  3. 💬 In Wall AC/DC Pcb for MySensors
pcbmysx1.4inwallacdc
62 Posts 17 Posters 31.1k Views 20 Watching
  • V
    V
    vil1driver
    wrote on last edited by vil1driver
    thanks for your great work..
    great to have chosed a pwm output for the relay (ssr can be used as a dimmer)
    but is it possible to add a fuse on the ssr output too ?
    thanks
    • sundberg84S
      sundberg84S
      Hi @vil1driver!
      This pcb does not contain any relay.
      • V
        V
        vil1driver
        roh sry :D bad thread lol, i was think it was the http://forum.mysensors.org/topic/1540/110v-230v-ac-to-mysensors-pcb-board/72
        too much windows opened =)
        I can delete it if needed
        • sundberg84S
          sundberg84S
          Ok - updated to 3.1. Its mainly changes on the AC side to decrease risk of creepage and increase clearance.
          See changes.txt for more detailed info.
          • sundberg84S
            sundberg84S
            Playtime...
            • Sefi NinioS
              Sefi NinioS
              Sefi Ninio
              Sweeet!!!!
              Say @sundberg84, have you considered also adding one or two relays to the mix?
              I know it'll probably increase it's size footprint but in terms for height, if you position them next to the HLK unit then there shouldn't be a noticeable height increase. SSRs are very small.
              • sundberg84S
                sundberg84S
                I have and might in the future... at the moment I'm focusing on safety, test and size. Rev 4 is ordered today with smd components. Let's see how that evolves first.
                • Sefi NinioS
                  Sefi NinioS
                  Sefi Ninio
                  Hi @sundberg84,
                  I was talking with a friend of mine who has pcb design experience about your board, and he told me to tell you that it would be better to add creapage protection between the 220v and the 5v sections, by bigger distance at also a longated gap. He told me the term, but I can't remember it now...
                  • Sefi NinioS
                    Sefi NinioS
                    Sefi Ninio
                    Like the picture here shows :
                    https://www.google.co.il/search?q=pcb+board+220v+5v&client=ms-android-om-lge&prmd=ivsn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjO2Yb_gLTLAhUIVBQKHRzGAzgQ_AUIBygB&biw=360&bih=518#tbm=isch&q=pcb+board+creapage+&imgrc=VW6CJt4F2bzR8M%3A
                    • sundberg84S
                      sundberg84S
                      @Sefi-Ninio - Yea I should. Im working on Rev 4 and there is more creepage both between primary (220) and secondary (5) and also internally in primary. Everything is ordered but nothing recieved yet, but let me give you a small peak:
                      • Sefi NinioS
                        Sefi NinioS
                        Sefi Ninio
                        Looking good!
                        I see you went with the SMD path! did it allow for a smaller PCB?
                        Don't see how you handle the creepage though.
                        • sundberg84S
                          sundberg84S
                          #25
                          Yes - smaller PCB.
                          Creepage is handled with:
                          1. Greater distance between components.
                          2. Holes in PCB between components/parts that are close to each other.
                          Creepage distance is calculated here: http://creepage.com/
                          • Sefi NinioS
                            Sefi NinioS
                            Sefi Ninio
                            Even though it's untested, would you mind publishing the Gerber and bom files?
                            • sundberg84S sundberg84
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @sundberg84
                              Very nice board !
                              • sundberg84S
                                sundberg84S
                                • Sefi NinioS
                                  Sefi NinioS
                                  Sefi Ninio
                                  SMD is easier with solder paste and hot air solder
                                  • sundberg84S
                                    sundberg84S
                                    #30
                                    This PCB has been updated to Rev 4.1 with the following changes:
                                    (Note that this thread contains the non SMD version)
                                    • Complete redesign of traces to improve size and stability.
                                    • Nrf24l01+ now on the bottom side to make more room (with hope not RF disturbace from HLK or AC traces).
                                    • Added silkmask with AC-DC seperation (Rev 4.1 > 5mm)
                                    • AC clearance 2.5mm minimum
                                    • Changed one AC trace from botton to top to increace creepage and changed milling
                                    • MysX 2.3 + Analog IO
                                    • Safety recommendations: This PCB meets the criteria of pollution level II (2,5mm (Basic) AC seperation and 5mm (Reinforced) AC-DC sepertion) and can be used "where only non-conductive contamination occurs. However, occasional temporary conductivity must be expected as a result of moisture condensation." Always use a sealed case to avoid contamination. Always read disclaimer.txt before using this PCB.
                                    Images on https://www.openhardware.io/view/13/In-Wall-ACDC-Pcb-for-MySensors has been updated.
                                    Please wait for PCB house to update to new gerber files before ordering (It should say M.Rev 2 (Manufacturer rev 2) for latest revision when selecting PCB house)
                                    Im currently testing this rev...
                                    If you want to be 100% sure, download and prev. revision.
                                    • carthiqueC
                                      carthiqueC
                                      carthique
                                      Can someone please suggest replacement parts for the 110v variant of this board.
                                      Karthik
                                      • carthiqueC carthique
                                        Karthik
                                        sundberg84S
                                        sundberg84S
                                        @carthique - You need a 110 v varistor maybe something like: http://www.ebay.com/itm/321024816822?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT&rmvSB=true. Fuses and other components is the same.
                                        • ashwayA
                                          ashwayA
                                          ashway
                                          @sundberg84, when I go to the order form, the revision there is M.Rev3. Which version of PCB does that manufacturer revision correspond to - 3.1 or 4.1???
