  3. SceneController
SceneController
28 Posts 9 Posters 19.9k Views 5 Watching
  • D
    Dalhoj
    Hi I have made a wall controller, but I'm using S_LIGHT as presentation. Is it possible to make it as S_SCENECONTROLLER1 insted. Then I only have one device and the node, insted of as now 4 devices and a node?
    I dont know if it possible. What I want is to make is a MySensor device that acts like a scene controller.
    Regards dalhoj
      I haven't played with scene-controllers. Do you run a Vera controller or have something else?
      • D
        Dalhoj
        I have the vera controller, and would like to make a node that acts like ie. The battery operated remotes you can get in z wave, so you can trigger scenes.
        • greglG
          greglG
          gregl
          Actually this is a pretty good idea.
          A zwave scene controller is roughly $50..i have an Aeon one. and yeah its ok function wise, but its pretty ugly. I thought i would open it up and wire its buttons to a nicer wall plate.( Something like the Clipsal Saturn plate...which is going to make it very $$$ but would look great.)
          So to save $$ by using a mysensors battery board/devDuino2 running a "scene Controller" sketch would be pretty nice!
          @hek - the Vera device files used by a scene controller are
          urn:schemas-micasaverde-com:device:SceneController:1
          D_SceneController1.xml
          Do you think these are able to be controlled by a mySensor device?
          hekH 1 Reply Last reply
          • greglG gregl
            wrote on last edited by hek
            @gregl
            Yes it is possible. Just don't know when I have time to do the necessary tests. Anyone want do do some tests on what variables we need to activate/deactivate scenes etc?
            I think ** NumButtons**, sl_SceneActivated and ** sl_SceneDeactivated** is involved.
            • greglG
              greglG
              gregl
              @hek said:
              sl_SceneActivated
              @hek - ill have a crack....but any idea where on vera these files reside?
              • greglG gregl
                @hek said:
                sl_SceneActivated
                @gregl
                Ok, added missing scene controller device (the SCENE_ON / SCENE_OFF variables was already there) to the 1.4 development branch.
                https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MyMessage.h#L58
                https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L74
                But I have no idea what happens if you create a SceneController device from your Arduino. When do you specify NumButtons? At creation time? That would be problematic as we today have no way of specifying custom data when doing sensor-presentation from Arduino.
                Edit: My post number 500!
                  @gregl
                  H
                  H
                  hhg
                  @hek
                  If you want buttons on the device widget I think you need to at some custom D_.xml and D_.js files (See AtiRemote in the rfxtrx code tree as an example)
                  But in my experience the generic Scene Controller works fine "as is" - Just sent the "Button number" as the value:
                  -- On button press
                  luup.variable_set("urn:micasaverde-com:serviceId:SceneController1","sl_SceneActivated", button_no, device_no)
                  -- On button release
                  luup.variable_set("urn:micasaverde-com:serviceId:SceneController1","sl_SceneDeactivated", button_no, device_no)
                  Please note: I have not tried this with MySensors - The above is from another Vera plugin I have written
                  • D
                    Dalhoj
                    Im not home at the moment so I cant test, but found the guide to set up a z wave remote
                    http://wiki.zwaveeurope.com/index.php?title=KFOB_VERA
                    So I think you will have each button on the node to send a scene_on with the id of the button and then deactivate the scene again.
                    And then just a picture of my wall plate in danish design, with the arduino behind.
                    https://dl.dropboxusercontent.com/u/3260168/arduinotryk01.jpg
                    • H
                      H
                      hhg
                      In 1.4b1 1.4b1 (18848a2) Scene Controller support is present, and works fine
                      Present with:
                      gw.present(CHILD_ID, S_SCENE_CONTROLLER);
                      And it shows as a generic scene controller in Vera:
                      upload-af0688b3-9110-434f-a57c-aa34e808e0fe
                      The sketch to support a 4 button wall controller:
                      // Simple SceneController
                      #define CHILD_ID 3
                      // PIN for the buttons
                      byte buttons[] = {3, 4, 5, 6};
                      #define NUMBUTTONS sizeof(buttons)
                      byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
                      Bounce debouncer[NUMBUTTONS];
                      int oldValue[NUMBUTTONS];
                      MyMessage msgOn(CHILD_ID,V_SCENE_ON);
                      MyMessage msgOff(CHILD_ID,V_SCENE_OFF);
                        gw.begin();
                        /// Make input & enable pull-up resistors on switch pins
                        for (short i=0; i < NUMBUTTONS; i++){
                          pinMode(buttons[i], INPUT);
                          digitalWrite(buttons[i], HIGH);
                          oldValue[i] = -1;
                          debouncer[i].attach(buttons[i]);
                          debouncer[i].interval(5);
                        gw.sendSketchInfo("LK 4-Tryk", "1.0");
                          debouncer[i].update();
                          // Get the update value
                          if (value != oldValue[i]) {
                             // Send in the new value
                             if (value==HIGH) {
                               gw.send(msgOff.set(i));
                             else {
                               gw.send(msgOn.set(i));
                             oldValue[i] = value;
                      • korttomaK
                        korttomaK
                        korttoma
                        Sweet!! Thanks @hhg exactly what I need.
                        • Tomas
                        • androbotA
                          androbotA
                          androbot
                          I tried this out last night and discovered an interesting issue. A scene will activate once and deactivate once, but all subsequent changes are not applied. I confirmed in my Vera logs that the messages make it through to the unit, but the subsequent application of scene never happens after the first time.
                          I'm suspecting this is due to the "setVariableIfChanged" nature of the code in conjunction with the split V_SCENE_ON/V_SCENE_OFF messages. In other words, it's not a single variable that is toggling, it's two separate ones.
                            This most surely is the problem! I will have to make a mental note of it and fix it the next time I mess with the Vera plugin code.
                            • androbotA androbot
                              H
                              H
                              hhg
                              Nice spottet!
                              Change line 182 in L_Arduino.lua from
                               if ((value ~= curValue) or (curValue == nil)) then
                              to:
                              if ((value ~= curValue) or (curValue == nil) or (serviceId == "urn:micasaverde-com:serviceId:SceneController1")) then
                              So the sl_SceneActivated/sl_SceneDeactivated variables are updated unconditionally
                              androbotA 1 Reply Last reply
                              • H hhg
                                Nice spottet!
                                to:
                                androbotA
                                androbotA
                                androbot
                                @hhg
                                Worked like a charm!
                                • D
                                  dayve218
                                  hey guys, trying to set this one up, i have the widget displaying, but no control happening
                                  pretty new to all of this so any help would be appreciated.
                                  dayve
                                  • D
                                    Dalhoj
                                    Hi
                                    After the Node and Scenecontroller shows up in the Vera UI you have to create a scene and then asign the scenecontroller as a trigger:
                                    For button 1 the scene number is 0
                                    for button 2 the scene number is 1 and so on.
                                    Hope is helps ;-)
                                    D 1 Reply Last reply
                                    • D
                                      dayve218
                                      @Dalhoj thanks for that, it seems super obvious now in retrospect.
                                      • D Dalhoj
                                        Hi
                                        Hope is helps ;-)
                                        dayve218
                                        @Dalhoj is it possible to have one button stop/start the same scene, as an on/off switch for a light for example?
                                        korttomaK hekH 2 Replies Last reply
                                        • D dayve218
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          @dayve218
                                          If you use PLEG you could do it like this:
                                          Condition ----------------- Action
                                          LightOn AND Button = Turn Light Off
                                          LightOff AND Button = Turn Light On
                                          • Tomas
