  3. Home Assistant
  4. Any plan to implement Ethernet GW?
69 Posts 5 Posters 26.4k Views 6 Watching
  • D drock1985
    Hi @martinhjelmare
    I'm getting close. I run into an error when running mkvirtualenv -p /usr/bin/python3 hasstest
    "bash: mkvirtualenv: command not found"
    The other packages listed above
    martinhjelmareM
    martinhjelmareM
    martinhjelmare
    @drock1985
    Did you source ~/.bashrc before running that command? You need to make sure the virtualenvwrapper.sh script is run for the terminal session you are in, before you have the commands on your path. Sourcing it in .bashrc will make sure it runs when you login. The first time, you have to do it manually though, if you don't want to logout/login.
    D 1 Reply Last reply
      @drock1985
      drock1985
      @martinhjelmare
      Got it installed and compiled. But when I start Hass, I am getting errors about not being able to isntall Netdisco (or any other addon). Seems to want to start fresh on very boot.
      The configuration file I used was in the homeassistant/config folder. There was a configuration.yaml.example file in there so I assumed thats where the config file would go.
      My Projects
      2 Door Chime Sensor
      Washing Machine Monitor
      • D drock1985
        @martinhjelmare
        martinhjelmareM
        martinhjelmareM
        martinhjelmare
        @drock1985
        Can you post your error log? Try installing netdisco manually with pip.
          @drock1985
          drock1985
          @martinhjelmare
          I tried manually installing Netdisco, but it won't compile. I get an error complaining about gcc failing with error status 1.
          The config file it looks for is in my normal home folder (which I assume is correct). The only error in the log is that it could not initialize discovery because dependency netdisco 0.5.2 could not be installed.
          I think I will try this again tomorrow with Debian or Ubuntu... seems to be a more favorable distro to install Home-Assistant to. I think I even may have an old Pi still kicking around.
          My Projects
          2 Door Chime Sensor
          • D drock1985
            @martinhjelmare
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @drock1985
            You don't need discovery for mysensors, so you could disable that in the config if you don't have any other component that you want to activate which need discovery.
            Do you have gcc installed and general packages for building, usually called build tools, build-essentials etc?
              @drock1985
              drock1985
              @martinhjelmare
              Haven't tried build-tools (tried build-essential, it couldn't find any packages) and I do have GCC installed.
              Will try again when i'm done work for the evening and see what happens.
              My Projects
              2 Door Chime Sensor
              • D drock1985
                @martinhjelmare
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @drock1985
                I think it's called development tools for Fedora. Google it.
                If you can post the build log message, I could advise better. It could be a specific lib package that is missing for the compile. The log will usually give some hint on what's missing.
                • martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  I've updated the branch at my fork of pymysensors. If you have installed the ethernet branch of my fork of home-assistant, you should uninstall/reinstall that, or just make a new virtual environment and install again. You should remove the lib directory in your home assistant config directory as well.
                  Eg:
                  rm -r ~/.homeassistant/lib
                  mkvirtualenv -p /usr/bin/python3 hasstest2
                  cd ~/dev/home-assistant
                  git branch -D mysensors-tcp-gateway
                  git fetch origin mysensors-tcp-gateway
                  git checkout mysensors-tcp-gateway
                  pip3 install -e .
                  pip3 install colorlog
                  pip3 install python-Levenshtein
                  • D
                    drock1985
                    @martinhjelmare
                    This is the error I am getting when starting up HASS.
                    (hasstest) pi@pitest:~/dev/home-assistant $ hass
                    Config directory: /home/pi/.homeassistant
                    16-03-05 20:07:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant>
                    16-03-05 20:07:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant>
                    16-03-05 20:07:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=toggle, domain=homeassistant>
                    16-03-05 20:07:57 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
                    16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
                    16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
                    16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
                    16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded introduction from homeassistant.components.introduction
                    16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater
                    16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation
                    16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded mysensors from homeassistant.components.mysensors
                    16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
                    16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun
                    16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery
                    16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
                    16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
                    16-03-05 20:07:59 INFO (MainThread) [homeassistant.components.introduction]
                            Hello, and welcome to Home Assistant!
                            We'll hope that we can make all your dreams come true.
                            Here are some resources to get started:
                             - Configuring Home Assistant:
                               https://home-assistant.io/getting-started/configuration/
                             - Available components:
                               https://home-assistant.io/components/
                             - Troubleshooting your configuration:
                               https://home-assistant.io/getting-started/troubleshooting-configuration/
                             - Getting help:
                               https://home-assistant.io/help/
                            This message is generated by the introduction component. You can
                            disable it in configuration.yaml.
                    16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=introduction>
                    16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=recorder>
                    16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=http>
                    16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=history>
                    16-03-05 20:07:59 INFO (MainThread) [requests.packages.urllib3.connectionpool] Starting new HTTPS connection (1): pypi.python.org
                    16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state updater.updater=0.14.2; friendly_name=Update Available @ 20:08:00 05-03-2016>, entity_id=updater.updater>
                    16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=updater>
                    16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=process, domain=conversation>
                    16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=conversation>
                    16-03-05 20:08:00 ERROR (MainThread) [homeassistant.components.mysensors] Missing required configuration items in mysensors: port
                    16-03-05 20:08:00 ERROR (MainThread) [homeassistant.bootstrap] component mysensors failed to initialize
                    16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=log, domain=logbook>
                    16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=logbook>
                    16-03-05 20:08:00 INFO (MainThread) [requests.packages.urllib3.connectionpool] Starting new HTTP connection (1): maps.googleapis.com
                    16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state sun.sun=below_horizon; next_setting=22:12:29 06-03-2016, elevation=-21.55, next_rising=10:44:01 06-03-2016, friendly_name=Sun @ 20:08:01 05-03-2016>, entity_id=sun.sun>
                    16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sun>
                    16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=discovery>
                    16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=api>
                    16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=frontend>
                    16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Starting Home Assistant (13 threads)
                    16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_start[L]>
                    16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
                    16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=restart, domain=homeassistant>
                    16-03-05 20:08:01 INFO (Thread-17) [homeassistant.components.http] Starting web interface at http://0.0.0.0:8123
                    16-03-05 20:08:01 INFO (Thread-15) [homeassistant.core] Timer:starting
                    16-03-05 20:08:01 INFO (Thread-18) [homeassistant.components.http] "GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                    16-03-05 20:08:01 INFO (Thread-19) [homeassistant.components.http] "GET /api/bootstrap HTTP/1.1" 200 -^C16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Stopping
                    16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_stop[L]>
                    16-03-05 20:08:02 INFO (Thread-16) [netdisco.service] Scanning
                    ^CProcess Process-1:
                      File "/home/pi/.virtualenvs/hasstest/bin/hass", line 9, in <module>
                        load_entry_point('homeassistant', 'console_scripts', 'hass')()
                      File "/home/pi/dev/home-assistant/homeassistant/__main__.py", line 330, in main
                        keep_running, exit_code = run_hass_process(hass_proc)
                      File "/usr/lib/python3.4/multiprocessing/process.py", line 254, in _bootstrap
                        self.run()
                      File "/usr/lib/python3.4/multiprocessing/process.py", line 93, in run
                        self._target(*self._args, **self._kwargs)
                      File "/home/pi/dev/home-assistant/homeassistant/__main__.py", line 248, in setup_and_run_hass
                        exit_code = int(hass.block_till_stopped())
                    TypeError: 'bool' object is not iterable
                      File "/home/pi/dev/home-assistant/homeassistant/core.py", line 100, in block_till_stopped
                        self.stop()
                      File "/home/pi/dev/home-assistant/homeassistant/core.py", line 107, in stop
                        self.pool.stop()
                      File "/home/pi/dev/home-assistant/homeassistant/util/__init__.py", line 364, in stop
                        self.block_till_done()
                      File "/home/pi/dev/home-assistant/homeassistant/util/__init__.py", line 358, in block_till_done
                        self._work_queue.join()
                      File "/usr/lib/python3.4/queue.py", line 86, in join
                        self.all_tasks_done.wait()
                      File "/usr/lib/python3.4/threading.py", line 290, in wait
                        waiter.acquire()
                    KeyboardInterrupt
                     mysensors:
                       gateways:
                         - device: '192.168.1.10'
                           persistence_file: '~/.homeassistant/mysensors3.json'
                           tcp_port: 5003
                       debug: true
                       persistence: true
                       version: '1.5'
                    My Projects
                    2 Door Chime Sensor
                    • D drock1985
                      @martinhjelmare
                               - Getting help:
                          self.run()
                          self.stop()
                          self.pool.stop()
                          waiter.acquire()
                      KeyboardInterrupt
                       mysensors:
                         gateways:
                             tcp_port: 5003
                         debug: true
                         persistence: true
                         version: '1.5'
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @drock1985
                      Did you checkout correct branch?
                      You should remove the lib directory in ~/.homeassistant/ before you start hass again after the git checkout also.
                      • D
                        drock1985
                        Ugh, forgot to run the checkout command. palm smacks head
                        Booting now, will report back in a minute if it is working or not.
                        My Projects
                        2 Door Chime Sensor
                        • D drock1985
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @drock1985
                          Don't forget to use the correct ip address of your gateway in your network.
                          • D
                            drock1985
                            wrote on last edited by drock1985
                            #22
                            @martinhjelmare
                            It works! Found my motion sensor with ease. Will start adding lights now shortly
                            Thanks again, loving this.
                            EDIT: Quick question: To autostart this, would I just use the normal Home-Assistant instructions in the virtualenv, or is there another method to do it?
                            My Projects
                            2 Door Chime Sensor
                            • D drock1985
                              @martinhjelmare
                              martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              #23
                              @drock1985
                              :thumbsup:
                              When you have time, can you run git log and tell me the top commit message, so I know which version you are using.
                              Regarding autostart, no I don't think you can use the normal instructions together with the virtualenv. You could write a script, that changes to the virtualenv and starts hass, and run that script at login or similar.
                              If you don't have another production install of home assistant on the computer, you can skip the virtualenv alltogether and just do:
                              pip3 install --user "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"
                              or if you want to install as root:
                              sudo pip3 install "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"
                              This way you should be able to autostart the usual way, per instructions on the web.
                              But then if you want to test an update from me, you have to make sure you uninstall everything correctly and manually remove ~/.homeassistant/lib before you install again.
                              Dave DanD 1 Reply Last reply
                              • D
                                drock1985
                                @martinhjelmare
                                Here is the info you requested:
                                commit d07f8097a6186611371b8bc918fcb0d436bb39ba
                                Author: MartinHjelmare <marhje52@kth.se>
                                Date:   Sat Feb 27 04:55:38 2016 +0100
                                    Add mysensors tcp ethernet gateway
                                    * Replace CONF_PORT with CONF_DEVICE and ATTR_PORT with ATTR_DEVICE.
                                    * Add tcp_port in config.
                                    * Use fork pymysensors repo, temporarily.
                                    * Try to guess if tcp or serial gateway is configured, by validating
                                        device name as an ip address. If successful setup tcp gateway, if it
                                        fails, setup serial gateway.
                                    * Update device_state_attributes to show correct device, ethernet or
                                        serial.
                                commit 278fdc0983a8528945e13cf912da82f3bc5fe14c
                                Merge: 6dc49df 8ffa368
                                Author: Daniel Høyer Iversen <daniel.h.iversen@ntnu.no>
                                Date:   Fri Feb 26 10:49:10 2016 +0100
                                    Merge pull request #1385 from balloob/rfxtrx
                                    improve rfxtrx sensor
                                My Projects
                                2 Door Chime Sensor
                                • D drock1985
                                  @martinhjelmare
                                          serial.
                                  martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  #25
                                  @drock1985
                                  Sorry, I forgot I've only updated the pymysensors project, so you checking the home-assistant git log is no use. Well, I think your're running the lastest version anyway, since you got it working just now. Everything should be ok.
                                  Let me know if you experience any problems.
                                  If everything seems ok for you after some time of testing, I don't see why we can't release this very soon. My limited testing after the lastest update, show no problems.
                                  • Dave DanD
                                    Dave DanD
                                    Dave Dan
                                    Hey @martinhjelmare,
                                    I finally got this working.
                                    I'm doing tests with a couple of multi-sensors (Temp, Hum, Light & motion). The discovery worked very well, no issue at all after following all the above steps.
                                    What I'm not seeing wotking are the updates. I always see the same values. I'm checking messages with MYSController and I see the GW is receiving the events and updates but I can't see new values showing in the portal.
                                    Still testing ...
                                    • Dave DanD Dave Dan
                                      Still testing ...
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @Dave-Dan
                                      Do you mean that the sensors are not showing the latest values in the gui?
                                      If the last value from a sensor is the same as the previous value, a state change won't happen. So the value will be reported as being as old as the previous value. Could this explain what you see?
                                      • Dave DanD
                                        Dave DanD
                                        Dave Dan
                                        actually, I just got it working ...
                                        yes, I was referrring to that. The way I have built the sensor is that everytime a movement is detected is sending all sensors statuses to the GW. This sensors are designed to be plugged (no battery powered) so no concern on power consumption.
                                        I restarted the server and now updates are working.
                                        What I'm seeing in the log is constantly this message:
                                        16-03-14 10:39:53 INFO (Thread-9) [mysensors.mysensors] Permission denied when writing to /home/pi/dev/home-assistant/path/mysensors3.json
                                        If I'm not wrong this is the persistence.
                                        Apart of this I now see updates coming in ...
                                        • martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          Good!
                                          The path to the persistence file must exist, not the file itself, but the directory tree above, and hass should have write permission to it.
                                          I usually put the file in the same directory as configuration.yml.
