  3. Slim Node Si7021 sensor example
137 Posts 18 Posters 98.4k Views 20 Watching
  • carlierdC carlierd
    @ar91 Hello. I am using the arduino playground lib. No issue with it ! I can post a sketch if necessary.
    David.
    ar91
    @carlierd If you could share your code that will be great.
    carlierdC 1 Reply Last reply
    • A ar91
      carlierdC
      carlierdC
      carlierd
      @ar91 Please find the code I used in 3 different nodes. The good thing with the playground lib is that there is error message if dialog with DHT22 failed.
      /* Temperature, humidity and luminosity measurements.                                 */
      /* Version     : 1.1.6        */
      /* Date        : 10/01/2016                                                           */
      /* Modified by : David Carlier                                                        */
      /*                            RST |             |  A5                                 */
      /*                            RX  |             |  A4                                 */
      /*                            TX  |   ARDUINO   |  A3                                 */
      /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
      /*            DHT22 --------- D3  |             |  A1                                 */
      /*            Power --------- D4  | ATMEGA 328p |  A0 --------- Light dep. resistor   */
      /*              +3v --------- VCC |             | GND --------- GND                   */
      /*              GND --------- GND |  8MHz int.  | REF                                 */
      /*                            OSC |             | VCC --------- +3v                   */
      /*                            OSC |             | D13 --------- RFM69 (SCK)           */
      /*                            D5  |             | D12 --------- RFM69 (MISO)          */
      /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
      /*                            D7  |             | D10 --------- RFM69 (NSS)           */
      /*                            D8  |             |  D9                                 */
      /* Power = Vcc for LDR.                                                               */
      /* +3v = 2*AA        */
      #include <dht.h>
      #include <MyTransportRFM69.h>
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      #define CHILD_ID_LIGHT 2
      #define CHILD_ID_VOLTAGE 3
      #define POWER_PIN 4
      //unsigned long SLEEP_TIME = 850000; // Sleep time between reads (in milliseconds) (close to 15')
      unsigned long SLEEP_TIME = 275000; // Sleep time between reads (in milliseconds) (close to 5')
      //Construct MySensors library
      MySigningAtsha204Soft signer;
      MyHwATMega328 hw;
      MyTransportRFM69 transport;
      MySensor gw(transport, hw, signer);
      dht DHT;
      MyMessage msgLum(CHILD_ID_LIGHT, V_LEVEL);
      MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
      /* Initialization        */
        //Get time (for setup duration)
        #ifdef DEBUG
          unsigned long startTime = millis();
        //Start MySensors
        gw.begin();
        //Send the Sketch Version Information to the Gateway
        gw.sendSketchInfo("GHAS sensor", "1.1.5");
        //Register all sensors to gw (they will be created as child devices)
        gw.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
        //Delay for DHT22
        delay(1500);
        //Print setup debug
        #ifdef DEBUG
          int duration = millis() - startTime;
          Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
      /* Main loop        */
        //Get time (for a complete loop)
        #ifdef DEBUG
        //Power on
        powerOnPeripherals();
        //Get DHT22 data
        int dht22Result = DHT.read22(HUMIDITY_SENSOR_DIGITAL_PIN);
        switch (dht22Result)
          case DHTLIB_OK:
                      //Serial.println("OK,\t");
          case DHTLIB_ERROR_CHECKSUM:
                      #ifdef DEBUG
                        Serial.println("Checksum error,\t");
          case DHTLIB_ERROR_TIMEOUT:
                      #ifdef DEBUG
                        Serial.println("Time out error,\t");
          case DHTLIB_ERROR_CONNECT:
                      #ifdef DEBUG
                        Serial.println("Connect error,\t");
          case DHTLIB_ERROR_ACK_L:
                      #ifdef DEBUG
                        Serial.println("Ack Low error,\t");
          case DHTLIB_ERROR_ACK_H:
                      #ifdef DEBUG
                        Serial.println("Ack High error,\t");
          default:
                      #ifdef DEBUG
                        Serial.println("Unknown error,\t");
        //Get temperature and humidity
        float temperature = 0;
        float humidity = 0;
        if (dht22Result == DHTLIB_OK)
          temperature = DHT.temperature;
          humidity = DHT.humidity;
        //Get power before luminosity to use real voltage
        float realVoltage = getVoltage() / 100.0;
        int batteryPcnt = realVoltage * 100 / 3.0;
        if (batteryPcnt > 100) {batteryPcnt = 100;}
        int lux = computeIlluminance(realVoltage);
        //Power off
        powerOffPeripherals();
        //Send data to gateway
        gw.send(msgLum.set(lux));
        gw.send(msgVolt.set(realVoltage, 2));
        //Print debug
        #ifdef DEBUG
          Serial.print(temperature, 1);
          Serial.print(" degC");
          Serial.print("   ");
          Serial.print(humidity, 1);
          Serial.print(" %");
          Serial.print("   ");
          Serial.print(lux);
          Serial.print(" lx");
          Serial.print("   ");
          Serial.print(realVoltage);
          Serial.print(" v");
          Serial.print("   ");
          Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
          Serial.flush();
        //Sleep
        gw.sleep(SLEEP_TIME);
      /* Allows to compute illuminance (in LUX) from LIGHT_SENSOR_ANALOG_PIN.               */
      int computeIlluminance(float realVoltage)
        //Get luminosity
        int luminosity = analogRead(LIGHT_SENSOR_ANALOG_PIN);
        //Calculating the voltage in the input of the ADC
        double voltage = realVoltage * ((double)luminosity / 1024.0);
        //Calculating the resistance of the photoresistor in the voltage divider
        double resistance = (10.0 * realVoltage) / voltage - 10.0;
        //Calculating the intensity of light in lux and return it
        int illuminance = 255.84 * pow(resistance, -10/9);
        return illuminance;
      /* Allows to get the real Vcc (return value * 100).                                   */
      int getVoltage()
        const long InternalReferenceVoltage = 1056L;
        ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
        delay(50);  // Let mux settle a little to get a more stable A/D conversion
        //Start a conversion
        ADCSRA |= _BV( ADSC );
        //Wait for it to complete
        while (((ADCSRA & (1<<ADSC)) != 0));
        //Scale the value
        int result = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L;
        return result;
      /* Allows to power ON peripherals.                                                    */
      void powerOnPeripherals()
        //Power-up
        pinMode (POWER_PIN, OUTPUT);
        digitalWrite (POWER_PIN, HIGH);
        delay(1);
      /* Allows to power OFF peripherals.                                                   */
      void powerOffPeripherals()
        //Power off
        digitalWrite (HUMIDITY_SENSOR_DIGITAL_PIN, LOW);
        digitalWrite (POWER_PIN, LOW);
        pinMode (HUMIDITY_SENSOR_DIGITAL_PIN, INPUT);
        pinMode (POWER_PIN, INPUT);
      Hope it helps !
      David.
      A siodS 3 Replies Last reply
        /*                            RST |             |  A5                                 */
        /*                            RX  |             |  A4                                 */
        /*                            D8  |             |  D9                                 */
        /* +3v = 2*AA        */
        #include <dht.h>
        #define POWER_PIN 4
        MyHwATMega328 hw;
        dht DHT;
          #ifdef DEBUG
          //Start MySensors
          gw.begin();
          //Delay for DHT22
          delay(1500);
          //Print setup debug
          #ifdef DEBUG
        /* Main loop        */
          #ifdef DEBUG
          //Power on
          //Get DHT22 data
            case DHTLIB_OK:
                        #ifdef DEBUG
                        #ifdef DEBUG
                        #ifdef DEBUG
                        #ifdef DEBUG
                        #ifdef DEBUG
            default:
                        #ifdef DEBUG
          float humidity = 0;
          //Power off
          //Print debug
          #ifdef DEBUG
            Serial.print("   ");
            Serial.print(" %");
            Serial.print("   ");
            Serial.print(lux);
            Serial.print("   ");
            Serial.print(" v");
            Serial.print("   ");
            Serial.flush();
          //Sleep
          //Get luminosity
          return illuminance;
        int getVoltage()
          //Scale the value
          return result;
          //Power-up
          delay(1);
          //Power off
        Hope it helps !
        David.
        ar91
        @carlierd Thank you very much. I really like your comment on the top :+1:
        • rsachocR
          rsachocR
          rsachoc
          Progress!
          http://imgur.com/zRvXvrN
          http://imgur.com/KpB7daz
          A question though. To get to this point, I copied the pictures posted above, but where do I now add these resistors?
          http://imgur.com/6mKJcgE
          Also, if I want to add a 2AA battery cage, where do I connect the red and black wires to?
          Thanks! And sorry for the newb questions!
          m26872M 1 Reply Last reply
          • GertSandersG
            GertSandersG
            GertSanders
            @rsachoc What you show are not resistors, they look like capacitors. 104 means 100nF (I think). Can you measure their value ?
              /*                            RST |             |  A5                                 */
              /*                            RX  |             |  A4                                 */
              /*                            D8  |             |  D9                                 */
              /* +3v = 2*AA        */
              #include <dht.h>
              #define POWER_PIN 4
              MyHwATMega328 hw;
              dht DHT;
                #ifdef DEBUG
                //Start MySensors
                gw.begin();
                //Delay for DHT22
                delay(1500);
                //Print setup debug
                #ifdef DEBUG
              /* Main loop        */
                #ifdef DEBUG
                //Power on
                //Get DHT22 data
                  case DHTLIB_OK:
                              #ifdef DEBUG
                              #ifdef DEBUG
                              #ifdef DEBUG
                              #ifdef DEBUG
                              #ifdef DEBUG
                  default:
                              #ifdef DEBUG
                float humidity = 0;
                //Power off
                //Print debug
                #ifdef DEBUG
                  Serial.print("   ");
                  Serial.print(" %");
                  Serial.print("   ");
                  Serial.print(lux);
                  Serial.print("   ");
                  Serial.print(" v");
                  Serial.print("   ");
                  Serial.flush();
                //Sleep
                //Get luminosity
                return illuminance;
              int getVoltage()
                //Scale the value
                return result;
                //Power-up
                delay(1);
                //Power off
              Hope it helps !
              David.
              ar91
              @carlierd Are you running your Atmega at 1Mhz, Because I tried to use your sketch and i am getting "Checksum Error".
              • rsachocR
                rsachocR
                rsachoc
                wrote on last edited by rsachoc
                #26
                @GertSanders indeed they are capacitors (silly me) - apparently they are 0.1uf - the black one I have already soldered is 4.7uf
                • A ar91
                  carlierdC
                  carlierdC
                  carlierd
                  No, I am working at 8 MHz (internal). Perhaps your DHT is out of order ? You try with another one ?
                  David.
                  • rsachocR
                    rsachocR
                    rsachoc
                    Bump, can anyone advise on how I got about finding out where I need to solder the resistors on? So far I've just soldered the 4.7uf capacitor, as can be seen from the pics. But I'm struggling to find out where I need to solder the other capacitor's I have (from the BOM).
                    • rsachocR rsachoc
                      m26872M
                      m26872M
                      m26872
                      @rsachoc C1,C2,C3 are clearly marked at top layer silkscreen. You'll see them in the middle of the uC socket if you look at your 2nd picture in you last post above. C5 is visible next to the 4.7u cap, in the 3rd picture of my first post in this thread.
                      • rsachocR rsachoc
                        Progress!
                        m26872M
                        m26872M
                        m26872
                        First picture in first post of this thread should be enough. Connect (+) to Vcc and (-) to Gnd.
                        • rsachocR
                          rsachocR
                          rsachoc
                          Thanks, apologies, I really should have looked at my board, I was searching for the answer in the main slim node thread and I think i was looking at older boards and couldn't for the life of me find where C3 is!
                          • rsachocR rsachoc
                            m26872M
                            m26872M
                            m26872
                            @rsachoc I'm sorry, I know I need to update those old pictures.
                            rsachocR 1 Reply Last reply
                            • m26872M m26872
                              rsachocR
                              rsachocR
                              rsachoc
                              @m26872 no problem, not your fault at all, mine for being a newbie. So much so that my first attempt resulted in me soldering the capacitor to the wrong hole, so I've had to abandon my first attempt. You live, you learn, next time I'll double check.
                              • rsachocR rsachoc
                                m26872M
                                m26872M
                                m26872
                                @rsachoc Yes. Double check polarity of the 4.7uF cap.
                                • rsachocR
                                  rsachocR
                                  rsachoc
                                  Hi all, again.
                                  I have now successfully built (I think) the slim node, but without the 7021 temp sensor. Because this is the most expensive part of the device and because I find desoldering a challenge, but mainly because I'm waiting for it to arrive from China, can I try and upload the bootloader and sketch without the sensor attached?
                                  If so, I had a couple questions from reading through this thread and the slim node thread. Firstly, uploading the bootloader, can this be done with the FTDI adaptor or do I need to follow the bit described in the slim node thread and attempt it using AVR studio? Secondly, once that is done, is it just a matter of uploading the sketch provided above?
                                  Also, I wanted to confirm a few things on attaching the si7021 temp sensor. From what I can see, SOA (SDA) on the si7021 goes to A4 and SCL goes to A5. Also, GND goes to GND on the board (rightmost set on pins bottom right when FTDI is at the top) and VIN goes to VCC (just next to GND on the board)?
                                  Thanks in advance.
                                  • rsachocR rsachoc
                                    Hi all, again.
                                    Thanks in advance.
                                    m26872M
                                    m26872M
                                    m26872
                                    wrote on last edited by m26872
                                    #36
                                    Yes, you should be able to get far without the sensor. Send something over MySensors net and view debug prints. Or make some simple sensor like a reed switch.
                                    Yes, Avr Studio or Uno as ISP.
                                    Yes, but if you don't connect a Si7021 I would go for some other simple test sketch to avoid any Si7021 library startup issues.
                                    Yes.
                                    • rsachocR
                                      rsachocR
                                      rsachoc
                                      #37
                                      Folks, a word of caution, for people that are attempting this for the first time, please burn the bootloader before you solder everything, as silly me, I built the entire thing (without the si7021) and now I'll need to bin it because the ATMega is soldered to the board and I've no way to load the bootloader soldered to the board!
                                      Ah, the life of a newbie :grin:
                                      I think what I'll do is once I've actually got a working board, I'll do a newbie writeup so that people don't make the same mistakes as me.
                                      • mfalkviddM
                                        First Attempt In Learning :-) A writeup would be awesome.
                                        • rsachocR rsachoc
                                          m26872M
                                          m26872M
                                          m26872
                                          @rsachoc Why don't you just solder some wires to pins you need ? The "in cicuit serial programming" concept would let you do it with almost anything attached.
