  3. SceneController
SceneController
28 Posts 9 Posters 19.8k Views 5 Watching
  • greglG gregl
    @hek said:
    sl_SceneActivated
    @hek - ill have a crack....but any idea where on vera these files reside?
    wrote on last edited by hek
    @gregl
    Ok, added missing scene controller device (the SCENE_ON / SCENE_OFF variables was already there) to the 1.4 development branch.
    https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MyMessage.h#L58
    https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L74
    But I have no idea what happens if you create a SceneController device from your Arduino. When do you specify NumButtons? At creation time? That would be problematic as we today have no way of specifying custom data when doing sensor-presentation from Arduino.
    Edit: My post number 500!
    H 1 Reply Last reply
      @gregl
      H
      H
      hhg
      @hek
      If you want buttons on the device widget I think you need to at some custom D_.xml and D_.js files (See AtiRemote in the rfxtrx code tree as an example)
      But in my experience the generic Scene Controller works fine "as is" - Just sent the "Button number" as the value:
      -- On button press
      luup.variable_set("urn:micasaverde-com:serviceId:SceneController1","sl_SceneActivated", button_no, device_no)
      -- On button release
      luup.variable_set("urn:micasaverde-com:serviceId:SceneController1","sl_SceneDeactivated", button_no, device_no)
      Please note: I have not tried this with MySensors - The above is from another Vera plugin I have written
      • D
        Dalhoj
        Im not home at the moment so I cant test, but found the guide to set up a z wave remote
        http://wiki.zwaveeurope.com/index.php?title=KFOB_VERA
        So I think you will have each button on the node to send a scene_on with the id of the button and then deactivate the scene again.
        And then just a picture of my wall plate in danish design, with the arduino behind.
        https://dl.dropboxusercontent.com/u/3260168/arduinotryk01.jpg
        • H
          H
          hhg
          In 1.4b1 1.4b1 (18848a2) Scene Controller support is present, and works fine
          Present with:
          gw.present(CHILD_ID, S_SCENE_CONTROLLER);
          And it shows as a generic scene controller in Vera:
          upload-af0688b3-9110-434f-a57c-aa34e808e0fe
          The sketch to support a 4 button wall controller:
          // Simple SceneController
          #define CHILD_ID 3
          // PIN for the buttons
          byte buttons[] = {3, 4, 5, 6};
          #define NUMBUTTONS sizeof(buttons)
          byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
          Bounce debouncer[NUMBUTTONS];
          int oldValue[NUMBUTTONS];
          MyMessage msgOn(CHILD_ID,V_SCENE_ON);
          MyMessage msgOff(CHILD_ID,V_SCENE_OFF);
            gw.begin();
            /// Make input & enable pull-up resistors on switch pins
            for (short i=0; i < NUMBUTTONS; i++){
              pinMode(buttons[i], INPUT);
              digitalWrite(buttons[i], HIGH);
              oldValue[i] = -1;
              debouncer[i].attach(buttons[i]);
              debouncer[i].interval(5);
            gw.sendSketchInfo("LK 4-Tryk", "1.0");
              debouncer[i].update();
              // Get the update value
              if (value != oldValue[i]) {
                 // Send in the new value
                 if (value==HIGH) {
                   gw.send(msgOff.set(i));
                 else {
                   gw.send(msgOn.set(i));
                 oldValue[i] = value;
          • korttomaK
            korttomaK
            korttoma
            Sweet!! Thanks @hhg exactly what I need.
            • Tomas
            • androbotA
              androbotA
              androbot
              I tried this out last night and discovered an interesting issue. A scene will activate once and deactivate once, but all subsequent changes are not applied. I confirmed in my Vera logs that the messages make it through to the unit, but the subsequent application of scene never happens after the first time.
              I'm suspecting this is due to the "setVariableIfChanged" nature of the code in conjunction with the split V_SCENE_ON/V_SCENE_OFF messages. In other words, it's not a single variable that is toggling, it's two separate ones.
                This most surely is the problem! I will have to make a mental note of it and fix it the next time I mess with the Vera plugin code.
                • androbotA androbot
                  H
                  H
                  hhg
                  Nice spottet!
                  Change line 182 in L_Arduino.lua from
                   if ((value ~= curValue) or (curValue == nil)) then
                  to:
                  if ((value ~= curValue) or (curValue == nil) or (serviceId == "urn:micasaverde-com:serviceId:SceneController1")) then
                  So the sl_SceneActivated/sl_SceneDeactivated variables are updated unconditionally
                  androbotA 1 Reply Last reply
                  • H hhg
                    Nice spottet!
                    to:
                    androbotA
                    androbotA
                    androbot
                    @hhg
                    Worked like a charm!
                    • D
                      dayve218
                      hey guys, trying to set this one up, i have the widget displaying, but no control happening
                      pretty new to all of this so any help would be appreciated.
                      dayve
                      • D
                        Dalhoj
                        Hi
                        After the Node and Scenecontroller shows up in the Vera UI you have to create a scene and then asign the scenecontroller as a trigger:
                        For button 1 the scene number is 0
                        for button 2 the scene number is 1 and so on.
                        Hope is helps ;-)
                        D 1 Reply Last reply
                        • D
                          dayve218
                          @Dalhoj thanks for that, it seems super obvious now in retrospect.
                          • D Dalhoj
                            Hi
                            Hope is helps ;-)
                            dayve218
                            @Dalhoj is it possible to have one button stop/start the same scene, as an on/off switch for a light for example?
                            korttomaK hekH 2 Replies Last reply
                            • D dayve218
                              korttomaK
                              korttomaK
                              korttoma
                              @dayve218
                              If you use PLEG you could do it like this:
                              Condition ----------------- Action
                              LightOn AND Button = Turn Light Off
                              LightOff AND Button = Turn Light On
                              • Tomas
                              • D dayve218
                                @dayve218
                                Some "scene controllers" I've seen triggers "scene off" when you push-and-hold button for say one a second.
                                • D
                                  dayve218
                                  wrote on last edited by dayve218
                                  #22
                                  how would i make that happen?
                                  @korttoma i dont, PLEG is infinitely confusing to me.
                                  • D
                                    Dalhoj
                                    I dont know if you can have a 1 sec press!
                                    but i uses LUUP and a simple ex could be turn on a lamp and if the lamp if on turn it off:
                                    local relay1 = 114 --Light ID
                                    local relay1_status = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", relay1) --Status of Light
                                    if (relay1_status == "0") then
                                    luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget",{ newTargetValue="1" }, relay1)
                                    luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget",{ newTargetValue="0" }, relay1)
                                    end
                                    Or you can use a toggle from the advanced scene menu:
                                    upload-cb06931d-0aaa-4ee3-b90f-345180b5247c
                                    That is how I do it.
                                    hekH 1 Reply Last reply
                                    • D Dalhoj
                                      end
                                      I mean that the Arduino checks if user presses button for one sec and send the SCENE_OFF. You probably shouldn't let Vera handle this.
                                      • NuubiN
                                        NuubiN
                                        Nuubi
                                        Hey! Any pictures of scene controller installations? I'm planning on DIY'ing some "aesthetically pleasing" ones :-)
                                          Dalhoj
                                          I would make the Arduino send ie. for button 1 send scene ID 0 at short press and scene ID 1 for long press and so on.
                                          @Nuubi Here is two of my scene controllers:
                                          The first one is installed in my bedtable upload-c29b281d-083c-4b73-a4df-b27240ee9e31 and is a combination of a scenecontroller and a relaysensor for controling the 3 leds.
                                          The 2. is installed in the living room, and is a 8 button scenecontroller.
                                          upload-aee5fc51-3dea-4a00-b592-db58744e1e87
                                          It controlles
                                          • the lights in the living room
                                          • Blinds Open / Close
                                          • a power outlet On/Off
                                          • pause/plays my XBMC Medie Center
                                          • starts my Yamaha reciver and starts playing net radio
                                          • stops the radion again and turn of the reciver
                                          • turns up / down the volume on the reciver
                                          That is what I use it for at the moment.
                                          S 1 Reply Last reply
