  3. Newbie starting his HA project
18 Posts 4 Posters 6.7k Views 3 Watching
  • HenryWhiteH HenryWhite
    @rsachoc said:
    Here's where I'm struggling - I bought an FTDI adaptor, which I thought was 5v and 3.3v, but from what I can see it's 5v.
    picture of the adaptor?
    some adapters have a jumper or solder bridge to switch between 5V and 3.3V
    rsachocR
    rsachocR
    rsachoc
    wrote on last edited by rsachoc
    @HenryWhite definitely a solder bridge, see the picture above (http://i.imgur.com/U9eo7Mc.jpg
    ), that's why I'm not confident I will be able to sucessfully desolder and solder it.
    HenryWhiteH 1 Reply Last reply
    • rsachocR rsachoc
      HenryWhiteH
      HenryWhiteH
      HenryWhite
      wrote on last edited by HenryWhite
      @rsachoc Well, you could
      • buy an FTDI adapter with jumper
      • buy a thinner soldering tip if yours is to big (make sure the tips fit to your soldering iron)
      • try to desolder the bridge and solder it to the right place
      • break the bridge with pliers and just solder the lower two solder points together. this would be possible even with a thicker soldering iron.
      If you want to switch continously between 5v and 3.3v, you should consider buying another ftdi adapter with jumper pins (or try to solder 3 pinheaders to the three solder pads)
      rsachocR 1 Reply Last reply
        rsachocR
        rsachocR
        rsachoc
        @HenryWhite thanks! I suspect since I've got nothing to lose the best option is to try and desolder/break the current bridge and try and resolder it. Let me have a go and see what happens.
        • rsachocR
          rsachocR
          rsachoc
          OK so I managed to desolder the bridge and put a dab of solder between the other 2 pins, so I think I have a 3.3v FTDI adaptor. However, I was reading here and I think, because I have the NRF2401 connected to my sensebender, that I might have fried it? Thinking 5v would have broken it?
          Also, I'm still confused as to how I connect the FTDI adaptor to the sensebender. mfalkvidd mentioned that I need to go "Vcc to Vcc, GND to GND, RxD to TxD and TxD to RxD", howeverthe sensbender pins don't seem to line up this way?
          edit just to be clear, the sensebender goes GND GND VCC RXD TXD DTR while the FTDI goes GND DTR RXI TXO PWR CTS GND, so I'm confused how the pins line up, if that makes any sense?
          mfalkviddM HenryWhiteH 2 Replies Last reply
          • rsachocR rsachoc
            sensebender:
            GND
            GND
            VCC
            RXD
            TXD
            DTR
            FTDI:
            GND
            DTR
            RXI
            TXO
            PWR
            CTS
            GND
            Turn FTDI upside-down:
            GND
            CTS
            PWR
            TXO
            RXI
            DTR
            GND
            now line them up:
            sensebender. FTDI
            GND GND
            GND CTS
            VCC PWR
            RXD TXO
            TXD RXI
            DTR DTR
            • rsachocR rsachoc
              HenryWhiteH
              HenryWhiteH
              HenryWhite
              Maybe! But maybe not. :smile: I'm using a FTDI adapter with jumper for my 3.3v/5v pro mini's, and sometimes I forgot to move the jumper to 3V when connecting my 3V pro mini's. Nevertheless, the nrf24l01 "survived" this stupidness every time.
              here's how you connect the sensebender to your ftdi:
              --Your_FTDI:Sensebender--
              GND:GND
              CTS:GND
              PWR:VCC
              TXO:RXD
              RXI:TXD
              DTR:DTR
              korttomaK 1 Reply Last reply
              • rsachocR
                rsachocR
                rsachoc
                Thank you both, I'll get soldering tomorrow - couple more (extremely rookie) questions:
                1. Do I need to have the Sensebender connected to battery and the FTDI connected to USB at the time I'm uploading the sketch?
                2. When I upload the sketch, do I need to select Board: Sensebender Micro and Programmer: USBAsp?
                3. Do I need to "Upload" or "Upload via Programmer"?
                • rsachocR rsachoc
                  rsachocR
                  rsachocR
                  rsachoc
                  @rsachoc OK answering my own question :) after a bit of experimentation and research
                  Do I need to have the Sensebender connected to battery and the FTDI connected to USB at the time I'm uploading the sketch? No
                  When I upload the sketch, do I need to select Board: Sensebender Micro and Programmer: USBAsp? Yes
                  Do I need to "Upload" or "Upload via Programmer"? Upload worked for me
                  • rsachocR rsachoc
                    rsachocR
                    rsachocR
                    rsachoc
                    An answer, but a new question:
                    I have setup a MQTT gateway (with NRF2401, Arduno nano clone, W5100 ethernet) - using the W5100 MQTT client sketch (from here), changing the necessary. I can see that this successfully boots and connects to my MQTT server (on a Pi 2 with Openhab).
                    0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0-beta)
                    0;255;3;0;9;MQTT connected
                    I've also successfully flashed the Sensebender .ino (from here), only changing the "//#deine MY_NODE_ID 3" to uncomment (and also correcting the spelling error :) )
                    Interestingly (no idea why) before I had loaded the new sketch on the Sensebender, when powering it on via battery I got the LED coming on, now with the new sketch...nothing. I also can't see it connecting to the gateway (should I see something in the serial monitor on the gateway)?
                    Or could I have a fried radio?
                      GND:GND
                      CTS:GND
                      PWR:VCC
                      TXO:RXD
                      RXI:TXD
                      DTR:DTR
                      korttomaK
                      korttomaK
                      korttoma
                      I have found that I can program the 5V Pro Minis with the FTDI adapter set to 3.3V so I newer change this anymore, no risk of braking something that can not handle 5V.
                      • Tomas
                      • rsachocR
                        rsachocR
                        rsachoc
                        OK, so I had some success with the Sensebender, it works sometimes and not other times. I've tried connected directly to the laptop (via the FTDI, no battery connected) and sometimes it works, other times it doesn't. Would this bad soldering?
                        Also, what's the minimum requirements from a voltage perspective? I've got 2 eneloops which delivers around 2.73volts, whereas the laptop measures 3.3v (tested with a voltmeter tester).
                        • mfalkviddM
                          Below 2.8V won't work with the Atmega328 unless you reconfigure the fuses
