  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 341.6k Views 68 Watching
  • toabhishekvermaT
    toabhishekvermaT
    toabhishekverma
    oops..
    here is the link
    http://www.ebay.com/itm/401045943120
    • GertSandersG
      GertSandersG
      GertSanders
      I use the same SONGLE relays:
      http://www.aliexpress.com/item/5pcs-SRD-03VDC-SL-C-3V-relay-5-feet-10A/32453591000.html
      • toabhishekvermaT
        toabhishekvermaT
        toabhishekverma
        @GertSanders thanks for this link.
        So do you have working prototype? what board are you using? I am in middle of finalising components and trying to finalise design. With little knowledge of electronics my progress is slow.
        Also for 220 to 3.3v there is another converter from Olimex https://www.olimex.com/Products/Power/PWR-90-240V-3.3V0.8A/
        overall its abit smaller then Hi-Link... Hi-Link abit better because all covered and less dangerous.
        Please share if you have any design finalised.
        • GertSandersG GertSanders
          @GertSanders @toabhishekverma Do you have the dimensions and/or holding resistance?
          • toabhishekvermaT
            toabhishekvermaT
            toabhishekverma
            Sorry I didnt get your questions .. do you mean dimensions of 220-3.3v converter. Here they are.
            output 2.5W 3.3V/0.8A +-0.2V size: 30x20x18mm
            I am not from electronics background so didn't get what holding resistance means?
            • toabhishekvermaT toabhishekverma
              @toabhishekverma No, I meant for the relay ;-)
              What's the resistance of the 3V coil? I want to know the current flowing when the relay is active.
              • toabhishekvermaT
                toabhishekvermaT
                toabhishekverma
                @Yveaux Still no idea about it. Check link if you get something from it. what I know is it can bear up to 10A current and can be controlled using 3v .... my order still in shipping so don't know more then that.
                  @toabhishekverma Ah, ok. Didn't know they were still in transit.
                  Maybe @GertSanders has them 'on stock'?
                  HenryWhiteH GertSandersG 2 Replies Last reply
                  • YveauxY Yveaux
                    HenryWhiteH
                    HenryWhiteH
                    HenryWhite
                    @Yveaux http://www.songle.com/en/pdf/20084141716341001.pdf
                    • HenryWhiteH HenryWhite
                      @HenryWhite Awesome! Didn't even think of looking for a datasheet of a Chinese relay ;-)
                      • P
                        P
                        Porky6666
                        Another source :
                        50Pieces/Lot JRC-21F 4100 3V DC 6 Pins Miniature PCB Relay Brand New
                        http://s.aliexpress.com/MNVv2myE
                        • YveauxY Yveaux
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @Yveaux No, also still waiting for the order to arrive. But a coil resistance of 20-25 Ohm means driving the coil with a FET. Not directly from a atmega328 pin.
                          HenryWhiteH 1 Reply Last reply
                          • P Porky6666
                            Another source :
                            GertSandersG
                            GertSandersG
                            GertSanders
                            @Porky6666 : only switches 3A, SONGLE relay can switch 10A.
                              HenryWhiteH
                              HenryWhiteH
                              HenryWhite
                              Correct. Here's how I wired the songle relay on my Lithium Ion Sensor PCB:
                              I wouldn't trust both of them when it comes to switching high amp devices over 3A. I think there is a reason no german electronics shop sells songle relays :smile:
                              Plus, relays from an electronics shop in your country might cost the same than the songle relays or will just be a tiny bit more expensive.
                              At least this is true for 5V relays. 3V relays are hard to find (at least in germany)
                                GertSandersG
                                GertSandersG
                                GertSanders
                                I agree, I plan to switch lights, so my preference goes to the 10A model, just to be sure. I have used the SONGLE 5V versions, and none have ever given me reason to doubt their quality. Since I found a 3V3 powersupply I want to try building a full 3V3 board. Should be fun.
                                • toabhishekvermaT
                                  toabhishekvermaT
                                  toabhishekverma
                                  @HenryWhite why do we need D1 Diode (if i am write) in that circuit? do this circuit will not work without diode?
                                  (sorry dont know much about electronics)
                                    HenryWhiteH
                                    HenryWhiteH
                                    HenryWhite
                                    wrote on last edited by HenryWhite
                                    #213
                                    @toabhishekverma https://en.m.wikipedia.org/wiki/Flyback_diode
                                    in short: It is needed to protect the NPN transistor from damage.
                                    The circuit will work without diode, But eventually damage the transistor.
                                    • m26872M
                                      m26872M
                                      m26872
                                      @GertSanders Have you breadboarded your 3.3V design? I'm a bit worried that removing linear converter will impair the performance of the our fussy nRF clones due to less power supply ripple rejection. I think those going for the ESP8266 are better off.
                                      • T
                                        tomkxy
                                        Anyone has an idea where to source the 5.5V varistor? I received a bunch from AliExpress following which seem to be broken.
                                        I found this link http://www.farnell.com/datasheets/575651.pdf. However, there seem to be a bunch of 5.5 V varistor. Can anybody help me figuring out the right ones?
                                        icebobI 1 Reply Last reply
                                        • T tomkxy
                                          icebobI
                                          icebobI
                                          icebob
                                          @tomkxy I'm using this one: http://hu.farnell.com/multicomp/mcvz1206m050agt/varistor-multilayer-4vac-0402/dp/2462756
