  3. Home Assistant
  4. Any plan to implement Ethernet GW?
69 Posts 5 Posters 26.4k Views 6 Watching
    @drock1985
    Can you post your error log? Try installing netdisco manually with pip.
    drock1985
    @martinhjelmare
    I tried manually installing Netdisco, but it won't compile. I get an error complaining about gcc failing with error status 1.
    The config file it looks for is in my normal home folder (which I assume is correct). The only error in the log is that it could not initialize discovery because dependency netdisco 0.5.2 could not be installed.
    I think I will try this again tomorrow with Debian or Ubuntu... seems to be a more favorable distro to install Home-Assistant to. I think I even may have an old Pi still kicking around.
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • D drock1985
      @martinhjelmare
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @drock1985
      You don't need discovery for mysensors, so you could disable that in the config if you don't have any other component that you want to activate which need discovery.
      Do you have gcc installed and general packages for building, usually called build tools, build-essentials etc?
      D 1 Reply Last reply
        @drock1985
        drock1985
        @martinhjelmare
        Haven't tried build-tools (tried build-essential, it couldn't find any packages) and I do have GCC installed.
        Will try again when i'm done work for the evening and see what happens.
        My Projects
        2 Door Chime Sensor
        • D drock1985
          @martinhjelmare
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @drock1985
          I think it's called development tools for Fedora. Google it.
          If you can post the build log message, I could advise better. It could be a specific lib package that is missing for the compile. The log will usually give some hint on what's missing.
          • martinhjelmareM
            martinhjelmareM
            martinhjelmare
            I've updated the branch at my fork of pymysensors. If you have installed the ethernet branch of my fork of home-assistant, you should uninstall/reinstall that, or just make a new virtual environment and install again. You should remove the lib directory in your home assistant config directory as well.
            Eg:
            rm -r ~/.homeassistant/lib
            mkvirtualenv -p /usr/bin/python3 hasstest2
            cd ~/dev/home-assistant
            git branch -D mysensors-tcp-gateway
            git fetch origin mysensors-tcp-gateway
            git checkout mysensors-tcp-gateway
            pip3 install -e .
            pip3 install colorlog
            pip3 install python-Levenshtein
            • D
              drock1985
              @martinhjelmare
              This is the error I am getting when starting up HASS.
              (hasstest) pi@pitest:~/dev/home-assistant $ hass
              Config directory: /home/pi/.homeassistant
              16-03-05 20:07:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant>
              16-03-05 20:07:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant>
              16-03-05 20:07:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=toggle, domain=homeassistant>
              16-03-05 20:07:57 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
              16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
              16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
              16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
              16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded introduction from homeassistant.components.introduction
              16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater
              16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation
              16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded mysensors from homeassistant.components.mysensors
              16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
              16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun
              16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery
              16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
              16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
              16-03-05 20:07:59 INFO (MainThread) [homeassistant.components.introduction]
                      Hello, and welcome to Home Assistant!
                      We'll hope that we can make all your dreams come true.
                      Here are some resources to get started:
                       - Configuring Home Assistant:
                         https://home-assistant.io/getting-started/configuration/
                       - Available components:
                         https://home-assistant.io/components/
                       - Troubleshooting your configuration:
                         https://home-assistant.io/getting-started/troubleshooting-configuration/
                       - Getting help:
                         https://home-assistant.io/help/
                      This message is generated by the introduction component. You can
                      disable it in configuration.yaml.
              16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=introduction>
              16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=recorder>
              16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=http>
              16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=history>
              16-03-05 20:07:59 INFO (MainThread) [requests.packages.urllib3.connectionpool] Starting new HTTPS connection (1): pypi.python.org
              16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state updater.updater=0.14.2; friendly_name=Update Available @ 20:08:00 05-03-2016>, entity_id=updater.updater>
              16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=updater>
              16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=process, domain=conversation>
              16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=conversation>
              16-03-05 20:08:00 ERROR (MainThread) [homeassistant.components.mysensors] Missing required configuration items in mysensors: port
              16-03-05 20:08:00 ERROR (MainThread) [homeassistant.bootstrap] component mysensors failed to initialize
              16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=log, domain=logbook>
              16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=logbook>
              16-03-05 20:08:00 INFO (MainThread) [requests.packages.urllib3.connectionpool] Starting new HTTP connection (1): maps.googleapis.com
              16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state sun.sun=below_horizon; next_setting=22:12:29 06-03-2016, elevation=-21.55, next_rising=10:44:01 06-03-2016, friendly_name=Sun @ 20:08:01 05-03-2016>, entity_id=sun.sun>
              16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sun>
              16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=discovery>
              16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=api>
              16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=frontend>
              16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Starting Home Assistant (13 threads)
              16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_start[L]>
              16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
              16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=restart, domain=homeassistant>
              16-03-05 20:08:01 INFO (Thread-17) [homeassistant.components.http] Starting web interface at http://0.0.0.0:8123
              16-03-05 20:08:01 INFO (Thread-15) [homeassistant.core] Timer:starting
              16-03-05 20:08:01 INFO (Thread-18) [homeassistant.components.http] "GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
              16-03-05 20:08:01 INFO (Thread-19) [homeassistant.components.http] "GET /api/bootstrap HTTP/1.1" 200 -^C16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Stopping
              16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_stop[L]>
              16-03-05 20:08:02 INFO (Thread-16) [netdisco.service] Scanning
              ^CProcess Process-1:
                File "/home/pi/.virtualenvs/hasstest/bin/hass", line 9, in <module>
                  load_entry_point('homeassistant', 'console_scripts', 'hass')()
                File "/home/pi/dev/home-assistant/homeassistant/__main__.py", line 330, in main
                  keep_running, exit_code = run_hass_process(hass_proc)
                File "/usr/lib/python3.4/multiprocessing/process.py", line 254, in _bootstrap
                  self.run()
                File "/usr/lib/python3.4/multiprocessing/process.py", line 93, in run
                  self._target(*self._args, **self._kwargs)
                File "/home/pi/dev/home-assistant/homeassistant/__main__.py", line 248, in setup_and_run_hass
                  exit_code = int(hass.block_till_stopped())
              TypeError: 'bool' object is not iterable
                File "/home/pi/dev/home-assistant/homeassistant/core.py", line 100, in block_till_stopped
                  self.stop()
                File "/home/pi/dev/home-assistant/homeassistant/core.py", line 107, in stop
                  self.pool.stop()
                File "/home/pi/dev/home-assistant/homeassistant/util/__init__.py", line 364, in stop
                  self.block_till_done()
                File "/home/pi/dev/home-assistant/homeassistant/util/__init__.py", line 358, in block_till_done
                  self._work_queue.join()
                File "/usr/lib/python3.4/queue.py", line 86, in join
                  self.all_tasks_done.wait()
                File "/usr/lib/python3.4/threading.py", line 290, in wait
                  waiter.acquire()
              KeyboardInterrupt
               mysensors:
                 gateways:
                   - device: '192.168.1.10'
                     persistence_file: '~/.homeassistant/mysensors3.json'
                     tcp_port: 5003
                 debug: true
                 persistence: true
                 version: '1.5'
              My Projects
              2 Door Chime Sensor
              • D drock1985
                @martinhjelmare
                         - Getting help:
                    self.run()
                    self.stop()
                    self.pool.stop()
                    waiter.acquire()
                KeyboardInterrupt
                 mysensors:
                   gateways:
                       tcp_port: 5003
                   debug: true
                   persistence: true
                   version: '1.5'
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @drock1985
                Did you checkout correct branch?
                You should remove the lib directory in ~/.homeassistant/ before you start hass again after the git checkout also.
                • D
                  drock1985
                  Ugh, forgot to run the checkout command. palm smacks head
                  Booting now, will report back in a minute if it is working or not.
                  My Projects
                  2 Door Chime Sensor
                  • D drock1985
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @drock1985
                    Don't forget to use the correct ip address of your gateway in your network.
                    • D
                      drock1985
                      wrote on last edited by drock1985
                      #22
                      @martinhjelmare
                      It works! Found my motion sensor with ease. Will start adding lights now shortly
                      Thanks again, loving this.
                      EDIT: Quick question: To autostart this, would I just use the normal Home-Assistant instructions in the virtualenv, or is there another method to do it?
                      My Projects
                      2 Door Chime Sensor
                      • D drock1985
                        @martinhjelmare
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        #23
                        @drock1985
                        :thumbsup:
                        When you have time, can you run git log and tell me the top commit message, so I know which version you are using.
                        Regarding autostart, no I don't think you can use the normal instructions together with the virtualenv. You could write a script, that changes to the virtualenv and starts hass, and run that script at login or similar.
                        If you don't have another production install of home assistant on the computer, you can skip the virtualenv alltogether and just do:
                        pip3 install --user "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"
                        or if you want to install as root:
                        sudo pip3 install "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"
                        This way you should be able to autostart the usual way, per instructions on the web.
                        But then if you want to test an update from me, you have to make sure you uninstall everything correctly and manually remove ~/.homeassistant/lib before you install again.
                        Dave DanD 1 Reply Last reply
                        • D
                          drock1985
                          @martinhjelmare
                          Here is the info you requested:
                          commit d07f8097a6186611371b8bc918fcb0d436bb39ba
                          Author: MartinHjelmare <marhje52@kth.se>
                          Date:   Sat Feb 27 04:55:38 2016 +0100
                              Add mysensors tcp ethernet gateway
                              * Replace CONF_PORT with CONF_DEVICE and ATTR_PORT with ATTR_DEVICE.
                              * Add tcp_port in config.
                              * Use fork pymysensors repo, temporarily.
                              * Try to guess if tcp or serial gateway is configured, by validating
                                  device name as an ip address. If successful setup tcp gateway, if it
                                  fails, setup serial gateway.
                              * Update device_state_attributes to show correct device, ethernet or
                                  serial.
                          commit 278fdc0983a8528945e13cf912da82f3bc5fe14c
                          Merge: 6dc49df 8ffa368
                          Author: Daniel Høyer Iversen <daniel.h.iversen@ntnu.no>
                          Date:   Fri Feb 26 10:49:10 2016 +0100
                              Merge pull request #1385 from balloob/rfxtrx
                              improve rfxtrx sensor
                          My Projects
                          2 Door Chime Sensor
                          • D drock1985
                            @martinhjelmare
                                    serial.
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            #25
                            @drock1985
                            Sorry, I forgot I've only updated the pymysensors project, so you checking the home-assistant git log is no use. Well, I think your're running the lastest version anyway, since you got it working just now. Everything should be ok.
                            Let me know if you experience any problems.
                            If everything seems ok for you after some time of testing, I don't see why we can't release this very soon. My limited testing after the lastest update, show no problems.
                            • Dave DanD
                              Dave DanD
                              Dave Dan
                              Hey @martinhjelmare,
                              I finally got this working.
                              I'm doing tests with a couple of multi-sensors (Temp, Hum, Light & motion). The discovery worked very well, no issue at all after following all the above steps.
                              What I'm not seeing wotking are the updates. I always see the same values. I'm checking messages with MYSController and I see the GW is receiving the events and updates but I can't see new values showing in the portal.
                              Still testing ...
                              • Dave DanD Dave Dan
                                Still testing ...
                                martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                @Dave-Dan
                                Do you mean that the sensors are not showing the latest values in the gui?
                                If the last value from a sensor is the same as the previous value, a state change won't happen. So the value will be reported as being as old as the previous value. Could this explain what you see?
                                • Dave DanD
                                  Dave DanD
                                  Dave Dan
                                  actually, I just got it working ...
                                  yes, I was referrring to that. The way I have built the sensor is that everytime a movement is detected is sending all sensors statuses to the GW. This sensors are designed to be plugged (no battery powered) so no concern on power consumption.
                                  I restarted the server and now updates are working.
                                  What I'm seeing in the log is constantly this message:
                                  16-03-14 10:39:53 INFO (Thread-9) [mysensors.mysensors] Permission denied when writing to /home/pi/dev/home-assistant/path/mysensors3.json
                                  If I'm not wrong this is the persistence.
                                  Apart of this I now see updates coming in ...
                                  • martinhjelmareM
                                    martinhjelmareM
                                    martinhjelmare
                                    Good!
                                    The path to the persistence file must exist, not the file itself, but the directory tree above, and hass should have write permission to it.
                                    I usually put the file in the same directory as configuration.yml.
                                    • Dave DanD
                                      Dave DanD
                                      Dave Dan
                                      Ok, couple of things that I'm seeing now.
                                      1. Everytime I restart the server the MySensor nodes are no longer in the system. I have to restart them to get them in again. All of them are in the persistence file.
                                      2. Now i can only have 1 node added.
                                        While in the persistence file I see multiple nodes, once I add one of them I can't add anymore. No error if fired (at least not that I've seen).
                                        martinhjelmareM
                                        martinhjelmareM
                                        martinhjelmare
                                        @Dave-Dan
                                        Can you attach the persistence file here and post your config, and I'll take a look?
                                        • Dave DanD
                                          Dave DanD
                                          Dave Dan
                                          wrote on last edited by Dave Dan
                                          #32
                                          Sure!
                                          Consistence file:
                                          {"156": {"sketch_version": null, "children": {}, "battery_level": 0, "sketch_name": null, "type": 17, "sensor_id": 156}, "102": {"sketch_version": null, "children": {}, "battery_level": 0, "sketch_name": null, "type": 17, "sensor_id": 102}}
                                          the Configuration is very light. Actually is the by default config and i just added this to test MySensors:
                                          mysensors:
                                            gateways:
                                              - device: 192.168.1.X
                                                persistence_file: '/home/pi/.homeassistant/MSPersistence.json'
                                                tcp_port: 5003
                                            debug: true
                                            persistence: true
                                            version: '1.5'
                                          let me know if you need anything else.
