  3. Domoticz
  4. Problems getting a RFM69HW gateway to work in domoticz
16 Posts 4 Posters 5.5k Views 4 Watching
    @Cliff-Karlsson said:
    I used serial monitor on both gateway and node and all seems to start up and send/recieve data.
    So, data from your sensors is received by gateway?
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      Yes If I use mysensors controller sketch on a mini pro with RFM69HW and a random sensor sketch on another mini pro + RFM69H I recieve data when the gateway is connected to the computer and I use the serial monitor in the arduino IDE.
      I have also tried the same thing with the lowpowerlab sketches and I also recieve data in that way.
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        wrote on last edited by Cliff Karlsson
        Can it be something that domotics does not like that I connect 3.3v mini pro's using FTDI->USB adapters supplying 3.3v instead of 5v?
        I forgot to say that often when everything seams to detect correctly, as soon as I power up a sensor I often get some error in domotics complaining of "serial lost" or something like that.
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @Cliff-Karlsson
          Can you adjust the baud rate in domoticz for the serial connection?
            Yeah, lowering baudrate could help.
            • Cliff KarlssonC
              Cliff KarlssonC
              Cliff Karlsson
              In the beta it defaults to 115000 or something witch I believe is correct. It is also possible to change to 4800 baud /mini pro/sensbender or something like that. But I have never got anything to show up when changing that setting.
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @Cliff-Karlsson
                An arduino at 8 MHz will not be able to communicate reliably at 115200 bps with a computer over serial.
                38400 or perhaps 57600 at the highest should work.
                • Cliff KarlssonC
                  Cliff KarlssonC
                  Cliff Karlsson
                  i have used RFM69HW adapter on all the recent tries witch should be ok, right?
                  I have also used 868Mhz antennas that I have got from ebay. Could faulty antennas cause something like that?
                    You'll also have to lower the baudrate in MyConfig.h before compiling/uploading the gateway. No need to touch the sensor node.
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      • Cliff KarlssonC
                        Cliff KarlssonC
                        Cliff Karlsson
                        Ahhhhhhh!!!!!!!!!!!!, thank you!!!!!! It finally works. 38400 was the other selectable baudrate specified in domoticz and it started working rightaway after selecting the right settings.
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @Cliff-Karlsson
                          :thumbsup:
                          • John TolJ
                            John TolJ
                            John Tol
                            wrote on last edited by John Tol
                            Hi Cliff, could you be so kind to share the full sketch with us? I'm also having trouble getting this RFM69HW to work.
