  3. Getting "ver mismatch"
9 Posts 4 Posters 3.9k Views 4 Watching
  • J Offline
    J Offline
    jocke4u
    I noticed that I am getting a lot of "ver mismatch"
    0;0;3;0;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
    0;0;3;0;9;ver mismatch
    0;0;3;0;9;read: 0-1-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
    ...etc
    The ethernet gateway is running Lib Ver 1.5 and sensors 1.4; is that the reason?
    How should I solve this?
    • H Offline
      H Offline
      Yes, upgrade.
      • S Offline
        shabba
        Out of interest - do differing versions work? Ie is "ver mismatch" a warning or an error?
        • H Offline
          H Offline
          It's an error. Messages with the wrong version will not be processed. But it's is only updated when the over-the-air format has been changed.
          • S Offline
            shabba
            Thanks @hek. Is there a way to tell from the version when the OTA format changes from versions? ie do you bump the major version etc? I have some sensors buried away so need to be cautious of using later versions.
            • H Offline
              H Offline
              Yes you can look in the following file:
              https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyMessage.h#L39
              We try to keep the OTA updates to a minimum (because of the problems you describe). I don't even think we need to bump this when going to 2.0.
              • mfalkviddM Offline
                Any by OTA updates you mean over the air protocol updates, not over the air firmware updates, right? ;-)
                • S Offline
                  shabba
                  Yes - the serial protocol.
                  • H Offline
                    H Offline
                    Mo ha ha... I will take over ALL your sensors. :)
                    12.2k
