  3. [SOLVED] Wifi gateway / motion sensor / value 1107296256 instead of tripped ?
16 Posts 4 Posters 5.4k Views 3 Watching
  • K
    K
    kr0815
    After long trying i managed to install the developer version.
    Now the gateway doesn´t receive any messages
    I see trough putty the comunication with FHEM, but no messages from the sensor laying next to the gateway
    The sensors definetly send, i see it on other wired gateway
    Are there any changes in the developer version regarding Channel / ID ?
      No it shouldn't be any changes in that regard.
      • K
        K
        kr0815
        That´s really strange, because 2 hours earlier, the gateway worked with the old version, only the problem of receiving numbers instead of v_tripped
        I´m using an NRF24L01 with external Antenna, i saw somewhere in the Code there are settings for TX-Power or similar ? Maybe that´s different in dev version ?
        Or any other ideas ?
          Yes, you could try setting tx power to low. Add this before including MySensor.h in gateway.
          #define MY_RF24_PA_LEVEL RF24_PA_MIN
          Anything useful in the debug log?
          • K
            K
            kr0815
            You mean the output when connected with putty ?
            There is nothing strange in it, i see the commands from my FHEM controller, but no errors
            With the old version i saw also the messages from my sensor nodes
            Is it possible to change debug level ?
              Debug is enabled by default.
              https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewayESP8266/GatewayESP8266.ino#L72
              You could perhaps have the gateway connected to your computer/Arduino IDE and open the serial monitor to see that sensor readings is picked up correctly.
              • K
                K
                kr0815
                Thats what i already did, that´s what i get after a diconnect / connect and then a inclusion-mode on / off in my controller software.
                0;255;3;0;2;2.0.0-beta
                0;255;3;0;5;1
                0;255;3;0;5;0
                But no messages from the sensors.
                Should there be additional messages when in debug mode ?
                So as there are no changes in Channel / ID, i see only the possibilities that i either damaged the NRF or that something is different with the Developer version
                I´ll try to flash the old software again this evening
                • K
                  K
                  kr0815
                  Got it working now, replaced the ampflified NRF with a regular one
                  Maybe i broke it, but can´t imagine how
                  In one of the many examples i found the following comment for myConfig.h:
                  #define RF24_PA_LEVEL_GW   RF24_PA_LOW  //Gateway PA Level, defaults to Sensor net PA Level.  Tune here if using an amplified nRF2401
                  Is there anything special about the amplified version ? Do they have like a register i have to switch on/ off ? or is it just an additional transistor and the antenna connection ?
                  N 1 Reply Last reply
                    It requires much more power. Do not feed it from the arduino directly. Especially if you turn up the transmit power level.
                    • K kr0815
                      N
                      N
                      netram
                      Now that you have the dev-branch WIFIgateway version up and running, did this solve the initial issue with the strange tripped-values?
                      • K
                        K
                        kr0815
                        Yes, the problem is solved now, no more strange values
                        • N
                          N
                          netram
                          :thumbsup:
