  3. NRF24L01+ range of only few meters
81 Posts 21 Posters 53.5k Views 25 Watching
  • petewillP petewill
    @epierre my notes are in inches so forgive me not converting it here. My thinking was to make a full wavelength antenna using the existing pcb antenna. A full wavelength antenna for 2.4GHz is 4.92 in. I measured the existing pcb antenna on the nRF and it was 1.64 in. So, 4.92 - 1.64 = 3.28 in. (or 8.3312 cm). I'm not claiming to be an expert at all (an other people have said this shouldn't work) but it has worked well for me so I keep doing it. :) Others have reported success too so hopefully it will help you.
    (thanks for your help @mfalkvidd)
    @nunver Have you changed the PA level to MAX in myconfig.h?
    N
    N
    nunver
    @petewill Yes, I did increase PA level to Max. I don't understand how I could change the payload size, though. Mysensors have a certain format.
    • Igor KatkovI Igor Katkov
      It appears that I was quite foolish expecting FTDI adapter board to power my nrf24 :-(
      datasheet says it can provide at most 50mA.
      I'll try 2AA batteries and a step up regulator
      AWIA
      AWIA
      AWI
      @Igor-Katkov powering the radio from a switching regulator is no guarantee for radio performance. Most of these (small) regulators have a high voltage ripple around their switching frequency.
      You have no need for it either... The radio should work perfectly when powered by two cells.
      N 1 Reply Last reply
      • AWIA AWI
        N
        N
        nunver
        @AWI It does not sound right to me having to use battery power where there is AC. There should be a way to get clean enough power for these little devices?
        AWIA 1 Reply Last reply
        • N nunver
          AWIA
          AWIA
          AWI
          @nunver sure, use a standard regulated power supply (phone charger) of 5v for the Arduino and make sure the radio gets a stable supply from a regulator. What always works is using one of those nrf24 adapter plates (look in the shop) for a stable radio.
          • Igor KatkovI
            Igor KatkovI
            Igor Katkov
            I was/am trying to make a battery powered wireless sensor so there would be no AC if I can avoid it.
            I intended to use the step up regulator to 3v3 to extend sensor life on a pair of AA batteries. I think voltage would drop fairly quickly below nrf24 lower limit.
              Don't count on that ftdi chip being genuine for only a few $$. I doubt if that data sheet applies to your unit...
                AWIA
                AWIA
                AWI
                wrote on last edited by AWI
                #36
                @Igor-Katkov Your AA batteries will be as good as dead before these drop below the nrf24 minimum voltage (1.9V). See below the graph for one cell. If the arduino survives depends on hardware/ fuse-settings.
                0_1455694674730_upload-9c67f65a-394a-4e60-a5fb-e25d0d8d2ba3
                • Igor KatkovI
                  Igor KatkovI
                  Igor Katkov
                  wrote on last edited by Igor Katkov
                  #37
                  OK, so I tried with AA cells, no regulators.
                  Plain and simple. TMRh20 lib.
                  Not any better.
                  I then tried with a chunk of bare copper wire 83mm long, soldered to the end of that curly PCB antenna - not any better either.
                  Not sure what might I've done wrong. Layout is pretty simple
                  image of nrf24 transmitter
                  Voltage with load is 3.1V, current never goes above 19.2mA
                  image of multimeter
                  I tried with direct line of sight, range has doubled to say 20m, but again - nothing to write home about.
                  • Igor KatkovI
                    Igor KatkovI
                    Igor Katkov
                    [Update for future generation]
                    I think I found my issue. It was the large transceiver see image below, with power amplifier and external antenna.
                    Once I replaced both receiver and transmitter with identical units, range got significantly better.
                    60m clear sight and almost whole house through multiple walls.
                    For whatever reason small unit can't hear ACK from the PA unit. I tried to reduce power on the PA end to
                     radio.setPALevel(RF24_PA_MIN);
                    but it did not seem to have any effect. My best guess now is that oscillator on the PA unit is slightly off. PCB antenna unit is battery powered.
                    Power source to arduino UNO that drives PA unit is good, 5V less that 2mV ripple. The transceiver is powered via 3V3 output (onboard regulator) of UNO though, could it be the problem?
                    petewillP 1 Reply Last reply
                    • OitzuO
                      OitzuO
                      Oitzu
                      Yes. But depends on which onboard regulator is used on your UNO.
                      Also have an look here: http://forum.mysensors.org/topic/3168/long-range-transmission/27
                        petewillP
                        petewillP
                        petewill
                        I have had issues with my NRF radio like the one you mention here. I'm not sure about range issues but it totally stopped my Z-Wave network from communicating. It was easier for me to just use one of the smaller radios instead of doing further troubleshooting. I know there are some other threads (that I can't think of off the top of my head) where users have found that shielding it has helped. Also, as @Oitzu said, try powering it from a separate 3.3v source instead of from the Uno.
                        • OitzuO
                          OitzuO
                          Oitzu
                          @petewill about shielding: you should have looked on the link http://blog.blackoise.de/2016/02/fixing-your-cheap-nrf24l01-palna-module/ . I explained it that often that i decided to write a blog article about it. :P
                          • OitzuO Oitzu
                            petewillP
                            petewillP
                            petewill
                            @Oitzu Awesome! I have one of these sitting in a drawer because of all the issues it caused me. :) I may need to pull it out and try your method one of these days. For now I have been getting by with the external hack but I'm sure I'll want further range at some point...
                            • OitzuO
                              OitzuO
                              Oitzu
                              @petewill great to hear. Let me know if you are successful. :)
                              • pkjjnealP
                                pkjjnealP
                                pkjjneal
                                This is great info. I actually had great luck with the chip antenna version with a mini pro and an UNO, and the range I wanted was just not there. I moved to the one with the PA+ ext antenna, and having a strange issue. If I swap out the chip antenna version for the PA+ ext antenna version on the mini pro, it only sends packets if I am physically touching the nRF board itself with my finger. The one connected to the UNO does not have this issue. It seems to be grounded sufficiently (only the GND pin on the nRF connector), and I changed the power source from the FTDI module to a separate 3.4V source with no difference in this behavior. Any ideas?
                                OitzuO 1 Reply Last reply
                                • pkjjnealP pkjjneal
                                  OitzuO
                                  OitzuO
                                  Oitzu
                                  Also read: http://blog.blackoise.de/2016/02/fixing-your-cheap-nrf24l01-palna-module/
                                  Its a typical behaviour i observed on badly shielded modules.
                                  pkjjnealP 1 Reply Last reply
                                  • G
                                    G
                                    gmccarthy
                                    I'm also getting poor range (Around 5m) and have tried most of the tricks. One thing with the homemade antenna from the video, which direction should the antenna be pointing?
                                    • Igor KatkovI
                                      Igor KatkovI
                                      Igor Katkov
                                      Typically you point it up. It gives you vertical polarization.
                                      You point both transmitter and received wire antennas same directions.
                                      It's possible that your chips are at fault, if non of other tricks worked (capacitors, clear power, enough current, short wires, lo-noise rf spectrum channel) try other transceivers.
                                      G 1 Reply Last reply
                                      • OitzuO Oitzu
                                        pkjjnealP
                                        pkjjnealP
                                        pkjjneal
                                        @Oitzu So I covered the nRF module in plastic and foil to create the shield. Previously, I had to touch a specific part of the board. Now I just touch any part of the foil, and it starts working. Makes sense, but I still cannot get transmissions without touching with my finger. I did try grounding the foil to the Arduino ground, but no change. The behavior makes me think I am on the correct path. Any other suggestions?
                                        • OitzuO
                                          OitzuO
                                          Oitzu
                                          @pkjjneal would try to let the foil touch the ground from the antenna socket.
                                          Grounding the foil on the arduino probably creates a ground loop.
                                          May also try to add a filter.
                                          Igor KatkovI 1 Reply Last reply
