  3. Home Assistant
  4. Any plan to implement Ethernet GW?
69 Posts 5 Posters 26.0k Views 6 Watching
  • Dave DanD
    Dave DanD
    Dave Dan
    Hi guys,
    I spend all day yesterday playing with Home Assistant and I must say I'm really impressed wit the UI and how easy some items are for configuring. Still I want to move forward and connect a GW and start connecting nodes, etc.
    In my current MySensors implementation I'm using Ethernet GW.
    Is there any plan to include this GW??
    Don't want to change all my installation before testing fully HA.
    Thanks!!
    • Dave DanD Dave Dan
      Hi guys,
      Thanks!!
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @Dave-Dan
      Hi!
      Yes, I'm working on that. It's not quite finished but the main building blocks are ready. Needs some testing and polishing.
      It's on the top of my priority list of features, so I hope to release it very soon.
      • Dave DanD
        Dave DanD
        Dave Dan
        Cool!!!
        Sing me up for testing if you need more testers.
        Thanks for your reply!!
          Cool!!!
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @Dave-Dan @drock1985
          Hi!
          I've just pushed a branch to my fork of home assistant on github with support for a tcp ethernet gateway. I would be very grateful if you can test this for some time, and let me know of any quirks, errors, improvement suggestions etc.
          If you want to do this, I advice you to install in a virtual environment or similar, to have a clean slate when getting dependencies, and to not interfere with your production install.
          Here's the link to the branch:
          https://github.com/MartinHjelmare/home-assistant/tree/mysensors-tcp-gateway
          You will have to modify the home assistant mysensors config. Here's an example:
          mysensors:
            gateways:
              - device: '/dev/ttyUSB0'
                persistence_file: 'path/mysensors.json'
                baud_rate: 38400
              - device: '/dev/ttyACM0'
                persistence_file: 'path/mysensors2.json'
                baud_rate: 115200
              - device: '192.168.1.10'
                persistence_file: 'path/mysensors3.json'
                tcp_port: 5003
            debug: true
            persistence: true
            version: '1.5'
          The third device in the config is the ethernet gateway. Device is required, tcp_port will default to 5003.
          One thing I think I need to tune, is the time-out between reading and writing attempts to the socket. Right now it feels kinda sluggish. So I'd like to shorten the time-out. Let me know what you notice in this regard, if it feels responsive or not.
          Oh, and everyone are welcome to test this. Please let me know if you do.
          • D
            drock1985
            Hi @martinhjelmare
            If you can post or link to a howto, I have a fresh laptop with Fedora 23 to test this on. Never have used Github before, so I don't know the first thing of what to do.
            My Projects
            2 Door Chime Sensor
            Washing Machine Monitor
            • D drock1985
              Hi @martinhjelmare
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @drock1985
              Great! I'll get back with a how-to asap.
              • D
                drock1985
                Thanks @martinhjelmare
                My Projects
                2 Door Chime Sensor
                • martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  How-to for setting up a linux python3 dev environment and cloning and installing my github fork of home-assistant.
                  Make sure you have python3 installed and also dev files, python3-dev. The dev files might be needed for some compiles.
                  https://github.com/zookeepr/zookeepr/wiki/Creating-a-Development-Environment-with-pip-and-virtualenv
                  Make sure you have pip installed, also for python3:
                  http://python-packaging-user-guide.readthedocs.org/en/latest/install_requirements_linux/
                  Install virtualenvwrapper:
                  TLDR:
                  sudo pip install virtualenv
                  mkdir ~/.virtualenvs
                  sudo pip install virtualenvwrapper
                  For Debian/Ubuntu add these lines to ~/.bashrc
                  export WORKON_HOME=~/.virtualenvs
                  source /usr/local/bin/virtualenvwrapper.sh
                  For Fedora:
                  source /usr/bin/virtualenvwrapper.sh
                  source ~/.bashrc
                  Create a virtualenv with python3:
                  mkvirtualenv -p /usr/bin/python3 hasstest
                  Use a virtualenv:
                  workon hasstest
                  Make sure you have git installed:
                  https://git-scm.com/book/en/v2/Getting-Started-Installing-Git
                  mkdir ~/dev
                  cd ~/dev
                  Clone the github repo:
                  git clone https://github.com/MartinHjelmare/home-assistant.git
                  cd home-assistant
                  Fetch and checkout the correct branch:
                  git fetch origin mysensors-tcp-gateway
                  git checkout mysensors-tcp-gateway
                  Install with pip:
                  pip3 install -e .
                  pip3 install colorlog
                  pip3 install python-Levenshtein
                  Start hass
                  hass
                  • D
                    drock1985
                    Hi @martinhjelmare
                    I'm getting close. I run into an error when running mkvirtualenv -p /usr/bin/python3 hasstest
                    "bash: mkvirtualenv: command not found"
                    The other packages listed above
                    My Projects
                    2 Door Chime Sensor
                    • D drock1985
                      Hi @martinhjelmare
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @drock1985
                      Did you source ~/.bashrc before running that command? You need to make sure the virtualenvwrapper.sh script is run for the terminal session you are in, before you have the commands on your path. Sourcing it in .bashrc will make sure it runs when you login. The first time, you have to do it manually though, if you don't want to logout/login.
                      D 1 Reply Last reply
                        @drock1985
                        drock1985
                        @martinhjelmare
                        Got it installed and compiled. But when I start Hass, I am getting errors about not being able to isntall Netdisco (or any other addon). Seems to want to start fresh on very boot.
                        The configuration file I used was in the homeassistant/config folder. There was a configuration.yaml.example file in there so I assumed thats where the config file would go.
                        My Projects
                        2 Door Chime Sensor
                        • D drock1985
                          @martinhjelmare
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @drock1985
                          Can you post your error log? Try installing netdisco manually with pip.
                            @drock1985
                            drock1985
                            @martinhjelmare
                            I tried manually installing Netdisco, but it won't compile. I get an error complaining about gcc failing with error status 1.
                            The config file it looks for is in my normal home folder (which I assume is correct). The only error in the log is that it could not initialize discovery because dependency netdisco 0.5.2 could not be installed.
                            I think I will try this again tomorrow with Debian or Ubuntu... seems to be a more favorable distro to install Home-Assistant to. I think I even may have an old Pi still kicking around.
                            My Projects
                            2 Door Chime Sensor
                            • D drock1985
                              @martinhjelmare
                              martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              @drock1985
                              You don't need discovery for mysensors, so you could disable that in the config if you don't have any other component that you want to activate which need discovery.
                              Do you have gcc installed and general packages for building, usually called build tools, build-essentials etc?
                                @drock1985
                                drock1985
                                @martinhjelmare
                                Haven't tried build-tools (tried build-essential, it couldn't find any packages) and I do have GCC installed.
                                Will try again when i'm done work for the evening and see what happens.
                                My Projects
                                2 Door Chime Sensor
                                • D drock1985
                                  @martinhjelmare
                                  martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  @drock1985
                                  I think it's called development tools for Fedora. Google it.
                                  If you can post the build log message, I could advise better. It could be a specific lib package that is missing for the compile. The log will usually give some hint on what's missing.
                                  • martinhjelmareM
                                    martinhjelmareM
                                    martinhjelmare
                                    I've updated the branch at my fork of pymysensors. If you have installed the ethernet branch of my fork of home-assistant, you should uninstall/reinstall that, or just make a new virtual environment and install again. You should remove the lib directory in your home assistant config directory as well.
                                    Eg:
                                    rm -r ~/.homeassistant/lib
                                    mkvirtualenv -p /usr/bin/python3 hasstest2
                                    cd ~/dev/home-assistant
                                    git branch -D mysensors-tcp-gateway
                                    pip3 install -e .
                                    • D
                                      drock1985
                                      @martinhjelmare
                                      This is the error I am getting when starting up HASS.
                                      (hasstest) pi@pitest:~/dev/home-assistant $ hass
                                      Config directory: /home/pi/.homeassistant
                                      16-03-05 20:07:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant>
                                      16-03-05 20:07:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant>
                                      16-03-05 20:07:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=toggle, domain=homeassistant>
                                      16-03-05 20:07:57 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
                                      16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
                                      16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
                                      16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
                                      16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded introduction from homeassistant.components.introduction
                                      16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater
                                      16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation
                                      16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded mysensors from homeassistant.components.mysensors
                                      16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
                                      16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun
                                      16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery
                                      16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
                                      16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
                                      16-03-05 20:07:59 INFO (MainThread) [homeassistant.components.introduction]
                                              Hello, and welcome to Home Assistant!
                                              We'll hope that we can make all your dreams come true.
                                              Here are some resources to get started:
                                               - Configuring Home Assistant:
                                                 https://home-assistant.io/getting-started/configuration/
                                               - Available components:
                                                 https://home-assistant.io/components/
                                               - Troubleshooting your configuration:
                                                 https://home-assistant.io/getting-started/troubleshooting-configuration/
                                               - Getting help:
                                                 https://home-assistant.io/help/
                                              This message is generated by the introduction component. You can
                                              disable it in configuration.yaml.
                                      16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=introduction>
                                      16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=recorder>
                                      16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=http>
                                      16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=history>
                                      16-03-05 20:07:59 INFO (MainThread) [requests.packages.urllib3.connectionpool] Starting new HTTPS connection (1): pypi.python.org
                                      16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state updater.updater=0.14.2; friendly_name=Update Available @ 20:08:00 05-03-2016>, entity_id=updater.updater>
                                      16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=updater>
                                      16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=process, domain=conversation>
                                      16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=conversation>
                                      16-03-05 20:08:00 ERROR (MainThread) [homeassistant.components.mysensors] Missing required configuration items in mysensors: port
                                      16-03-05 20:08:00 ERROR (MainThread) [homeassistant.bootstrap] component mysensors failed to initialize
                                      16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=log, domain=logbook>
                                      16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=logbook>
                                      16-03-05 20:08:00 INFO (MainThread) [requests.packages.urllib3.connectionpool] Starting new HTTP connection (1): maps.googleapis.com
                                      16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state sun.sun=below_horizon; next_setting=22:12:29 06-03-2016, elevation=-21.55, next_rising=10:44:01 06-03-2016, friendly_name=Sun @ 20:08:01 05-03-2016>, entity_id=sun.sun>
                                      16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sun>
                                      16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=discovery>
                                      16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=api>
                                      16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=frontend>
                                      16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Starting Home Assistant (13 threads)
                                      16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_start[L]>
                                      16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
                                      16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=restart, domain=homeassistant>
                                      16-03-05 20:08:01 INFO (Thread-17) [homeassistant.components.http] Starting web interface at http://0.0.0.0:8123
                                      16-03-05 20:08:01 INFO (Thread-15) [homeassistant.core] Timer:starting
                                      16-03-05 20:08:01 INFO (Thread-18) [homeassistant.components.http] "GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                                      16-03-05 20:08:01 INFO (Thread-19) [homeassistant.components.http] "GET /api/bootstrap HTTP/1.1" 200 -^C16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Stopping
                                      16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_stop[L]>
                                      16-03-05 20:08:02 INFO (Thread-16) [netdisco.service] Scanning
                                      ^CProcess Process-1:
                                        File "/home/pi/.virtualenvs/hasstest/bin/hass", line 9, in <module>
                                          load_entry_point('homeassistant', 'console_scripts', 'hass')()
                                        File "/home/pi/dev/home-assistant/homeassistant/__main__.py", line 330, in main
                                          keep_running, exit_code = run_hass_process(hass_proc)
                                        File "/usr/lib/python3.4/multiprocessing/process.py", line 254, in _bootstrap
                                          self.run()
                                        File "/usr/lib/python3.4/multiprocessing/process.py", line 93, in run
                                          self._target(*self._args, **self._kwargs)
                                        File "/home/pi/dev/home-assistant/homeassistant/__main__.py", line 248, in setup_and_run_hass
                                          exit_code = int(hass.block_till_stopped())
                                      TypeError: 'bool' object is not iterable
                                        File "/home/pi/dev/home-assistant/homeassistant/core.py", line 100, in block_till_stopped
                                          self.stop()
                                        File "/home/pi/dev/home-assistant/homeassistant/core.py", line 107, in stop
                                          self.pool.stop()
                                        File "/home/pi/dev/home-assistant/homeassistant/util/__init__.py", line 364, in stop
                                          self.block_till_done()
                                        File "/home/pi/dev/home-assistant/homeassistant/util/__init__.py", line 358, in block_till_done
                                          self._work_queue.join()
                                        File "/usr/lib/python3.4/queue.py", line 86, in join
                                          self.all_tasks_done.wait()
                                        File "/usr/lib/python3.4/threading.py", line 290, in wait
                                          waiter.acquire()
                                      KeyboardInterrupt
                                       mysensors:
                                         gateways:
                                             persistence_file: '~/.homeassistant/mysensors3.json'
                                             tcp_port: 5003
                                         debug: true
                                         persistence: true
                                         version: '1.5'
                                      My Projects
                                      2 Door Chime Sensor
                                      • D drock1985
                                        @martinhjelmare
                                                 - Getting help:
                                            self.run()
                                            self.stop()
                                            self.pool.stop()
                                            waiter.acquire()
                                        KeyboardInterrupt
                                         mysensors:
                                           gateways:
                                               tcp_port: 5003
                                           debug: true
                                           persistence: true
                                           version: '1.5'
                                        martinhjelmareM
                                        martinhjelmareM
                                        martinhjelmare
                                        @drock1985
                                        Did you checkout correct branch?
                                        You should remove the lib directory in ~/.homeassistant/ before you start hass again after the git checkout also.
                                        • D
                                          drock1985
                                          Ugh, forgot to run the checkout command. palm smacks head
                                          Booting now, will report back in a minute if it is working or not.
                                          My Projects
                                          2 Door Chime Sensor
