  3. Home Assistant
  4. Any plan to implement Ethernet GW?
69 Posts 5 Posters 26.4k Views 6 Watching
  • D drock1985
    @martinhjelmare
    Haven't tried build-tools (tried build-essential, it couldn't find any packages) and I do have GCC installed.
    Will try again when i'm done work for the evening and see what happens.
    martinhjelmareM
    martinhjelmareM
    martinhjelmare
    @drock1985
    I think it's called development tools for Fedora. Google it.
    If you can post the build log message, I could advise better. It could be a specific lib package that is missing for the compile. The log will usually give some hint on what's missing.
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      I've updated the branch at my fork of pymysensors. If you have installed the ethernet branch of my fork of home-assistant, you should uninstall/reinstall that, or just make a new virtual environment and install again. You should remove the lib directory in your home assistant config directory as well.
      Eg:
      rm -r ~/.homeassistant/lib
      mkvirtualenv -p /usr/bin/python3 hasstest2
      cd ~/dev/home-assistant
      git branch -D mysensors-tcp-gateway
      git fetch origin mysensors-tcp-gateway
      git checkout mysensors-tcp-gateway
      pip3 install -e .
      pip3 install colorlog
      pip3 install python-Levenshtein
      • D
        drock1985
        @martinhjelmare
        This is the error I am getting when starting up HASS.
        (hasstest) pi@pitest:~/dev/home-assistant $ hass
        Config directory: /home/pi/.homeassistant
        16-03-05 20:07:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant>
        16-03-05 20:07:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant>
        16-03-05 20:07:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=toggle, domain=homeassistant>
        16-03-05 20:07:57 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
        16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
        16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
        16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
        16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded introduction from homeassistant.components.introduction
        16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater
        16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation
        16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded mysensors from homeassistant.components.mysensors
        16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
        16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun
        16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery
        16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
        16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
        16-03-05 20:07:59 INFO (MainThread) [homeassistant.components.introduction]
                Hello, and welcome to Home Assistant!
                We'll hope that we can make all your dreams come true.
                Here are some resources to get started:
                 - Configuring Home Assistant:
                   https://home-assistant.io/getting-started/configuration/
                 - Available components:
                   https://home-assistant.io/components/
                 - Troubleshooting your configuration:
                   https://home-assistant.io/getting-started/troubleshooting-configuration/
                 - Getting help:
                   https://home-assistant.io/help/
                This message is generated by the introduction component. You can
                disable it in configuration.yaml.
        16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=introduction>
        16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=recorder>
        16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=http>
        16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=history>
        16-03-05 20:07:59 INFO (MainThread) [requests.packages.urllib3.connectionpool] Starting new HTTPS connection (1): pypi.python.org
        16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state updater.updater=0.14.2; friendly_name=Update Available @ 20:08:00 05-03-2016>, entity_id=updater.updater>
        16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=updater>
        16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=process, domain=conversation>
        16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=conversation>
        16-03-05 20:08:00 ERROR (MainThread) [homeassistant.components.mysensors] Missing required configuration items in mysensors: port
        16-03-05 20:08:00 ERROR (MainThread) [homeassistant.bootstrap] component mysensors failed to initialize
        16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=log, domain=logbook>
        16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=logbook>
        16-03-05 20:08:00 INFO (MainThread) [requests.packages.urllib3.connectionpool] Starting new HTTP connection (1): maps.googleapis.com
        16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state sun.sun=below_horizon; next_setting=22:12:29 06-03-2016, elevation=-21.55, next_rising=10:44:01 06-03-2016, friendly_name=Sun @ 20:08:01 05-03-2016>, entity_id=sun.sun>
        16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sun>
        16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=discovery>
        16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=api>
        16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=frontend>
        16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Starting Home Assistant (13 threads)
        16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_start[L]>
        16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
        16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=restart, domain=homeassistant>
        16-03-05 20:08:01 INFO (Thread-17) [homeassistant.components.http] Starting web interface at http://0.0.0.0:8123
        16-03-05 20:08:01 INFO (Thread-15) [homeassistant.core] Timer:starting
        16-03-05 20:08:01 INFO (Thread-18) [homeassistant.components.http] "GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
        16-03-05 20:08:01 INFO (Thread-19) [homeassistant.components.http] "GET /api/bootstrap HTTP/1.1" 200 -^C16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Stopping
        16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_stop[L]>
        16-03-05 20:08:02 INFO (Thread-16) [netdisco.service] Scanning
        ^CProcess Process-1:
          File "/home/pi/.virtualenvs/hasstest/bin/hass", line 9, in <module>
            load_entry_point('homeassistant', 'console_scripts', 'hass')()
          File "/home/pi/dev/home-assistant/homeassistant/__main__.py", line 330, in main
            keep_running, exit_code = run_hass_process(hass_proc)
          File "/usr/lib/python3.4/multiprocessing/process.py", line 254, in _bootstrap
            self.run()
          File "/usr/lib/python3.4/multiprocessing/process.py", line 93, in run
            self._target(*self._args, **self._kwargs)
          File "/home/pi/dev/home-assistant/homeassistant/__main__.py", line 248, in setup_and_run_hass
            exit_code = int(hass.block_till_stopped())
        TypeError: 'bool' object is not iterable
          File "/home/pi/dev/home-assistant/homeassistant/core.py", line 100, in block_till_stopped
            self.stop()
          File "/home/pi/dev/home-assistant/homeassistant/core.py", line 107, in stop
            self.pool.stop()
          File "/home/pi/dev/home-assistant/homeassistant/util/__init__.py", line 364, in stop
            self.block_till_done()
          File "/home/pi/dev/home-assistant/homeassistant/util/__init__.py", line 358, in block_till_done
            self._work_queue.join()
          File "/usr/lib/python3.4/queue.py", line 86, in join
            self.all_tasks_done.wait()
          File "/usr/lib/python3.4/threading.py", line 290, in wait
            waiter.acquire()
        KeyboardInterrupt
         mysensors:
           gateways:
             - device: '192.168.1.10'
               persistence_file: '~/.homeassistant/mysensors3.json'
               tcp_port: 5003
           debug: true
           persistence: true
           version: '1.5'
        My Projects
        2 Door Chime Sensor
        Washing Machine Monitor
        • D drock1985
          @martinhjelmare
                   - Getting help:
              self.run()
              self.stop()
              self.pool.stop()
              waiter.acquire()
          KeyboardInterrupt
           mysensors:
             gateways:
                 tcp_port: 5003
             debug: true
             persistence: true
             version: '1.5'
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @drock1985
          Did you checkout correct branch?
          You should remove the lib directory in ~/.homeassistant/ before you start hass again after the git checkout also.
          • D
            drock1985
            Ugh, forgot to run the checkout command. palm smacks head
            Booting now, will report back in a minute if it is working or not.
            My Projects
            2 Door Chime Sensor
            • D drock1985
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @drock1985
              Don't forget to use the correct ip address of your gateway in your network.
              • D
                drock1985
                wrote on last edited by drock1985
                #22
                @martinhjelmare
                It works! Found my motion sensor with ease. Will start adding lights now shortly
                Thanks again, loving this.
                EDIT: Quick question: To autostart this, would I just use the normal Home-Assistant instructions in the virtualenv, or is there another method to do it?
                My Projects
                2 Door Chime Sensor
                • D drock1985
                  @martinhjelmare
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  #23
                  @drock1985
                  :thumbsup:
                  When you have time, can you run git log and tell me the top commit message, so I know which version you are using.
                  Regarding autostart, no I don't think you can use the normal instructions together with the virtualenv. You could write a script, that changes to the virtualenv and starts hass, and run that script at login or similar.
                  If you don't have another production install of home assistant on the computer, you can skip the virtualenv alltogether and just do:
                  pip3 install --user "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"
                  or if you want to install as root:
                  sudo pip3 install "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"
                  This way you should be able to autostart the usual way, per instructions on the web.
                  But then if you want to test an update from me, you have to make sure you uninstall everything correctly and manually remove ~/.homeassistant/lib before you install again.
                  Dave DanD 1 Reply Last reply
                  • D
                    drock1985
                    @martinhjelmare
                    Here is the info you requested:
                    commit d07f8097a6186611371b8bc918fcb0d436bb39ba
                    Author: MartinHjelmare <marhje52@kth.se>
                    Date:   Sat Feb 27 04:55:38 2016 +0100
                        Add mysensors tcp ethernet gateway
                        * Replace CONF_PORT with CONF_DEVICE and ATTR_PORT with ATTR_DEVICE.
                        * Add tcp_port in config.
                        * Use fork pymysensors repo, temporarily.
                        * Try to guess if tcp or serial gateway is configured, by validating
                            device name as an ip address. If successful setup tcp gateway, if it
                            fails, setup serial gateway.
                        * Update device_state_attributes to show correct device, ethernet or
                            serial.
                    commit 278fdc0983a8528945e13cf912da82f3bc5fe14c
                    Merge: 6dc49df 8ffa368
                    Author: Daniel Høyer Iversen <daniel.h.iversen@ntnu.no>
                    Date:   Fri Feb 26 10:49:10 2016 +0100
                        Merge pull request #1385 from balloob/rfxtrx
                        improve rfxtrx sensor
                    My Projects
                    2 Door Chime Sensor
                    • D drock1985
                      @martinhjelmare
                              serial.
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      #25
                      @drock1985
                      Sorry, I forgot I've only updated the pymysensors project, so you checking the home-assistant git log is no use. Well, I think your're running the lastest version anyway, since you got it working just now. Everything should be ok.
                      Let me know if you experience any problems.
                      If everything seems ok for you after some time of testing, I don't see why we can't release this very soon. My limited testing after the lastest update, show no problems.
                      • Dave DanD
                        Dave DanD
                        Dave Dan
                        Hey @martinhjelmare,
                        I finally got this working.
                        I'm doing tests with a couple of multi-sensors (Temp, Hum, Light & motion). The discovery worked very well, no issue at all after following all the above steps.
                        What I'm not seeing wotking are the updates. I always see the same values. I'm checking messages with MYSController and I see the GW is receiving the events and updates but I can't see new values showing in the portal.
                        Still testing ...
                        • Dave DanD Dave Dan
                          Still testing ...
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @Dave-Dan
                          Do you mean that the sensors are not showing the latest values in the gui?
                          If the last value from a sensor is the same as the previous value, a state change won't happen. So the value will be reported as being as old as the previous value. Could this explain what you see?
                          • Dave DanD
                            Dave DanD
                            Dave Dan
                            actually, I just got it working ...
                            yes, I was referrring to that. The way I have built the sensor is that everytime a movement is detected is sending all sensors statuses to the GW. This sensors are designed to be plugged (no battery powered) so no concern on power consumption.
                            I restarted the server and now updates are working.
                            What I'm seeing in the log is constantly this message:
                            16-03-14 10:39:53 INFO (Thread-9) [mysensors.mysensors] Permission denied when writing to /home/pi/dev/home-assistant/path/mysensors3.json
                            If I'm not wrong this is the persistence.
                            Apart of this I now see updates coming in ...
                            • martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              Good!
                              The path to the persistence file must exist, not the file itself, but the directory tree above, and hass should have write permission to it.
                              I usually put the file in the same directory as configuration.yml.
                              • Dave DanD
                                Dave DanD
                                Dave Dan
                                Ok, couple of things that I'm seeing now.
                                1. Everytime I restart the server the MySensor nodes are no longer in the system. I have to restart them to get them in again. All of them are in the persistence file.
                                2. Now i can only have 1 node added.
                                  While in the persistence file I see multiple nodes, once I add one of them I can't add anymore. No error if fired (at least not that I've seen).
                                  martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  @Dave-Dan
                                  Can you attach the persistence file here and post your config, and I'll take a look?
                                  • Dave DanD
                                    Dave DanD
                                    Dave Dan
                                    wrote on last edited by Dave Dan
                                    #32
                                    Sure!
                                    Consistence file:
                                    {"156": {"sketch_version": null, "children": {}, "battery_level": 0, "sketch_name": null, "type": 17, "sensor_id": 156}, "102": {"sketch_version": null, "children": {}, "battery_level": 0, "sketch_name": null, "type": 17, "sensor_id": 102}}
                                    the Configuration is very light. Actually is the by default config and i just added this to test MySensors:
                                    mysensors:
                                      gateways:
                                        - device: 192.168.1.X
                                          persistence_file: '/home/pi/.homeassistant/MSPersistence.json'
                                          tcp_port: 5003
                                      debug: true
                                      persistence: true
                                      version: '1.5'
                                    let me know if you need anything else.
                                    • martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      In the persistence file I can see two issues.
                                      Sketch name is null for both nodes.
                                      Both nodes don't have any children.
                                      Are you using a non default example sketch, if so can you post it?
                                      • Dave DanD
                                        Dave DanD
                                        Dave Dan
                                        hey Martin,
                                        that's correct, those are the 2 items I saw that was little curious about.
                                        The sketch I'm using, while custom, is a mix of different sketches that can be found in the MySensors page.
                                        As you'll see below, each node (which are identical) have all the information (Sketch name, version, etc). And all of them have 4 childs:
                                        - Ambient Humidity
                                        - Ambient Temperature
                                        - Ambient Light
                                        - Movement (Motion Sensor Trip).
                                        But I might have something wrong so ... happy to learn! :)
                                        #define NODE_ID 102
                                        #define SKETCH_NAME "dyaSensor (HTLM) v1.2"
                                        #define SKETCH_VERSION "1.2"
                                        #define CHILD_ID_HUM 0
                                        #define CHILD_ID_TEMP 1
                                        #define CHILD_ID_LIGHT 2
                                        #define CHILD_ID_MOV 3
                                        #defin TEMP_CORRECTION 2
                                        unsigned long SLEEP_TIME = 1000; // Sleep time between reads (in milliseconds)
                                        DHT dht;
                                        float lastTemp;
                                        float lastHum;
                                        int lastLightLevel;
                                        boolean metric = true;
                                        //Building Messages
                                        MyMessage msgHum(CHILD_ID_HUM, V_HUM);            // Initialize humidity message
                                        MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);         // Initialize temperature message
                                        MyMessage msgLum(CHILD_ID_LIGHT, V_LIGHT_LEVEL);  // Initialize Light message
                                        MyMessage msgMov(CHILD_ID_MOV, V_TRIPPED);        // Initialize motion message
                                          gw.begin(NULL, NODE_ID, false);
                                          Serial.println("Presenting Humidity Sensor");
                                          gw.present(CHILD_ID_HUM, S_HUM, "Humidity Sensor");
                                          Serial.println("Presenting Temperature Sensor");
                                          gw.present(CHILD_ID_TEMP, S_TEMP, "Temperature Sensor");
                                          Serial.println("Light Level Sensor");
                                          gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL, "Light Level Sensor");
                                          Serial.println("Presenting Motion Sensor");
                                          gw.present(CHILD_ID_MOV, S_MOTION, "Motion Sensor");
                                          // By calling process() you route messages in the background
                                          float temperature = dht.getTemperature()-TEMP_CORRECTION;
                                          if (isnan(temperature)) {
                                            lastTemp = temperature;
                                            if (!metric) {
                                            Serial.print("- T: ");
                                          if (isnan(humidity)) {
                                              lastHum = humidity;
                                              Serial.print("- H: ");
                                              Serial.println(humidity);
                                          int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                                            lastLightLevel = lightLevel;
                                            gw.send(msgLum.set(lightLevel));
                                            Serial.print("- L: ");
                                            Serial.println(lightLevel);
                                          // Read digital motion value
                                          gw.send(msgMov.set(tripped?"1":"0"));  // Send tripped value to gw
                                          Serial.println(tripped?"- Movement Detected":"- No Movement Detected");
                                          gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                                          @drock1985
                                          :thumbsup:
                                          Dave DanD
                                          Dave DanD
                                          Dave Dan
                                          #35
                                          Hey @martinhjelmare
                                          Does the above reply to @drock1985 means that I can do a basic installation as per https://home-assistant.io/
                                          pip3 install homeassistant
                                          hass --open-ui
                                          followed by
                                          and will have a valid testing env without going into all the above steps of creating a virtualenv??
                                          If so I'd rather more this avenue because I can clean up everything with a new installation, install the zip and have a new testing env in minutes :)
                                          martinhjelmareM 2 Replies Last reply
