  3. #error No forward link or gateway feature activated.
18 Posts 4 Posters 11.6k Views 4 Watching
    You must either define a radio type or gateway type.
    You probably commented away one of them from the examples.
    Wilco EliveldW 1 Reply Last reply
      Wilco EliveldW
      Wilco EliveldW
      Wilco Eliveld
      Hi
      Where can i find this? can you give me a example?
        There are numerous examples in the "examples" folder under the MySensors library.
          Wilco EliveldW
          Wilco EliveldW
          Wilco Eliveld
          Yes i know, but all the examples are giving the same issues.
          So i miss something
            Hmm.. not sure what you could have done wrong. Have you mixed downloaded versions or something?
              Wilco EliveldW
              Wilco EliveldW
              Wilco Eliveld
              Nope, fresh install of everything.
              But.... im not sure if i must make some changes on MyConfig.H on old movies from youtube i see some settings which are not in MyConfig.H, See also no documentation so i assume it is not needed to make some changes to this file
                No, all configuration can be controlled from sketch nowadays. So unless you want to change something globally for all sketches (like frequecy etc.) you can just set it in sketch.
                  Wilco EliveldW
                  Wilco EliveldW
                  Wilco Eliveld
                  wrote on last edited by Wilco Eliveld
                  Oke, where can i find those settings? because i dont know which settings are needed to get it working.
                  i ḿ playing with this file
                  https://raw.githubusercontent.com/mysensors/Arduino/development/libraries/MySensors/examples/RelayActuator/RelayActuator.ino
                    You must have done some changes. Latest compiles fine here on my computer.
                      Wilco EliveldW
                      Wilco EliveldW
                      Wilco Eliveld
                      i only did a clone of the repo and copy all libraryś to my librarys dir
                      Gives also:
                      In file included from /tmp/arduino_c2cf6ad24e4a2a0e97af5bb50875ab91/sketch_feb04b.ino:1:0:
                      /home/wilco/stack/documents/arduino/libraries/MySensors/MySensor.h:285:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                      exit status 1
                      Error compiling.
                        Strange.
                        Just downloaded 1.6.7 (only difference from your setup). The RelayActuator sketch compiles just fine there as well.
                          Strange.
                          Wilco EliveldW
                          Wilco EliveldW
                          Wilco Eliveld
                          @hek said:
                          Strange.
                          i still think i need some parameters/settings somewhere..
                          get a exit status 1 because of the No Forward link message
                          edit:
                          When i use version 1.4 of MySensors i dont have the error message and compiles goes fine
                            The RelayActuator is working as-is. No more configuration is needed to make it compile.
                            • mikeM
                              mikeM
                              mike
                              I am having the same problem did you ever resolve it?
                              • mikeM mike
                                Wilco EliveldW
                                Wilco EliveldW
                                Wilco Eliveld
                                @mike Hi, no didnt find any fix for this.
                                But on my Macbook everything works fine, the problem is only on a 32 bits linux machine.
                                • mikeM
                                  mikeM
                                  mike
                                  @Wilco-Eliveld
                                  I think I found it. while learning Arduino IDE I had several copies of Arduino.exe installed in different locations. Short cuts link to different folder exe's and each folder had it's own librarys.
                                  the compiler was confused as to where to get it's include files. I am still wondering what the logic is as to where it looks. But I cleaned up the other libraries and deleted and re added the short cuts now it works correctly. As always when trouble shooting we spend hours on things that didn't work but only seconds on the actual fix.
                                  • SkysoftS
                                    SkysoftS
                                    Skysoft
                                    On development, I've this problem too...
