  3. battery level doesn't appear ?
25 Posts 6 Posters 7.9k Views 4 Watching
  • flylowgofastF
    flylowgofastF
    flylowgofast
    hello,
    thanks for your answer. For me 97,1 means 97% and acknowledge. And the same code work properly with my other nodes with temperature sensors !
    Any other ideas ?
    • F
      F
      flopp
      wrote on last edited by flopp
      I have rain, light and temp sensor and battery level is working, so I think you can have it for almost any sensor type.
      Have you tried to remove everything except gw.sendbattery...
      Just to check?
      The last } does it have a { above if
      I guess you have otherwise you cannot compile but maybe that is in an IF loop or some other loop that doesn't work as expected
      flylowgofastF 1 Reply Last reply
      • flylowgofastF flylowgofast
        Hello all,
        I have a node with switchs and dimmer, and I tried to send Battery level like that :
          if ((millis() - myTime) > 10000) { // toutes les dix secondes
            myTime = millis();
            gw.sendBatteryLevel(97,1);
            if ((millis() - myTime) < 0) {
              myTime = millis();
        but in Domoticz I can't see the battery level ! however, I have the same code for two other nodes with temperature sensors and in this case It works ? is Battery level for temperature sensors only ?
        thanks
        AWIA
        AWIA
        AWI
        @flylowgofast Is the actual sensor updating? From my experience Domoticz only updates/shows the new battery level when a new value is received for the sensor data..
        • F flopp
          Just to check?
          flylowgofastF
          flylowgofastF
          flylowgofast
          Hello @flopp,
          I'll try this evening to remove all the code but gw.sendbattery...
          I think there isn't problem with { or }, perhaps you don't like my way to write code :smile:
          thanks
          • AWIA AWI
            flylowgofastF
            flylowgofastF
            flylowgofast
            hello @AWI,
            is there a way to verify if my sensor send a newx value ? because I can't use terminal with debug informations, I use Rx / Tx for an other purpose !
            thanks
            • sundberg84S
              sundberg84S
              @flylowgofast - Check Domoticz log, if the value updates you see it there.
              Or for more details, check serial log on your gateway. There you see all trafic. As AWI said, you wont see any updates on Domoticz if its the same value as before, Domoticz needs new value to update.
              • XanderX
                XanderX
                Xander
                "Battery Level" is a internal message.
                See: http://www.mysensors.org/download/serial_api_15
                This means it is going to the gateway and nobody knows what the gateway is doing with it...
                Please correct me if I am wrong.
                • sundberg84S
                  sundberg84S
                  I have several nodes reporting battery level to Domoticz.
                  • flylowgofastF
                    flylowgofastF
                    flylowgofast
                    hello,
                    here is logs from gateway
                    2;4;1;1;3;70;0;3;0;9;send: 0-0-2-2 s=4,c=1,t=3,pt=0,l=1,sg=0,st=fail:7
                    Finished
                    0;0;3;0;18;PINGFinished
                    0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:97
                    0;0;3;0;9;send: 0-0-1-1 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:97
                    1;255;3;0;0;97
                    Finished
                    0;0;3;0;18;PING0;0;3;0;9;read: 65-65-0 s=255,c=3,t=0,pt=1,l=1,sg=0:99
                    0;0;3;0;9;send: 0-0-65-65 s=255,c=3,t=0,pt=1,l=1,sg=0,st=fail:99
                    65;255;3;0;0;99
                    1;255;3;0;0;97
                    Finished
                    Is there a documentation to understand better ?
                    thanks
                    AWIA 1 Reply Last reply
                    • F
                      F
                      flopp
                      Can you post your sketch here?
                      • F
                        F
                        flopp
                        This is from my GW
                        0;0;3;0;18;PING0;0;3;0;9;read: 12-12-0 s=255,c=3,t=0,pt=1,l=1,sg=0:98
                        12;255;3;0;0;98
                        0;0;3;0;9;read: 12-12-0 s=1,c=1,t=38,pt=7,l=5,sg=0:2.979
                        12;1;1;0;38;2.979
                        0;0;3;0;9;read: 12-12-0 s=0,c=1,t=23,pt=3,l=2,sg=0:66
                        12;0;1;0;23;66
                        Finished
                        98% battery
                        2.979 voltage
                        66 lux
                        • F
                          F
                          flopp
                          You can also restart your Node and then it will send all data again like, Sketchname, version and also all childs
                          • flylowgofastF
                            flylowgofastF
                            flylowgofast
                            my loop(){}
                            // the loop routine runs over and over again forever:
                              // Process incoming messages (like config from server)
                              //---------------Lecture des ouvertures de porte------------------
                              doorOpenOffState = digitalRead(HALLOFFICEDOOR); // lecture à chaque cycle (urgence)
                              if (doorOpenOffState != doorOpenOffChange){
                                gw.send(msgDoorOffice.setSensor(OFFICEDOOR).set(doorOpenOffState));
                                doorOpenOffChange = doorOpenOffState;
                              doorOpenBedState = digitalRead(HALLBEDROOMDOOR); // lecture à chaque cycle (urgence)
                              if (doorOpenBedState != doorOpenBedChange){
                                gw.send(msgDoorBedroom.setSensor(BEDROOMDOOR).set(doorOpenBedState));
                                doorOpenBedChange = doorOpenBedState;
                              if (digitalRead(ECLEXT) != oldInterExt){
                                oldInterExt = !oldInterExt;
                                eclState = !eclState;
                                gw.send(msgLightSwitch.set(eclState));
                              //---------------Envoi du niveau de batterie !! pour rester eveillé------------------
                              /*if ((millis() - myTime) > 10000) { // toutes les dix secondes
                                myTime = millis();
                                  myTime = millis();
                            // ---------------Traitement volet 1-----------------
                              analogUpV1 = analogRead(UPV1);
                              if ((analogUpV1 <25) && !manOnV1) { //analogUp proche de zéro et ancienne valeur niveau haut (en l'air)
                                digitalWrite(TRIAC5, HIGH);
                                digitalWrite(TRIAC2, LOW);
                                triacTempoV1 = millis();
                                triacManPriorityV1 = true;
                                manOnV1 = true;
                                memoStopV1 = false;
                                analogDownV1 = analogRead(DOWNV1);
                                if ((analogDownV1 <25) && !manOnV1) { //proche de zéro
                                  digitalWrite(TRIAC5, LOW);
                                  digitalWrite(TRIAC2, HIGH);
                                  manOnV1 = true;
                                  memoStopV1 = false;
                                  if (analogUpV1 > 800 && analogDownV1 > 800 && !memoStopV1){ // les deux fils en l'air
                                    triacManPriorityV1 = false;
                                    manOnV1 = false;
                                    memoStopV1 = true;
                                    if (!triacManPriorityV1){
                                      if (shutterOff1State && shutterOff2State) {
                                        shutterOff1State = false;
                                        shutterOff2State = false;
                                        if (shutterOff1State) {
                                          if (shutterOff2State) {
                              if (((triacTempoV1 + TEMPOOPENV1) < millis())) {
                            // --------------------------Traitement volet 2------------------------
                              analogUpV2 = analogRead(UPV2);
                              if ((analogUpV2 <25) && !manOnV2) { //analogUp proche de zéro et ancienne valeur niveau haut (en l'air)
                                digitalWrite(TRIAC3, HIGH);
                                digitalWrite(TRIAC4, LOW);
                                triacTempoV2 = millis();
                                triacManPriorityV2 = true;
                                manOnV2 = true;
                                memoStopV2 = false;
                                analogDownV2 = analogRead(DOWNV2);
                                if ((analogDownV2 <25) && !manOnV2) { //proche de zéro
                                  digitalWrite(TRIAC3, LOW);
                                  digitalWrite(TRIAC4, HIGH);
                                  manOnV2 = true;
                                  memoStopV2 = false;
                                  if (analogUpV2 > 800 && analogDownV2 > 800 && !memoStopV2){ // les deux fils en l'air
                                    //triac3 = false;
                                    //triac4 = false;
                                    triacManPriorityV2 = false;
                                    manOnV2 = false;
                                    memoStopV2 = true;
                                    if (!triacManPriorityV2){
                                      if (shutterBed1State && shutterBed2State) {
                                        shutterBed1State = false;
                                        shutterBed2State = false;
                                        if (shutterBed1State) {
                                          if (shutterBed2State) {
                              if (((triacTempoV2 + TEMPOOPENV2) < millis())) {
                              my loop(){}
                                  myTime = millis();
                                    myTime = millis();
                                  manOnV1 = true;
                                  memoStopV1 = false;
                                    manOnV1 = true;
                                    memoStopV1 = false;
                                      manOnV1 = false;
                                      memoStopV1 = true;
                                  manOnV2 = true;
                                  memoStopV2 = false;
                                    manOnV2 = true;
                                    memoStopV2 = false;
                                      //triac3 = false;
                                      //triac4 = false;
                                      manOnV2 = false;
                                      memoStopV2 = true;
                              F
                              F
                              flopp
                              @flylowgofast
                              Look ok
                                hello,
                                Finished
                                1;255;3;0;0;97
                                Finished
                                65;255;3;0;0;99
                                1;255;3;0;0;97
                                Finished
                                thanks
                                AWIA
                                AWIA
                                AWI
                                @flylowgofast for information on the logs take a look at the debug topic
                                • flylowgofastF
                                  flylowgofastF
                                  flylowgofast
                                  My real problem is not to send battery level. I try to do that because after 24 or 48 hours my node stop sending messages . So, I hoped that was a way to make it awake !
                                  AWIA F 2 Replies Last reply
                                    AWIA
                                    AWIA
                                    AWI
                                    @flylowgofast From what I read from your sketch you seem to do some high voltage / current switching. Especially the radio doesn't like all kinds of electronic disturbances (emc etc.) To avoid lockups you need to pay special attention/separate power supplies (if you haven't done already).
                                    • flylowgofastF
                                      flylowgofastF
                                      flylowgofast
                                      Hello AWI,
                                      Thanks for your reply, yes my node trigs 5 triacs. I use snubber, regulator, capacitor. And ond the other hand, all commands to the node work properly ? just battery level doesn't work and after several hours NRF24L01 stop to work.
                                      I would like to reset NRF24L01 but with MySensors we don't have direct access to it anymore. Perhaps there is a way to reset the sketch globaly ?
                                      thanks for your help
                                        F
                                        F
                                        flopp
                                        #21
                                        It would have been nice if you had wrote this in your first post.:disappointed:
                                        So everyone could focus on the main problem
                                        • flylowgofastF
                                          flylowgofastF
                                          flylowgofast
                                          Hello @flopp ,
                                          Sorry I was myself focus on this second problem that's interesting to solve too ?
                                          At the end twice aren't solve ! :disappointed:
