  3. [SOLVED] Wifi gateway / motion sensor / value 1107296256 instead of tripped ?
16 Posts 4 Posters 5.4k Views 3 Watching
  • mfalkviddM
    Looks similar to this thread: http://forum.mysensors.org/topic/2737/2-channel-relais-with-2-buttons-sending-strange-values-for-on-off
    Haven't seen any solution yet though :(
    • N
      N
      netram
      I have the same problem with TRIPPED-messages and the Wifi gateway:
      http://forum.mysensors.org/topic/2878/messed-up-payload-from-binary-switch-sensor
        Please try the dev-branch gateway version and report back if the problem persist.
        • K
          K
          kr0815
          After long trying i managed to install the developer version.
          Now the gateway doesn´t receive any messages
          I see trough putty the comunication with FHEM, but no messages from the sensor laying next to the gateway
          The sensors definetly send, i see it on other wired gateway
          Are there any changes in the developer version regarding Channel / ID ?
            No it shouldn't be any changes in that regard.
            • K
              K
              kr0815
              That´s really strange, because 2 hours earlier, the gateway worked with the old version, only the problem of receiving numbers instead of v_tripped
              I´m using an NRF24L01 with external Antenna, i saw somewhere in the Code there are settings for TX-Power or similar ? Maybe that´s different in dev version ?
              Or any other ideas ?
                Yes, you could try setting tx power to low. Add this before including MySensor.h in gateway.
                #define MY_RF24_PA_LEVEL RF24_PA_MIN
                Anything useful in the debug log?
                • K
                  K
                  kr0815
                  You mean the output when connected with putty ?
                  There is nothing strange in it, i see the commands from my FHEM controller, but no errors
                  With the old version i saw also the messages from my sensor nodes
                  Is it possible to change debug level ?
                    Debug is enabled by default.
                    https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewayESP8266/GatewayESP8266.ino#L72
                    You could perhaps have the gateway connected to your computer/Arduino IDE and open the serial monitor to see that sensor readings is picked up correctly.
                    • K
                      K
                      kr0815
                      Thats what i already did, that´s what i get after a diconnect / connect and then a inclusion-mode on / off in my controller software.
                      0;255;3;0;2;2.0.0-beta
                      0;255;3;0;5;1
                      0;255;3;0;5;0
                      But no messages from the sensors.
                      Should there be additional messages when in debug mode ?
                      So as there are no changes in Channel / ID, i see only the possibilities that i either damaged the NRF or that something is different with the Developer version
                      I´ll try to flash the old software again this evening
                      • K
                        K
                        kr0815
                        Got it working now, replaced the ampflified NRF with a regular one
                        Maybe i broke it, but can´t imagine how
                        In one of the many examples i found the following comment for myConfig.h:
                        #define RF24_PA_LEVEL_GW   RF24_PA_LOW  //Gateway PA Level, defaults to Sensor net PA Level.  Tune here if using an amplified nRF2401
                        Is there anything special about the amplified version ? Do they have like a register i have to switch on/ off ? or is it just an additional transistor and the antenna connection ?
                        N 1 Reply Last reply
                          It requires much more power. Do not feed it from the arduino directly. Especially if you turn up the transmit power level.
                          • K kr0815
                            N
                            N
                            netram
                            Now that you have the dev-branch WIFIgateway version up and running, did this solve the initial issue with the strange tripped-values?
                            • K
                              K
                              kr0815
                              Yes, the problem is solved now, no more strange values
                              • N
                                N
                                netram
                                :thumbsup:
