  3. [SOLVED] ESP8266 fails to boot with NRF24L01+ connected
14 Posts 6 Posters 12.3k Views 6 Watching
  • DaanozD
    DaanozD
    Daanoz
    wrote on last edited by Daanoz
    Got it solved!
    Ok, after debugging for a while: the problem is with the CSN pin on GPIO pin 15. Pin 15 is also used in the ESP8266 to define boot from SD card. Somehow, at least in my case, after a reset, the NRF chip sets the CSN pin to high (measured it with a multimeter), causing the ESP8266 to start the SD-card procedure, which fails of course. The solution for me is swapping the pins for inclusion with the CSN pin:
    So:
    CSN -> GPIO 5 -> D1
    Inclusion mode -> GPIO 15 -> D78
    One question though: I also seem to have SPI pins on the other side of the Devkit, why aren't those used?
      https://github.com/mysensors/Arduino/issues/408
      • DaanozD
        DaanozD
        Daanoz
        Ok, another small update from my side. I think I localized the root cause of what was putting my CSN in a high state.
        Last couple of days I was testing with a sensor connected with power through a FTDI adapter, the adapter had a nice switch to chose between 3.3v and 5v. The sensor was actually having a problem, this problem to be precise, the sensor fails after a couple of hours. At first I didn't think much about it, since the switch was on 3.3v. After having 2 NRF chips failing, I measured the output of the 3.3v pin on the arduino pro mini, you guessed it: 5V! :sob:
        The funny thing is, the first chip that failed, I used on the gateway to test if it was working, because it did work without a reset, I didn't think much about it. Now I know that the 5V Probaly fried something in the chip, causing to output high on the CSN in some cases...
        Attached a photo of the second chip that fried even more (the right one with the 2 black blobs below the chip). Anyway, thanks for the help folks, finally can start building something!
        right chip after 5v
        barduinoB 1 Reply Last reply
          Ok, thanks for the update on your issue.
          • DaanozD Daanoz
            right chip after 5v
            barduinoB
            barduinoB
            barduino
            @Daanoz,
            Inland FTDI?
            I have the same with one of those.
            • I
              I
              Ironbar
              I also had one that would not change from 5v to 3.3v. I don't remember which brand it was but it had a switch instead of a jumper. It took me a long time to figure out that it was the problem.
              • DaanozD
                DaanozD
                Daanoz
                It's not really a brand... It's this one: http://www.aliexpress.com/item/FT232RL-3-3V-5-5V-FTDI-USB-to-TTL-Serial-Adapter-Module-For-Arduino-TE321/32574619454.html
                • I
                  I
                  Ironbar
                  That's the one.
                  • YveauxY
                    The switch most likely has only to do with logic levels of the data lines. It is not related to the power output. Very confusing indeed (another Chinese fail if you ask me)
                    • barduinoB
                      barduinoB
                      barduino
                      I have this one, looks the same...
                      0_1457097851989_upload-506933d0-e884-43a3-868d-57bfdad86b69
