  3. 3 in 1 incl battery monitor
60 Posts 11 Posters 37.1k Views 12 Watching
  • D
    Dylano
    When i put this sketch in to a nano..
    With a 9volt battery....
    How long do think this working?
    Or how long is this acting on your 3 volt battery's?
    Domoticz, with a lot of working hardware, include mysensors :-)
    OpenPLI, RuneAudio, Solarmeter, etc......
    Not a great builder of software and hardware, more a user...
    Only i try to do my best :-(
    • carlierdC
      carlierdC
      carlierd
      It depends on the activity close to the sensor so not possible to say but some people reach several month without problem.
      In my house it's very fresh so I have not a lot of feedback to give.
      David.
      • D
        Dylano
        wrote on last edited by Dylano
        #50
        5 days....:-1: on a 9volt block
        The sketch on a nano
        On my toilet.... so not a very busy room
        Is there some one that live longer, with this sketch......?
        • icebobI icebob
          @the-cosmic-gate Nothing special. I made a big sketch, which contains 7-8 sensors (DHT, Si7021, MQ-2/9, PIR, Door magnet, Light, battery) reading code because I would like to upload the same sketch to all nodes and configurate it on controller side, which sensors is on the node and need to read.
          But currently I reached the limit with I2C includes, so I need to think over this solution.
          Dylano
          Dear..
          Did you finish your big code....
          • carlierdC
            carlierdC
            carlierd
            9v means that you are using a voltage regulator which probably consumes a lot of power.
            Why not using AA or AAA battery directly connected to Vcc ?
            David
            D 1 Reply Last reply
            • carlierdC carlierd
              David
              Dylano
              David
              Motion and DHT needed 5volt i wash thinking..?
              So 9 @ the vcc should be strong enough i was thinking.
              And i do have @ the same time 3.5 for the radio
              Are the extern step up better than the step down on a nano?
              • carlierdC
                carlierdC
                carlierd
                The motion can be adapt to run on 3v easily (connect the Vcc to the H pad if available. You can find information on the forum). The DHT could also run on 3v. I have several nodes like that. No problem.
                Can't reply for the step-up because I don't use it.
                David.
                  David.
                  Dylano
                  David.
                  @ David
                  How long is the 3v battery running whit this option?
                  • carlierdC
                    carlierdC
                    carlierd
                    @Dylano : My nodes are really new so difficult to say exactly but for the moment the oldest node was started one month ago (04/02) and battery still at 3.32v.
                    David.
                    • the cosmic gateT
                      the cosmic gateT
                      the cosmic gate
                      i'am back in business after the "big move" and going to try again to get this 4:1 sensor working for a long time uning 2 x AA batteries.
                      If someone has some new input, please let me know :) and feel free to change the sketch
                      There's more than meets the eye
                      carlierdC 1 Reply Last reply
                      • the cosmic gateT the cosmic gate
                        carlierdC
                        carlierdC
                        carlierd
                        @the-cosmic-gate
                        Motion nodes are still working correctly. The oldest node started the 4 of February is still at 3,29v. My other nodes (temp / humidity / light) are also working correctly but I will replace DHT22 for another sensor.
                        David.
                        • rhuehnR
                          rhuehnR
                          rhuehn
                          Hey @carlierd Just curious if you are still using a DHT22 with your sketch? Have you modified the code much from the above? I am looking at implementing something similiar ( identical actually ) and was wondering if much has changed for you over the last few months?
                          • carlierdC
                            carlierdC
                            carlierd
                            All nodes are still working correctly but I still want to replace DHT22. But nothing done for the moment. Not at top position on my todo list ;)
                            David.
