  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 345.6k Views 68 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    I use the same SONGLE relays:
    http://www.aliexpress.com/item/5pcs-SRD-03VDC-SL-C-3V-relay-5-feet-10A/32453591000.html
    • toabhishekvermaT
      toabhishekvermaT
      toabhishekverma
      @GertSanders thanks for this link.
      So do you have working prototype? what board are you using? I am in middle of finalising components and trying to finalise design. With little knowledge of electronics my progress is slow.
      Also for 220 to 3.3v there is another converter from Olimex https://www.olimex.com/Products/Power/PWR-90-240V-3.3V0.8A/
      overall its abit smaller then Hi-Link... Hi-Link abit better because all covered and less dangerous.
      Please share if you have any design finalised.
      • GertSandersG GertSanders
        @GertSanders @toabhishekverma Do you have the dimensions and/or holding resistance?
        • toabhishekvermaT
          toabhishekvermaT
          toabhishekverma
          Sorry I didnt get your questions .. do you mean dimensions of 220-3.3v converter. Here they are.
          output 2.5W 3.3V/0.8A +-0.2V size: 30x20x18mm
          I am not from electronics background so didn't get what holding resistance means?
          • toabhishekvermaT toabhishekverma
            @toabhishekverma No, I meant for the relay ;-)
            What's the resistance of the 3V coil? I want to know the current flowing when the relay is active.
            • toabhishekvermaT
              toabhishekvermaT
              toabhishekverma
              @Yveaux Still no idea about it. Check link if you get something from it. what I know is it can bear up to 10A current and can be controlled using 3v .... my order still in shipping so don't know more then that.
                @toabhishekverma Ah, ok. Didn't know they were still in transit.
                Maybe @GertSanders has them 'on stock'?
                HenryWhiteH GertSandersG 2 Replies Last reply
                • YveauxY Yveaux
                  HenryWhiteH
                  HenryWhiteH
                  HenryWhite
                  @Yveaux http://www.songle.com/en/pdf/20084141716341001.pdf
                  • HenryWhiteH HenryWhite
                    @HenryWhite Awesome! Didn't even think of looking for a datasheet of a Chinese relay ;-)
                    • P
                      P
                      Porky6666
                      Another source :
                      50Pieces/Lot JRC-21F 4100 3V DC 6 Pins Miniature PCB Relay Brand New
                      http://s.aliexpress.com/MNVv2myE
                      • YveauxY Yveaux
                        GertSandersG
                        GertSandersG
                        GertSanders
                        @Yveaux No, also still waiting for the order to arrive. But a coil resistance of 20-25 Ohm means driving the coil with a FET. Not directly from a atmega328 pin.
                        HenryWhiteH 1 Reply Last reply
                        • P Porky6666
                          Another source :
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @Porky6666 : only switches 3A, SONGLE relay can switch 10A.
                            HenryWhiteH
                            HenryWhiteH
                            HenryWhite
                            Correct. Here's how I wired the songle relay on my Lithium Ion Sensor PCB:
                            I wouldn't trust both of them when it comes to switching high amp devices over 3A. I think there is a reason no german electronics shop sells songle relays :smile:
                            Plus, relays from an electronics shop in your country might cost the same than the songle relays or will just be a tiny bit more expensive.
                            At least this is true for 5V relays. 3V relays are hard to find (at least in germany)
                              GertSandersG
                              GertSandersG
                              GertSanders
                              I agree, I plan to switch lights, so my preference goes to the 10A model, just to be sure. I have used the SONGLE 5V versions, and none have ever given me reason to doubt their quality. Since I found a 3V3 powersupply I want to try building a full 3V3 board. Should be fun.
                              • toabhishekvermaT
                                toabhishekvermaT
                                toabhishekverma
                                @HenryWhite why do we need D1 Diode (if i am write) in that circuit? do this circuit will not work without diode?
                                (sorry dont know much about electronics)
                                  HenryWhiteH
                                  HenryWhiteH
                                  HenryWhite
                                  wrote on last edited by HenryWhite
                                  #213
                                  @toabhishekverma https://en.m.wikipedia.org/wiki/Flyback_diode
                                  in short: It is needed to protect the NPN transistor from damage.
                                  The circuit will work without diode, But eventually damage the transistor.
                                  • m26872M
                                    m26872M
                                    m26872
                                    @GertSanders Have you breadboarded your 3.3V design? I'm a bit worried that removing linear converter will impair the performance of the our fussy nRF clones due to less power supply ripple rejection. I think those going for the ESP8266 are better off.
                                    • T
                                      tomkxy
                                      Anyone has an idea where to source the 5.5V varistor? I received a bunch from AliExpress following which seem to be broken.
                                      I found this link http://www.farnell.com/datasheets/575651.pdf. However, there seem to be a bunch of 5.5 V varistor. Can anybody help me figuring out the right ones?
                                      icebobI 1 Reply Last reply
                                      • T tomkxy
                                        icebobI
                                        icebobI
                                        icebob
                                        @tomkxy I'm using this one: http://hu.farnell.com/multicomp/mcvz1206m050agt/varistor-multilayer-4vac-0402/dp/2462756
                                        • m26872M m26872
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          #217
                                          @m26872 I have not used the 3V3 version of the Hilink converter, it was just shipped today (ordered last week). It will take a few more weeks to reach me. But then I will test it on my ac board. We will see.
                                          23/FEB: Update: the converters are here. I will make a node with this converter version this weekend.
