  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 256.4k Views 53 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    wrote on last edited by hek
    https://www.mysensors.org/view/12/Sensebender-Gateway
    • tbowmoT
      tbowmoT
      tbowmo
      Almost ready for a last roll of prototype.. I've updated github with latest changes, if anyone cares to have a look at it, and give me some feedback on it, then it is now! during Easter, I will (hopefully) do the last prototype spin!
      GertSandersG kalinaK 2 Replies Last reply
      • tbowmoT tbowmo
        GertSandersG
        GertSandersG
        GertSanders
        @tbowmo
        hi Thomas, I was looking at the schematic on OpenHardware.io an![alt text](image url)d saw that you pull WP and HOLD to low permanently. By pulling WP low, doesn't that make the write protect active all the time (blocking any writing) ?
        I believed we needed to pull WP high to allow writing to the flash. If I'm wrong I would like to know, so I can correct my schematic because I'm making a board that also uses the flash.
        Update: I saw that your new schematic no longer has this flash (SD card is better).
          @tbowmo : cool, your project is tempting :)
          For programming it, I guess you recommand an atmel ice??? I am searching if I could use my st link v2 but not sure ( maybe I dreamt of this but I thought I read a link somewhere about using st link with atmel m0..). I will need something as now I am waiting my homemade atsam node pcb, because of you and Gert :laughing:
          Edit: it seems that it could be possible to flash st link to use cmsis (which is the protocol used to flash atsam if I understand right) but don't know if i want to do this. So maybe others cmsis jtag cheap programmer could work ...I read that it could be possible to use another "zero" like to program an homemade one, or why not an atsam10 explained..Or more simple atmel ice, maybe I will choose this easy/less bad suprise way...
          • tbowmoT
            tbowmoT
            tbowmo
            @GertSanders
            Oops.. I think it's an old schematic from the first iterations of the project.. the onboard flash is now exchanged with an SD-CARD reader instead..
            I'll update the PDF once I get to my own computer (which should be Sunday evening)
            • tbowmoT
              tbowmoT
              tbowmo
              @GertSanders
              Just checked github, and it seems that it does have the correct revision of the schematics
              https://github.com/tbowmo/MySensorGW/blob/master/MysensorsGW.pdf
              And I have updated the schematics at openhardware as well (Forgot that it doesn't do automatic refresh from GH yet)
              • tbowmoT tbowmo
                @GertSanders
                GertSandersG
                GertSandersG
                GertSanders
                @tbowmo
                Hi Thomas, Github did have the correct schematic, my remark was based on the schematic on OpenHardware.io (which is now also updated).
                But my question remains: when using the flash memory, what do you normally do with WP and HOLD ? Should they be pulled up or down ?
                tbowmoT 1 Reply Last reply
                • GertSandersG GertSanders
                  @tbowmo
                  tbowmoT
                  tbowmoT
                  tbowmo
                  @GertSanders
                  Depends on if they are active high, or active low.. In this case they where active low, so it actually was an error in the schematics, as it will writeprotect the flash chip.
                  @tekka please be aware of this, when you try to use the external flash in the bootloader on the dev board that I sent you..
                  • tbowmoT tbowmo
                    @GertSanders
                    GertSandersG
                    GertSandersG
                    GertSanders
                    @tbowmo
                    Thanks, in my case they are also active low, so I pull them to VCC.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @GertSanders
                      Actually I think that it's more or less an industry standard, that they are active low, Must have had a brain meltdown when I made the schematics back then :)
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @scalz
                        It seems that the CMSIS is a Cortex communication protocol, so all cortex debuggers should use that protocol?
                        Are you sure that the st link, doesn't support it?
                          @tbowmo: thx for reply. Yes I have understood the same thing, so it should work... I will try with my stlink (st brand) asap I will receive my pcb.
                          Talking about stlink, I have just ordered this, very curious.. http://www.aliexpress.com/item/Free-shipping-1pcs-mini-ST-LINK-V2-ST-LINK-STLINK-STM8-STM32-emulator-download-super-protection/32600512506.html?spm=2114.01010208.3.1.1O5urT&ws_ab_test=searchweb201556_9,searchweb201602_1_505_506_503_504_10034_10020_502_10001_10002_10017_10010_10005_10006_10011_10003_10021_10004_10022_10009_10008_10018_10019,searchweb201603_3&btsid=0dfc1060-5064-466c-8071-ac0bab24a988
                          seriously??so cheap compared to some tools..if it can do the job, could be interesting!
                          There is also the nice IBDAP, cheap alternative to ice :
                          https://www.adafruit.com/products/2764
                          maybe you already know, I have not tested this yet, but seems very simple/useful tool:https://github.com/ataradov/edbg
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @scalz
                            That is cheap.. Perhaps I should buy one, just for the fun of it, and try it out :)
                            I have my jtagice3 though, and it's working fine.. (Even though they don't have the correct cortex-m0 debug port pin layout..)
                            • nemikN
                              nemikN
                              nemik
                              I've been using those cheap $3 ST-Link adapters for flashing ARM cortex chips with OpenOCD, using SWD pins. They're fantastic and work very well.
                              • nick van alstN
                                nick van alstN
                                nick van alst
                                i really like this idea, i'm getting a bit tierd of having the mysensors gateway connected through a breadboard.
                                how far is it? i saw your comment that it is almost ready for last prototype, is this board fully functional?
                                Plus, will it be able to act as a Serial/Ethernet/MQTT gateway? or only 1 of these?
                                And if it is ready, is there a place to order them, or just send the files to a PCB company?
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  I'm still waiting for the last prototype pcb's to arrive.
                                  Depending on the sketch you load it with, it can be a serial, ethernet or MQTT gateway. It has native USB in the atsam, and a connector for a w5100 module.
                                  Besides that it will have SD card for local storage of sensor data, so it could in theory operate without a controller at all..
                                  TheoLT 1 Reply Last reply
                                  • tbowmoT tbowmo
                                    TheoLT
                                    TheoLT
                                    TheoL
                                    @tbowmo Can you give some details about the final dimensions on the board? I want to start the woodworking on the casing for my current gateway. But I'll make sure your prototype fits in as well.
                                    I can't wait 'till this one goes to production. Great work, I'm impressed.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @TheoL
                                      The base board is 5x5 cm, but if you use nrf modules they will protrude over the edge of the PCB. Rfm69 is soldered to the bottom so they won't add to the dimensions. W5100 will probably make the base a few mm wider and longer (depending on the module..).
                                      Design files are available at GH, so you can check the dimensions yourself
                                      • tbowmoT tbowmo
                                        @TheoL
                                        TheoLT
                                        TheoLT
                                        TheoL
                                        @tbowmo Thanx for your fast reply. It's a great size. I'll create a mockup of it with cardboard. It'll give me a better visualization when I make the housing. Just a final question. I'm guessing I won't be able to stick an Arduino ethernet shield on it right?
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @TheoL
                                          the GW is not the same dimensions as arduino, so Arduino shields would not fit :)
                                          A mini w5100 board like this would fit..
                                          Also, see this "old" forum post about the GW device, there is some conceptual pictures of how it would look like with nrf and w5100 attached.
