  3. [SOLVED] ESP8266 fails to boot with NRF24L01+ connected
14 Posts 6 Posters 12.3k Views 6 Watching
  • mfalkviddM
    Try setting your serial monitor to 76800 (Arduino IDE doesn't support that speed but Putty does). See the "Boot up" section on http://www.esp8266.com/wiki/doku.php?id=getting-started-with-the-esp8266
    • DaanozD
      DaanozD
      Daanoz
      Thanks, that already makes more sense:
       ets Jan  8 2013,rst cause:2, boot mode:(7,7)
      waiting for host
      From what I understand: 'rst cause: 2' means reset pin (or button?) being used, which I did.
      Boot mode (7, 7) is a bit more vague?
      • DaanozD
        DaanozD
        Daanoz
        Debugging futher...
        So if I understand correctly from the ESP8266 docs: boot mode 7, means boot from SPI FLASH (7 = 0111).
        I can disconnect 3 types of wires to get the boot procedure to run with: boot mode:(3,x)
        The boot flow changes if I disconnect either the VCC, GROUND or the CSN wire... But the boot is not always the same, I'll try to summarize:
        All pins of the NRF connected: boot mode:(7,7) - not booting
        Disconnect VCC pin, reset, reconnect after 1s: boot mode:(3,7) - booting, gateway working
        All pins connected: boot mode:(7,7) - not booting
        Disconnect CSN pin, reset, reconnect after 1s: boot mode:(3,7) - booting, gateway working
        So, this boot changes if I leave the pin disconnected for the full boot process (you'll get a radio init fail of course)
        Disconnect VCC pin: boot mode:(3,7) - booting, gateway not working
        Reconnect VCC pin before reset: boot mode: (7,6) - not booting
        Disconnect VCC pin: boot mode:(3,6) - booting, gateway not working
        So guessing on the bootmodes: if the first integer is a 7, there is an error with the boot sequence, the second integer seems to be related to the NRF, did it fully run last time -> a 7, if I keep it out for a full boot sequence (including running of the gateway) we get a 6. Strange......
        • DaanozD
          DaanozD
          Daanoz
          wrote on last edited by Daanoz
          Got it solved!
          Ok, after debugging for a while: the problem is with the CSN pin on GPIO pin 15. Pin 15 is also used in the ESP8266 to define boot from SD card. Somehow, at least in my case, after a reset, the NRF chip sets the CSN pin to high (measured it with a multimeter), causing the ESP8266 to start the SD-card procedure, which fails of course. The solution for me is swapping the pins for inclusion with the CSN pin:
          So:
          CSN -> GPIO 5 -> D1
          Inclusion mode -> GPIO 15 -> D78
          One question though: I also seem to have SPI pins on the other side of the Devkit, why aren't those used?
            https://github.com/mysensors/Arduino/issues/408
            • DaanozD
              DaanozD
              Daanoz
              Ok, another small update from my side. I think I localized the root cause of what was putting my CSN in a high state.
              Last couple of days I was testing with a sensor connected with power through a FTDI adapter, the adapter had a nice switch to chose between 3.3v and 5v. The sensor was actually having a problem, this problem to be precise, the sensor fails after a couple of hours. At first I didn't think much about it, since the switch was on 3.3v. After having 2 NRF chips failing, I measured the output of the 3.3v pin on the arduino pro mini, you guessed it: 5V! :sob:
              The funny thing is, the first chip that failed, I used on the gateway to test if it was working, because it did work without a reset, I didn't think much about it. Now I know that the 5V Probaly fried something in the chip, causing to output high on the CSN in some cases...
              Attached a photo of the second chip that fried even more (the right one with the 2 black blobs below the chip). Anyway, thanks for the help folks, finally can start building something!
              right chip after 5v
              barduinoB 1 Reply Last reply
                Ok, thanks for the update on your issue.
                • DaanozD Daanoz
                  right chip after 5v
                  barduinoB
                  barduinoB
                  barduino
                  @Daanoz,
                  Inland FTDI?
                  I have the same with one of those.
                  • I
                    I
                    Ironbar
                    I also had one that would not change from 5v to 3.3v. I don't remember which brand it was but it had a switch instead of a jumper. It took me a long time to figure out that it was the problem.
                    • DaanozD
                      DaanozD
                      Daanoz
                      It's not really a brand... It's this one: http://www.aliexpress.com/item/FT232RL-3-3V-5-5V-FTDI-USB-to-TTL-Serial-Adapter-Module-For-Arduino-TE321/32574619454.html
                      • I
                        I
                        Ironbar
                        That's the one.
                        • YveauxY
                          The switch most likely has only to do with logic levels of the data lines. It is not related to the power output. Very confusing indeed (another Chinese fail if you ask me)
                          • barduinoB
                            barduinoB
                            barduino
                            I have this one, looks the same...
                            0_1457097851989_upload-506933d0-e884-43a3-868d-57bfdad86b69
