  3. SceneController
SceneController
28 Posts 9 Posters 19.8k Views 5 Watching
    I haven't played with scene-controllers. Do you run a Vera controller or have something else?
    • D
      Dalhoj
      I have the vera controller, and would like to make a node that acts like ie. The battery operated remotes you can get in z wave, so you can trigger scenes.
      • greglG
        greglG
        gregl
        Actually this is a pretty good idea.
        A zwave scene controller is roughly $50..i have an Aeon one. and yeah its ok function wise, but its pretty ugly. I thought i would open it up and wire its buttons to a nicer wall plate.( Something like the Clipsal Saturn plate...which is going to make it very $$$ but would look great.)
        So to save $$ by using a mysensors battery board/devDuino2 running a "scene Controller" sketch would be pretty nice!
        @hek - the Vera device files used by a scene controller are
        urn:schemas-micasaverde-com:device:SceneController:1
        D_SceneController1.xml
        Do you think these are able to be controlled by a mySensor device?
        hekH 1 Reply Last reply
        • greglG gregl
          wrote on last edited by hek
          @gregl
          Yes it is possible. Just don't know when I have time to do the necessary tests. Anyone want do do some tests on what variables we need to activate/deactivate scenes etc?
          I think ** NumButtons**, sl_SceneActivated and ** sl_SceneDeactivated** is involved.
          • greglG
            greglG
            gregl
            @hek said:
            sl_SceneActivated
            @hek - ill have a crack....but any idea where on vera these files reside?
            • greglG gregl
              @hek said:
              sl_SceneActivated
              @gregl
              Ok, added missing scene controller device (the SCENE_ON / SCENE_OFF variables was already there) to the 1.4 development branch.
              https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MyMessage.h#L58
              https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L74
              But I have no idea what happens if you create a SceneController device from your Arduino. When do you specify NumButtons? At creation time? That would be problematic as we today have no way of specifying custom data when doing sensor-presentation from Arduino.
              Edit: My post number 500!
                @gregl
                H
                H
                hhg
                @hek
                If you want buttons on the device widget I think you need to at some custom D_.xml and D_.js files (See AtiRemote in the rfxtrx code tree as an example)
                But in my experience the generic Scene Controller works fine "as is" - Just sent the "Button number" as the value:
                -- On button press
                luup.variable_set("urn:micasaverde-com:serviceId:SceneController1","sl_SceneActivated", button_no, device_no)
                -- On button release
                luup.variable_set("urn:micasaverde-com:serviceId:SceneController1","sl_SceneDeactivated", button_no, device_no)
                Please note: I have not tried this with MySensors - The above is from another Vera plugin I have written
                • D
                  Dalhoj
                  Im not home at the moment so I cant test, but found the guide to set up a z wave remote
                  http://wiki.zwaveeurope.com/index.php?title=KFOB_VERA
                  So I think you will have each button on the node to send a scene_on with the id of the button and then deactivate the scene again.
                  And then just a picture of my wall plate in danish design, with the arduino behind.
                  https://dl.dropboxusercontent.com/u/3260168/arduinotryk01.jpg
                  • H
                    H
                    hhg
                    In 1.4b1 1.4b1 (18848a2) Scene Controller support is present, and works fine
                    Present with:
                    gw.present(CHILD_ID, S_SCENE_CONTROLLER);
                    And it shows as a generic scene controller in Vera:
                    upload-af0688b3-9110-434f-a57c-aa34e808e0fe
                    The sketch to support a 4 button wall controller:
                    // Simple SceneController
                    #define CHILD_ID 3
                    // PIN for the buttons
                    byte buttons[] = {3, 4, 5, 6};
                    #define NUMBUTTONS sizeof(buttons)
                    byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
                    Bounce debouncer[NUMBUTTONS];
                    int oldValue[NUMBUTTONS];
                    MyMessage msgOn(CHILD_ID,V_SCENE_ON);
                    MyMessage msgOff(CHILD_ID,V_SCENE_OFF);
                      gw.begin();
                      /// Make input & enable pull-up resistors on switch pins
                      for (short i=0; i < NUMBUTTONS; i++){
                        pinMode(buttons[i], INPUT);
                        digitalWrite(buttons[i], HIGH);
                        oldValue[i] = -1;
                        debouncer[i].attach(buttons[i]);
                        debouncer[i].interval(5);
                      gw.sendSketchInfo("LK 4-Tryk", "1.0");
                        debouncer[i].update();
                        // Get the update value
                        if (value != oldValue[i]) {
                           // Send in the new value
                           if (value==HIGH) {
                             gw.send(msgOff.set(i));
                           else {
                             gw.send(msgOn.set(i));
                           oldValue[i] = value;
                    • korttomaK
                      korttomaK
                      korttoma
                      Sweet!! Thanks @hhg exactly what I need.
                      • Tomas
                      • androbotA
                        androbotA
                        androbot
                        I tried this out last night and discovered an interesting issue. A scene will activate once and deactivate once, but all subsequent changes are not applied. I confirmed in my Vera logs that the messages make it through to the unit, but the subsequent application of scene never happens after the first time.
                        I'm suspecting this is due to the "setVariableIfChanged" nature of the code in conjunction with the split V_SCENE_ON/V_SCENE_OFF messages. In other words, it's not a single variable that is toggling, it's two separate ones.
                          This most surely is the problem! I will have to make a mental note of it and fix it the next time I mess with the Vera plugin code.
                          • androbotA androbot
                            H
                            H
                            hhg
                            Nice spottet!
                            Change line 182 in L_Arduino.lua from
                             if ((value ~= curValue) or (curValue == nil)) then
                            to:
                            if ((value ~= curValue) or (curValue == nil) or (serviceId == "urn:micasaverde-com:serviceId:SceneController1")) then
                            So the sl_SceneActivated/sl_SceneDeactivated variables are updated unconditionally
                            androbotA 1 Reply Last reply
                            • H hhg
                              Nice spottet!
                              to:
                              androbotA
                              androbotA
                              androbot
                              @hhg
                              Worked like a charm!
                              • D
                                dayve218
                                hey guys, trying to set this one up, i have the widget displaying, but no control happening
                                pretty new to all of this so any help would be appreciated.
                                dayve
                                • D
                                  Dalhoj
                                  Hi
                                  After the Node and Scenecontroller shows up in the Vera UI you have to create a scene and then asign the scenecontroller as a trigger:
                                  For button 1 the scene number is 0
                                  for button 2 the scene number is 1 and so on.
                                  Hope is helps ;-)
                                  D 1 Reply Last reply
                                  • D
                                    dayve218
                                    @Dalhoj thanks for that, it seems super obvious now in retrospect.
                                    • D Dalhoj
                                      Hi
                                      Hope is helps ;-)
                                      dayve218
                                      @Dalhoj is it possible to have one button stop/start the same scene, as an on/off switch for a light for example?
                                      korttomaK hekH 2 Replies Last reply
                                      • D dayve218
                                        korttomaK
                                        korttomaK
                                        korttoma
                                        @dayve218
                                        If you use PLEG you could do it like this:
                                        Condition ----------------- Action
                                        LightOn AND Button = Turn Light Off
                                        LightOff AND Button = Turn Light On
                                        • Tomas
                                        • D dayve218
                                          @dayve218
                                          Some "scene controllers" I've seen triggers "scene off" when you push-and-hold button for say one a second.
