  3. 💬 In Wall AC/DC Pcb for MySensors
pcbmysx1.4inwallacdc
62 Posts 17 Posters 31.1k Views 20 Watching
  • Sefi NinioS
    Sefi NinioS
    Sefi Ninio
    Looking good!
    I see you went with the SMD path! did it allow for a smaller PCB?
    Don't see how you handle the creepage though.
    • sundberg84S
      sundberg84S
      #25
      Yes - smaller PCB.
      Creepage is handled with:
      1. Greater distance between components.
      2. Holes in PCB between components/parts that are close to each other.
      Creepage distance is calculated here: http://creepage.com/
      • Sefi NinioS
        Sefi NinioS
        Sefi Ninio
        Even though it's untested, would you mind publishing the Gerber and bom files?
        • sundberg84S sundberg84
          @Sefi-Ninio - Yea I should. Im working on Rev 4 and there is more creepage both between primary (220) and secondary (5) and also internally in primary. Everything is ordered but nothing recieved yet, but let me give you a small peak:
          GertSandersG
          GertSandersG
          GertSanders
          @sundberg84
          Very nice board !
          • sundberg84S
            sundberg84S
            • Sefi NinioS
              Sefi NinioS
              Sefi Ninio
              SMD is easier with solder paste and hot air solder
              • sundberg84S
                sundberg84S
                #30
                This PCB has been updated to Rev 4.1 with the following changes:
                (Note that this thread contains the non SMD version)
                • Complete redesign of traces to improve size and stability.
                • Nrf24l01+ now on the bottom side to make more room (with hope not RF disturbace from HLK or AC traces).
                • Added silkmask with AC-DC seperation (Rev 4.1 > 5mm)
                • AC clearance 2.5mm minimum
                • Changed one AC trace from botton to top to increace creepage and changed milling
                • MysX 2.3 + Analog IO
                • Safety recommendations: This PCB meets the criteria of pollution level II (2,5mm (Basic) AC seperation and 5mm (Reinforced) AC-DC sepertion) and can be used "where only non-conductive contamination occurs. However, occasional temporary conductivity must be expected as a result of moisture condensation." Always use a sealed case to avoid contamination. Always read disclaimer.txt before using this PCB.
                Images on https://www.openhardware.io/view/13/In-Wall-ACDC-Pcb-for-MySensors has been updated.
                Please wait for PCB house to update to new gerber files before ordering (It should say M.Rev 2 (Manufacturer rev 2) for latest revision when selecting PCB house)
                Im currently testing this rev...
                If you want to be 100% sure, download and prev. revision.
                • carthiqueC
                  carthiqueC
                  carthique
                  Can someone please suggest replacement parts for the 110v variant of this board.
                  Karthik
                  • carthiqueC carthique
                    Karthik
                    sundberg84S
                    sundberg84S
                    @carthique - You need a 110 v varistor maybe something like: http://www.ebay.com/itm/321024816822?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT&rmvSB=true. Fuses and other components is the same.
                    • ashwayA
                      ashwayA
                      ashway
                      @sundberg84, when I go to the order form, the revision there is M.Rev3. Which version of PCB does that manufacturer revision correspond to - 3.1 or 4.1???
                      • ashwayA ashway
                        sundberg84S
                        sundberg84S
                        @ashway - this is correct/latest version. The manufacturer rev 3 equals the latest 4.1.
                          shabba
                          Excuse the possibly silly question but the buy options is PCBs only? Or does it come with the housing too?
                          • S shabba
                            sundberg84S
                            sundberg84S
                            @shabba - PCB only.
                            I recommend using 3dhubs.com and find a local 3d printer for the case.
                            Files (.stl) attached in the project.
                            J 1 Reply Last reply
                              shabba
                              @sundberg84 thanks - I had a look in the design files and I think I covered the comments but could not find a .stl file.
                              • S shabba
                                sundberg84S
                                sundberg84S
                                @shabba - sorry you are right.
                                If i remember right I removed it because I wasnt 100% sure it would be ok going from 4.0 to 4.1 on the pcb.
                                Let me have a look and post it asap.
                                • bmokenaB
                                  bmokenaB
                                  bmokena
                                  Hi sundberg84,
                                  I bought 10 of these PCBs. So can I use this PCB, add a relay and fuse and use it inside the wall to control light switches? or should I go rather go for the other PCB "In Wall AC/DC Pcb (with Relay) for MySensors (SMD)" ?
                                  Bob
                                  • bmokenaB bmokena
                                    Hi sundberg84,
                                    Bob
                                    sundberg84S
                                    sundberg84S
                                    @bmokena - if it fits, that should be ok. This PCB is made a more generic pcb so you can add any sensor/accuator to it including a relay. Use the MysX i/o and you can controll your relay through D3 for example.
                                      @shabba - PCB only.
                                      J
                                      J
                                      johmei
                                      @sundberg84
                                      Hi, do you have any local Swedish printing services to recommend?
                                      Ps. Got the PCBs from Pcbway yesterday and man was I surprised how small they were. Looks great and hope to get some nodes up and running soon, once all components get here.
                                      • J johmei
                                        @sundberg84
                                        sundberg84S
                                        sundberg84S
                                        @johmei - sorry, I wish i had any good recommendations for local PCB service.
                                        The only research I have done leads me to that they are VERY expensive compared to these 10x10 chinese.
                                        Good luck with your build! Images are always appreciated! ;)
                                        • J
                                          J
                                          johmei
                                          @sundberg84 - Thanks, but I was thinking about 3D printing services for boxes, cases and mounts in very small series (maybe even singles)?!
                                          Regarding images we'll see if I manage to get any AC stuff going anytime soon. I have a lot of respect for AC and probably want to get to know the Arduino platform a bit more first. Got my first couple of regular DC nodes running yesterday and they have been running really well for 12 hours now (impressed of the small nrf24+ radio range). So many ideas to explore. =)
                                          Actually ordered a set of your newbie PCBs a few days after my In wall AC PCB order so there will be a lot your autograph around my house..
