  3. 💬 In Wall AC/DC Pcb for MySensors
pcbmysx1.4inwallacdc
62 Posts 17 Posters 31.1k Views 20 Watching
  • sundberg84S
    sundberg84S
    @Sefi-Ninio - Yea I should. Im working on Rev 4 and there is more creepage both between primary (220) and secondary (5) and also internally in primary. Everything is ordered but nothing recieved yet, but let me give you a small peak:
    • Sefi NinioS
      Sefi NinioS
      Sefi Ninio
      Looking good!
      I see you went with the SMD path! did it allow for a smaller PCB?
      Don't see how you handle the creepage though.
      • sundberg84S
        sundberg84S
        #25
        Yes - smaller PCB.
        Creepage is handled with:
        1. Greater distance between components.
        2. Holes in PCB between components/parts that are close to each other.
        Creepage distance is calculated here: http://creepage.com/
        • Sefi NinioS
          Sefi NinioS
          Sefi Ninio
          Even though it's untested, would you mind publishing the Gerber and bom files?
          • sundberg84S sundberg84
            GertSandersG
            GertSandersG
            GertSanders
            @sundberg84
            Very nice board !
            • sundberg84S
              sundberg84S
              • Sefi NinioS
                Sefi NinioS
                Sefi Ninio
                SMD is easier with solder paste and hot air solder
                • sundberg84S
                  sundberg84S
                  #30
                  This PCB has been updated to Rev 4.1 with the following changes:
                  (Note that this thread contains the non SMD version)
                  • Complete redesign of traces to improve size and stability.
                  • Nrf24l01+ now on the bottom side to make more room (with hope not RF disturbace from HLK or AC traces).
                  • Added silkmask with AC-DC seperation (Rev 4.1 > 5mm)
                  • AC clearance 2.5mm minimum
                  • Changed one AC trace from botton to top to increace creepage and changed milling
                  • MysX 2.3 + Analog IO
                  • Safety recommendations: This PCB meets the criteria of pollution level II (2,5mm (Basic) AC seperation and 5mm (Reinforced) AC-DC sepertion) and can be used "where only non-conductive contamination occurs. However, occasional temporary conductivity must be expected as a result of moisture condensation." Always use a sealed case to avoid contamination. Always read disclaimer.txt before using this PCB.
                  Images on https://www.openhardware.io/view/13/In-Wall-ACDC-Pcb-for-MySensors has been updated.
                  Please wait for PCB house to update to new gerber files before ordering (It should say M.Rev 2 (Manufacturer rev 2) for latest revision when selecting PCB house)
                  Im currently testing this rev...
                  If you want to be 100% sure, download and prev. revision.
                  • carthiqueC
                    carthiqueC
                    carthique
                    Can someone please suggest replacement parts for the 110v variant of this board.
                    Karthik
                    • carthiqueC carthique
                      Karthik
                      sundberg84S
                      sundberg84S
                      @carthique - You need a 110 v varistor maybe something like: http://www.ebay.com/itm/321024816822?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT&rmvSB=true. Fuses and other components is the same.
                      • ashwayA
                        ashwayA
                        ashway
                        @sundberg84, when I go to the order form, the revision there is M.Rev3. Which version of PCB does that manufacturer revision correspond to - 3.1 or 4.1???
                        • ashwayA ashway
                          sundberg84S
                          sundberg84S
                          @ashway - this is correct/latest version. The manufacturer rev 3 equals the latest 4.1.
                            shabba
                            Excuse the possibly silly question but the buy options is PCBs only? Or does it come with the housing too?
                            • S shabba
                              sundberg84S
                              sundberg84S
                              @shabba - PCB only.
                              I recommend using 3dhubs.com and find a local 3d printer for the case.
                              Files (.stl) attached in the project.
                              J 1 Reply Last reply
                                shabba
                                @sundberg84 thanks - I had a look in the design files and I think I covered the comments but could not find a .stl file.
                                • S shabba
                                  sundberg84S
                                  sundberg84S
                                  @shabba - sorry you are right.
                                  If i remember right I removed it because I wasnt 100% sure it would be ok going from 4.0 to 4.1 on the pcb.
                                  Let me have a look and post it asap.
                                  • bmokenaB
                                    bmokenaB
                                    bmokena
                                    Hi sundberg84,
                                    I bought 10 of these PCBs. So can I use this PCB, add a relay and fuse and use it inside the wall to control light switches? or should I go rather go for the other PCB "In Wall AC/DC Pcb (with Relay) for MySensors (SMD)" ?
                                    Bob
                                    • bmokenaB bmokena
                                      Hi sundberg84,
                                      Bob
                                      sundberg84S
                                      sundberg84S
                                      @bmokena - if it fits, that should be ok. This PCB is made a more generic pcb so you can add any sensor/accuator to it including a relay. Use the MysX i/o and you can controll your relay through D3 for example.
                                        @shabba - PCB only.
                                        J
                                        J
                                        johmei
                                        @sundberg84
                                        Hi, do you have any local Swedish printing services to recommend?
                                        Ps. Got the PCBs from Pcbway yesterday and man was I surprised how small they were. Looks great and hope to get some nodes up and running soon, once all components get here.
                                        • J johmei
                                          @sundberg84
                                          sundberg84S
                                          sundberg84S
                                          @johmei - sorry, I wish i had any good recommendations for local PCB service.
                                          The only research I have done leads me to that they are VERY expensive compared to these 10x10 chinese.
                                          Good luck with your build! Images are always appreciated! ;)
