  3. Easy/Newbie PCB for MySensors
257 Posts 37 Posters 177.2k Views 38 Watching
  • sundberg84S
    sundberg84S
    Hi!
    Just wanted to comfirm that REV. 7 with the MysX connector works great so I have removed the Rev6 option from first post.
    Offcourse i allready have some ideas for Rev 8... but ill do that later.
    In the meantime please enjoy the rev. history (aka learning curve) :)
    • ErrKE
      ErrKE
      ErrK
      This is what i have been looking for. Nice work @sundberg84 .
      Where is the best site to order this from?
      • sundberg84S
        sundberg84S
        Thank you.
        There are many different, Im using Itead.
        • ErrKE
          ErrKE
          ErrK
          Thanks, then i will look in to it.
          • N
            N
            nunver
            @sundberg84 Really nice work.
            • D
              Dylano
              I ordered the latest version...
              What is the battery life?
              Domoticz, with a lot of working hardware, include mysensors :-)
              OpenPLI, RuneAudio, Solarmeter, etc......
              Not a great builder of software and hardware, more a user...
              Only i try to do my best :-(
              • sundberg84S
                sundberg84S
                @Dylano Depending on what sensor you wish to run and how frequent you want to get data!
                One example: DHT22, sleeping 15min and sending Temp/Hum with a china/ebay booster is about a year.
                D 1 Reply Last reply
                • sundberg84S sundberg84
                  Dylano
                  @sundberg84
                  Ok thanks for fast response..
                  I think i am going to build my whole house with your board, incl Domoticz, i got the best Home automation house of the world :-)
                  Give it a try, i hope i have ordered the good stuff, and i hope i get the boards..
                  Is there a latest or best working sketch, include the batterysave option from mysensors, you use?
                  • sundberg84S
                    sundberg84S
                    You use any sketch you want. The PCB is just a platform for the arduino and radio and sensor input.
                    Then you upload your code to the arduino as usual (see the getting started and build section for code examples.
                    To save battery use the sleep function, you find all info in the battery page.
                    Good luck!
                    • jlehtinenJ
                      jlehtinenJ
                      jlehtinen
                      I also chose your PCB as "a base" for my mysensor network expansion. :-) Ordered 10 boards via dirtypcb, now it's just the wait that kills me. :wink: Thanks for your effort sundberg84 on designing this PCB, appreciated. :thumbsup:
                      • sundberg84S
                        sundberg84S
                        @jlehtinen @Dylano - Thank you for the kind words. My reward is to see so many use it and it helps people out.
                        • D
                          dakipro
                          as said, excellent design, should come as an option in the store, so that people can just get started.
                          Is there maybe a revision or version where radio is 180 degrees rotated, so that it "covers" the pins on the left (radio antena is looking down)? That way we can have radio on the stands, and after we solder pins then we just plug inn the radio, that would reduce overall footprint while still having all other benefits? I might try to modify the PCB when I find time, but just trowing ideas in the air :)
                          • mfalkviddM
                            Having metal close to the radio antenna will likely mess up the reception. That's why the pcb is designed to have the antenna sticking out.
                            • sundberg84S
                              sundberg84S
                              @dakipro - as @mfalkvidd said, i have learnt that the hard way.
                              Feel free to change and modify the design, it might work in some cases but as generic/general pcb having the radio sticking out some has worked best.
                              • D
                                dakipro
                                ok, i was not considering that at all... I made few sensors in a "sandwich" of radio and pro mini and they worked fine (although they are pretty close to gateway now that I think about it), so it seamed like the logical choice to have radio in parallell with something else :)
                                But then I will not complicate my life and order package of the board, and ofcourse donate a few bucks to support hard work and your time! :+1:
                                  shabba
                                  I bought a pile of these too. Thanks @sundberg84 - Now for the RFM69 version ? :-)
                                  • sundberg84S
                                    sundberg84S
                                    #24
                                    @shabba - I dont use RFM69 but if you order and debug i can build it.
                                      shabba
                                      I ordered some. Just would need a pin layout and make sure only 3.3v to all pins.
                                      • N
                                        N
                                        nunver
                                        @sundberg84 I am ordering the PCB's of Ver.8 today. Again, really nice and helpful work for newbies like me. Just one newbie question, though. I understand that both Arduino and NRF are capable of operating down to about 2V. Why do we need the booster in battery operation. I plan to use only Dallas 18B20. Thanks.
                                        • sundberg84S
                                          sundberg84S
                                          @nunver Some sensors are not able to work down below 3.3v, and the im really skeptical if you can operate the arduino 3.3v down to 2v... mine dies when it reaches like 2.8V. Also, with a booster you can operate down to 0.9v - so i highly recommend it.
                                          AnticimexA N 2 Replies Last reply
