  2. Announcements
  3. 2.0 Discussion: Units, sensor types and protocol
170 Posts 23 Posters 116.2k Views 7 Watching
  • hekH Offline
    hekH Offline
    wrote on last edited by hek
    To simplify sketches even further we've discussed and decided to let sensors send in standard SI units and let controller convert them to the appropriate format.
    This will also remove the need for a unit-config exchange with controller at sensor startup.
    The new over-the-air messages has changed quite much with a more logical structure that can handle extension and even a completely different network layer if needed.
    The ongoing work can be found here:
    https://github.com/henrikekblad/Arduino/blob/development/libraries/MySensors/MyMessage.h
    Will not bring this into development until it actually compiles.
    Feel free to give feedback and report any missed sensor-types.
    In parallell we should probably discuss the serial-protocol for 2.0. Is it time for json perhaps?
    greglG Z D 5 Replies Last reply
    • R Offline
      R Offline
      RJ_Make
      How about
      V_RELAY_STATUS 1=Active, 0=Deactive
      RJ_Make
      hekH 1 Reply Last reply
      • A Offline
        A Offline
        a-lurker
        wrote on last edited by a-lurker
        @HEK I'll bite:
        Use under scores consistently ? eg V_RAINRATE and V_LIGHT_LEVEL
        The units to be used here can be clearer:
        V_VOLTAGE ---> V_VOLTS
        V_CURRENT ---> V_AMPS
        Where the base unit is not used - should the name reflect that? eg V_DISTANCE --> V_DISTANCE_CM
        Electrical impedance and resistance are not the same thing- suspect resistance is intended here?
        V_IMPEDANCE --> V_RESISTANCE
        HUM is a bit vague - suggest: V_HUM --> V_HUMIDITY
        V_DIRECTION may be confused with an angle or up/down. Could use V_COMPASS_POINT, but that may be confused with magnetic or true north!
        V_LIGHT could be confused with V_LIGHT_LEVEL. Could use V_LIGHT_STATUS
        V_TEMP while often used, can be confused with a temporary variable? Could use V_TEMPERATURE
        V_VOLUME could be confused with audio volume? Could use V_CUBIC_MEASURE
        V_HEATER_MODE for V_HEATER?
        Could add V_DEW_POINT
        STATUS always be used for binary values eg on/off, locked/unlocked?
        V_LOCK_STATUS
        V_LIGHT_STATUS
        V_HEATER_STATUS
          greglG Offline
          greglG Offline
          gregl
          @hek could we pleas add a V_pH. Or V_PH_LEVEL
          • Y Offline
            Y Offline
            @hek said:
            V_HUM - Humidity percentage 0-100% <int>
            No reason to limit to int, can also be float.
            Why do you mention the data types for some and not for most? Mysensors doesn't really care....
            • Y Offline
              Y Offline
              @hek said:
              V_WIND - m/s (average wind speed during last hour)
              V_GUST - m/s (highest wind speed during last hour)
              Why average/highest over last hour? My weather station reports wind speed every minute and I like to see the minute detail instead of averaging everything over an hour.
              • Y Offline
                Y Offline
                @hek said:
                Do we need another one for lux?
                Yes please.
                • Y Offline
                  Y Offline
                  @hek said:
                  V_DUST_LEVEL - ug/m3
                  g/m3 if you standardize on SI
                  Same for distance BTW. Might be more...
                  • Y Offline
                    Y Offline
                    @hek said:
                    V_DIRECTION
                    Maybe just return angle ( in radians and call it V_ANGLE) then textual indication. This way higher resolutions can also be supported.
                    Sorry for all the separate messages. Works more convenient on a tablet...
                    • Y Offline
                      Y Offline
                      I would like a way to configure a sensor from the gateway, to e.g calibrate a sensor or store some ID. Maybe a V_CONFIG can be added, where childid indicates the actual variable written. Or define a few V_CONFIG0,V_CONFIG1 etc.
                      What do you think?
                      • Y Yveaux
                        hekH Offline
                        hekH Offline
                        I choose to scale the SI units to something relevant for thing getting measured. E.g. g/m3 would give a VERY small small value for dust.
                        Distance is mainly for the distance sensor now, which only has a small range.
                        Rain - measure in meters would also render very small numbers.
                        So, until we have a scaling factor in the protocol or something similar we'll have select a proper scaling at the source and agree on it between sensor and controller.
                        Y 1 Reply Last reply
                        • Y Yveaux
                          What do you think?
                          hekH Offline
                          hekH Offline
                          @Yveaux said:
                          V_CONFIG0,V_CONFIG1
                          A few config-placeholders would be a nice.
                          • greglG gregl
                            hekH Offline
                            hekH Offline
                            @gregl said:
                            V_PH_LEVEL
                            Added.
                            • Y Yveaux
                              hekH Offline
                              hekH Offline
                              I'll change the definition to "over the last report period".
                              • A Offline
                                A Offline
                                a-lurker
                                V_ANGLE sounds good. With a bit of (floating point) maths, all can be calculated.
                                • R RJ_Make
                                  How about
                                  hekH Offline
                                  hekH Offline
                                  Not sure what differs this form V_LIGHT_STATUS.
                                  Maybe we need a better word than LIGHT that describes a thing-that-can-be-turned-on-or-off?
                                    Y Offline
                                    Y Offline
                                    When values are sent as floats it doesn't matter. Scaling is implicitly store in the floating point value when sent as binary float. When transfered as ASCII you're right, but that isn't required with 1.4 anymore...
                                      Y Offline
                                      Y Offline
                                      Hmmmm.... Let me think.... a switch ? ;-)
                                      • A a-lurker
                                        @HEK I'll bite:
                                        V_LOCK_STATUS
                                        V_LIGHT_STATUS
                                        V_HEATER_STATUS
                                        hekH Offline
                                        hekH Offline
                                        I think the impedance-variable comes from the RFXTRX plugin. And it is related to body fat measurements for body scales.
                                        http://code.mios.com/trac/mios_rfxtrx/browser/trunk/L_RFXtrx.lua
                                        If I understand it correctly Impedace is used for AC and resistance for DC. Not sure what would be most useful in this setup.
                                        D Z 2 Replies Last reply
                                        • Y Yveaux
                                          hekH Offline
                                          hekH Offline
                                          Most users still use the serial protocol. Which means strings like "0.000003423" must be generated and transferred to the controller from gateway.
