  3. battery level doesn't appear ?
25 Posts 6 Posters 7.9k Views 4 Watching
  • flylowgofastF
    flylowgofastF
    flylowgofast
    hello,
    here is logs from gateway
    2;4;1;1;3;70;0;3;0;9;send: 0-0-2-2 s=4,c=1,t=3,pt=0,l=1,sg=0,st=fail:7
    Finished
    0;0;3;0;18;PINGFinished
    0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:97
    0;0;3;0;9;send: 0-0-1-1 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:97
    1;255;3;0;0;97
    Finished
    0;0;3;0;18;PING0;0;3;0;9;read: 65-65-0 s=255,c=3,t=0,pt=1,l=1,sg=0:99
    0;0;3;0;9;send: 0-0-65-65 s=255,c=3,t=0,pt=1,l=1,sg=0,st=fail:99
    65;255;3;0;0;99
    1;255;3;0;0;97
    Finished
    Is there a documentation to understand better ?
    thanks
    AWIA 1 Reply Last reply
    • F
      F
      flopp
      Can you post your sketch here?
      • F
        F
        flopp
        wrote on last edited by flopp
        This is from my GW
        0;0;3;0;18;PING0;0;3;0;9;read: 12-12-0 s=255,c=3,t=0,pt=1,l=1,sg=0:98
        12;255;3;0;0;98
        0;0;3;0;9;read: 12-12-0 s=1,c=1,t=38,pt=7,l=5,sg=0:2.979
        12;1;1;0;38;2.979
        0;0;3;0;9;read: 12-12-0 s=0,c=1,t=23,pt=3,l=2,sg=0:66
        12;0;1;0;23;66
        Finished
        98% battery
        2.979 voltage
        66 lux
        • F
          F
          flopp
          You can also restart your Node and then it will send all data again like, Sketchname, version and also all childs
          • flylowgofastF
            flylowgofastF
            flylowgofast
            my loop(){}
            // the loop routine runs over and over again forever:
              // Process incoming messages (like config from server)
              //---------------Lecture des ouvertures de porte------------------
              doorOpenOffState = digitalRead(HALLOFFICEDOOR); // lecture à chaque cycle (urgence)
              if (doorOpenOffState != doorOpenOffChange){
                gw.send(msgDoorOffice.setSensor(OFFICEDOOR).set(doorOpenOffState));
                doorOpenOffChange = doorOpenOffState;
              doorOpenBedState = digitalRead(HALLBEDROOMDOOR); // lecture à chaque cycle (urgence)
              if (doorOpenBedState != doorOpenBedChange){
                gw.send(msgDoorBedroom.setSensor(BEDROOMDOOR).set(doorOpenBedState));
                doorOpenBedChange = doorOpenBedState;
              if (digitalRead(ECLEXT) != oldInterExt){
                oldInterExt = !oldInterExt;
                eclState = !eclState;
                gw.send(msgLightSwitch.set(eclState));
              //---------------Envoi du niveau de batterie !! pour rester eveillé------------------
              /*if ((millis() - myTime) > 10000) { // toutes les dix secondes
                myTime = millis();
                gw.sendBatteryLevel(97,1);
                if ((millis() - myTime) < 0) {
                  myTime = millis();
            // ---------------Traitement volet 1-----------------
              analogUpV1 = analogRead(UPV1);
              if ((analogUpV1 <25) && !manOnV1) { //analogUp proche de zéro et ancienne valeur niveau haut (en l'air)
                digitalWrite(TRIAC5, HIGH);
                digitalWrite(TRIAC2, LOW);
                triacTempoV1 = millis();
                triacManPriorityV1 = true;
                manOnV1 = true;
                memoStopV1 = false;
                analogDownV1 = analogRead(DOWNV1);
                if ((analogDownV1 <25) && !manOnV1) { //proche de zéro
                  digitalWrite(TRIAC5, LOW);
                  digitalWrite(TRIAC2, HIGH);
                  manOnV1 = true;
                  memoStopV1 = false;
                  if (analogUpV1 > 800 && analogDownV1 > 800 && !memoStopV1){ // les deux fils en l'air
                    triacManPriorityV1 = false;
                    manOnV1 = false;
                    memoStopV1 = true;
                    if (!triacManPriorityV1){
                      if (shutterOff1State && shutterOff2State) {
                        shutterOff1State = false;
                        shutterOff2State = false;
                        if (shutterOff1State) {
                          if (shutterOff2State) {
              if (((triacTempoV1 + TEMPOOPENV1) < millis())) {
            // --------------------------Traitement volet 2------------------------
              analogUpV2 = analogRead(UPV2);
              if ((analogUpV2 <25) && !manOnV2) { //analogUp proche de zéro et ancienne valeur niveau haut (en l'air)
                digitalWrite(TRIAC3, HIGH);
                digitalWrite(TRIAC4, LOW);
                triacTempoV2 = millis();
                triacManPriorityV2 = true;
                manOnV2 = true;
                memoStopV2 = false;
                analogDownV2 = analogRead(DOWNV2);
                if ((analogDownV2 <25) && !manOnV2) { //proche de zéro
                  digitalWrite(TRIAC3, LOW);
                  digitalWrite(TRIAC4, HIGH);
                  manOnV2 = true;
                  memoStopV2 = false;
                  if (analogUpV2 > 800 && analogDownV2 > 800 && !memoStopV2){ // les deux fils en l'air
                    //triac3 = false;
                    //triac4 = false;
                    triacManPriorityV2 = false;
                    manOnV2 = false;
                    memoStopV2 = true;
                    if (!triacManPriorityV2){
                      if (shutterBed1State && shutterBed2State) {
                        shutterBed1State = false;
                        shutterBed2State = false;
                        if (shutterBed1State) {
                          if (shutterBed2State) {
              if (((triacTempoV2 + TEMPOOPENV2) < millis())) {
            F 1 Reply Last reply
            • flylowgofastF flylowgofast
              my loop(){}
                  myTime = millis();
                    myTime = millis();
                  manOnV1 = true;
                  memoStopV1 = false;
                    manOnV1 = true;
                    memoStopV1 = false;
                      manOnV1 = false;
                      memoStopV1 = true;
                  manOnV2 = true;
                  memoStopV2 = false;
                    manOnV2 = true;
                    memoStopV2 = false;
                      //triac3 = false;
                      //triac4 = false;
                      manOnV2 = false;
                      memoStopV2 = true;
              F
              F
              flopp
              @flylowgofast
              Look ok
                hello,
                Finished
                1;255;3;0;0;97
                Finished
                65;255;3;0;0;99
                1;255;3;0;0;97
                Finished
                thanks
                AWIA
                AWIA
                AWI
                @flylowgofast for information on the logs take a look at the debug topic
                • flylowgofastF
                  flylowgofastF
                  flylowgofast
                  My real problem is not to send battery level. I try to do that because after 24 or 48 hours my node stop sending messages . So, I hoped that was a way to make it awake !
                  AWIA F 2 Replies Last reply
                    AWIA
                    AWIA
                    AWI
                    @flylowgofast From what I read from your sketch you seem to do some high voltage / current switching. Especially the radio doesn't like all kinds of electronic disturbances (emc etc.) To avoid lockups you need to pay special attention/separate power supplies (if you haven't done already).
                    • flylowgofastF
                      flylowgofastF
                      flylowgofast
                      Hello AWI,
                      Thanks for your reply, yes my node trigs 5 triacs. I use snubber, regulator, capacitor. And ond the other hand, all commands to the node work properly ? just battery level doesn't work and after several hours NRF24L01 stop to work.
                      I would like to reset NRF24L01 but with MySensors we don't have direct access to it anymore. Perhaps there is a way to reset the sketch globaly ?
                      thanks for your help
                        F
                        F
                        flopp
                        #21
                        It would have been nice if you had wrote this in your first post.:disappointed:
                        So everyone could focus on the main problem
                        • flylowgofastF
                          flylowgofastF
                          flylowgofast
                          Hello @flopp ,
                          Sorry I was myself focus on this second problem that's interesting to solve too ?
                          At the end twice aren't solve ! :disappointed:
                          • flylowgofastF
                            flylowgofastF
                            flylowgofast
                            Hello all,
                            At the end, I choose to do a software reset every 24 hours. This solution is very bad for me but it works !!
                            bye
                            • sundberg84S
                              sundberg84S
                              @flylowgofast One simple thing can be to move the radio away a bit and see if that helps. Its as AWI said probably interferance power-radio.
                              flylowgofastF 1 Reply Last reply
                              • sundberg84S sundberg84
                                flylowgofastF
                                flylowgofastF
                                flylowgofast
                                Hello @sundberg84,
                                I already considered this idea but my node have been running perfectly for two days before failed. So I think, power consideration are not the problem. I can trigg on and off my shutters many and many times without problem.
