  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 345.6k Views 68 Watching
  • toabhishekvermaT
    toabhishekvermaT
    toabhishekverma
    Hey Guys,
    I am working on ESP8266 as well. But I am newbie to electronic designs. But in my view it should be silmple and we can replace Arduino nano with ESP8266 and remove NRF module.
    One diagram and circuit is explained here http://iot-playground.com/blog/2-uncategorised/77-esp8266-internet-controlled-switch-easyiot-cloud-mqtt-api#materials
    @csa02221862 you can use this cercuit with SPST buttons. But Switch will notbe connected to mains. It will be conneted to ESP8266 GPIO of (or arduino). And in Sketch (i.e code ) you have to write code based on GPIO when ever it goes 0 to 1 or 1 to 0 Relay state shoud be toggled.
    I hope I make sense
    @aproxx you did great job here.
    I am looking to reduce its size more if possible and wish to use ESP8266. Also looking to add more then one relays to the board. In some rooms there are 3 buttons on one panel. So thinking to use 3 relays. Will it be a good Idea? I think should not matter as long as I have enough GPIO to control relays and Electric wire connectors can bear the load.
    • J
      J
      jemish
      yes , I also thinking to use more than one relay.
      • GertSandersG
        GertSandersG
        GertSanders
        Found something interesting on Aliexpress which is a drop in replacement for the HLK-PM01:
        the HLK-PM03
        Same size and pin locations, but 110-200 V AC to 3V3 DC.
        http://www.aliexpress.com/item/5-pcs-HLK-PM03-AC-DC-220V-to-3-3V-Step-Down-Buck-Power-Supply-Module/32585760937.html
        It fits my multi-power options board perfectly.
        • toabhishekvermaT
          toabhishekvermaT
          toabhishekverma
          Nice find GertSanders ... I am planning to use esp8266 which runs on 3.3 volt... best fit ..
          If we use this we may have to drop few things from 5.5 board right?
          Like no need of 5v - 3.3 converter
          change relay to match 3.3v like this http://vod.ebay.com/vod/FetchOrderDetails?qu=1&itemid=401045943120&transid=522355020027&viewpaymentstatus=
          Anyexpert around? do we need to remove anythingelse (any capacitor?)
          • toabhishekvermaT
            toabhishekvermaT
            toabhishekverma
            But 3.3v relay will not match the board. If we use 5.5v relay do we need to add something to circuit?
            • J
              J
              johnr
              Thank you for this pcb. In which program did you do the design? Do you think you can share an editable version of the design?
              I would like to modify it to accept the Mean Well IRM-05-5 instead of the Hi-Link.
              It is more expensive and bigger AC-DC circuit but since I hace some in my stash i would like to use them.
              • toabhishekvermaT toabhishekverma
                That's a link to your shopping cart, we don't have access to...
                I'm interested in the relay, can you post a working link?
                • toabhishekvermaT
                  toabhishekvermaT
                  toabhishekverma
                  oops..
                  here is the link
                  http://www.ebay.com/itm/401045943120
                  • GertSandersG
                    GertSandersG
                    GertSanders
                    I use the same SONGLE relays:
                    http://www.aliexpress.com/item/5pcs-SRD-03VDC-SL-C-3V-relay-5-feet-10A/32453591000.html
                    • toabhishekvermaT
                      toabhishekvermaT
                      toabhishekverma
                      @GertSanders thanks for this link.
                      So do you have working prototype? what board are you using? I am in middle of finalising components and trying to finalise design. With little knowledge of electronics my progress is slow.
                      Also for 220 to 3.3v there is another converter from Olimex https://www.olimex.com/Products/Power/PWR-90-240V-3.3V0.8A/
                      overall its abit smaller then Hi-Link... Hi-Link abit better because all covered and less dangerous.
                      Please share if you have any design finalised.
                      • GertSandersG GertSanders
                        @GertSanders @toabhishekverma Do you have the dimensions and/or holding resistance?
                        • toabhishekvermaT
                          toabhishekvermaT
                          toabhishekverma
                          Sorry I didnt get your questions .. do you mean dimensions of 220-3.3v converter. Here they are.
                          output 2.5W 3.3V/0.8A +-0.2V size: 30x20x18mm
                          I am not from electronics background so didn't get what holding resistance means?
                            @toabhishekverma No, I meant for the relay ;-)
                            What's the resistance of the 3V coil? I want to know the current flowing when the relay is active.
                            • toabhishekvermaT
                              toabhishekvermaT
                              toabhishekverma
                              @Yveaux Still no idea about it. Check link if you get something from it. what I know is it can bear up to 10A current and can be controlled using 3v .... my order still in shipping so don't know more then that.
                                @toabhishekverma Ah, ok. Didn't know they were still in transit.
                                Maybe @GertSanders has them 'on stock'?
                                HenryWhiteH GertSandersG 2 Replies Last reply
                                • YveauxY Yveaux
                                  HenryWhiteH
                                  HenryWhiteH
                                  HenryWhite
                                  @Yveaux http://www.songle.com/en/pdf/20084141716341001.pdf
                                  • HenryWhiteH HenryWhite
                                    @HenryWhite Awesome! Didn't even think of looking for a datasheet of a Chinese relay ;-)
                                    • P
                                      P
                                      Porky6666
                                      Another source :
                                      50Pieces/Lot JRC-21F 4100 3V DC 6 Pins Miniature PCB Relay Brand New
                                      http://s.aliexpress.com/MNVv2myE
                                      • YveauxY Yveaux
                                        GertSandersG
                                        GertSandersG
                                        GertSanders
                                        @Yveaux No, also still waiting for the order to arrive. But a coil resistance of 20-25 Ohm means driving the coil with a FET. Not directly from a atmega328 pin.
                                        HenryWhiteH 1 Reply Last reply
                                        • P Porky6666
                                          Another source :
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          @Porky6666 : only switches 3A, SONGLE relay can switch 10A.
