  3. S_MULTIMETER Help
S_MULTIMETER Help
5 Posts 4 Posters 2.7k Views 4 Watching
  • Boots33B Offline
    Boots33B Offline
    Boots33
    Hi
    I am building a sensor to monitor a small solar/battery combination and am trying to use the Multimeter device to measure current in and out of the battery. I am using a 5amp ASC712 to read the current and then send the result to my Domoticz server.
    I am getting the data back to Domoticz ok but it is not formatting as i would of hoped. The device is being shown as type Current, CM113. For example if I send 1.250 the Domoticz device will only show 1.2A . As the ASC712 can read current flow in both directions I can also send negative numbers when the battery is discharging, so if I send -2.350 the Domoticz device shows 2.3A and ignores the negative number.
    I am thinking this may be a limitation of S_MULTIMETER ?
    Interestingly using V_VOLTAGE results in showing three decimal places but V_CURRENT shows only one decimal place.
    any help would be much appreciated.
    • mfalkviddM Offline
      I use S_CUSTOM and V_VOLTAGE to report voltage in my plant moisture sketch. Haven't tried with negative values, but I get three decimals. Maybe Domoticz handles S_CUSTOM better?
      • Boots33B Offline
        Boots33B Offline
        Boots33
        Thanks I will give that a try. I guess I could use two V_CURRENT devices, one for charging and one for discharging but an all in one would be better.
        • F Offline
          F Offline
          flopp
          You can maybe use Temperature, but of course it will be wrong type but it can handle plus and minus
          • siklosiS Offline
            siklosiS Offline
            siklosi
            Im also having problems with domoticz and negative values. Im reporting value and want to see increase or decrease. And negative values are represented as long int value -1 (I think).
