  3. Problems trying to compile Ethernet MQTT Gateway but samples OK
15 Posts 3 Posters 4.1k Views 3 Watching
  • KiZDK
    KiZDK
    KiZD
    It's not the same sketch. I can't find any sketch in the examples that have the same two tabs.
    In the other hand, I can upload without issue with codebender this one:
    http://www.mysensors.org/build/ethernet_gateway ...but I need ENC28J60 and MQTT
    Regards
    • KiZDK KiZD
      Regards
      Could you explain what you refer to as "it" in this sentence? EthernetGateway? or MQTTGateway? or something else?
      • KiZDK
        KiZDK
        KiZD
        Sorry...
        In the example sketches provided with the libraries, I can't find any one like http://www.mysensors.org/build/mqtt_gateway
        • KiZDK
          KiZDK
          KiZD
          wrote on last edited by KiZD
          I can compile all examples like GatewayW5100MQTTClient, GatewayENC28J60... but not this one:
          In my Arduino install, this method to install libraries didn't work:
          http://www.mysensors.org/about/arduino#installing-the-sensor-libraries
          I have to move MySensors folder to my libraries folder to make examples work.
          Why can't compile http://www.mysensors.org/build/mqtt_gateway with codebender plugin? (other MySensor's sketches do)
          Why this "MySigningNone.h" error with Arduino IDE? Is something related with this http://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors ??
          • KiZDK
            KiZDK
            KiZD
            Hello!
            ...any idea? I've seen similar issues with this MySigningNone.h error, but haven't seen any clear sollution.
            • KiZDK KiZD
              Hello!
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @KiZD
              Hi!
              I'm not sure exactly what you have tried, but the mqtt client gateway sketch is only for development branch library while the old mqtt gateway sketch that you linked to, is for the 1.5 releases. You can't mix old style sketches with dev branch library and vice versa. It's sounds like you should try to reinstall the mysensors library from scratch. Remove everything first. Read the install instructions on the mysensors web carefully. Decide if you want to go for dev branch or a release. Then install either, and only use sketch examples from the correct source per library install.
              • KiZDK
                KiZDK
                KiZD
                Thanks!!
                I've done in a new install in Windows, installed this libraries:
                https://github.com/mysensors/Arduino/tree/development
                And now, I get this error:
                ...MQTTGateway.ino:77:23: fatal error: DigitalIO.h: No such file or directory
                #include <DigitalIO.h>
                Wich sketch should I use if I'm looking for a MQTTGateway with ENC28J60? Sample sketch provided with libraries is for W5100, can I use this sketch:
                https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewayW5100MQTTClient/GatewayW5100MQTTClient.ino
                and replace #include <Ethernet.h> for #include <UIPEthernet.h> ??
                • KiZDK KiZD
                  Thanks!!
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  @KiZD
                  I don't think so, but you can always try. The mqtt client gateway in the dev branch was not developed with support for enc28j60 in mind.
                  If you want to use that module, your best bet is to use a 1.5 release of mysensors and the old mqtt broker gateway sketch. Although I can't remember if I've read successful reports on that in the forum.
                  The enc28j60 ethernet module is notoriosly hard to get working in combination with mysensors according to a lot of posts in the forum. My advice is, get a 5100 module.
                  • KiZDK
                    KiZDK
                    KiZD
                    In the example that I'm trying
                    I thought that was developed for both enc28j60 and 5100 , but now I can see that I was wrong. (I can't compile, anyway)
                    The example provided with libraries (dev branch)
                    is very different from the one proposed on the web:
                    The one provided in dev branch libraries examples is not 1.5?
                    If I get a W5100 wich sketch sould I use?
                    Perhaps, I should try to use a serial gateway, but I like the idea to have a device for only RFL24>Eth / MQTT.
                    Thanks for your answers.
                    • KiZDK KiZD
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @KiZD
                      Dev branch source, means that the code is under development and a lot of things have changed after the latest release of mysensors, which is currently 1.5.4.
                      Old sketches from 1.5 releases or earlier have to be modified to work in combination with the dev branch library. The examples that you get together with the library if downloading the dev branch, have all been modified to work with the dev branch library.
                      Some sketches like the mqtt gateway sketch, have been completely rewritten. In the old sketch the gateway was acting as an mqtt broker. In the new dev branch sketch, the gateway is an mqtt client.
                      The W5100 module should work with all mysensors gateway sketches for ethernet modules, ie both ethernet and mqtt gateway and both 1.5 release and dev branch.
                      • KiZDK
                        KiZDK
                        KiZD
                        OK, I understand...
                        I'll buy a W5100 and will try with serial until module arrives.
                        Thank you!!
                        12.5k
