  3. How To - Doorbell Automation Hack
106 Posts 29 Posters 128.8k Views 26 Watching
  • Moshe LivneM
    Moshe LivneM
    Moshe Livne
    Hello all - sorry I have been away for so long...
    This bring back memories http://forum.mysensors.org/topic/1620/mysensored-doorbell
    I wish I found a way of triggering the notification from the ring and not the other way around, as this way when something happen to your arduino the doorbell will not ring. Didn't happen yet - it works perfectly for 6 months but I would feel more relaxed if it was the other way around. Oh well...
    petewillP 1 Reply Last reply
    • Moshe LivneM Moshe Livne
      petewillP
      petewillP
      petewill
      @Moshe-Livne Cool! You can look at it the other way around on the Arduino processing the ring issue you raised. I now have the ability to turn off the ring if I want to. So I guess there is some give and take :)
      • petewillP petewill
        Moshe LivneM
        Moshe LivneM
        Moshe Livne
        @petewill ummmm you could still cut the ring even if it was the other way around with a relay. Sorry to be a pain :-) can't fight my mold hehehe. generally I find the reliability of dorrbells (especially the old wired kind) to be excellent. mine has been working flawlessly for at least 35 years.
          petewillP
          petewillP
          petewill
          @Moshe-Livne Ok, I must have misunderstood. I thought you wanted the bell to ring no matter what then just detect the signal so you could send it to your gateway. Either way, that's why MySensors is so great, you can do pretty much what ever YOU want, not what someone else wants :)
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @petewill My original plan was to unintrusively detect the ring and trigger the arduino without effecting the bell circuit. However, it proved to be a bit more complicated and 2 dead arduinos and several other fried components later I gave up.
              mike0913
              I am new to home automation but curious if this same setup would work by having the arduino centrally located with the transformer in a closet and use the extra connections on the existing 4 conductor wire from the transformer to connect the new relay installed in the chime?
              All this saves is some extra space and having to run 5V to the chime but one could use a larger arduino for additional automation projects rather than dedicated to just the chime.
              Very nice tutorial- very easy to follow. Thanks
              • D
                drock1985
                Hey @mike0913 ,
                You can check out what I did with my Doorbell hack here (http://forum.mysensors.org/topic/2293/how-to-2-door-chime-automation-hack-thanks-petewill), it may help with your situation. Basically, I used the 16VAC input from the doorbell to power my Arduino, relays, and actual doorbell chime itself. Due to confined space, I had to mount mine in an external box below the existing door chime.
                My Projects
                2 Door Chime Sensor
                Washing Machine Monitor
                • N
                  N
                  Newzwaver
                  @petewill, thanks for the reply and sorry it took me so long. I have decided to keep it to a small project starting with the remote on off, then moving to a trigger to my camera. I plan on breaking the doorbell down once the wife is out of the house for a day, lol. Thanks again.
                    Hi Everyone,
                    I put together this quick how to video for hacking your doorbell to work with MySensors. It's pretty basic and the code is based on the Relay Actuator sketch. It has two main features: controlling if the doorbell rings with an on/off switch and sending a triggered state whenever it's pressed. The silence feature can be useful if a child (or you) is taking a nap. The triggered state can be used for many different things like starting a security camera, sending an alert or text message, playing custom sounds via Sonos or other device, etc. Another note, the doorbell will still function even if your home automation the controller is down for some reason.
                    Here are the additional details:
                    https://youtu.be/nMIcalwpstc
                     * Version 1.0 - PeteWill
                     * This sketch is used to control a doorbell ring with a relay as well as send an
                     * alert when the buttons is pressed.  Connect the button to ground and digital
                     * pin 3.  The relay controlling the doorbell is conntected to pin 4.
                     * Watch the How To video here: https://youtu.be/nMIcalwpstc
                    #define NODE_ID 16 // or set to AUTO if you want gw to assign a NODE_ID for you.
                    #define DOORBELL_PIN  3      // Arduino Digital I/O pin number for the doorbell button
                    #define RELAY_PIN  4         // Arduino Digital I/O pin number for the relay
                    #define DOORBELL_CHILD_ID 0  //ID of the doorbell
                    #define SWITCH_CHILD_ID 1    // Id of the switch that will control doorbell sound
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    Bounce debouncer = Bounce();
                    MyMessage switchMsg(SWITCH_CHILD_ID, V_LIGHT);
                    MyMessage doorbellMsg(DOORBELL_CHILD_ID, V_TRIPPED);
                    unsigned int doorbellDelay = 1000; // interval at which to keep the doorbell button sensor triggered (milliseconds). This is used to stop people (kids) from pressing it too often
                    unsigned int ringTime = 700; //How long the doorbell relay is on (in milliseconds)
                    unsigned long doorbellMillis;  //Used to keep track of the last doorbell button press
                    unsigned long doorbellTimer;  //Used to keep track of doorbell ring time
                    byte doorbellPreviousVal;  //Used to keep track of doorbell button pressed state
                    boolean ringDoorbell;  //Used to initiate the ring doorbell if statement
                    boolean doorbellSound; //Used to keep track if the doorbell should sound or be silent.  Value recieved from doorbell on/off switch
                    boolean doorbellOff = true;  //Used to keep track of doorbell ring state
                      gw.begin(incomingMessage, NODE_ID);
                      gw.sendSketchInfo("Doorbell Monitor", "1.0");
                      // Setup the button and activate internal pull-up
                      pinMode(DOORBELL_PIN, INPUT_PULLUP);
                      debouncer.attach(DOORBELL_PIN);
                      debouncer.interval(5);
                      gw.present(SWITCH_CHILD_ID, S_LIGHT);
                      gw.present(DOORBELL_CHILD_ID, S_MOTION);
                      pinMode(RELAY_PIN, OUTPUT);
                      // Set doorbellSound to last known state (using eeprom storage)
                      doorbellSound = gw.loadState(SWITCH_CHILD_ID);
                      //Check to see if doorbell button was pushed.
                      if (currentMillis - doorbellMillis > doorbellDelay) //used to stop doorbell from being pressed too frequently
                        debouncer.update();
                        // Read doorbell button value
                        byte doorbellDetect = !debouncer.read();//read, then reverse the value so it will send correct trigger state to controller
                        if (doorbellDetect != doorbellPreviousVal)
                          //Serial.print("doorbellDetect Value: ");
                          //Serial.println(doorbellDetect);
                          gw.send(doorbellMsg.set(doorbellDetect));
                          if (doorbellDetect == 1)
                            ringDoorbell = true;
                            doorbellTimer = currentMillis;
                          doorbellMillis = currentMillis;
                          doorbellPreviousVal = doorbellDetect;
                      if (ringDoorbell)
                        if (doorbellSound)
                          if (doorbellOff)
                            digitalWrite(RELAY_PIN, RELAY_ON);
                            //Serial.println("Doorbell sounded.");
                            doorbellOff = false;
                            if (currentMillis - doorbellTimer > ringTime)
                              ringDoorbell = false;
                              //Serial.println("Doorbell off.");
                              doorbellOff = true;
                      void incomingMessage(const MyMessage & message) {
                        if (message.isAck()) {
                          // Change relay state
                          doorbellSound = message.getBool();
                          // Store state in eeprom
                          gw.saveState(SWITCH_CHILD_ID, doorbellSound);
                    riochickenR
                    riochickenR
                    riochicken
                    @petewill
                    Thanks for the code! For some reason it is not functioning on my arduino pro, the relay doesnt do anything when I push the button on pin 3, I do see within the Vera that the button is being pushed I have no clue what is going wrong..
                    This is the output from the serial monitor:
                    send: 16-16-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                    send: 16-16-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.3
                    send: 16-16-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                    sensor started, id=16, parent=0, distance=1
                    send: 16-16-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,st=ok:Doorbell Monitor
                    send: 16-16-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                    send: 16-16-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                    send: 16-16-0-0 s=0,c=0,t=1,pt=0,l=0,sg=0,st=ok:
                    Pushing button
                    send: 16-16-0-0 s=0,c=1,t=16,pt=1,l=1,sg=0,st=ok:1
                    send: 16-16-0-0 s=0,c=1,t=16,pt=1,l=1,sg=0,st=ok:0
                    Pushing button
                    Anybody that can help me out?
                    Kind regards,
                    Richard
                    riochickenR 1 Reply Last reply
                    • riochickenR riochicken
                      @petewill
                      Pushing button
                      Pushing button
                      Kind regards,
                      Richard
                      riochickenR
                      riochickenR
                      riochicken
                      @riochicken
                      Never mind, I didnt know I had to enable both switches within the arduino interface... ahum..
                      Thanks anyhoe!
                      Kind regards
                      Richard
                      • riochickenR
                        riochickenR
                        riochicken
                        Excellent hack, works like a charm! I added two extra activations for my doorbell so it rings two times short and one longer time... Is there a way to create a variable in the Vera options so you can change the number of time the relay activates? Now I added them in the code but that is not really handy when the thing is build in and such... :)
                          petewillP
                          petewillP
                          petewill
                          Yeah, that should be possible. Have a look at the Irrigation Controller code. That has some examples of getting variables from the controller.
                          • T
                            timropp
                            I had my doorbell working fine on Vera for months, but now I'm switching over to Domoticz. I used the updated domoticz version of the code above (by drock1985) but it's still not working right. My only changes were the pin assignments to match my wiring and setting the repeater to true since it's powered.
                            My domoticz is version v3.4834. Mysensors ethernet gateway is working fine. When I powered up the doorbell, I got an unknown node with sketch "unknown" show up under mysensors. It has 2 children - a repeater with childID 255, and an unknown with childID 0 and a V_Tripped value.
                            Any idea what I need to do to make it work?
                            VeraEdge UI7 with Mysensors ethernet gateway
                            D 1 Reply Last reply
                            • T timropp
                              drock1985
                              @timropp
                              Try this code and see if it works.
                               * Version 2.1 - Derrick Rockwell (Drock1985)
                               * - Complete Re-write of code to provide better flow/structure.
                               * Version 2.0 - ResentedPoet
                               * Based on original concept/code by @petewill for 1 Door bell chime. See original thread
                               * http://forum.mysensors.org/topic/2064/how-to-doorbell-automation-hack
                               * This sketch is used to control a front and back doorbell ring with relays as well as send an
                               * alert when the buttons are pressed. For front door, Connect the button to ground and digital
                               * pin 3.  The relay controlling the doorbell is conntected to pin 4. For rear door bell
                               * connect second button to ground and digital pin 5. The relay controlling that pin goes
                               * to pin 6.
                              #define NODE_ID 2                   // or set to AUTO if you want gw to assign a NODE_ID for you.
                              #define FRONT_DOOR_BUTTON  3        // Arduino Digital I/O pin number for the front doorbell button
                              #define FRONT_CHIME_RELAY  4        // Aduino Digital I/O pin number for the front door chime relay
                              #define CHILD_ID_0 0                // Child ID for the front doorbell sensor
                              #define BACK_DOOR_BUTTON 5          // Arduino Digital I/O pin number for the back doorbell button
                              #define BACK_CHIME_RELAY 6          // Aduino Digital I/O pin number for the back door chime relay
                              #define CHILD_ID_1 1                // Child ID for the back doorbell sensor
                              #define CHILD_ID_2 2                // Child ID for the mute option
                              #define CHIME_MUTE_STATE            // Used to hold value of door chime mute funtion.
                              #define CHIME_OFF 0                 // Variable to define ring the chime
                              #define CHIME_ON 1
                              #define FRONT_CHIME_RELAY_ON LOW    // Variable for front chime. Reverse low/high if relay pin set different
                              #define FRONT_CHIME_RELAY_OFF HIGH  // Variable for front chime. Reverse low/high if relay pin set different
                              #define BACK_CHIME_RELAY_ON LOW     // Variable for front chime. Reverse low/high if relay pin set different
                              #define BACK_CHIME_RELAY_OFF HIGH   // Variable for front chime. Reverse low/high if relay pin set different
                              Bounce debouncerF = Bounce();
                              Bounce debouncerB = Bounce();
                              boolean CHIME_MUTE = 1;
                              MyMessage msg(CHILD_ID_2, CHIME_MUTE);
                              MyMessage frontDoorbell(CHILD_ID_0, V_TRIPPED);
                              MyMessage backDoorbell(CHILD_ID_1, V_TRIPPED);
                              MyMessage chimeMute(CHILD_ID_2, V_STATUS);
                              int pestTimeout = 4000;               // Delay between registered button presses. Stops button mashers ;) Set to whatever delay you want.
                              unsigned long previousMillis=0;       // Tracks time since last door chime button press
                                gw.sendSketchInfo("2 Door bell/chime Monitor", "2.1");
                                pinMode(FRONT_DOOR_BUTTON, INPUT);
                                pinMode(BACK_DOOR_BUTTON, INPUT);
                                digitalWrite(FRONT_DOOR_BUTTON, HIGH);
                                digitalWrite(BACK_DOOR_BUTTON, HIGH);
                                debouncerF.attach(FRONT_DOOR_BUTTON);
                                debouncerB.attach(BACK_DOOR_BUTTON);
                                debouncerF.interval(5);
                                debouncerB.interval(5);
                                gw.present(CHILD_ID_0, S_MOTION);
                                gw.present(CHILD_ID_1, S_MOTION);
                                gw.present(CHILD_ID_2, S_LIGHT);
                                gw.send(msg.set(CHILD_ID_2, CHIME_MUTE));
                                digitalWrite(FRONT_CHIME_RELAY, FRONT_CHIME_RELAY_OFF);
                                digitalWrite(BACK_CHIME_RELAY, BACK_CHIME_RELAY_OFF);
                                pinMode(FRONT_CHIME_RELAY, OUTPUT);
                                pinMode(BACK_CHIME_RELAY, OUTPUT);
                                debouncerF.update();
                                debouncerB.update();
                                int valueF = debouncerF.read();
                                int valueB = debouncerB.read();
                              //Front Doorbell
                              if ( ((unsigned long)(currentMillis - previousMillis) >= pestTimeout) && valueF != HIGH && CHIME_MUTE == 1) {
                                digitalWrite(FRONT_CHIME_RELAY, FRONT_CHIME_RELAY_ON);
                                gw.send(frontDoorbell.set(1));
                                gw.wait(50);
                                gw.send(frontDoorbell.set(0));
                              if ( ((unsigned long)(currentMillis - previousMillis) >= pestTimeout) && valueF != HIGH && CHIME_MUTE == 0) {
                                gw.wait(50);;
                              //Back Doorbell
                              if ( ((unsigned long)(currentMillis - previousMillis) >= pestTimeout) && valueB != HIGH && CHIME_MUTE == 1) {
                                digitalWrite(BACK_CHIME_RELAY, BACK_CHIME_RELAY_ON);
                                gw.send(backDoorbell.set(1));
                                gw.wait(450);
                                gw.send(backDoorbell.set(0));
                              if ( ((unsigned long)(currentMillis - previousMillis) >= pestTimeout) && valueB != HIGH && CHIME_MUTE == 0) {
                                gw.wait(50);
                                   CHIME_MUTE = message.getBool();
                                   gw.send(msg.set(CHILD_ID_2, CHIME_MUTE?CHIME_ON:CHIME_OFF));
                                   gw.saveState(CHILD_ID_2, CHIME_MUTE);
                              My Projects
                              2 Door Chime Sensor
                              • T
                                timropp
                                Thanks, I'll give that a try. I don't have any need for the dual bell functionality, but we can see if it works and if so, then comment out the back bell part to simplify things.
                                • T
                                  timropp
                                  Tried that sketch (with just changing pin assignments and flipping the relay high/low settings). As soon as I powered it up, the relay started clicking every 4 seconds and it never appeared in Domoticz. I think it's because after the pin is set to input, there's " digitalWrite(FRONT_DOOR_BUTTON, HIGH);" command that's like someone holding the button down.
                                  Went back to the original sketch I used. I changed from an auto NODE_ID to a fixed setting in the defines and re-uploaded it. The device appeared in Domoticz correctly! I've got a "doorbell sketch 1.0" with 3 devices - repeater, the doorbell button as a S_Motion, and the doorbell on/off as a S_Lights.
                                  However, it still doesn't work. My wiring is shown above and it worked great under Vera. Now, I cannot get the doorbell to actually chime. Nor does the outdoor button do anything. I've verified the wiring, but shorting the A0 pin to the ground input doesn't do anything like it should. However, there's ANOTHER ground next to the A0 (under the wireless card), and if I short the A0 to that ground pin, the switch shows on in Domoticz. I can change the wiring since for some reason which ground I use is making a difference.
                                  No matter what, still no relay action though. I tried turning the doorbell on/off switch both ways and it made no difference. In either setting, shorting the two pins turns the switch in Domoticz on.
                                  I was comparing the two sketches (the one I'm using, and the dual-bell one). The single bell sketch sets the button pin with pinmode(Doorbell_pin, input_pullup) where the dual uses input without the pullup. Which should be right?
                                  • T timropp
                                    drock1985
                                    @timropp
                                    The sketch I use doesn't use internal pull ups; external only.
                                    As for the relay clicking, could be either the jumper on the relay, or not enough current to power it properly.
                                    Not sure why you are having issues with either of the scripts. What type of gateway do you use?
                                    My Projects
                                    2 Door Chime Sensor
                                    • T
                                      timropp
                                      It's an ethernet gateway.
                                      I don't think it's really a Mysensors issue though as I think about it - the doorbell should ring when you press the button whether you have the gateway running or not. And I'm not even getting that. In fact, I AM getting the signal to the gateway, but it's not activating the relay.
                                      Is it possible that the doorbell on/off switch isn't working right in the code? I never used that before. I think I'll try tomorrow (kids in bed now, so can't really play around with a doorbell!) removing that switch for now and have it always set to on.
                                      I looked through comparing the sketch I'm using now (the one drock1985 made that's for domoticz) and the original. The only change is moving the gw.send command and changing it slightly. But again, that shouldn't impact the bell physically working. So there's something else going on.
                                      Is there a way to check if the code uploaded to the arduino correctly? I'm using the rboard and a FTDI to upload. I'm wondering if something isn't going weird there and it's not uploading correctly and that's why I'm getting different issues every time I try something...
                                      • D
                                        drock1985
                                        Not really. You could try uploading at a slower speed. Slower speed over serial usually equals less chance of missed data.
                                        Have you tried running this connected to your PC and viewing the data from serial console/window? Copy/paste the output from the serial monitor so we can see what's going on.
                                        My Projects
                                        2 Door Chime Sensor
                                        • T
                                          timropp
                                          Yep, both those are on my to do list fo tonight. Thanks for your help troubleshooting!
