  3. SI7021 boards
SI7021 boards
22 Posts 9 Posters 10.7k Views 11 Watching
  • GertSandersG GertSanders
    Without LDO, but with pull up resistors (smallest board I could find):
    http://www.aliexpress.com/item/Industrial-High-Precision-Si7021-Humidity-Sensor-with-I2C-Interface-for-Arduino/32524005324.html
    With LDO:
    http://www.aliexpress.com/item/Si7021-Industrial-High-Precision-Humidity-Sensor-with-I2C-Interface-for-Arduino/32529522264.html
    m26872M
    m26872M
    m26872
    @GertSanders and @AWI Thanks!
    • Carl HC
      Carl HC
      Carl H
      Your plan is it to change your narrow board with SDL/SDA pad. maybe a jumper to change D2/D3 pin to SDL/SDA?
      • G
        G
        gloob
        It`s a mess that the pinout of both modules is different.
        • GertSandersG
          GertSandersG
          GertSanders
          @Carl-H it's a possibility. No plans yet, other projects ongoing.
          • F
            F
            fleinze
            I just received some si7021 boards from china. They are with LDO and level shifter, similar to
            (the original offer went offline, it was from a reseller named "home boutique", no idea why they sold this item)
            If I use them with a battery node, is it sufficient to remove (and short-cut) the LDO or do I need to remove the level shifter too?
            AWIA ? m26872M 3 Replies Last reply
            • F fleinze
              AWIA
              AWIA
              AWI
              @fleinze I would suggest to leave these as they are and measure the consumption. Removing the LDO didn't give me a noticeable difference. It could depend on the board however.
              • F fleinze
                A Former User
                @fleinze I am using ATmega328 with 1Mhz and with LDO i have 15uA in standby mode. I have removed the LDO and measured 8uA. You should try it yourself.
                • F fleinze
                  m26872M
                  m26872M
                  m26872
                  @fleinze I wrote a few words about it over here http://forum.mysensors.org/topic/3049/slim-node-si7021-sensor-example/
                  • F
                    F
                    fleinze
                    wrote on last edited by fleinze
                    @m26872 @kenci @AWI Thank you very much for your answers!
                    I will go for removing the LDO but letting the level-shifter in place, because it is a pain in the ass to bypass the levelshifter.
                    Bypassing the desoldered LDO is very easy. Just connect the following point on the resistor-array:
                    AWIA 1 Reply Last reply
                    • F fleinze
                      AWIA
                      AWIA
                      AWI
                      @fleinze The 662k on this board has a typical drop-out of 250mV and power consumption of only 1uA... and takes care of a stable power supply. I doubt if there is any advantage in bridging or removing the LDO.
                      662k
                      0_1456149818998_upload-5b22a252-988a-4acd-b4d8-15be0500a58c
                      si7021
                      0_1456149758981_upload-6a1d2eb3-c0c8-4556-a701-7d2e5db8608c
                      • AWIA AWI
                        662k
                        si7021
                        GertSandersG
                        GertSandersG
                        GertSanders
                        @AWI What happens when the input voltage drops below 3.1V ? It seems the output voltage just follows the input voltage minus the dropout. I have not measured this yet, but I'm assuming this, since i have nodes working below 3.1V and sending temperature and humidity readings.
                          AWIA
                          AWIA
                          AWI
                          wrote on last edited by AWI
                          #22
                          @GertSanders No conclusive reading from the datasheet. I will do some measurements later. ..
                          0_1456219785462_upload-af85eb98-f577-4011-96e9-ef35b5ef97bb
