  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 345.6k Views 68 Watching
  • J
    J
    johnr
    Thank you for this pcb. In which program did you do the design? Do you think you can share an editable version of the design?
    I would like to modify it to accept the Mean Well IRM-05-5 instead of the Hi-Link.
    It is more expensive and bigger AC-DC circuit but since I hace some in my stash i would like to use them.
    • toabhishekvermaT toabhishekverma
      Nice find GertSanders ... I am planning to use esp8266 which runs on 3.3 volt... best fit ..
      If we use this we may have to drop few things from 5.5 board right?
      Like no need of 5v - 3.3 converter
      change relay to match 3.3v like this http://vod.ebay.com/vod/FetchOrderDetails?qu=1&itemid=401045943120&transid=522355020027&viewpaymentstatus=
      Anyexpert around? do we need to remove anythingelse (any capacitor?)
      That's a link to your shopping cart, we don't have access to...
      I'm interested in the relay, can you post a working link?
      • toabhishekvermaT
        toabhishekvermaT
        toabhishekverma
        oops..
        here is the link
        http://www.ebay.com/itm/401045943120
        • GertSandersG
          GertSandersG
          GertSanders
          I use the same SONGLE relays:
          http://www.aliexpress.com/item/5pcs-SRD-03VDC-SL-C-3V-relay-5-feet-10A/32453591000.html
          • toabhishekvermaT
            toabhishekvermaT
            toabhishekverma
            @GertSanders thanks for this link.
            So do you have working prototype? what board are you using? I am in middle of finalising components and trying to finalise design. With little knowledge of electronics my progress is slow.
            Also for 220 to 3.3v there is another converter from Olimex https://www.olimex.com/Products/Power/PWR-90-240V-3.3V0.8A/
            overall its abit smaller then Hi-Link... Hi-Link abit better because all covered and less dangerous.
            Please share if you have any design finalised.
            • GertSandersG GertSanders
              @GertSanders @toabhishekverma Do you have the dimensions and/or holding resistance?
              • toabhishekvermaT
                toabhishekvermaT
                toabhishekverma
                Sorry I didnt get your questions .. do you mean dimensions of 220-3.3v converter. Here they are.
                output 2.5W 3.3V/0.8A +-0.2V size: 30x20x18mm
                I am not from electronics background so didn't get what holding resistance means?
                  @toabhishekverma No, I meant for the relay ;-)
                  What's the resistance of the 3V coil? I want to know the current flowing when the relay is active.
                  • toabhishekvermaT
                    toabhishekvermaT
                    toabhishekverma
                    @Yveaux Still no idea about it. Check link if you get something from it. what I know is it can bear up to 10A current and can be controlled using 3v .... my order still in shipping so don't know more then that.
                      @toabhishekverma Ah, ok. Didn't know they were still in transit.
                      Maybe @GertSanders has them 'on stock'?
                      HenryWhiteH GertSandersG 2 Replies Last reply
                      • YveauxY Yveaux
                        HenryWhiteH
                        HenryWhiteH
                        HenryWhite
                        @Yveaux http://www.songle.com/en/pdf/20084141716341001.pdf
                        • HenryWhiteH HenryWhite
                          @HenryWhite Awesome! Didn't even think of looking for a datasheet of a Chinese relay ;-)
                          • P
                            P
                            Porky6666
                            Another source :
                            50Pieces/Lot JRC-21F 4100 3V DC 6 Pins Miniature PCB Relay Brand New
                            http://s.aliexpress.com/MNVv2myE
                            • YveauxY Yveaux
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @Yveaux No, also still waiting for the order to arrive. But a coil resistance of 20-25 Ohm means driving the coil with a FET. Not directly from a atmega328 pin.
                              HenryWhiteH 1 Reply Last reply
                              • P Porky6666
                                Another source :
                                GertSandersG
                                GertSandersG
                                GertSanders
                                @Porky6666 : only switches 3A, SONGLE relay can switch 10A.
                                  HenryWhiteH
                                  HenryWhiteH
                                  HenryWhite
                                  Correct. Here's how I wired the songle relay on my Lithium Ion Sensor PCB:
                                  I wouldn't trust both of them when it comes to switching high amp devices over 3A. I think there is a reason no german electronics shop sells songle relays :smile:
                                  Plus, relays from an electronics shop in your country might cost the same than the songle relays or will just be a tiny bit more expensive.
                                  At least this is true for 5V relays. 3V relays are hard to find (at least in germany)
                                    GertSandersG
                                    GertSandersG
                                    GertSanders
                                    I agree, I plan to switch lights, so my preference goes to the 10A model, just to be sure. I have used the SONGLE 5V versions, and none have ever given me reason to doubt their quality. Since I found a 3V3 powersupply I want to try building a full 3V3 board. Should be fun.
                                    • toabhishekvermaT
                                      toabhishekvermaT
                                      toabhishekverma
                                      @HenryWhite why do we need D1 Diode (if i am write) in that circuit? do this circuit will not work without diode?
                                      (sorry dont know much about electronics)
                                        HenryWhiteH
                                        HenryWhiteH
                                        HenryWhite
                                        wrote on last edited by HenryWhite
                                        #213
                                        @toabhishekverma https://en.m.wikipedia.org/wiki/Flyback_diode
                                        in short: It is needed to protect the NPN transistor from damage.
                                        The circuit will work without diode, But eventually damage the transistor.
                                        • m26872M
                                          m26872M
                                          m26872
                                          @GertSanders Have you breadboarded your 3.3V design? I'm a bit worried that removing linear converter will impair the performance of the our fussy nRF clones due to less power supply ripple rejection. I think those going for the ESP8266 are better off.
