  3. Home Assistant
  4. Any plan to implement Ethernet GW?
69 Posts 5 Posters 26.4k Views 6 Watching
  • Dave DanD Dave Dan
    Cool!!!
    Sing me up for testing if you need more testers.
    Thanks for your reply!!
    martinhjelmareM
    martinhjelmareM
    martinhjelmare
    @Dave-Dan @drock1985
    Hi!
    I've just pushed a branch to my fork of home assistant on github with support for a tcp ethernet gateway. I would be very grateful if you can test this for some time, and let me know of any quirks, errors, improvement suggestions etc.
    If you want to do this, I advice you to install in a virtual environment or similar, to have a clean slate when getting dependencies, and to not interfere with your production install.
    Here's the link to the branch:
    https://github.com/MartinHjelmare/home-assistant/tree/mysensors-tcp-gateway
    You will have to modify the home assistant mysensors config. Here's an example:
    mysensors:
      gateways:
        - device: '/dev/ttyUSB0'
          persistence_file: 'path/mysensors.json'
          baud_rate: 38400
        - device: '/dev/ttyACM0'
          persistence_file: 'path/mysensors2.json'
          baud_rate: 115200
        - device: '192.168.1.10'
          persistence_file: 'path/mysensors3.json'
          tcp_port: 5003
      debug: true
      persistence: true
      version: '1.5'
    The third device in the config is the ethernet gateway. Device is required, tcp_port will default to 5003.
    One thing I think I need to tune, is the time-out between reading and writing attempts to the socket. Right now it feels kinda sluggish. So I'd like to shorten the time-out. Let me know what you notice in this regard, if it feels responsive or not.
    Oh, and everyone are welcome to test this. Please let me know if you do.
    • D
      drock1985
      Hi @martinhjelmare
      If you can post or link to a howto, I have a fresh laptop with Fedora 23 to test this on. Never have used Github before, so I don't know the first thing of what to do.
      My Projects
      2 Door Chime Sensor
      Washing Machine Monitor
      • D drock1985
        Hi @martinhjelmare
        martinhjelmareM
        martinhjelmareM
        martinhjelmare
        @drock1985
        Great! I'll get back with a how-to asap.
        • D
          drock1985
          Thanks @martinhjelmare
          My Projects
          2 Door Chime Sensor
          • martinhjelmareM
            martinhjelmareM
            martinhjelmare
            How-to for setting up a linux python3 dev environment and cloning and installing my github fork of home-assistant.
            Make sure you have python3 installed and also dev files, python3-dev. The dev files might be needed for some compiles.
            https://github.com/zookeepr/zookeepr/wiki/Creating-a-Development-Environment-with-pip-and-virtualenv
            Make sure you have pip installed, also for python3:
            http://python-packaging-user-guide.readthedocs.org/en/latest/install_requirements_linux/
            Install virtualenvwrapper:
            TLDR:
            sudo pip install virtualenv
            mkdir ~/.virtualenvs
            sudo pip install virtualenvwrapper
            For Debian/Ubuntu add these lines to ~/.bashrc
            export WORKON_HOME=~/.virtualenvs
            source /usr/local/bin/virtualenvwrapper.sh
            For Fedora:
            source /usr/bin/virtualenvwrapper.sh
            source ~/.bashrc
            Create a virtualenv with python3:
            mkvirtualenv -p /usr/bin/python3 hasstest
            Use a virtualenv:
            workon hasstest
            Make sure you have git installed:
            https://git-scm.com/book/en/v2/Getting-Started-Installing-Git
            mkdir ~/dev
            cd ~/dev
            Clone the github repo:
            git clone https://github.com/MartinHjelmare/home-assistant.git
            cd home-assistant
            Fetch and checkout the correct branch:
            git fetch origin mysensors-tcp-gateway
            git checkout mysensors-tcp-gateway
            Install with pip:
            pip3 install -e .
            pip3 install colorlog
            pip3 install python-Levenshtein
            Start hass
            hass
            • D
              drock1985
              Hi @martinhjelmare
              I'm getting close. I run into an error when running mkvirtualenv -p /usr/bin/python3 hasstest
              "bash: mkvirtualenv: command not found"
              The other packages listed above
              My Projects
              2 Door Chime Sensor
              • D drock1985
                Hi @martinhjelmare
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @drock1985
                Did you source ~/.bashrc before running that command? You need to make sure the virtualenvwrapper.sh script is run for the terminal session you are in, before you have the commands on your path. Sourcing it in .bashrc will make sure it runs when you login. The first time, you have to do it manually though, if you don't want to logout/login.
                D 1 Reply Last reply
                  @drock1985
                  drock1985
                  @martinhjelmare
                  Got it installed and compiled. But when I start Hass, I am getting errors about not being able to isntall Netdisco (or any other addon). Seems to want to start fresh on very boot.
                  The configuration file I used was in the homeassistant/config folder. There was a configuration.yaml.example file in there so I assumed thats where the config file would go.
                  My Projects
                  2 Door Chime Sensor
                  • D drock1985
                    @martinhjelmare
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @drock1985
                    Can you post your error log? Try installing netdisco manually with pip.
                      @drock1985
                      drock1985
                      @martinhjelmare
                      I tried manually installing Netdisco, but it won't compile. I get an error complaining about gcc failing with error status 1.
                      The config file it looks for is in my normal home folder (which I assume is correct). The only error in the log is that it could not initialize discovery because dependency netdisco 0.5.2 could not be installed.
                      I think I will try this again tomorrow with Debian or Ubuntu... seems to be a more favorable distro to install Home-Assistant to. I think I even may have an old Pi still kicking around.
                      My Projects
                      2 Door Chime Sensor
                      • D drock1985
                        @martinhjelmare
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        @drock1985
                        You don't need discovery for mysensors, so you could disable that in the config if you don't have any other component that you want to activate which need discovery.
                        Do you have gcc installed and general packages for building, usually called build tools, build-essentials etc?
                          @drock1985
                          drock1985
                          @martinhjelmare
                          Haven't tried build-tools (tried build-essential, it couldn't find any packages) and I do have GCC installed.
                          Will try again when i'm done work for the evening and see what happens.
                          My Projects
                          2 Door Chime Sensor
                          • D drock1985
                            @martinhjelmare
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @drock1985
                            I think it's called development tools for Fedora. Google it.
                            If you can post the build log message, I could advise better. It could be a specific lib package that is missing for the compile. The log will usually give some hint on what's missing.
                            • martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              I've updated the branch at my fork of pymysensors. If you have installed the ethernet branch of my fork of home-assistant, you should uninstall/reinstall that, or just make a new virtual environment and install again. You should remove the lib directory in your home assistant config directory as well.
                              Eg:
                              rm -r ~/.homeassistant/lib
                              mkvirtualenv -p /usr/bin/python3 hasstest2
                              cd ~/dev/home-assistant
                              git branch -D mysensors-tcp-gateway
                              pip3 install -e .
                              • D
                                drock1985
                                @martinhjelmare
                                This is the error I am getting when starting up HASS.
                                (hasstest) pi@pitest:~/dev/home-assistant $ hass
                                Config directory: /home/pi/.homeassistant
                                16-03-05 20:07:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant>
                                16-03-05 20:07:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant>
                                16-03-05 20:07:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=toggle, domain=homeassistant>
                                16-03-05 20:07:57 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
                                16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
                                16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
                                16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
                                16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded introduction from homeassistant.components.introduction
                                16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater
                                16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation
                                16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded mysensors from homeassistant.components.mysensors
                                16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
                                16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun
                                16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery
                                16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
                                16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
                                16-03-05 20:07:59 INFO (MainThread) [homeassistant.components.introduction]
                                        Hello, and welcome to Home Assistant!
                                        We'll hope that we can make all your dreams come true.
                                        Here are some resources to get started:
                                         - Configuring Home Assistant:
                                           https://home-assistant.io/getting-started/configuration/
                                         - Available components:
                                           https://home-assistant.io/components/
                                         - Troubleshooting your configuration:
                                           https://home-assistant.io/getting-started/troubleshooting-configuration/
                                         - Getting help:
                                           https://home-assistant.io/help/
                                        This message is generated by the introduction component. You can
                                        disable it in configuration.yaml.
                                16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=introduction>
                                16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=recorder>
                                16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=http>
                                16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=history>
                                16-03-05 20:07:59 INFO (MainThread) [requests.packages.urllib3.connectionpool] Starting new HTTPS connection (1): pypi.python.org
                                16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state updater.updater=0.14.2; friendly_name=Update Available @ 20:08:00 05-03-2016>, entity_id=updater.updater>
                                16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=updater>
                                16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=process, domain=conversation>
                                16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=conversation>
                                16-03-05 20:08:00 ERROR (MainThread) [homeassistant.components.mysensors] Missing required configuration items in mysensors: port
                                16-03-05 20:08:00 ERROR (MainThread) [homeassistant.bootstrap] component mysensors failed to initialize
                                16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=log, domain=logbook>
                                16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=logbook>
                                16-03-05 20:08:00 INFO (MainThread) [requests.packages.urllib3.connectionpool] Starting new HTTP connection (1): maps.googleapis.com
                                16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state sun.sun=below_horizon; next_setting=22:12:29 06-03-2016, elevation=-21.55, next_rising=10:44:01 06-03-2016, friendly_name=Sun @ 20:08:01 05-03-2016>, entity_id=sun.sun>
                                16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sun>
                                16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=discovery>
                                16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=api>
                                16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=frontend>
                                16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Starting Home Assistant (13 threads)
                                16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_start[L]>
                                16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
                                16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=restart, domain=homeassistant>
                                16-03-05 20:08:01 INFO (Thread-17) [homeassistant.components.http] Starting web interface at http://0.0.0.0:8123
                                16-03-05 20:08:01 INFO (Thread-15) [homeassistant.core] Timer:starting
                                16-03-05 20:08:01 INFO (Thread-18) [homeassistant.components.http] "GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                                16-03-05 20:08:01 INFO (Thread-19) [homeassistant.components.http] "GET /api/bootstrap HTTP/1.1" 200 -^C16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Stopping
                                16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_stop[L]>
                                16-03-05 20:08:02 INFO (Thread-16) [netdisco.service] Scanning
                                ^CProcess Process-1:
                                  File "/home/pi/.virtualenvs/hasstest/bin/hass", line 9, in <module>
                                    load_entry_point('homeassistant', 'console_scripts', 'hass')()
                                  File "/home/pi/dev/home-assistant/homeassistant/__main__.py", line 330, in main
                                    keep_running, exit_code = run_hass_process(hass_proc)
                                  File "/usr/lib/python3.4/multiprocessing/process.py", line 254, in _bootstrap
                                    self.run()
                                  File "/usr/lib/python3.4/multiprocessing/process.py", line 93, in run
                                    self._target(*self._args, **self._kwargs)
                                  File "/home/pi/dev/home-assistant/homeassistant/__main__.py", line 248, in setup_and_run_hass
                                    exit_code = int(hass.block_till_stopped())
                                TypeError: 'bool' object is not iterable
                                  File "/home/pi/dev/home-assistant/homeassistant/core.py", line 100, in block_till_stopped
                                    self.stop()
                                  File "/home/pi/dev/home-assistant/homeassistant/core.py", line 107, in stop
                                    self.pool.stop()
                                  File "/home/pi/dev/home-assistant/homeassistant/util/__init__.py", line 364, in stop
                                    self.block_till_done()
                                  File "/home/pi/dev/home-assistant/homeassistant/util/__init__.py", line 358, in block_till_done
                                    self._work_queue.join()
                                  File "/usr/lib/python3.4/queue.py", line 86, in join
                                    self.all_tasks_done.wait()
                                  File "/usr/lib/python3.4/threading.py", line 290, in wait
                                    waiter.acquire()
                                KeyboardInterrupt
                                 mysensors:
                                   gateways:
                                       persistence_file: '~/.homeassistant/mysensors3.json'
                                       tcp_port: 5003
                                   debug: true
                                   persistence: true
                                   version: '1.5'
                                My Projects
                                2 Door Chime Sensor
                                • D drock1985
                                  @martinhjelmare
                                           - Getting help:
                                      self.run()
                                      self.stop()
                                      self.pool.stop()
                                      waiter.acquire()
                                  KeyboardInterrupt
                                   mysensors:
                                     gateways:
                                         tcp_port: 5003
                                     debug: true
                                     persistence: true
                                     version: '1.5'
                                  martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  @drock1985
                                  Did you checkout correct branch?
                                  You should remove the lib directory in ~/.homeassistant/ before you start hass again after the git checkout also.
                                  • D
                                    drock1985
                                    Ugh, forgot to run the checkout command. palm smacks head
                                    Booting now, will report back in a minute if it is working or not.
                                    My Projects
                                    2 Door Chime Sensor
                                    • D drock1985
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @drock1985
                                      Don't forget to use the correct ip address of your gateway in your network.
                                      • D
                                        drock1985
                                        wrote on last edited by drock1985
                                        #22
                                        @martinhjelmare
                                        It works! Found my motion sensor with ease. Will start adding lights now shortly
                                        Thanks again, loving this.
                                        EDIT: Quick question: To autostart this, would I just use the normal Home-Assistant instructions in the virtualenv, or is there another method to do it?
                                        My Projects
                                        2 Door Chime Sensor
                                        • D drock1985
                                          @martinhjelmare
                                          martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          #23
                                          @drock1985
                                          :thumbsup:
                                          When you have time, can you run git log and tell me the top commit message, so I know which version you are using.
                                          Regarding autostart, no I don't think you can use the normal instructions together with the virtualenv. You could write a script, that changes to the virtualenv and starts hass, and run that script at login or similar.
                                          If you don't have another production install of home assistant on the computer, you can skip the virtualenv alltogether and just do:
                                          pip3 install --user "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"
                                          or if you want to install as root:
                                          sudo pip3 install "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"
                                          This way you should be able to autostart the usual way, per instructions on the web.
                                          But then if you want to test an update from me, you have to make sure you uninstall everything correctly and manually remove ~/.homeassistant/lib before you install again.
                                          Dave DanD 1 Reply Last reply
