  2. Announcements
  3. 2.0 Discussion: Units, sensor types and protocol
170 Posts 23 Posters 120.1k Views 7 Watching
    To simplify sketches even further we've discussed and decided to let sensors send in standard SI units and let controller convert them to the appropriate format.
    This will also remove the need for a unit-config exchange with controller at sensor startup.
    The new over-the-air messages has changed quite much with a more logical structure that can handle extension and even a completely different network layer if needed.
    The ongoing work can be found here:
    https://github.com/henrikekblad/Arduino/blob/development/libraries/MySensors/MyMessage.h
    Will not bring this into development until it actually compiles.
    Feel free to give feedback and report any missed sensor-types.
    In parallell we should probably discuss the serial-protocol for 2.0. Is it time for json perhaps?
    greglG
    greglG
    gregl
    @hek could we pleas add a V_pH. Or V_PH_LEVEL
    hekH 1 Reply Last reply
    • YveauxY
      @hek said:
      V_HUM - Humidity percentage 0-100% <int>
      No reason to limit to int, can also be float.
      Why do you mention the data types for some and not for most? Mysensors doesn't really care....
      • YveauxY
        @hek said:
        V_WIND - m/s (average wind speed during last hour)
        V_GUST - m/s (highest wind speed during last hour)
        Why average/highest over last hour? My weather station reports wind speed every minute and I like to see the minute detail instead of averaging everything over an hour.
        • YveauxY
          @hek said:
          Do we need another one for lux?
          Yes please.
          • YveauxY
            @hek said:
            V_DUST_LEVEL - ug/m3
            g/m3 if you standardize on SI
            Same for distance BTW. Might be more...
            • YveauxY
              @hek said:
              V_DIRECTION
              Maybe just return angle ( in radians and call it V_ANGLE) then textual indication. This way higher resolutions can also be supported.
              Sorry for all the separate messages. Works more convenient on a tablet...
              • YveauxY
                I would like a way to configure a sensor from the gateway, to e.g calibrate a sensor or store some ID. Maybe a V_CONFIG can be added, where childid indicates the actual variable written. Or define a few V_CONFIG0,V_CONFIG1 etc.
                What do you think?
                • YveauxY Yveaux
                  I choose to scale the SI units to something relevant for thing getting measured. E.g. g/m3 would give a VERY small small value for dust.
                  Distance is mainly for the distance sensor now, which only has a small range.
                  Rain - measure in meters would also render very small numbers.
                  So, until we have a scaling factor in the protocol or something similar we'll have select a proper scaling at the source and agree on it between sensor and controller.
                  • YveauxY Yveaux
                    What do you think?
                    @Yveaux said:
                    V_CONFIG0,V_CONFIG1
                    A few config-placeholders would be a nice.
                    • greglG gregl
                      @gregl said:
                      V_PH_LEVEL
                      Added.
                      • YveauxY Yveaux
                        I'll change the definition to "over the last report period".
                        • A
                          a-lurker
                          V_ANGLE sounds good. With a bit of (floating point) maths, all can be calculated.
                          • RJ_MakeR RJ_Make
                            How about
                            V_RELAY_STATUS 1=Active, 0=Deactive
                            Not sure what differs this form V_LIGHT_STATUS.
                            Maybe we need a better word than LIGHT that describes a thing-that-can-be-turned-on-or-off?
                              When values are sent as floats it doesn't matter. Scaling is implicitly store in the floating point value when sent as binary float. When transfered as ASCII you're right, but that isn't required with 1.4 anymore...
                                Hmmmm.... Let me think.... a switch ? ;-)
                                • A a-lurker
                                  @HEK I'll bite:
                                  Use under scores consistently ? eg V_RAINRATE and V_LIGHT_LEVEL
                                  The units to be used here can be clearer:
                                  V_VOLTAGE ---> V_VOLTS
                                  V_CURRENT ---> V_AMPS
                                  Where the base unit is not used - should the name reflect that? eg V_DISTANCE --> V_DISTANCE_CM
                                  Electrical impedance and resistance are not the same thing- suspect resistance is intended here?
                                  V_IMPEDANCE --> V_RESISTANCE
                                  HUM is a bit vague - suggest: V_HUM --> V_HUMIDITY
                                  V_DIRECTION may be confused with an angle or up/down. Could use V_COMPASS_POINT, but that may be confused with magnetic or true north!
                                  V_LIGHT could be confused with V_LIGHT_LEVEL. Could use V_LIGHT_STATUS
                                  V_TEMP while often used, can be confused with a temporary variable? Could use V_TEMPERATURE
                                  V_VOLUME could be confused with audio volume? Could use V_CUBIC_MEASURE
                                  V_HEATER_MODE for V_HEATER?
                                  Could add V_DEW_POINT
                                  STATUS always be used for binary values eg on/off, locked/unlocked?
                                  V_LOCK_STATUS
                                  V_LIGHT_STATUS
                                  V_HEATER_STATUS
                                  I think the impedance-variable comes from the RFXTRX plugin. And it is related to body fat measurements for body scales.
                                  http://code.mios.com/trac/mios_rfxtrx/browser/trunk/L_RFXtrx.lua
                                  If I understand it correctly Impedace is used for AC and resistance for DC. Not sure what would be most useful in this setup.
                                  DammeD Z 2 Replies Last reply
                                  • YveauxY Yveaux
                                    Most users still use the serial protocol. Which means strings like "0.000003423" must be generated and transferred to the controller from gateway.
                                    • YveauxY Yveaux
                                      Haha.. yeah.. :+1:
                                        DammeD
                                        DammeD
                                        Damme
                                        Code Contributor
                                        @hek Moisture or Water detecded... Might be 2 different ?
                                        Thinking different applications: Moisture in ground. (I.e. Water needed? Ground dry?) And Water level, hmm, if you have a fluid level meter to detect overfill. or leakage. Fluid flow
                                          Ok, but is this a problem? You could even pass it as 3.423e-6....
                                          You don't want this string on air if you can transfer the same thing in 4 bytes, that's true.
                                          I only want to state that if you transfer it purely in SI units, without scaling, you always know what the actual value is.
                                          12.5k
