  3. SI7021 boards
SI7021 boards
22 Posts 9 Posters 10.7k Views 11 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    @m26872 I found both SI7021 on Aliexpress.com
    m26872M 1 Reply Last reply
    • GertSandersG GertSanders
      m26872M
      m26872M
      m26872
      @GertSanders Link?
      AWIA 1 Reply Last reply
      • E
        E
        emc2
        Not SI7021 directly, but there are a lot of small sized I2C sensors.
        I use a BME280 board on my gateway and on a node.
        I also use a BH1750 (slightly bigger) outside to track plants sun exposure.
        If you end up with a design where the I2C bus is included I can definitively see a lot of uses for it!
        • AWIA
          AWIA
          AWI
          wrote on last edited by AWI
          Another off-topic.. I use these bmp180 boards to power the low power nodes from a 4.1 volt rechargeable Li cell. The LDO is broken out on the connection
          • m26872M m26872
            @GertSanders Link?
            AWIA
            AWIA
            AWI
            @m26872 Industrial High Precision Si7021 Humidity Sensor Module With I2C Interface link
            • GertSandersG
              GertSandersG
              GertSanders
              Without LDO, but with pull up resistors (smallest board I could find):
              http://www.aliexpress.com/item/Industrial-High-Precision-Si7021-Humidity-Sensor-with-I2C-Interface-for-Arduino/32524005324.html
              With LDO:
              http://www.aliexpress.com/item/Si7021-Industrial-High-Precision-Humidity-Sensor-with-I2C-Interface-for-Arduino/32529522264.html
                With LDO:
                m26872M
                m26872M
                m26872
                @GertSanders and @AWI Thanks!
                • Carl HC
                  Carl HC
                  Carl H
                  Your plan is it to change your narrow board with SDL/SDA pad. maybe a jumper to change D2/D3 pin to SDL/SDA?
                  • G
                    G
                    gloob
                    It`s a mess that the pinout of both modules is different.
                    • GertSandersG
                      GertSandersG
                      GertSanders
                      @Carl-H it's a possibility. No plans yet, other projects ongoing.
                      • F
                        F
                        fleinze
                        I just received some si7021 boards from china. They are with LDO and level shifter, similar to
                        (the original offer went offline, it was from a reseller named "home boutique", no idea why they sold this item)
                        If I use them with a battery node, is it sufficient to remove (and short-cut) the LDO or do I need to remove the level shifter too?
                        AWIA ? m26872M 3 Replies Last reply
                        • F fleinze
                          AWIA
                          AWIA
                          AWI
                          @fleinze I would suggest to leave these as they are and measure the consumption. Removing the LDO didn't give me a noticeable difference. It could depend on the board however.
                          • F fleinze
                            A Former User
                            @fleinze I am using ATmega328 with 1Mhz and with LDO i have 15uA in standby mode. I have removed the LDO and measured 8uA. You should try it yourself.
                            • F fleinze
                              m26872M
                              m26872M
                              m26872
                              @fleinze I wrote a few words about it over here http://forum.mysensors.org/topic/3049/slim-node-si7021-sensor-example/
                              • F
                                F
                                fleinze
                                wrote on last edited by fleinze
                                @m26872 @kenci @AWI Thank you very much for your answers!
                                I will go for removing the LDO but letting the level-shifter in place, because it is a pain in the ass to bypass the levelshifter.
                                Bypassing the desoldered LDO is very easy. Just connect the following point on the resistor-array:
                                • F fleinze
                                  AWIA
                                  AWIA
                                  AWI
                                  @fleinze The 662k on this board has a typical drop-out of 250mV and power consumption of only 1uA... and takes care of a stable power supply. I doubt if there is any advantage in bridging or removing the LDO.
                                  662k
                                  0_1456149818998_upload-5b22a252-988a-4acd-b4d8-15be0500a58c
                                  si7021
                                  0_1456149758981_upload-6a1d2eb3-c0c8-4556-a701-7d2e5db8608c
                                  • AWIA AWI
                                    662k
                                    si7021
                                    GertSandersG
                                    GertSandersG
                                    GertSanders
                                    @AWI What happens when the input voltage drops below 3.1V ? It seems the output voltage just follows the input voltage minus the dropout. I have not measured this yet, but I'm assuming this, since i have nodes working below 3.1V and sending temperature and humidity readings.
                                      AWIA
                                      AWIA
                                      AWI
                                      #22
                                      @GertSanders No conclusive reading from the datasheet. I will do some measurements later. ..
                                      0_1456219785462_upload-af85eb98-f577-4011-96e9-ef35b5ef97bb
