INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.4:32469/DeviceDescription.xml
                                  INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.113:9000/plugins/UPnP/MediaServer.xml
                                  INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.101', 8009)
                                  INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.101', 8009)>
                                  INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.102', 8009)
                                  INFO:homeassistant.loader:Loaded media_player.cast from homeassistant.components.media_player.cast
                                  INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.102', 8009)>
                                  INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')
                                  INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')>
                                  INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')
                                  INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')>
                                  INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')
                                  INFO:homeassistant.loader:Loaded switch.wemo from homeassistant.components.switch.wemo
                                  INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')>
                                  ERROR:homeassistant.components.switch:Error while setting up platform wemo
                                    File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 145, in _setup_platform
                                      self.hass, platform_config, self.add_entities, discovery_info)
                                    File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/switch/wemo.py", line 25, in setup_platform
                                      import pywemo.discovery as discovery
                                  AttributeError: 'module' object has no attribute 'discovery'
                                  INFO:pychromecast:Querying device status
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.man_cave=off; friendly_name=Man Cave, supported_media_commands=1021 @ 17:05:19 24-01-2016>, entity_id=media_player.man_cave>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.master_bedroom=off; friendly_name=Master Bedroom, supported_media_commands=1021 @ 17:05:19 24-01-2016>, entity_id=media_player.master_bedroom>
                                  INFO:homeassistant.components.discovery:Found new service: plex_mediaserver ('Rocknet Server', 'https://192.168.86.4:32400')
                                  INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=plex_mediaserver, discovered=('Rocknet Server', 'https://192.168.86.4:32400')>
                                  INFO:homeassistant.components.discovery:Found new service: philips_hue ('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')
                                  INFO:homeassistant.loader:Loaded media_player.plex from homeassistant.components.media_player.plex
                                  INFO:homeassistant.loader:Loaded light from homeassistant.components.light
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_on>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_off>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=light>
                                  INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=philips_hue, discovered=('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')>
                                  INFO:homeassistant.loader:Loaded light.hue from homeassistant.components.light.hue
                                  INFO:phue:Attempting to connect to the bridge...
                                  INFO:phue:Using ip: 192.168.86.199
                                  INFO:phue:Using username from config: 30f609e6210320e41f0dfc32220a525f
                                  Exception in thread Thread-25:
                                    File "/usr/lib/python3.4/threading.py", line 920, in _bootstrap_inner
                                      self.run()
                                    File "/home/pi/.homeassistant/lib/zeroconf.py", line 1063, in run
                                      handler(self.zc)
                                    File "/home/pi/.homeassistant/lib/zeroconf.py", line 1014, in <lambda>
                                      state_change=state_change,
                                    File "/home/pi/.homeassistant/lib/zeroconf.py", line 931, in fire
                                      h(**kwargs)
                                    File "/home/pi/.homeassistant/lib/zeroconf.py", line 989, in on_change
                                      listener.add_service(*args)
                                    File "/home/pi/.homeassistant/lib/netdisco/discoverables/__init__.py", line 84, in add_service
                                      service = zconf.get_service_info(typ, name)
                                    File "/home/pi/.homeassistant/lib/zeroconf.py", line 1404, in get_service_info
                                      if info.request(self, timeout):
                                    File "/home/pi/.homeassistant/lib/zeroconf.py", line 1221, in request
                                      zc.send(out)
                                    File "/home/pi/.homeassistant/lib/zeroconf.py", line 1663, in send
                                      bytes_sent = s.sendto(packet, 0, (addr, port))
                                  OSError: [Errno 9] Bad file descriptor
                                  INFO:plexapi:GET http://192.168.86.4:32400/
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_1=off; friendly_name=Master bedroom 1 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_1>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_2=off; friendly_name=Master bedroom 2 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_2>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.aprils_lamp=off; friendly_name=April's lamp @ 17:05:20 24-01-2016>, entity_id=light.aprils_lamp>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_1=off; friendly_name=Living room light 1 @ 17:05:20 24-01-2016>, entity_id=light.living_room_light_1>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_light_strip=off; friendly_name=Master bedroom light strip @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_light_strip>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_2=off; friendly_name=Living room light 2 @ 17:05:20 24-01-2016>, entity_id=light.living_room_light_2>
                                  INFO:homeassistant.components.media_player.plex:Connected to: htts://192.168.86.4:32400
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_3=off; friendly_name=Master bedroom 3 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_3>
                                  INFO:plexapi:GET http://192.168.86.4:32400/clients
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=unknown; entity_id=[], friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>, entity_id=group.all_lights>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=off; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>, entity_id=group.all_lights>
                                  INFO:plexapi:GET http://192.168.86.4:32400/status/sessions
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669530.5242217 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669504.2007444 @ 17:05:04 24-01-2016>>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.1 @ 17:05:03 24-01-2016>, entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.17 @ 17:05:03 24-01-2016>>
                                  INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=homeassistant, entity_id=light.living_room_light_1, service_call_id=1981876976-1, service=turn_on>
                                  INFO:homeassistant.loader:Loaded group from homeassistant.components.group
                                  INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=light, entity_id=['light.living_room_light_1'], service_call_id=1981876976-2, service=turn_on>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_1=on; brightness=254, friendly_name=Living room light 1 @ 17:05:47 24-01-2016>, entity_id=light.living_room_light_1, old_state=<state light.living_room_light_1=off; friendly_name=Living room light 1 @ 17:05:20 24-01-2016>>
                                  INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-2>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=on; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:47 24-01-2016>, entity_id=group.all_lights, old_state=<state group.all_lights=off; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>>
                                  INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-1>
                                  INFO:homeassistant.components.http:"POST /api/services/homeassistant/turn_on HTTP/1.1" 200 -
                                  INFO:homeassistant.components.http:"GET /api/history/period?filter_entity_id=light.living_room_light_2 HTTP/1.1" 200 -
                                  INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=homeassistant, entity_id=light.living_room_light_2, service_call_id=1981876976-3, service=turn_on>
                                  INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=light, entity_id=['light.living_room_light_2'], service_call_id=1981876976-4, service=turn_on>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_2=on; brightness=254, friendly_name=Living room light 2 @ 17:05:49 24-01-2016>, entity_id=light.living_room_light_2, old_state=<state light.living_room_light_2=off; friendly_name=Living room light 2 @ 17:05:20 24-01-2016>>
                                  INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-4>
                                  INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-3>
                                  INFO:homeassistant.components.http:"GET /api/history/period?filter_entity_id=light.living_room_light_1 HTTP/1.1" 200 -
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669560.5092123 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669530.5242217 @ 17:05:04 24-01-2016>>
                                  INFO:homeassistant.components.http:"GET /devInfo HTTP/1.1" 200 -
                                  ^CINFO:homeassistant.core:Stopping
                                  INFO:homeassistant.core:Bus:Handling <Event homeassistant_stop[L]>
                                  INFO:mysensors.mysensors:Disconnecting from /dev/ttyUSB0
                                  INFO:mysensors.mysensors:Stopping thread
                                  My Projects
                                  2 Door Chime Sensor
                                  • D
                                    drock1985
                                    I'm still trying to get this to work, with mixed results. Noticed on startup sometimes that HA was starting before my Serial port was initialized. Added a .timer file to delay the start of HA until the Pi is fully booted. Still having problems, but now i'm getting this in the HA logs:
                                    16-01-24 18:37:40 homeassistant.core: BusHandler:Exception doing job
                                      File "/usr/local/lib/python3.4/dist-packages/homeassistant/core.py", line 829, in job_handler
                                        func(arg)
                                      File "/usr/local/lib/python3.4/dist-packages/homeassistant/core.py", line 302, in onetime_listener
                                        listener(event)
                                      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 104, in gw_start
                                        gateway.event_callback('persistence', node_id)
                                      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 226, in node_update
                                        callback(self, node_id)
                                      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 165, in mysensors_callback
                                        add_devices(devices[node_id])
                                      File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 81, in add_entities
                                        entity.update_ha_state()
                                      File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 108, in update_ha_state
                                        self.unit_of_measurement is not None:
                                      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/sensor/mysensors.py", line 137, in unit_of_measurement
                                        self.value_type == self.gateway.const.SetReq.V_PERCENTAGE or \
                                      File "/usr/lib/python3.4/enum.py", line 255, in __getattr__
                                        raise AttributeError(name) from None
                                    AttributeError: V_PERCENTAGE
                                    16-01-24 18:37:43 mysensors.mysensors: Error decoding message from gateway, probably received bad byte.
                                    My Projects
                                    2 Door Chime Sensor
                                    • D drock1985
                                          func(arg)
                                          listener(event)
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @drock1985
                                      I think you need to delete the persistence file and start over and present your sensors. You should do this while looking at the output from hass so you get feedback if it's working or not.
                                      From the top of your log output there was a warning about bad byte from the gateway. The gateway started confirmation was never logged. You should see this before you start your sensors. If you don't get the gateway confirmation, try restarting home assistant.
                                      Also in the log, the persistence file loaded sensor 2 and 3, but some data was missing, probably. There was a note about missing sketch name for one of the sensors.
                                      You need to present the sensors properly, including sketch name and then send one value per sensor before they show up in the gui.
                                      • asmA
                                        asmA
                                        asm
                                        Hey @drock1985 , would you please update the thread if you are able to work around this ? I am experiencing something similar after my latest upgrade: None of the sensors appear in the UI. I have disabled persistence and removed the json files, and presented the nodes again, but still nothing appears. In debug mode I can see the messages from the Humidity sensor, for instance, but that's all.
                                        D 1 Reply Last reply
                                        • asmA asm
                                          drock1985
                                          Hi @asm and @martinhjelmare
                                          Still having issues after multiple restarts and two different nano's and NRF radios. I am like you, can see the messages but whatever I try I can't get rid of the bad byte error in the beginning.
                                          Going to try a uno next and see if that changes anything.
                                          My Projects
                                          2 Door Chime Sensor
                                          12.5k
