  2. Feature Requests
  3. Domoticz full integration
Scheduled Pinned Locked Moved Feature Requests
79 Posts 26 Posters 77.6k Views 11 Watching
    @qqlapraline said:
    I have exchanged with Gizmocuz who's in charge of Domoticz code. He is very eager to integrate mysensors into Domoticz.
    If Gizmocuz has specific questions about MySensors protocol or library I can probably answer them.
    • epierreE epierre
      Hey QQ it is always easier to ask than to do...
      So far there is no will on one side to do something, on the other same issue... (one developper on each side alone...)some people have ported the mysensors integration to openahab (which has a working z-wave integration and RFXtrx), but for your case it is a bit different...
      First ask yourself if you are building a mysensors and for what use (needs some soldering, DIY, purchase, enery solving issue, boxing... that is not things bought uppon a shelf), and then you'll need to find people or make it yourself.
      qqlapralineQ
      qqlapralineQ
      qqlapraline
      wrote on last edited by qqlapraline
      @epierre Yeah..right..:| thank you for the life lesson.
      Actually, how surprising it might look, I don't have the need: I have Arduino, communicating together in a simple protocol and integrating very well with my domoticz installation (by the way, it supports lots of devices...). But, I have good will....And integration between mysensors and Domoticz seems quite logical to me. If this is a fight between number of code lines (which is probably not to the advantage of mysensors), then, fine by me: I'm out the game.
      Regards.
      QQ.
      • qqlapralineQ qqlapraline
        Regards.
        QQ.
        marceltrapmanM
        marceltrapmanM
        marceltrapman
        @qqlapraline I don't really understand what you are trying to ask or say but I do know that the mySensors project is a project supported by only a handful of people.
        I for myself wanted integration with Indigo Domotica and, because I soon understood that I am the first (and at this point only) person asking for it I started developing a plugin for it.
        It is not my first priority (I have to make a living and my partner needs some attention as well) but I will get there.
        What you are asking (as far as I understand) is others to step up to the plate for something that you want or think makes sense in some future.
        That, as you probably understand by now, will only happen when more people start asking for it and/or someone takes the lead.
        When you are not that person I don't think it is correct to 'blame' anybody or get cynical because, just maybe, the time is not on your side.
        Fulltime Servoy Developer
          maglo18
          1 + for full integration with domoticz.
          • jendrushJ
            jendrushJ
            jendrush
            Nevertheless i am not a good programmer i will try tomorrow to make mysensors work with domoticz with at least temp sensors by the ethernet and json. Will see what i can acomplish with 90% desire, and 10% of knowledge:) Maybe it would be first step for others:)
            • epierreE
              epierreE
              epierre
              Hi all,
              A hint of what is going on... with the vera gateway !
              http://forum.mysensors.org/topic/142/#1321
              z-wave - Vera -> Domoticz
              • L
                L
                larky
                +1 on domoticz integration!
                • R
                  R
                  roblom
                  +1 for the full domoticz integration.
                  And sorry for not being helpful because i'm no programmer..
                  • D
                    Dylantje
                    So please..
                    Include this realy nice stuff to domoticz.
                    +10
                      maglo18
                      I ask again what is the best way to use mysensor in domoticz software?
                      hekH 1 Reply Last reply
                      • M maglo18
                        @maglo18
                        Someone who knows Domoticz need to step up and help creating a plugin for the controller. Either by using the serial protocol or by utilizing MQTT.
                        We can help someone get started but the actual work has to be done by someone actually using the controller.
                        • epierreE
                          epierreE
                          epierre
                          I would add someone developping in domoticz for there are (too) few and some new features should be added too...
                          externally is possible and ongoing...
                          • V
                            V
                            Vincent TODESCHINI
                            +1 to domoticz full integration plizzzz !!!!
                              ShaK
                              +1 to Domoticz full integration :)
                                wrote on last edited by hek
                                #30
                                I've commented on the Domiticz feature request:
                                http://www.domoticz.com/forum/tracker.php?p=2&t=143
                                epierreE 1 Reply Last reply
                                • bjornhallbergB
                                  bjornhallbergB
                                  bjornhallberg
                                  Also, if such a C++ ninja would appear, many would be very, very happy to also see native MQTT support for Domoticz.
                                  http://www.domoticz.com/forum/viewtopic.php?f=5&t=838
                                    @bjornhallberg did you call for a c++ ninja? ;-)
                                      epierreE
                                      epierreE
                                      epierre
                                      @hek I would say a demi dozen ninjas would be necessary, one for understanding, one for mapping, one for coding, one for testing one for answering people claims and one ... to support the integration of the code... did I miss one ? ;-)
                                      the internal model is not unified, this is more types built uppon types in several classes, based on evolutions from rfxtrx and then zwave, some are duplications of others (hard coded, no attributes...)... a real headache just on the JSON interface and no testbed/test cases/testmaterial, just full debug with users reporting bugs... doing the Imperihome integration I can say I had a hard time just from outside the code...
                                      • YveauxY Yveaux
                                        bjornhallbergB
                                        bjornhallbergB
                                        bjornhallberg
                                        @Yveaux Haha, yeah, but in all honestly I'm not expecting or suggesting anyone here do their work for them. If they had any sense they would have had support for MQTT and such years ago. And an infrastructure in place for user plugins. I'm such a sad sod that I actually subscribe to the RSS feed for Domoticz commits (for a few months now, as I do with many of these HA software) and I can't say I'm often surprised by anything they put into the code.
                                        On the other hand Domoticz has a lot going for it, including pretty decent graphs that work out of the box. It has blockly. And it has native code. And its JSON API isn't half bad either. I mean, I did try the script by @epierre for a while and I could have settled for hard coding sensor input into Domoticz ... but now I've scrapped the serial gateway due to issues brought up in the other thread and I'm back to either the MQTT or Ethernet gateway so no more Domoticz input. Unless I get a new single-board computer or NUC or whatever to interface with.
                                          epierreE
                                          epierreE
                                          epierre
                                          @bjornhallberg What do you mean by :
                                          Domoticz is perfect for 433Mhz users supported by the rfxtrx, which is its origin. Here you need to code, flash, wire, power, find a box... not for the faintest of heart... clearly not a plug and play philosophy of Domoticz. This is why I'm wopndering so many people ask for the integration but actually don't report questions on sketches or issues, are there are many...
