  2. Announcements
  3. 2.0 Discussion: Units, sensor types and protocol
170 Posts 23 Posters 118.9k Views 7 Watching
    @Zeph
    FYI: Sleeping sensors (who also can be woken by a interrupt on a pin) will have a hard time keeping time without clock module or by fetching time from server at each wakeup from pin trigger.
    Good idea about a STATUS for RAIN sensor. It will be added and indicates if rain is ongoing.
    Will also change to ACCUMULATED for all accumulated values. Average for these makes no sense.
    So.. I see now that there is need for more than one reset command. We'll need RESET_ACCUMELATED, RESET_LEVEL, RESET_PERCENTAGE. They should also have their respective MAX, MIN, AVERAGE. Could you please give me a use case for V_LEVEL_SUM.
    Just to clarify for anyone getting a bit scared of all these new variables. Using them for your own sensor is of course optional!
    I feel it's time to move the new stuff to the first post to keep it in focus.
    DammeD
    DammeD
    Damme
    Code Contributor
    wrote on last edited by Damme
    #51
    I dont know why we have to limit some S_type to a number of V_types. Why not just let a S_type have 'all' V_types... User can be more flexible
    If I wanted node could send
    S_MOTION V_TRIPPED 1 (motion tripped)
    S_MOTION V_ARMED 0 (no longer armed)
    S_MOTION V_LEVEL 24 (motion quality 24 of 255) (probobly animal)
    controller decides S_MOTION V_RESET 1
    (order not thought of at all, needs to be fixed)
     #DEFINE S_DOOR	1
     #DEFINE S_MOTION	2
     #DEFINE S_SMOKE	3
     #DEFINE S_BINARY	4
     #DEFINE S_DIMMABLE	5
     #DEFINE S_WINDOW_COVER	6
     #DEFINE S_THERMOMETER	7
     #DEFINE S_HUMIDITY	8
     #DEFINE S_BAROMETER	9
     #DEFINE S_WIND	10
     #DEFINE S_RAIN	11
     #DEFINE S_UV	12
     #DEFINE S_WEIGHT_SCALE	13
     #DEFINE S_POWER	14
     #DEFINE S_HEATER	15
     #DEFINE S_DISTANCE	16
     #DEFINE S_LIGHT_SENSOR	17
     #DEFINE S_NODE	18
     #DEFINE S_LOCK	19
     #DEFINE S_IR	20
     #DEFINE S_WATER_METER	21
     #DEFINE S_AIR_QUALITY	22
     #DEFINE S_CUSTOM	23
     #DEFINE S_DUST	24
     #DEFINE S_PH	25
     #DEFINE S_SCENE_CONTROLLER	26
     #DEFINE S_NODE	255
     #DEFINE V_CONFIG1	1
     #DEFINE V_CONFIG2	2
     #DEFINE V_CONFIG3	3
     #DEFINE V_CONFIG4	4
     #DEFINE V_CONFIG5	5
     #DEFINE V_VAR1	6
     #DEFINE V_VAR2	7
     #DEFINE V_VAR3	8
     #DEFINE V_VAR4	9
     #DEFINE V_VAR5	10
     #DEFINE V_ARMED	11
     #DEFINE V_STATUS	12
     #DEFINE V_WATT	13
     #DEFINE V_PERCENTAGE	14
     #DEFINE V_STOP	15
     #DEFINE V_LEVEL	16
     #DEFINE V_MAX	17
     #DEFINE V_MIN	18
     #DEFINE V_RESET	19
     #DEFINE V_DEW_POINT	20
     #DEFINE V_MODE	21
     #DEFINE V_ANGLE	22
     #DEFINE V_RATE	23
     #DEFINE V_VOLTS	24
     #DEFINE V_AMPS	25
     #DEFINE V_PRESENTATION	26
     #DEFINE V_BATTERY_LEVEL	27
     #DEFINE V_RESET	28
     #DEFINE V_TIME	29
     #DEFINE V_ID	30
     #DEFINE V_LOG_MESSAGE	31
     #DEFINE V_SKETCH_NAME	32
     #DEFINE V_SKETCH_VERSION	33
     #DEFINE V_FIND_PARENT	34
     #DEFINE V_CHILDREN	35
     #DEFINE V_VERSION	36
     #DEFINE V_INCLUSION_MODE	37
     #DEFINE V_GATEWAY_READY	38
     #DEFINE V_STATUS	39
     #DEFINE V_IR_SEND	40
     #DEFINE V_IR_RECEIVE	41
    Z epierreE 2 Replies Last reply
      @Zeph
      Z
      Z
      Zeph
      @hek said:
      @Zeph
      Sleeping nodes may have a hard time averaging in some cases too.. But your point is well taken and it is a real concern.
      One of the sleep libraries calibrate the RC watchdog timer against the main clock, so it can make a good guess for adjusting milliseconds upon each wakeup. That could help for a simple sleep, but not for waking up from an interrupt.
      So the problem child is a node for which all the following apply:
      • sleeps
      • is awoken by interrupts at unpredictable intervals
      • has no local RTC
      • has accumulated variables
      One option would just be to ignore the accumulated time feature for the subset of nodes in that category; for them, you have to fall back to where would be be if I had never spoken up about tracking time. For other nodes, the tracking & reporting of accumulation time can be an enhancement, as described in an earlier message.
      But suppose we DO want to go further and determine accumulation time for all nodes, even the above.
      (Sigh. I acknowledged that there was a simplicity advantage to not dealing with time, and that just using the local node's millis() was the simplest but not only way to handle time; and that does handle most cases but not the above)
      System Time approach 1: Master Clock Broadcast to nodes
      The hub will have the master clock, using its millis(). Periodically it will broadcast the value of this to all nodes. A node could also request a time be sent. We could apply a crude delta to adjust this according to number of hops and typical transmission time, or not - we don't need anywhere close to millisecond accuracy. Each node would maintain a delta between its own millisecond clock and the broadcast millis and adjust that every time it receives that broadcast. (Smart nodes could even use a computed time scaling factor to adjust for differences in their clock vs the master). When for any reason has a need to estimate the current time (including but not limited to the case of having been powered up from sleeping by an interrupt AND needing to repost accumulations with more precision than it can estimate), the node can either wait for the next broadcast, or request one.
      System Time approach 2: Track accumulation times in the hub
      Whenever an accumulation period is started, the node will send a message to the hub to that effect (telling it which variable is involved and an incrementing reset count). This could be triggered by a commanded or manual reset, or by the automatic reset of an external weather station or service, or whatever. Then it would send the reset count (V_RESET_COUNT) rather than the accumulated time along with accumulation based values. The hub can look at its current time, and at the recorded time of the last reported reset of that variable, to compute for itself the elapsed time. The reset count makes sure both sides are sync'd as to which reset they are talking about. Both the "Starting accumulation period #n for (variable)" and the "reporting accumulated value for (variable)" messages travel from node to hub, and their travel times will roughly cancel out, at least well enough.
      The former approach is more powerful. It better supports rolling averages. And it would provide a flexible "MySensors network time" framework for future features, like reporting event times or periods more accurately.
      For example, I've considered putting two motion detectors at angles and with masks such that one could usually detect which way somebody went through a doorway by the trigger times, or at different place in a hallway. I'm not proposing to support that directly at this time, but when it comes up, if each node had the option of knowing the hub's master clock time to within tens of milliseconds or better, that could be a useful base upon which to build.
      [Total aside. My ambition for another nRF + Arduino system is more precise than this, possibly even enough to do PWM of 60 Hz mains powered lights without a local zero crossing detector - not yet determined. That's why I connect the nRF24L01+'s IRQ output to Arduino pin 8 = ICP1, even if I'm not using interrupt driven nRF code. If the nRF's receive interrupt is enabled, this allows the ATMega328p to get a very accurate time of reception using Timer 1 if it wants, even in polling mode without interrupts. And if I ever do want to interrupt the ATMega from the nRF, I can use the capture interrupt, while leaving INT0 and INT1 on pins 3 & 4 for other uses. The above first option is a smaller, simpler version of that design, adapted for the needs of a sensor network]
        @Zeph
        Z
        Z
        Zeph
        • "snapshot in time" values like temperature and humidity and watts logically accumulate as (averages. min, and max) over the given period as their end product. Tuesday the average temperature was 22.3 degrees.
        • "incrementing total" values like KWH, liquid flow, and rainfall logically accumulate as total or (sum) over the given period as their primary end product: Tuesday a total of 20mm of rain fell. (IFF you know the time as well, you can calculate an average as a secondary product)
        These two types of values have somewhat different dynamics.
        Of course if you report a total AND an elapsed time, the hub can calculate averages for itself, but not min and max. This calculation can be done at the hub even for temperature, tho total degrees C is not meaningful and total mm rain is.
        So IF we can rely on S_LEVEL_ELAPSED and S_LEVEL_SUM both always being available (and the latter not overflowing integer formats), we could omit S_LEVEL_AVG. But in the original proposal without a time framework, the node should report S_LEVEL_SUM for rain and S_LEVEL_AVG for temp.
          To simplify sketches even further we've discussed and decided to let sensors send in standard SI units and let controller convert them to the appropriate format.
          This will also remove the need for a unit-config exchange with controller at sensor startup.
          The new over-the-air messages has changed quite much with a more logical structure that can handle extension and even a completely different network layer if needed.
          The ongoing work can be found here:
          https://github.com/henrikekblad/Arduino/blob/development/libraries/MySensors/MyMessage.h
          Will not bring this into development until it actually compiles.
          Feel free to give feedback and report any missed sensor-types.
          In parallell we should probably discuss the serial-protocol for 2.0. Is it time for json perhaps?
          Z
          Z
          Zeph
          wrote on last edited by Zeph
          #54
          EDIT - there are some good concepts in the next few posts from me (IMHO obviously), but some may turn out to be sidestepped by a more radical change described in response
          http://forum.mysensors.org/topic/304/unit-standardization-1-4/57,
          so you might want to just read that first.
          @hek said:
          ###S_WIND - Wind sensor
          V_LEVEL - Wind level in m/s (average wind speed during last report period)
          V_LEVEL_MIN - Min wind level
          V_LEVEL_MAX - Max wind level (gust)
          V_LEVEL_AVERAGE - Average wind level-
          V_LEVEL_RESET - Reset max/min value
          V_ANGLE - radians <float or int>
          First, i still want to convince you that V_ANGLE in "degrees clockwise from true north" is the proper measure here, not radians. (and you need to define if this points to where the wind comes from or where it's moving towards, so is a west wind 90 degrees or 270 degrees - or translate to radians if you want to see ugly)
          Look, I'm a math person (or was) and I totally get that e, national logs and exponents, pi and radians are more fundamentally defined values than degrees or using base 10 for decibels or logs. But the point is not scientific purity (which are are not really close to anyway) but pragmatic utility in the field of sensor networks. And degrees simply work better in this context of conveying direction, especially if you allow int representation. Enough on that for now.
          Second, notice that you really only have two real measurements here: speed and direction. Those are what I call snapshot values - if you sample them at a given time, you get a value, which can later rise or fall.
          The former has additional derived or calculated sub-values, and those subvalues follow a pattern representing "simple time accumulation statistics" and also common to many other snapshot variable types, like humidity.
          The thing is - direction is also a snapshot value. If you are going to report average wind over the past hour, you can also report average direction.
          Alas, angle differs from continuum measurements in that it wraps, so average/min/max have to be computed carefully and are only meaningful if the source stays within a reasonable range; and sum makes no sense.
          But any continuum variable is a potential candidate for accumulation-period based derived sub-variables. I picture that there will be a single "accumulation" library which can be applied to any int or float variable, rather than that the temperature library will have accumulation code and the humidity library will have its own accumulation code.
          So in the hierarchy I'd put V_LEVEL_MIN, etc one level indented under V_LEVEL rather than make it look like a parallel and independent measurement.
          Let's also be clear that there are two reasons to have accumulation period based derived variables. One is that the node could be getting values from a device which does its own accumulation of some sort (eg: a weather station or some rain gauges). The other is that the device may sample the instantaneous variables more often than it transmits them. If we transmitted every measurement, the hub could potentially do its own min/max/average/sum calculations. No big deal there, but the hub could also accumulate by multiple arbitrary periods, like hour of the day AND since sunrise AND past 10 minutes AND past hour AND since Oct 1st (which is the start of the water year as used by scientists around here). So the most flexible thing would be to report every measurement to the hub and let it handle aggregation any way (as many ways) as it wants. But that could be bandwidth heavy, or might impose too much work on simple hubs (or controllers they report to).
          So for one or more of these reasons, sometimes it may make sense to have the sketch running in a node handle accumulation sub-variables. If it reports often enough in a well considered format, the hub or controller or cloud based analytical software can still do aggregation over some of these alternative time periods.
            Z
            Z
            Zeph
            #55
            @hek said:
            ###S_BINARY - Light (or other) on/off actuator
            V_STATUS - 1 - turn on, 0 = turn off
            ###S_DIMMABLE - Dimmable actuator
            V_PERCENTAGE - Dimmer level 0-100%
            OK, let's define what happens if you get more than one type of command (probably just making explicit what we are thinking anyway).
            S_DIMMABLE:
            V_STATUS = 1 is the same as V_PERCENTAGE = 100, either has same effect
            V_STATUS = 0 is the same as V_PERCENTAGE = 0, either has same effect
            If you set V_STATUS = 1 and then query V_PERCENTAGE it should return 100% (or 0 => 0%)
            If you set V_PERCENTAGE = 100 and query V_STATUS it should return 1
            OK?
            The only question is setting V_PERCENTAGE = 1..99 and querying V_STATUS.
            Option 1: Return -1 for "neither fully on nor fully off"
            Option 2: Return 1 for "at least partially on" (ie: anything above 0%)
            OK, what about a Fan with setting Off, Low and High, and another fan with settings "Off, Low, Medium and High?
            We could map those to text "OFF, LOW, MED, HIGH"
            Or we could map them to 0,1,2 where 2=HIGH for the first fan, and 0,1,2,3 where 3 = HIGH for the second
            I'm going to suggest that we primarily map to V_PERCENTAGE, but perhaps also support the latter option as an expansion of binary 0..1 into multi step value 0..N_STEPS.
            All fans:
                OFF = 0%
                HIGH = 100%
            Fan 1:
                Low = 50%
            Fan 2:
                Low = 33%
                Med = 67%
            If you are sent a V_PERCENTAGE, set the fan to the closest speed to the given percentage. 100% is always the highest speed, 0% is always OFF, in between will approximate. This extends to 4 level fans. And it works for a heater or motor with multiple speeds as well. If you query V_PERCENTAGE the actual value chosen from the list will be returned, not the requested value (ie: requesting 45% but reporting 50% in the case of fan 1).
            The above intermediate percentages are the default. However the node is empowered to set other values. We all know of fans or other devices where the speeds are not evenly spaced. I have a heater which has 600, 900 and 1500 watt settings (both elements). The Low and Medium setpoints could be 40% and 60%. Otherwise it works as described above.
            And there could be an integer V_SET_STEP (or something), corresponding to V_BINARY* but ranging from 0 to N_STEPS where N_STEPS is per-variable defined. I'm not attached to this, but it's an option, It would work in the obvious way. So V_SET_STEP of 1 for Fan1 would set it to Low=50% and V_SET_STEP of 1 for fan2 would set it to Low=33% (and V_SET_STEP of 1 for the heater example would set it to Low=40%. SET_STEP of 0 is always off, and SET_STEP of N_STEPS is always HIGH or 100%
            For completeness, I will mention that there's another way to define this for V_DIMMABLE. It could be required to memorize the last set percentage, and then V_STATUS = 0 means turn to 0% but remember last non-zero percentat, and V_STATUS = 1 could mean return to last non-zero percentage.
            Tho I don't favor this dynamcic, it too could work. However I strongly favor defining which way we expect things to work rather than leaving it ambiguous!
            • DammeD Damme
               #DEFINE S_DOOR	1
               #DEFINE S_MOTION	2
               #DEFINE S_SMOKE	3
               #DEFINE S_BINARY	4
               #DEFINE S_WIND	10
               #DEFINE S_RAIN	11
               #DEFINE S_UV	12
               #DEFINE S_POWER	14
               #DEFINE S_HEATER	15
               #DEFINE S_NODE	18
               #DEFINE S_LOCK	19
               #DEFINE S_IR	20
               #DEFINE S_CUSTOM	23
               #DEFINE S_DUST	24
               #DEFINE S_PH	25
               #DEFINE S_NODE	255
               #DEFINE V_CONFIG1	1
               #DEFINE V_CONFIG2	2
               #DEFINE V_CONFIG3	3
               #DEFINE V_CONFIG4	4
               #DEFINE V_CONFIG5	5
               #DEFINE V_VAR1	6
               #DEFINE V_VAR2	7
               #DEFINE V_VAR3	8
               #DEFINE V_VAR4	9
               #DEFINE V_VAR5	10
               #DEFINE V_ARMED	11
               #DEFINE V_STATUS	12
               #DEFINE V_WATT	13
               #DEFINE V_STOP	15
               #DEFINE V_LEVEL	16
               #DEFINE V_MAX	17
               #DEFINE V_MIN	18
               #DEFINE V_RESET	19
               #DEFINE V_MODE	21
               #DEFINE V_ANGLE	22
               #DEFINE V_RATE	23
               #DEFINE V_VOLTS	24
               #DEFINE V_AMPS	25
               #DEFINE V_RESET	28
               #DEFINE V_TIME	29
               #DEFINE V_ID	30
               #DEFINE V_STATUS	39
              Z
              Z
              Zeph
              As described at the time I write, the proposed taxonomy of values isn't really as heirarchical as it's presented.
              You can also parse the meaning from V code to S code:
              Ah, we have a V_LEVEL value, that means it represents a one dimensions continuum
              But what does that continuum represents?
              Oh, I see the variable is also tagged with S_TEMPERATURE
              That means the continuum is temperature in degrees C
              That is, the V code tells you something of the structural concept, and the S code adds some degree of semantics (like dimension and unit).
              So you could also invert the displayed hierarchy and show which S codes are available for a given V code
              • Z
                Z
                Zeph
                Hold the presses.
                I've happily engaged in the collaborative process of cleaning up the variable taxonomies of V 1.4b here.
                But we keep coming to conceptual tricky parts. Some of that is inherent, but in thinking deeper about it, i've come to the conclusion that a good part of what makes it hard to resolve cleanly is that we are trying to cram too much information into too few bits of variable metadata which has to be included in every packet.
                So rather than reforming S and V codes, I'm thinking a more radical approach is needed, to make the system both more flexible and simpler. Part of that comes from identifying what metadata about a variable is static and what needs to be dynamic, and then moving the static part out of the normal OTA operations. That turns out to make the taxonomy much more tractable and flexible while simplifying the node firmware.
                Guess what - even child ID turns out to be metadata in this approach, rather than addressing.
                Here's the sketch of the new approach.
                http://forum.mysensors.org/topic/308/another-way-of-organizing-variables
                It's sufficiently different that I expect it may encounter resistance - from the natural and appropriate fear of breaking too much (I share that concern). But it just may turn out to be sufficiently attractive to be worth it. Have a look. And now would be the time to consider such a break - with RadioHead and OTA programming support also in the air.
                  @Yveaux said:
                  [dissing start] Did you think about sending the sensor type only once, durig presentation? There really is no need to send it with each set/req message as it is static for the duration of the connection. For Vera and the like this probably means you should buffer these values in the gateway... [dissing end]
                  Yes, it would save a byte. But it could be very useful for a simpler controller (which can determine sensor type from each and every message) and when displaying sniffing data ;).
                  This would only leave 3 COMMAND types left. REQ, SET and STREAM. Where STREAM-data probably could be handled by S_NODE (internal). This means just 1 bit is needed for a SET/REQ flag. But @ToSa would have to feedback on this.
                  ToSa
                  Code Contributor
                  I switched the bootloader code between using stream and using simple internal messages - at the end doesn't matter as long as it's simple enough to dis-samble and assemble a packet without a lot of additional code overhead.
                  hekH 1 Reply Last reply
                  • T ToSa
                    @ToSa
                    Sorry, forget I brought this up. We'll keep the STREAM command as-is. Skyped you about it yesterday ;)
                    • Z Zeph
                      @hek said:
                      @Zeph
                      • sleeps
                      • has no local RTC
                      ToSa
                      Code Contributor
                      I'm in favor of approach 1 as well - and an optional addition to the MySensors class to keep track of time. Only specific sensor types would use this feature - interesting mainly for actuators rather than sensors:
                      Let's assume you use a relay to turn on/off your garden watering while you are on vacation. The network breaks (controller or gateway or whatever node needed to relay messages).
                      • If the sensor node itself knows about the time and the schedule for watering, it can turn on and off the watering itself. If there is an issue with the communication, the time would not be 100% accurate over time but still good enough.
                      • If the sensor node relies completely on the controller for time and (worst case) the communication breaks just between the start watering and stop watering command you can imagine what happens...
                      Knowing about the time heavily reduces the single points of failure. The protocol already covers the "request time" communication so this should be relatively easy to implement...
                      • controller sends a time broadcast every e.g. 15 minutes
                      • only the nodes interested in time care about it and update their internal time
                      • when a node needs the current time it calculates it based on the last timestamp received, the millis() when it was received and the current millis...
                      Doesn't solve the sleep issue (as long as you don't want to submit a separate "get time request" every time you wake up) but at least for sensors that are not battery powered (relay nodes in most cases are not) it's a feasible approach.
                      This is probably worth a separate thread :)
                      • T ToSa
                        @ToSa, @Zeph
                        Yes, and to extend this even further it would be great to be able to distribute/push simple rules all the way out to the nodes. It might be enough with simple scheduler-commands to start with but this could easily support even advances scenarios. The question is where to set the cuttingpoint...
                        The most extreme solution would be to allow a graphical rule engine on the controller which automatically generates a sketch, compiles it and sends it out OTA to the node.
                        Definitely worth discussing in a new thread...
                        Z 1 Reply Last reply
                          @ToSa, @Zeph
                          Z
                          Z
                          Zeph
                          For the level of protocol under current discussion, the cuttingpoint could just be giving nodes an optional sense of time (using broadcast packets to keep in sync with the master as needed). And making use of that time as part of the (optional) accumulation enhancement for some variables.
                          What else they do with that time at higher layers would continue to evolve in the future. We don't have to bite it all off now.
                          • R
                            R
                            Rasmus Eneman
                            V_R_PERCENTAGE - Red component % <int>
                            V_G_PERCENTAGE - Green component % <int>
                            V_B_PERCENTAGE - Blue component % <int>
                            V_W_PERCENTAGE - White component % <int>
                            Just a hundred steps might be to low, especially for green in the lower end which the eye sees much brighter.
                            Please consider floats or per thousand instead.
                            • R Rasmus Eneman
                              @Rasmus-Eneman
                              Ok! Didn't know that. But couldn't the sensor code adjust this with some sort of color curve?
                              R 1 Reply Last reply
                                @Rasmus-Eneman
                                R
                                R
                                Rasmus Eneman
                                @hek
                                That would probably do it, however one would need to be defined and standardized so that all behaves the same. One more clever than me needs to propose how the curve would look tough.
                                • JohnJ
                                  JohnJ
                                  John
                                  wrote on last edited by John
                                  #66
                                  @hek @Rasmus-Eneman
                                  S_RGBW - RGBW Light
                                  Ain't it better to split up S_RGBW to two different types. W is already present in full R, G, and B. For example i have implemented Philips Hue and there is a difference in fixture types some do RGB some only W. If an user would implement such with mysensors the same option can be possible. An S_RGBW declaration for a W only would indicate RGB capabilities and maybe cause confusion.
                                  Agree, but thousands could be too much (which never is the case of course), maybe 0-255 would be sufficient and widely used (all though not as precise in steps as with thousands)? Also the W_PERCENTAGE should be left out because this is full R,G,B or similar calibrated R,G,B levels (which is quite difficult to do at every possible level) with the end result it then in fact is a brightness level instead of a white component.
                                  An addition could be S_HSB/S_HSV with float,float,float (0.0-360.0, 0.0-100.0, 0.0-100.0)? Also i think the color presentation should be or calibrated on the device or in the controller. Even some of those Philips Hue's fixtures are often controller side calibrated (better said color index modified after color selection)....
                                    I actually have RGBW led strips mounted around our house. W is indeed its own component (Warm White in my case). So it will stick ;)
                                    (Warm White using the special W-component)
                                    Cold white (RGB activated)
                                    Crazy
                                    JohnJ YveauxY 2 Replies Last reply
                                      @John
                                      But switching to LEVEL and using 0-255 would be ok (if we need it ;)).
                                        Crazy
                                        JohnJ
                                        JohnJ
                                        John
                                        #69
                                        @hek
                                        Ahhh... understood :)... Splitting those up will not be an option then because it could then create a numerous amount of options....
                                        A S_HSB would be nice though, even if it would only be ints....:
                                        V_H_DEGREE - Degree (0-360)<int>
                                        V_S_PERCENTAGE - Saturation % <int>
                                        V_B_PERCENTAGE/V_V_PERCENTAGE - Brightness/Value % <int>
                                        V_WATT - Watt <int>
                                        V_WATT_MAX - Max watt value
                                        V_WATT_MIN - Min watt value
                                        V_WATT_AVERAGE - Min watt value
                                        V_WATT_RESET - Reset max/min value
                                        I must say it is a personal request :$....
                                        [Edit]
                                        But switching to LEVEL and using 0-255 would be ok (if we need it :wink:).
                                        It would create space to add the HSB/HSV option ;)
                                        • Z
                                          Z
                                          Zeph
                                          #70
                                          What's wrong with setting lights at 1.475% Is percentage limited to integer?
                                          Let's be very explicit about that. Is the idea that all values accept only integers unless they say they have the option of using floats? If so that should be made clear in the list.
                                          Another thing that needs to be more clear is how to handle multiple V codes for the same sensacturator (like the RGB or HSV lights).
                                          • Is a sensor expected to report all of them?
                                          • Is an actuator expected to respond to all of them?
                                          • How do both sides stay in sync about subsetting?
                                          By the way, there is a distinction to be made between RGB lights (three blendable primaries able to synthesize many colors in a predictable and fairly standard way) and multichannel control of N lights of arbitrary colors. RGBW is another thing entirely. The W could be cool or warm white. For that matter the fourth color could be yellow or violet. It's not a color space.
                                          If the RGB channels blend I'd implement it as an RGB light plus a monochrome light, because there is no RGBW color space. If they don't blend I'd implement it as 4 monochrome channels, the same way I'd implement a Yellow and Green pair that didn't blend.
                                          JohnJ 1 Reply Last reply
