  3. 3 in 1 incl battery monitor
60 Posts 11 Posters 37.1k Views 12 Watching
  • carlierdC
    carlierdC
    carlierd
    This is the code I use but it's not perfect especially with the battery report.
    The principle is as follow when the sensor start:
    • node in sleep mode with interrupt enable
    • if a move is detected, the detection is reported to the gateway
    • the node then go in sleep mode WITHOUT interrupt for 5 minutes
    • then the node return to sleep mode with interrupt enable
    This is to avoid having many report (and power consumption) to the gateway.
    The code (not perfect ! I have to rework on it but it's ok for the moment):
    /* Motion sensor.        */
    /* Version     : 1.1.5        */
    /* Date        : 30/01/2016                                                           */
    /* Modified by : David Carlier                                                        */
    /*                            RST |             |  A5                                 */
    /*                            RX  |             |  A4                                 */
    /*                            TX  |   ARDUINO   |  A3                                 */
    /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
    /*           Motion --------- D3  |             |  A1                                 */
    /*            Power --------- D4  | ATMEGA 328p |  A0                                 */
    /*              +3v --------- VCC |             | GND --------- GND                   */
    /*              GND --------- GND |  8MHz int.  | REF                                 */
    /*                            OSC |             | VCC --------- +3v                   */
    /*                            OSC |             | D13 --------- RFM69 (SCK)           */
    /*                            D5  |             | D12 --------- RFM69 (MISO)          */
    /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
    /*                            D7  |             | D10 --------- RFM69 (NSS)           */
    /*                            D8  |             |  D9                                 */
    /* +3v = 2*AA        */
    #include <MyTransportRFM69.h>
    //Constants
    #define SKETCH_NAME           "Motion Sensor"
    #define SKETCH_VERSION        "1.1.5"
    #define CHILD_ID              0
    #define CHILD_ID_VOLTAGE      1
    #define DIGITAL_INPUT_SENSOR  3
    #define BATTERY_REPORT_CYCLE  4   //Report each hour (4 * 15')
    //Misc. variables
    uint8_t switchState = 2;
    unsigned long SLEEP_TIME = 820000; // Sleep time between reads (in milliseconds) (close to 15')
    unsigned long SLEEP_TIME2 = 275000; // Sleep time after int. (in milliseconds) (close to 5')
    uint8_t cycleInProgress = 0;
    uint8_t firstReportDone = 0;
    uint8_t firstReportWithZeroDone = 0;
    //Construct MySensors library
    MySigningAtsha204Soft signer;
    MyHwATMega328 hw;
    MyTransportRFM69 transport;
    MySensor node(transport, hw, signer);
    MyMessage msgSwitch(CHILD_ID, V_TRIPPED);
    MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
    /* Initialization        */
      //Get time (for setup duration)
      #ifdef DEBUG
        unsigned long startTime = millis();
      //Start MySensors and send the Sketch Version Information to the Gateway
      node.begin();
      node.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
      //Setup the button
      pinMode(DIGITAL_INPUT_SENSOR, INPUT);
      //Register all sensors
      node.present(CHILD_ID, S_MOTION);
      node.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
      //Print setup debug
      #ifdef DEBUG
        int duration = millis() - startTime;
        Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
    /* Main loop        */
      //Get time (for a complete loop)
      #ifdef DEBUG
      //Read digital motion value
      uint8_t value = digitalRead(DIGITAL_INPUT_SENSOR);
      //Get voltage for battery capacity report (add 0.1v to the read value)
      float realVoltage = (getVoltage() / 100.0) + 0.1;
      int batteryPcnt = realVoltage * 100 / 3.0;
      if (batteryPcnt > 100) {batteryPcnt = 100;}
      //Check is state change
      if (value != switchState)
        //Report result if not first loop
        if (firstReportDone != 0)
          node.send(msgSwitch.set(value==HIGH ? 1 : 0));
        //Store result
        switchState = value;
      //Report data to the gateway each hour
      if (cycleInProgress >= BATTERY_REPORT_CYCLE || firstReportDone == 0)
        node.send(msgVolt.set(realVoltage, 2));
        node.sendBatteryLevel(batteryPcnt);
        firstReportDone = 1;
      //Change cycle number
      cycleInProgress++;
      //Print debug
      #ifdef DEBUG
        Serial.print("Value is ");
        Serial.print(value, 1);
        Serial.print("   ");
        Serial.print("Cycle is ");
        Serial.print(cycleInProgress, 1);
        Serial.print("   ");
        Serial.print(realVoltage);
        Serial.print(" v");
        Serial.print("   ");
        Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
        Serial.flush();
      //Check if the motion was triggered and if it's not the first report
      if (switchState == 0 && firstReportWithZeroDone == 1)
        //Sleep 5' without interrupt
        node.sleep(SLEEP_TIME2);
      //Check if it's the first loop
      if (switchState == 0 && firstReportWithZeroDone == 0)
        firstReportWithZeroDone = 1;
      //Sleep until something happens with the sensor
      node.sleep(DIGITAL_INPUT_SENSOR-2, CHANGE, SLEEP_TIME);
    /* Allows to get the real Vcc (return value * 100).                                   */
    int getVoltage()
      const long InternalReferenceVoltage = 1056L;
      ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
      delay(50);  // Let mux settle a little to get a more stable A/D conversion
      //Start a conversion
      ADCSRA |= _BV( ADSC );
      //Wait for it to complete
      while (((ADCSRA & (1<<ADSC)) != 0));
      //Scale the value
      int result = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L;
      return result;
    On one sensor I tweak the PIR (remove regulator and diode) but on a second one, I just plug the 3 v to the H pin (see other topic on the forum).
    Working correctly for the moment (one month) but it depends on the presence in the house.
    David.
    • D
      Dylano
      wrote on last edited by Dylano
      #46
      @ Carlied,
      What code is better that one of you or the one from cosmi gate?
      What are the different thing? Is your code check'the battery status?
      And i get a error:
      no matching function for call to 'MySensor::MySensor(MyTransportRFM69&, MyHwATMega328&, MySigningAtsha204Soft&)'
      Domoticz, with a lot of working hardware, include mysensors :-)
      OpenPLI, RuneAudio, Solarmeter, etc......
      Not a great builder of software and hardware, more a user...
      Only i try to do my best :-(
      • carlierdC
        carlierdC
        carlierd
        The error is because I enable the signing function !
        Remove the following line:
        And replace
        by
        MySensor node(transport, hw);
        I don't know who had the best sketch.
        I measure internal battery status using the 1.1 reference.
        David.
        • D
          Dylano
          When i put this sketch in to a nano..
          With a 9volt battery....
          How long do think this working?
          Or how long is this acting on your 3 volt battery's?
          • carlierdC
            carlierdC
            carlierd
            It depends on the activity close to the sensor so not possible to say but some people reach several month without problem.
            In my house it's very fresh so I have not a lot of feedback to give.
            David.
            • D
              Dylano
              #50
              5 days....:-1: on a 9volt block
              The sketch on a nano
              On my toilet.... so not a very busy room
              Is there some one that live longer, with this sketch......?
              • icebobI icebob
                @the-cosmic-gate Nothing special. I made a big sketch, which contains 7-8 sensors (DHT, Si7021, MQ-2/9, PIR, Door magnet, Light, battery) reading code because I would like to upload the same sketch to all nodes and configurate it on controller side, which sensors is on the node and need to read.
                But currently I reached the limit with I2C includes, so I need to think over this solution.
                Dylano
                Dear..
                Did you finish your big code....
                • carlierdC
                  carlierdC
                  carlierd
                  9v means that you are using a voltage regulator which probably consumes a lot of power.
                  Why not using AA or AAA battery directly connected to Vcc ?
                  David
                  D 1 Reply Last reply
                  • carlierdC carlierd
                    David
                    Dylano
                    David
                    Motion and DHT needed 5volt i wash thinking..?
                    So 9 @ the vcc should be strong enough i was thinking.
                    And i do have @ the same time 3.5 for the radio
                    Are the extern step up better than the step down on a nano?
                    • carlierdC
                      carlierdC
                      carlierd
                      The motion can be adapt to run on 3v easily (connect the Vcc to the H pad if available. You can find information on the forum). The DHT could also run on 3v. I have several nodes like that. No problem.
                      Can't reply for the step-up because I don't use it.
                      David.
                        David.
                        Dylano
                        David.
                        @ David
                        How long is the 3v battery running whit this option?
                        • carlierdC
                          carlierdC
                          carlierd
                          @Dylano : My nodes are really new so difficult to say exactly but for the moment the oldest node was started one month ago (04/02) and battery still at 3.32v.
                          David.
                          • the cosmic gateT
                            the cosmic gateT
                            the cosmic gate
                            i'am back in business after the "big move" and going to try again to get this 4:1 sensor working for a long time uning 2 x AA batteries.
                            If someone has some new input, please let me know :) and feel free to change the sketch
                            There's more than meets the eye
                            carlierdC 1 Reply Last reply
                            • the cosmic gateT the cosmic gate
                              carlierdC
                              carlierdC
                              carlierd
                              @the-cosmic-gate
                              Motion nodes are still working correctly. The oldest node started the 4 of February is still at 3,29v. My other nodes (temp / humidity / light) are also working correctly but I will replace DHT22 for another sensor.
                              David.
                              • rhuehnR
                                rhuehnR
                                rhuehn
                                Hey @carlierd Just curious if you are still using a DHT22 with your sketch? Have you modified the code much from the above? I am looking at implementing something similiar ( identical actually ) and was wondering if much has changed for you over the last few months?
                                • carlierdC
                                  carlierdC
                                  carlierd
                                  All nodes are still working correctly but I still want to replace DHT22. But nothing done for the moment. Not at top position on my todo list ;)
                                  David.
