  3. 3 in 1 incl battery monitor
60 Posts 11 Posters 37.1k Views 12 Watching
  • D
    Dylano
    wrote on last edited by Dylano
    #46
    @ Carlied,
    What code is better that one of you or the one from cosmi gate?
    What are the different thing? Is your code check'the battery status?
    And i get a error:
    no matching function for call to 'MySensor::MySensor(MyTransportRFM69&, MyHwATMega328&, MySigningAtsha204Soft&)'
    Domoticz, with a lot of working hardware, include mysensors :-)
    OpenPLI, RuneAudio, Solarmeter, etc......
    Not a great builder of software and hardware, more a user...
    Only i try to do my best :-(
    • carlierdC
      carlierdC
      carlierd
      The error is because I enable the signing function !
      Remove the following line:
      MySigningAtsha204Soft signer;
      And replace
      MySensor node(transport, hw, signer);
      by
      MySensor node(transport, hw);
      I don't know who had the best sketch.
      I measure internal battery status using the 1.1 reference.
      David.
      • D
        Dylano
        When i put this sketch in to a nano..
        With a 9volt battery....
        How long do think this working?
        Or how long is this acting on your 3 volt battery's?
        • carlierdC
          carlierdC
          carlierd
          It depends on the activity close to the sensor so not possible to say but some people reach several month without problem.
          In my house it's very fresh so I have not a lot of feedback to give.
          David.
          • D
            Dylano
            #50
            5 days....:-1: on a 9volt block
            The sketch on a nano
            On my toilet.... so not a very busy room
            Is there some one that live longer, with this sketch......?
            • icebobI icebob
              @the-cosmic-gate Nothing special. I made a big sketch, which contains 7-8 sensors (DHT, Si7021, MQ-2/9, PIR, Door magnet, Light, battery) reading code because I would like to upload the same sketch to all nodes and configurate it on controller side, which sensors is on the node and need to read.
              But currently I reached the limit with I2C includes, so I need to think over this solution.
              Dylano
              Dear..
              Did you finish your big code....
              • carlierdC
                carlierdC
                carlierd
                9v means that you are using a voltage regulator which probably consumes a lot of power.
                Why not using AA or AAA battery directly connected to Vcc ?
                David
                D 1 Reply Last reply
                • carlierdC carlierd
                  David
                  Dylano
                  David
                  Motion and DHT needed 5volt i wash thinking..?
                  So 9 @ the vcc should be strong enough i was thinking.
                  And i do have @ the same time 3.5 for the radio
                  Are the extern step up better than the step down on a nano?
                  • carlierdC
                    carlierdC
                    carlierd
                    The motion can be adapt to run on 3v easily (connect the Vcc to the H pad if available. You can find information on the forum). The DHT could also run on 3v. I have several nodes like that. No problem.
                    Can't reply for the step-up because I don't use it.
                    David.
                      David.
                      Dylano
                      David.
                      @ David
                      How long is the 3v battery running whit this option?
                      • carlierdC
                        carlierdC
                        carlierd
                        @Dylano : My nodes are really new so difficult to say exactly but for the moment the oldest node was started one month ago (04/02) and battery still at 3.32v.
                        David.
                        • the cosmic gateT
                          the cosmic gateT
                          the cosmic gate
                          i'am back in business after the "big move" and going to try again to get this 4:1 sensor working for a long time uning 2 x AA batteries.
                          If someone has some new input, please let me know :) and feel free to change the sketch
                          There's more than meets the eye
                          carlierdC 1 Reply Last reply
                          • the cosmic gateT the cosmic gate
                            carlierdC
                            carlierdC
                            carlierd
                            @the-cosmic-gate
                            Motion nodes are still working correctly. The oldest node started the 4 of February is still at 3,29v. My other nodes (temp / humidity / light) are also working correctly but I will replace DHT22 for another sensor.
                            David.
                            • rhuehnR
                              rhuehnR
                              rhuehn
                              Hey @carlierd Just curious if you are still using a DHT22 with your sketch? Have you modified the code much from the above? I am looking at implementing something similiar ( identical actually ) and was wondering if much has changed for you over the last few months?
                              • carlierdC
                                carlierdC
                                carlierd
                                All nodes are still working correctly but I still want to replace DHT22. But nothing done for the moment. Not at top position on my todo list ;)
                                David.
