  3. 3 in 1 incl battery monitor
60 Posts 11 Posters 37.1k Views 12 Watching
  • carlierdC
    carlierdC
    carlierd
    I just finished my first motion sensor node and the power consumption in idle is about 75uA. Could be better but not too bad ;)
    The only thing is that the range is a little bit low for good detection. It's between 1 and 3 meters ...
    David.
    the cosmic gateT 1 Reply Last reply
    • carlierdC carlierd
      David.
      the cosmic gateT
      the cosmic gateT
      the cosmic gate
      David.
      Hello David
      Could you share what and how ? :)
      Thnx
      There's more than meets the eye
      • D
        Dylano
        And how is this sensor acting?
        This is what i am looking for..
        How lang can this sensor work? [ i wil try this with a 9Volt battery with a nano ]
        What battery do you use?
        Domoticz, with a lot of working hardware, include mysensors :-)
        OpenPLI, RuneAudio, Solarmeter, etc......
        Not a great builder of software and hardware, more a user...
        Only i try to do my best :-(
        • carlierdC
          carlierdC
          carlierd
          This is the code I use but it's not perfect especially with the battery report.
          The principle is as follow when the sensor start:
          • node in sleep mode with interrupt enable
          • if a move is detected, the detection is reported to the gateway
          • the node then go in sleep mode WITHOUT interrupt for 5 minutes
          • then the node return to sleep mode with interrupt enable
          This is to avoid having many report (and power consumption) to the gateway.
          The code (not perfect ! I have to rework on it but it's ok for the moment):
          /* Motion sensor.        */
          /* Version     : 1.1.5        */
          /* Date        : 30/01/2016                                                           */
          /* Modified by : David Carlier                                                        */
          /*                            RST |             |  A5                                 */
          /*                            RX  |             |  A4                                 */
          /*                            TX  |   ARDUINO   |  A3                                 */
          /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
          /*           Motion --------- D3  |             |  A1                                 */
          /*            Power --------- D4  | ATMEGA 328p |  A0                                 */
          /*              +3v --------- VCC |             | GND --------- GND                   */
          /*              GND --------- GND |  8MHz int.  | REF                                 */
          /*                            OSC |             | VCC --------- +3v                   */
          /*                            OSC |             | D13 --------- RFM69 (SCK)           */
          /*                            D5  |             | D12 --------- RFM69 (MISO)          */
          /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
          /*                            D7  |             | D10 --------- RFM69 (NSS)           */
          /*                            D8  |             |  D9                                 */
          /* +3v = 2*AA        */
          #include <MyTransportRFM69.h>
          //Constants
          #define SKETCH_NAME           "Motion Sensor"
          #define SKETCH_VERSION        "1.1.5"
          #define CHILD_ID              0
          #define CHILD_ID_VOLTAGE      1
          #define DIGITAL_INPUT_SENSOR  3
          #define BATTERY_REPORT_CYCLE  4   //Report each hour (4 * 15')
          //Misc. variables
          uint8_t switchState = 2;
          unsigned long SLEEP_TIME = 820000; // Sleep time between reads (in milliseconds) (close to 15')
          unsigned long SLEEP_TIME2 = 275000; // Sleep time after int. (in milliseconds) (close to 5')
          uint8_t cycleInProgress = 0;
          uint8_t firstReportDone = 0;
          uint8_t firstReportWithZeroDone = 0;
          //Construct MySensors library
          MySigningAtsha204Soft signer;
          MyHwATMega328 hw;
          MyTransportRFM69 transport;
          MySensor node(transport, hw, signer);
          MyMessage msgSwitch(CHILD_ID, V_TRIPPED);
          MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
          /* Initialization        */
            //Get time (for setup duration)
            #ifdef DEBUG
              unsigned long startTime = millis();
            //Start MySensors and send the Sketch Version Information to the Gateway
            node.begin();
            node.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
            //Setup the button
            pinMode(DIGITAL_INPUT_SENSOR, INPUT);
            //Register all sensors
            node.present(CHILD_ID, S_MOTION);
            node.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
            //Print setup debug
            #ifdef DEBUG
              int duration = millis() - startTime;
              Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
          /* Main loop        */
            //Get time (for a complete loop)
            #ifdef DEBUG
            //Read digital motion value
            uint8_t value = digitalRead(DIGITAL_INPUT_SENSOR);
            //Get voltage for battery capacity report (add 0.1v to the read value)
            float realVoltage = (getVoltage() / 100.0) + 0.1;
            int batteryPcnt = realVoltage * 100 / 3.0;
            if (batteryPcnt > 100) {batteryPcnt = 100;}
            //Check is state change
            if (value != switchState)
              //Report result if not first loop
              if (firstReportDone != 0)
                node.send(msgSwitch.set(value==HIGH ? 1 : 0));
              //Store result
              switchState = value;
            //Report data to the gateway each hour
            if (cycleInProgress >= BATTERY_REPORT_CYCLE || firstReportDone == 0)
              node.send(msgVolt.set(realVoltage, 2));
              node.sendBatteryLevel(batteryPcnt);
              firstReportDone = 1;
            //Change cycle number
            cycleInProgress++;
            //Print debug
            #ifdef DEBUG
              Serial.print("Value is ");
              Serial.print(value, 1);
              Serial.print("   ");
              Serial.print("Cycle is ");
              Serial.print(cycleInProgress, 1);
              Serial.print("   ");
              Serial.print(realVoltage);
              Serial.print(" v");
              Serial.print("   ");
              Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
              Serial.flush();
            //Check if the motion was triggered and if it's not the first report
            if (switchState == 0 && firstReportWithZeroDone == 1)
              //Sleep 5' without interrupt
              node.sleep(SLEEP_TIME2);
            //Check if it's the first loop
            if (switchState == 0 && firstReportWithZeroDone == 0)
              firstReportWithZeroDone = 1;
            //Sleep until something happens with the sensor
            node.sleep(DIGITAL_INPUT_SENSOR-2, CHANGE, SLEEP_TIME);
          /* Allows to get the real Vcc (return value * 100).                                   */
          int getVoltage()
            const long InternalReferenceVoltage = 1056L;
            ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
            delay(50);  // Let mux settle a little to get a more stable A/D conversion
            //Start a conversion
            ADCSRA |= _BV( ADSC );
            //Wait for it to complete
            while (((ADCSRA & (1<<ADSC)) != 0));
            //Scale the value
            int result = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L;
            return result;
          On one sensor I tweak the PIR (remove regulator and diode) but on a second one, I just plug the 3 v to the H pin (see other topic on the forum).
          Working correctly for the moment (one month) but it depends on the presence in the house.
          David.
          • D
            Dylano
            wrote on last edited by Dylano
            #46
            @ Carlied,
            What code is better that one of you or the one from cosmi gate?
            What are the different thing? Is your code check'the battery status?
            And i get a error:
            no matching function for call to 'MySensor::MySensor(MyTransportRFM69&, MyHwATMega328&, MySigningAtsha204Soft&)'
            • carlierdC
              carlierdC
              carlierd
              The error is because I enable the signing function !
              Remove the following line:
              And replace
              by
              MySensor node(transport, hw);
              I don't know who had the best sketch.
              I measure internal battery status using the 1.1 reference.
              David.
              • D
                Dylano
                When i put this sketch in to a nano..
                With a 9volt battery....
                How long do think this working?
                Or how long is this acting on your 3 volt battery's?
                • carlierdC
                  carlierdC
                  carlierd
                  It depends on the activity close to the sensor so not possible to say but some people reach several month without problem.
                  In my house it's very fresh so I have not a lot of feedback to give.
                  David.
                  • D
                    Dylano
                    #50
                    5 days....:-1: on a 9volt block
                    The sketch on a nano
                    On my toilet.... so not a very busy room
                    Is there some one that live longer, with this sketch......?
                    • icebobI icebob
                      @the-cosmic-gate Nothing special. I made a big sketch, which contains 7-8 sensors (DHT, Si7021, MQ-2/9, PIR, Door magnet, Light, battery) reading code because I would like to upload the same sketch to all nodes and configurate it on controller side, which sensors is on the node and need to read.
                      But currently I reached the limit with I2C includes, so I need to think over this solution.
                      Dylano
                      Dear..
                      Did you finish your big code....
                      • carlierdC
                        carlierdC
                        carlierd
                        9v means that you are using a voltage regulator which probably consumes a lot of power.
                        Why not using AA or AAA battery directly connected to Vcc ?
                        David
                        D 1 Reply Last reply
                          David
                          Dylano
                          David
                          Motion and DHT needed 5volt i wash thinking..?
                          So 9 @ the vcc should be strong enough i was thinking.
                          And i do have @ the same time 3.5 for the radio
                          Are the extern step up better than the step down on a nano?
                          • carlierdC
                            carlierdC
                            carlierd
                            The motion can be adapt to run on 3v easily (connect the Vcc to the H pad if available. You can find information on the forum). The DHT could also run on 3v. I have several nodes like that. No problem.
                            Can't reply for the step-up because I don't use it.
                            David.
                              David.
                              Dylano
                              David.
                              @ David
                              How long is the 3v battery running whit this option?
                              • carlierdC
                                carlierdC
                                carlierd
                                @Dylano : My nodes are really new so difficult to say exactly but for the moment the oldest node was started one month ago (04/02) and battery still at 3.32v.
                                David.
                                • the cosmic gateT
                                  the cosmic gateT
                                  the cosmic gate
                                  i'am back in business after the "big move" and going to try again to get this 4:1 sensor working for a long time uning 2 x AA batteries.
                                  If someone has some new input, please let me know :) and feel free to change the sketch
                                  carlierdC 1 Reply Last reply
                                  • the cosmic gateT the cosmic gate
                                    carlierdC
                                    carlierdC
                                    carlierd
                                    @the-cosmic-gate
                                    Motion nodes are still working correctly. The oldest node started the 4 of February is still at 3,29v. My other nodes (temp / humidity / light) are also working correctly but I will replace DHT22 for another sensor.
                                    David.
                                    • rhuehnR
                                      rhuehnR
                                      rhuehn
                                      Hey @carlierd Just curious if you are still using a DHT22 with your sketch? Have you modified the code much from the above? I am looking at implementing something similiar ( identical actually ) and was wondering if much has changed for you over the last few months?
                                      • carlierdC
                                        carlierdC
                                        carlierd
                                        All nodes are still working correctly but I still want to replace DHT22. But nothing done for the moment. Not at top position on my todo list ;)
                                        David.
