  3. SI7021 boards
SI7021 boards
22 Posts 9 Posters 10.7k Views 11 Watching
  • G
    G
    gloob
    It`s a mess that the pinout of both modules is different.
    • GertSandersG
      GertSandersG
      GertSanders
      @Carl-H it's a possibility. No plans yet, other projects ongoing.
      • F
        F
        fleinze
        I just received some si7021 boards from china. They are with LDO and level shifter, similar to
        http://www.aliexpress.com/item/Si7021-Industrial-High-Precision-Humidity-Sensor-with-I2C-Interface-for-Arduino/32529522264.html
        (the original offer went offline, it was from a reseller named "home boutique", no idea why they sold this item)
        If I use them with a battery node, is it sufficient to remove (and short-cut) the LDO or do I need to remove the level shifter too?
        AWIA ? m26872M 3 Replies Last reply
        • F fleinze
          AWIA
          AWIA
          AWI
          @fleinze I would suggest to leave these as they are and measure the consumption. Removing the LDO didn't give me a noticeable difference. It could depend on the board however.
          • F fleinze
            A Former User
            @fleinze I am using ATmega328 with 1Mhz and with LDO i have 15uA in standby mode. I have removed the LDO and measured 8uA. You should try it yourself.
            • F fleinze
              m26872M
              m26872M
              m26872
              @fleinze I wrote a few words about it over here http://forum.mysensors.org/topic/3049/slim-node-si7021-sensor-example/
              • F
                F
                fleinze
                wrote on last edited by fleinze
                @m26872 @kenci @AWI Thank you very much for your answers!
                I will go for removing the LDO but letting the level-shifter in place, because it is a pain in the ass to bypass the levelshifter.
                Bypassing the desoldered LDO is very easy. Just connect the following point on the resistor-array:
                AWIA 1 Reply Last reply
                • F fleinze
                  AWIA
                  AWIA
                  AWI
                  @fleinze The 662k on this board has a typical drop-out of 250mV and power consumption of only 1uA... and takes care of a stable power supply. I doubt if there is any advantage in bridging or removing the LDO.
                  662k
                  0_1456149818998_upload-5b22a252-988a-4acd-b4d8-15be0500a58c
                  si7021
                  0_1456149758981_upload-6a1d2eb3-c0c8-4556-a701-7d2e5db8608c
                  • AWIA AWI
                    662k
                    si7021
                    GertSandersG
                    GertSandersG
                    GertSanders
                    @AWI What happens when the input voltage drops below 3.1V ? It seems the output voltage just follows the input voltage minus the dropout. I have not measured this yet, but I'm assuming this, since i have nodes working below 3.1V and sending temperature and humidity readings.
                    • GertSandersG GertSanders
                      AWIA
                      AWIA
                      AWI
                      wrote on last edited by AWI
                      #22
                      @GertSanders No conclusive reading from the datasheet. I will do some measurements later. ..
                      0_1456219785462_upload-af85eb98-f577-4011-96e9-ef35b5ef97bb
