  3. Slim Node Si7021 sensor example
137 Posts 18 Posters 98.4k Views 20 Watching
  • rsachocR
    rsachocR
    rsachoc
    Progress!
    http://imgur.com/zRvXvrN
    http://imgur.com/KpB7daz
    A question though. To get to this point, I copied the pictures posted above, but where do I now add these resistors?
    http://imgur.com/6mKJcgE
    Also, if I want to add a 2AA battery cage, where do I connect the red and black wires to?
    Thanks! And sorry for the newb questions!
    m26872M 1 Reply Last reply
    • GertSandersG
      GertSandersG
      GertSanders
      @rsachoc What you show are not resistors, they look like capacitors. 104 means 100nF (I think). Can you measure their value ?
      • carlierdC carlierd
        @ar91 Please find the code I used in 3 different nodes. The good thing with the playground lib is that there is error message if dialog with DHT22 failed.
        /* Temperature, humidity and luminosity measurements.                                 */
        /* Version     : 1.1.6        */
        /* Date        : 10/01/2016                                                           */
        /* Modified by : David Carlier                                                        */
        /*                            RST |             |  A5                                 */
        /*                            RX  |             |  A4                                 */
        /*                            TX  |   ARDUINO   |  A3                                 */
        /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
        /*            DHT22 --------- D3  |             |  A1                                 */
        /*            Power --------- D4  | ATMEGA 328p |  A0 --------- Light dep. resistor   */
        /*              +3v --------- VCC |             | GND --------- GND                   */
        /*              GND --------- GND |  8MHz int.  | REF                                 */
        /*                            OSC |             | VCC --------- +3v                   */
        /*                            OSC |             | D13 --------- RFM69 (SCK)           */
        /*                            D5  |             | D12 --------- RFM69 (MISO)          */
        /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
        /*                            D7  |             | D10 --------- RFM69 (NSS)           */
        /*                            D8  |             |  D9                                 */
        /* Power = Vcc for LDR.                                                               */
        /* +3v = 2*AA        */
        #include <dht.h>
        #include <MyTransportRFM69.h>
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        #define CHILD_ID_LIGHT 2
        #define CHILD_ID_VOLTAGE 3
        #define POWER_PIN 4
        //unsigned long SLEEP_TIME = 850000; // Sleep time between reads (in milliseconds) (close to 15')
        unsigned long SLEEP_TIME = 275000; // Sleep time between reads (in milliseconds) (close to 5')
        //Construct MySensors library
        MySigningAtsha204Soft signer;
        MyHwATMega328 hw;
        MyTransportRFM69 transport;
        MySensor gw(transport, hw, signer);
        dht DHT;
        MyMessage msgLum(CHILD_ID_LIGHT, V_LEVEL);
        MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
        /* Initialization        */
          //Get time (for setup duration)
          #ifdef DEBUG
            unsigned long startTime = millis();
          //Start MySensors
          gw.begin();
          //Send the Sketch Version Information to the Gateway
          gw.sendSketchInfo("GHAS sensor", "1.1.5");
          //Register all sensors to gw (they will be created as child devices)
          gw.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
          //Delay for DHT22
          delay(1500);
          //Print setup debug
          #ifdef DEBUG
            int duration = millis() - startTime;
            Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
        /* Main loop        */
          //Get time (for a complete loop)
          #ifdef DEBUG
          //Power on
          powerOnPeripherals();
          //Get DHT22 data
          int dht22Result = DHT.read22(HUMIDITY_SENSOR_DIGITAL_PIN);
          switch (dht22Result)
            case DHTLIB_OK:
                        //Serial.println("OK,\t");
            case DHTLIB_ERROR_CHECKSUM:
                        #ifdef DEBUG
                          Serial.println("Checksum error,\t");
            case DHTLIB_ERROR_TIMEOUT:
                        #ifdef DEBUG
                          Serial.println("Time out error,\t");
            case DHTLIB_ERROR_CONNECT:
                        #ifdef DEBUG
                          Serial.println("Connect error,\t");
            case DHTLIB_ERROR_ACK_L:
                        #ifdef DEBUG
                          Serial.println("Ack Low error,\t");
            case DHTLIB_ERROR_ACK_H:
                        #ifdef DEBUG
                          Serial.println("Ack High error,\t");
            default:
                        #ifdef DEBUG
                          Serial.println("Unknown error,\t");
          //Get temperature and humidity
          float temperature = 0;
          float humidity = 0;
          if (dht22Result == DHTLIB_OK)
            temperature = DHT.temperature;
            humidity = DHT.humidity;
          //Get power before luminosity to use real voltage
          float realVoltage = getVoltage() / 100.0;
          int batteryPcnt = realVoltage * 100 / 3.0;
          if (batteryPcnt > 100) {batteryPcnt = 100;}
          int lux = computeIlluminance(realVoltage);
          //Power off
          powerOffPeripherals();
          //Send data to gateway
          gw.send(msgLum.set(lux));
          gw.send(msgVolt.set(realVoltage, 2));
          //Print debug
          #ifdef DEBUG
            Serial.print(temperature, 1);
            Serial.print(" degC");
            Serial.print("   ");
            Serial.print(humidity, 1);
            Serial.print(" %");
            Serial.print("   ");
            Serial.print(lux);
            Serial.print(" lx");
            Serial.print("   ");
            Serial.print(realVoltage);
            Serial.print(" v");
            Serial.print("   ");
            Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
            Serial.flush();
          //Sleep
          gw.sleep(SLEEP_TIME);
        /* Allows to compute illuminance (in LUX) from LIGHT_SENSOR_ANALOG_PIN.               */
        int computeIlluminance(float realVoltage)
          //Get luminosity
          int luminosity = analogRead(LIGHT_SENSOR_ANALOG_PIN);
          //Calculating the voltage in the input of the ADC
          double voltage = realVoltage * ((double)luminosity / 1024.0);
          //Calculating the resistance of the photoresistor in the voltage divider
          double resistance = (10.0 * realVoltage) / voltage - 10.0;
          //Calculating the intensity of light in lux and return it
          int illuminance = 255.84 * pow(resistance, -10/9);
          return illuminance;
        /* Allows to get the real Vcc (return value * 100).                                   */
        int getVoltage()
          const long InternalReferenceVoltage = 1056L;
          ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
          delay(50);  // Let mux settle a little to get a more stable A/D conversion
          //Start a conversion
          ADCSRA |= _BV( ADSC );
          //Wait for it to complete
          while (((ADCSRA & (1<<ADSC)) != 0));
          //Scale the value
          int result = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L;
          return result;
        /* Allows to power ON peripherals.                                                    */
        void powerOnPeripherals()
          //Power-up
          pinMode (POWER_PIN, OUTPUT);
          digitalWrite (POWER_PIN, HIGH);
          delay(1);
        /* Allows to power OFF peripherals.                                                   */
        void powerOffPeripherals()
          //Power off
          digitalWrite (HUMIDITY_SENSOR_DIGITAL_PIN, LOW);
          digitalWrite (POWER_PIN, LOW);
          pinMode (HUMIDITY_SENSOR_DIGITAL_PIN, INPUT);
          pinMode (POWER_PIN, INPUT);
        Hope it helps !
        David.
        ar91
        @carlierd Are you running your Atmega at 1Mhz, Because I tried to use your sketch and i am getting "Checksum Error".
        carlierdC 1 Reply Last reply
        • rsachocR
          rsachocR
          rsachoc
          wrote on last edited by rsachoc
          #26
          @GertSanders indeed they are capacitors (silly me) - apparently they are 0.1uf - the black one I have already soldered is 4.7uf
          • A ar91
            carlierdC
            carlierdC
            carlierd
            No, I am working at 8 MHz (internal). Perhaps your DHT is out of order ? You try with another one ?
            David.
            • rsachocR
              rsachocR
              rsachoc
              Bump, can anyone advise on how I got about finding out where I need to solder the resistors on? So far I've just soldered the 4.7uf capacitor, as can be seen from the pics. But I'm struggling to find out where I need to solder the other capacitor's I have (from the BOM).
              • rsachocR rsachoc
                m26872M
                m26872M
                m26872
                @rsachoc C1,C2,C3 are clearly marked at top layer silkscreen. You'll see them in the middle of the uC socket if you look at your 2nd picture in you last post above. C5 is visible next to the 4.7u cap, in the 3rd picture of my first post in this thread.
                • rsachocR rsachoc
                  Progress!
                  m26872M
                  m26872M
                  m26872
                  First picture in first post of this thread should be enough. Connect (+) to Vcc and (-) to Gnd.
                  • rsachocR
                    rsachocR
                    rsachoc
                    Thanks, apologies, I really should have looked at my board, I was searching for the answer in the main slim node thread and I think i was looking at older boards and couldn't for the life of me find where C3 is!
                    • rsachocR rsachoc
                      m26872M
                      m26872M
                      m26872
                      @rsachoc I'm sorry, I know I need to update those old pictures.
                      rsachocR 1 Reply Last reply
                      • m26872M m26872
                        rsachocR
                        rsachocR
                        rsachoc
                        @m26872 no problem, not your fault at all, mine for being a newbie. So much so that my first attempt resulted in me soldering the capacitor to the wrong hole, so I've had to abandon my first attempt. You live, you learn, next time I'll double check.
                        • rsachocR rsachoc
                          m26872M
                          m26872M
                          m26872
                          @rsachoc Yes. Double check polarity of the 4.7uF cap.
                          • rsachocR
                            rsachocR
                            rsachoc
                            Hi all, again.
                            I have now successfully built (I think) the slim node, but without the 7021 temp sensor. Because this is the most expensive part of the device and because I find desoldering a challenge, but mainly because I'm waiting for it to arrive from China, can I try and upload the bootloader and sketch without the sensor attached?
                            If so, I had a couple questions from reading through this thread and the slim node thread. Firstly, uploading the bootloader, can this be done with the FTDI adaptor or do I need to follow the bit described in the slim node thread and attempt it using AVR studio? Secondly, once that is done, is it just a matter of uploading the sketch provided above?
                            Also, I wanted to confirm a few things on attaching the si7021 temp sensor. From what I can see, SOA (SDA) on the si7021 goes to A4 and SCL goes to A5. Also, GND goes to GND on the board (rightmost set on pins bottom right when FTDI is at the top) and VIN goes to VCC (just next to GND on the board)?
                            Thanks in advance.
                            • rsachocR rsachoc
                              Hi all, again.
                              Thanks in advance.
                              m26872M
                              m26872M
                              m26872
                              wrote on last edited by m26872
                              #36
                              Yes, you should be able to get far without the sensor. Send something over MySensors net and view debug prints. Or make some simple sensor like a reed switch.
                              Yes, Avr Studio or Uno as ISP.
                              Yes, but if you don't connect a Si7021 I would go for some other simple test sketch to avoid any Si7021 library startup issues.
                              Yes.
                              • rsachocR
                                rsachocR
                                rsachoc
                                #37
                                Folks, a word of caution, for people that are attempting this for the first time, please burn the bootloader before you solder everything, as silly me, I built the entire thing (without the si7021) and now I'll need to bin it because the ATMega is soldered to the board and I've no way to load the bootloader soldered to the board!
                                Ah, the life of a newbie :grin:
                                I think what I'll do is once I've actually got a working board, I'll do a newbie writeup so that people don't make the same mistakes as me.
                                • mfalkviddM
                                  First Attempt In Learning :-) A writeup would be awesome.
                                  • rsachocR rsachoc
                                    m26872M
                                    m26872M
                                    m26872
                                    @rsachoc Why don't you just solder some wires to pins you need ? The "in cicuit serial programming" concept would let you do it with almost anything attached.
                                    • m26872M m26872
                                      rsachocR
                                      rsachocR
                                      rsachoc
                                      I might as well attempt that! I'm waiting for a breadboard, so I'll try and attempt it when that arrives.
                                      • rsachocR
                                        rsachocR
                                        rsachoc
                                        #41
                                        Some of my tips (noob alert) that I've gathered in my travels so far for this temp Slim node
                                        1. Burn the bootloader onto the ATMega328 first! (here is a guide for Arduino as ISP)
                                        2. Check the capacitor polarity before you solder it (the 4.7uF electrolytic capacitor, the others don't matter)
                                        3. I prefer using strips for the Atmega (see here) as you'll have more clearance for the capacitors which sit underneath (there is a caveat to this however, in that if you're not sure if you've got/burnt a bootloader onto the ATMega, using strips there is no going back, whereas with the chip socket, you can remove the ATMega). Update I think, for me anyway, if you're confident that the ATMega has been bootloaded successfully, I still prefer strips, however if you're unsure what you can do is use the socket and just sit it higher in it's position to get a decent clearance.
                                        4. The bill of materials (BOM) is here and also helps with figuring out which pieces go where
                                        5. Solder the capacitors, wires for Si7021 (with si7021 attached) and FTDI pins to the board first, then the strips + AtMega328p (see below), then the NRF last to the board. I found that the FTDI pins facing straight up were best for the box I was going to put it in
                                        6. Solder the strips to the ATMega first, then to the board
                                        7. Check the size of the box/fitting you are going to mount this in before you do all the above!
                                        8. Check that you are putting the ATMega chip the right way on the board, the notch should be facing the pins for the FTDI.
                                        9. Check continuity of the pins from the ATMega to the board pins underneath, I found the ATMega to strips were the most difficult to solder, and after I tested continuity I found a single pin which didn't have connection, so I added some more solder to this pin.
                                        10. Don't forget the resistor at R1 (I soldered this to the underside of the board, less by choice and more by the fact that I forgot about it, but I guess the preference would be the same side as the capacitors)
                                        11. I strongly advise buying the 3.3v ready si7021 temp sensor (here) as the modification to the 5v version is quite difficult for a newbie (the components are quite small) and you'll probably mess it up like I did.
                                        General soldering tips
                                        12) Practice soldering first, some of the joins are a little challenging and it took me a few attempts to get the hang of it
                                        13) Get a decent size tip, my first was a bit large
                                        • rsachocR rsachoc
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          @rsachoc As a great man once said: "most bananas grow bent, and yet everyone loves them. There is nothing strange about the diversity of routes to success"
