  3. [SOLVED] Wifi gateway / motion sensor / value 1107296256 instead of tripped ?
16 Posts 4 Posters 5.4k Views 3 Watching
    @kr0815 said:
    Are there any changes in the developer version regarding Channel / ID ?
    No it shouldn't be any changes in that regard.
    • K
      K
      kr0815
      That´s really strange, because 2 hours earlier, the gateway worked with the old version, only the problem of receiving numbers instead of v_tripped
      I´m using an NRF24L01 with external Antenna, i saw somewhere in the Code there are settings for TX-Power or similar ? Maybe that´s different in dev version ?
      Or any other ideas ?
        Yes, you could try setting tx power to low. Add this before including MySensor.h in gateway.
        #define MY_RF24_PA_LEVEL RF24_PA_MIN
        Anything useful in the debug log?
        • K
          K
          kr0815
          You mean the output when connected with putty ?
          There is nothing strange in it, i see the commands from my FHEM controller, but no errors
          With the old version i saw also the messages from my sensor nodes
          Is it possible to change debug level ?
            Debug is enabled by default.
            https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewayESP8266/GatewayESP8266.ino#L72
            You could perhaps have the gateway connected to your computer/Arduino IDE and open the serial monitor to see that sensor readings is picked up correctly.
            • K
              K
              kr0815
              Thats what i already did, that´s what i get after a diconnect / connect and then a inclusion-mode on / off in my controller software.
              0;255;3;0;2;2.0.0-beta
              0;255;3;0;5;1
              0;255;3;0;5;0
              But no messages from the sensors.
              Should there be additional messages when in debug mode ?
              So as there are no changes in Channel / ID, i see only the possibilities that i either damaged the NRF or that something is different with the Developer version
              I´ll try to flash the old software again this evening
              • K
                K
                kr0815
                Got it working now, replaced the ampflified NRF with a regular one
                Maybe i broke it, but can´t imagine how
                In one of the many examples i found the following comment for myConfig.h:
                #define RF24_PA_LEVEL_GW   RF24_PA_LOW  //Gateway PA Level, defaults to Sensor net PA Level.  Tune here if using an amplified nRF2401
                Is there anything special about the amplified version ? Do they have like a register i have to switch on/ off ? or is it just an additional transistor and the antenna connection ?
                N 1 Reply Last reply
                  It requires much more power. Do not feed it from the arduino directly. Especially if you turn up the transmit power level.
                  • K kr0815
                    N
                    N
                    netram
                    Now that you have the dev-branch WIFIgateway version up and running, did this solve the initial issue with the strange tripped-values?
                    • K
                      K
                      kr0815
                      Yes, the problem is solved now, no more strange values
                      • N
                        N
                        netram
                        :thumbsup:
